path: root/Documentation/filesystems
2011-03-25Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (43 commits) ext4: fix a BUG in mb_mark_used during trim. ext4: unused variables cleanup in fs/ext4/extents.c ext4: remove redundant set_buffer_mapped() in ext4_da_get_block_prep() ext4: add more tracepoints and use dev_t in the trace buffer ext4: don't kfree uninitialized s_group_info members ext4: add missing space in printk's in __ext4_grp_locked_error() ext4: add FITRIM to compat_ioctl. ext4: handle errors in ext4_clear_blocks() ext4: unify the ext4_handle_release_buffer() api ext4: handle errors in ext4_rename jbd2: add COW fields to struct jbd2_journal_handle jbd2: add the b_cow_tid field to journal_head struct ext4: Initialize fsync transaction ids in ext4_new_inode() ext4: Use single thread to perform DIO unwritten convertion ext4: optimize ext4_bio_write_page() when no extent conversion is needed ext4: skip orphan cleanup if fs has unknown ROCOMPAT features ext4: use the nblocks arg to ext4_truncate_restart_trans() ext4: fix missing iput of root inode for some mount error paths ext4: make FIEMAP and delayed allocation play well together ext4: suppress verbose debugging information if malloc-debug is off ... Fi up conflicts in fs/ext4/super.c due to workqueue changes
2011-03-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fs: simplify iget & friends fs: pull inode->i_lock up out of writeback_single_inode fs: rename inode_lock to inode_hash_lock fs: move i_wb_list out from under inode_lock fs: move i_sb_list out from under inode_lock fs: remove inode_lock from iput_final and prune_icache fs: Lock the inode LRU list separately fs: factor inode disposal fs: protect inode->i_state with inode->i_lock autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd() autofs4 - remove autofs4_lock autofs4 - fix d_manage() return on rcu-walk autofs4 - fix autofs4_expire_indirect() traversal autofs4 - fix dentry leak in autofs4_expire_direct() autofs4 - reinstate last used update on access vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
2011-03-24fs: remove inode_lock from iput_final and prune_icacheDave Chinner
Now that inode state changes are protected by the inode->i_lock and the inode LRU manipulations by the inode_lru_lock, we can remove the inode_lock from prune_icache and the initial part of iput_final(). instead of using the inode_lock to protect the inode during iput_final, use the inode->i_lock instead. This protects the inode against new references being taken while we change the inode state to I_FREEING, as well as preventing prune_icache from grabbing the inode while we are manipulating it. Hence we no longer need the inode_lock in iput_final prior to setting I_FREEING on the inode. For prune_icache, we no longer need the inode_lock to protect the LRU list, and the inodes themselves are protected against freeing races by the inode->i_lock. Hence we can lift the inode_lock from prune_icache as well. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus: Squashfs: Use vmalloc rather than kmalloc for zlib workspace Squashfs: handle corruption of directory structure Squashfs: wrap squashfs_mount() definition Squashfs: xz_wrapper doesn't need to include squashfs_fs_i.h anymore Squashfs: Update documentation to include compression options Squashfs: Update Kconfig help text to include xz compression Squashfs: add compression options support to xz decompressor Squashfs: extend decompressor framework to handle compression options
2011-03-24Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
* 'for-linus' of git://git.open-osd.org/linux-open-osd: exofs: deprecate the commands pending counter exofs: Write sbi->s_nextid as part of the Create command exofs: Add option to mount by osdname exofs: Override read-ahead to align on stripe_size exofs: simple fsync race fix exofs: Optimize read_4_write exofs: Trivial: fix some indentation and debug prints exofs: Remove redundant unlikely()
2011-03-22adfs: add hexadecimal filetype suffix optionStuart Swales
ADFS (FileCore) storage complies with the RISC OS filetype specification (12 bits of file type information is stored in the file load address, rather than using a file extension). The existing driver largely ignores this information and does not present it to the end user. It is desirable that stored filetypes be made visible to the end user to facilitate a precise copy of data and metadata from a hard disc (or image thereof) into a RISC OS emulator (such as RPCEmu) or to a network share which can be accessed by real Acorn systems. This patch implements a per-mount filetype suffix option (use -o ftsuffix=1) to present any filetype as a ,xyz hexadecimal suffix on each file. This type suffix is compatible with that used by RISC OS systems that access network servers using NFS client software and by RPCemu's host filing system. Signed-off-by: Stuart Swales <stuart.swales.croftnuisk@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-21Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: (23 commits) xfs: don't name variables "panic" xfs: factor agf counter updates into a helper xfs: clean up the xfs_alloc_compute_aligned calling convention xfs: kill support/debug.[ch] xfs: Convert remaining cmn_err() callers to new API xfs: convert the quota debug prints to new API xfs: rename xfs_cmn_err_fsblock_zero() xfs: convert xfs_fs_cmn_err to new error logging API xfs: kill xfs_fs_mount_cmn_err() macro xfs: kill xfs_fs_repair_cmn_err() macro xfs: convert xfs_cmn_err to xfs_alert_tag xfs: Convert xlog_warn to new logging interface xfs: Convert linux-2.6/ files to new logging interface xfs: introduce new logging API. xfs: zero proper structure size for geometry calls xfs: enable delaylog by default xfs: more sensible inode refcounting for ialloc xfs: stop using xfs_trans_iget in the RT allocator xfs: check if device support discard in xfs_ioc_trim() xfs: prevent leaking uninitialized stack memory in FSGEOMETRY_V1 ...
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fs: call security_d_instantiate in d_obtain_alias V2 lose 'mounting_here' argument in ->d_manage() don't pass 'mounting_here' flag to follow_down() change the locking order for namespace_sem fix deadlock in pivot_root() vfs: split off vfsmount-related parts of vfs_kern_mount() Some fixes for pstore kill simple_set_mnt()
2011-03-18Merge branch 'linux-next' of git://git.infradead.org/ubifs-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubifs-2.6: (25 commits) UBIFS: clean-up commentaries UBIFS: save 128KiB or more RAM UBIFS: allocate orphans scan buffer on demand UBIFS: allocate lpt dump buffer on demand UBIFS: allocate ltab checking buffer on demand UBIFS: allocate scanning buffer on demand UBIFS: allocate dump buffer on demand UBIFS: do not check data crc by default UBIFS: simplify UBIFS Kconfig menu UBIFS: print max. index node size UBIFS: handle allocation failures in UBIFS write path UBIFS: use max_write_size during recovery UBIFS: use max_write_size for write-buffers UBIFS: introduce write-buffer size field UBI: incorporate LEB offset information UBIFS: incorporate maximum write size UBI: provide LEB offset information UBI: incorporate maximum write size UBIFS: fix LEB number in printk UBIFS: restrict world-writable debugfs files ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-18lose 'mounting_here' argument in ->d_manage()Al Viro
it's always false... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-17Merge branch 'nfs-for-2.6.39' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.39' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (54 commits) RPC: killing RPC tasks races fixed xprt: remove redundant check SUNRPC: Convert struct rpc_xprt to use atomic_t counters SUNRPC: Ensure we always run the tk_callback before tk_action sunrpc: fix printk format warning xprt: remove redundant null check nfs: BKL is no longer needed, so remove the include NFS: Fix a warning in fs/nfs/idmap.c Cleanup: Factor out some cut-and-paste code. cleanup: save 60 lines/100 bytes by combining two mostly duplicate functions. NFS: account direct-io into task io accounting gss:krb5 only include enctype numbers in gm_upcall_enctypes RPCRDMA: Fix FRMR registration/invalidate handling. RPCRDMA: Fix to XDR page base interpretation in marshalling logic. NFSv4: Send unmapped uid/gids to the server when using auth_sys NFSv4: Propagate the error NFS4ERR_BADOWNER to nfs4_do_setattr NFSv4: cleanup idmapper functions to take an nfs_server argument NFSv4: Send unmapped uid/gids to the server if the idmapper fails NFSv4: If the server sends us a numeric uid/gid then accept it NFSv4.1: reject zero layout with zeroed stripe unit ...
2011-03-16Merge branch 'mnt_devname' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'mnt_devname' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: vfs: bury ->get_sb() nfs: switch NFS from ->get_sb() to ->mount() nfs: stop mangling ->mnt_devname on NFS vfs: new superblock methods to override /proc/*/mount{s,info} nfs: nfs_do_{ref,sub}mount() superblock argument is redundant nfs: make nfs_path() work without vfsmount nfs: store devname at disconnected NFS roots nfs: propagate devname to nfs{,4}_get_root()
2011-03-16vfs: bury ->get_sb()Al Viro
This is an ex-parrot. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-15exofs: Add option to mount by osdnameBoaz Harrosh
If /dev/osd* devices are shuffled because more devices where added, and/or login order has changed. It is hard to mount the FS you want. Add an option to mount by osdname. osdname is any osd-device's osdname as specified to the mkfs.exofs command when formatting the osd-devices. The new mount format is: OPT="osdname=$UUID0,pid=$PID,_netdev" mount -t exofs -o $OPT $DEV_OSD0 $MOUNTDIR if "osdname=" is specified in options above $DEV_OSD0 is ignored and can be empty. Also while at it: Removed some old unused Opt_* enums. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2011-03-11NFSv4.1: lseg documentationFred Isaman
Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11UBIFS: do not check data crc by defaultArtem Bityutskiy
Change the default UBIFS behavior WRT data CRC checking. Currently, UBIFS checks data CRC when reading, which slows it down quite a bit, and this is the default option. However, it looks like in average user does not need this feature and would prefer faster read speed over extra reliability. And this seems to be de-facto standard that file-systems do not check data CRC every time they read from the media. Thus, make UBIFS default behavior so that it does not check data CRC. This corresponds to the no_chk_data_crc mount option. Those users who need extra protection can always enable it using the chk_data_crc option. Please, read more information about this feature here: http://www.linux-mtd.infradead.org/doc/ubifs.html#L_checksumming Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-02-28Squashfs: Update documentation to include compression optionsPhillip Lougher
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2011-02-22xfs: enable delaylog by defaultChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-02-21ext4: update ext4 documentationLukas Czerner
Add documentation for mount options and ioctls to Documentation/filesystem/ext4.txt, which has not been udpated for some time. Also add for ext4 sysfs tunables to the Documentation/ABI/testing/sysfs-fs-ext4 file, and fix a few typographical errors in that file. https://bugzilla.kernel.org/show_bug.cgi?id=9423 Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-02-17Documentation/filesystems/romfs.txt: fixing link to genromfsAlexander Kurz
Signed-off-by: Alexander Kurz <linux@kbdbabel.org> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-03docs/sysfs: show() methods should use scnprintf().Bart Van Assche
Since snprintf() may return a value that exceeds its second argument, show() methods should use scnprintf() instead of snprintf(). This patch updates the example in the sysfs documentation accordingly. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Cc: Tejun Heo <tj@kernel.org> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-03docs/sysfs: Update directory/kobject documentation.Bart Van Assche
Some time ago the way how sysfs stores a pointer to a kobject corresponding to a directory was modified. This patch brings the documentation again in sync with the implementation. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Cc: Tejun Heo <tj@kernel.org> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-31NTFS: Fix invalid pointer dereference in ntfs_mft_record_alloc().Anton Altaparmakov
In ntfs_mft_record_alloc() when mapping the new extent mft record with map_extent_mft_record() we overwrite @m with the return value and on error, we then try to use the old @m but that is no longer there as @m now contains an error code instead so we crash when dereferencing the error code as if it were a pointer. The simple fix is to use a temporary variable to store the return value thus preserving the original @m for later use. This is a backport from the commercial Tuxera-NTFS driver and is well tested... Thanks go to Julia Lawall for pointing this out (whilst I had fixed it in the commercial driver I had failed to fix it in the Linux kernel). Signed-off-by: Anton Altaparmakov <anton@tuxera.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-17fallocate should be a file operationChristoph Hellwig
Currently all filesystems except XFS implement fallocate asynchronously, while XFS forced a commit. Both of these are suboptimal - in case of O_SYNC I/O we really want our allocation on disk, especially for the !KEEP_SIZE case where we actually grow the file with user-visible zeroes. On the other hand always commiting the transaction is a bad idea for fast-path uses of fallocate like for example in recent Samba versions. Given that block allocation is a data plane operation anyway change it from an inode operation to a file operation so that we have the file structure available that lets us check for O_SYNC. This also includes moving the code around for a few of the filesystems, and remove the already unnedded S_ISDIR checks given that we only wire up fallocate for regular files. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (23 commits) sanitize vfsmount refcounting changes fix old umount_tree() breakage autofs4: Merge the remaining dentry ops tables Unexport do_add_mount() and add in follow_automount(), not ->d_automount() Allow d_manage() to be used in RCU-walk mode Remove a further kludge from __do_follow_link() autofs4: Bump version autofs4: Add v4 pseudo direct mount support autofs4: Fix wait validation autofs4: Clean up autofs4_free_ino() autofs4: Clean up dentry operations autofs4: Clean up inode operations autofs4: Remove unused code autofs4: Add d_manage() dentry operation autofs4: Add d_automount() dentry operation Remove the automount through follow_link() kludge code from pathwalk CIFS: Use d_automount() rather than abusing follow_link() NFS: Use d_automount() rather than abusing follow_link() AFS: Use d_automount() rather than abusing follow_link() Add an AT_NO_AUTOMOUNT flag to suppress terminal automount ...
2011-01-15Unexport do_add_mount() and add in follow_automount(), not ->d_automount()David Howells
Unexport do_add_mount() and make ->d_automount() return the vfsmount to be added rather than calling do_add_mount() itself. follow_automount() will then do the addition. This slightly complicates things as ->d_automount() normally wants to add the new vfsmount to an expiration list and start an expiration timer. The problem with that is that the vfsmount will be deleted if it has a refcount of 1 and the timer will not repeat if the expiration list is empty. To this end, we require the vfsmount to be returned from d_automount() with a refcount of (at least) 2. One of these refs will be dropped unconditionally. In addition, follow_automount() must get a 3rd ref around the call to do_add_mount() lest it eat a ref and return an error, leaving the mount we have open to being expired as we would otherwise have only 1 ref on it. d_automount() should also add the the vfsmount to the expiration list (by calling mnt_set_expiry()) and start the expiration timer before returning, if this mechanism is to be used. The vfsmount will be unlinked from the expiration list by follow_automount() if do_add_mount() fails. This patch also fixes the call to do_add_mount() for AFS to propagate the mount flags from the parent vfsmount. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Allow d_manage() to be used in RCU-walk modeDavid Howells
Allow d_manage() to be called from pathwalk when it is in RCU-walk mode as well as when it is in Ref-walk mode. This permits __follow_mount_rcu() to call d_manage() directly. d_manage() needs a parameter to indicate that it is in RCU-walk mode as it isn't allowed to sleep if in that mode (but should return -ECHILD instead). autofs4_d_manage() can then be set to retain RCU-walk mode if the daemon accesses it and otherwise request dropping back to ref-walk mode. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Add a dentry op to allow processes to be held during pathwalk transitDavid Howells
Add a dentry op (d_manage) to permit a filesystem to hold a process and make it sleep when it tries to transit away from one of that filesystem's directories during a pathwalk. The operation is keyed off a new dentry flag (DCACHE_MANAGE_TRANSIT). The filesystem is allowed to be selective about which processes it holds and which it permits to continue on or prohibits from transiting from each flagged directory. This will allow autofs to hold up client processes whilst letting its userspace daemon through to maintain the directory or the stuff behind it or mounted upon it. The ->d_manage() dentry operation: int (*d_manage)(struct path *path, bool mounting_here); takes a pointer to the directory about to be transited away from and a flag indicating whether the transit is undertaken by do_add_mount() or do_move_mount() skipping through a pile of filesystems mounted on a mountpoint. It should return 0 if successful and to let the process continue on its way; -EISDIR to prohibit the caller from skipping to overmounted filesystems or automounting, and to use this directory; or some other error code to return to the user. ->d_manage() is called with namespace_sem writelocked if mounting_here is true and no other locks held, so it may sleep. However, if mounting_here is true, it may not initiate or wait for a mount or unmount upon the parameter directory, even if the act is actually performed by userspace. Within fs/namei.c, follow_managed() is extended to check with d_manage() first on each managed directory, before transiting away from it or attempting to automount upon it. follow_down() is renamed follow_down_one() and should only be used where the filesystem deliberately intends to avoid management steps (e.g. autofs). A new follow_down() is added that incorporates the loop done by all other callers of follow_down() (do_add/move_mount(), autofs and NFSD; whilst AFS, NFS and CIFS do use it, their use is removed by converting them to use d_automount()). The new follow_down() calls d_manage() as appropriate. It also takes an extra parameter to indicate if it is being called from mount code (with namespace_sem writelocked) which it passes to d_manage(). follow_down() ignores automount points so that it can be used to mount on them. __follow_mount_rcu() is made to abort rcu-walk mode if it hits a directory with DCACHE_MANAGE_TRANSIT set on the basis that we're probably going to have to sleep. It would be possible to enter d_manage() in rcu-walk mode too, and have that determine whether to abort or not itself. That would allow the autofs daemon to continue on in rcu-walk mode. Note that DCACHE_MANAGE_TRANSIT on a directory should be cleared when it isn't required as every tranist from that directory will cause d_manage() to be invoked. It can always be set again when necessary. ========================== WHAT THIS MEANS FOR AUTOFS ========================== Autofs currently uses the lookup() inode op and the d_revalidate() dentry op to trigger the automounting of indirect mounts, and both of these can be called with i_mutex held. autofs knows that the i_mutex will be held by the caller in lookup(), and so can drop it before invoking the daemon - but this isn't so for d_revalidate(), since the lock is only held on _some_ of the code paths that call it. This means that autofs can't risk dropping i_mutex from its d_revalidate() function before it calls the daemon. The bug could manifest itself as, for example, a process that's trying to validate an automount dentry that gets made to wait because that dentry is expired and needs cleaning up: mkdir S ffffffff8014e05a 0 32580 24956 Call Trace: [<ffffffff885371fd>] :autofs4:autofs4_wait+0x674/0x897 [<ffffffff80127f7d>] avc_has_perm+0x46/0x58 [<ffffffff8009fdcf>] autoremove_wake_function+0x0/0x2e [<ffffffff88537be6>] :autofs4:autofs4_expire_wait+0x41/0x6b [<ffffffff88535cfc>] :autofs4:autofs4_revalidate+0x91/0x149 [<ffffffff80036d96>] __lookup_hash+0xa0/0x12f [<ffffffff80057a2f>] lookup_create+0x46/0x80 [<ffffffff800e6e31>] sys_mkdirat+0x56/0xe4 versus the automount daemon which wants to remove that dentry, but can't because the normal process is holding the i_mutex lock: automount D ffffffff8014e05a 0 32581 1 32561 Call Trace: [<ffffffff80063c3f>] __mutex_lock_slowpath+0x60/0x9b [<ffffffff8000ccf1>] do_path_lookup+0x2ca/0x2f1 [<ffffffff80063c89>] .text.lock.mutex+0xf/0x14 [<ffffffff800e6d55>] do_rmdir+0x77/0xde [<ffffffff8005d229>] tracesys+0x71/0xe0 [<ffffffff8005d28d>] tracesys+0xd5/0xe0 which means that the system is deadlocked. This patch allows autofs to hold up normal processes whilst the daemon goes ahead and does things to the dentry tree behind the automouter point without risking a deadlock as almost no locks are held in d_manage() and none in d_automount(). Signed-off-by: David Howells <dhowells@redhat.com> Was-Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Add a dentry op to handle automounting rather than abusing follow_link()David Howells
Add a dentry op (d_automount) to handle automounting directories rather than abusing the follow_link() inode operation. The operation is keyed off a new dentry flag (DCACHE_NEED_AUTOMOUNT). This also makes it easier to add an AT_ flag to suppress terminal segment automount during pathwalk and removes the need for the kludge code in the pathwalk algorithm to handle directories with follow_link() semantics. The ->d_automount() dentry operation: struct vfsmount *(*d_automount)(struct path *mountpoint); takes a pointer to the directory to be mounted upon, which is expected to provide sufficient data to determine what should be mounted. If successful, it should return the vfsmount struct it creates (which it should also have added to the namespace using do_add_mount() or similar). If there's a collision with another automount attempt, NULL should be returned. If the directory specified by the parameter should be used directly rather than being mounted upon, -EISDIR should be returned. In any other case, an error code should be returned. The ->d_automount() operation is called with no locks held and may sleep. At this point the pathwalk algorithm will be in ref-walk mode. Within fs/namei.c itself, a new pathwalk subroutine (follow_automount()) is added to handle mountpoints. It will return -EREMOTE if the automount flag was set, but no d_automount() op was supplied, -ELOOP if we've encountered too many symlinks or mountpoints, -EISDIR if the walk point should be used without mounting and 0 if successful. The path will be updated to point to the mounted filesystem if a successful automount took place. __follow_mount() is replaced by follow_managed() which is more generic (especially with the patch that adds ->d_manage()). This handles transits from directories during pathwalk, including automounting and skipping over mountpoints (and holding processes with the next patch). __follow_mount_rcu() will jump out of RCU-walk mode if it encounters an automount point with nothing mounted on it. follow_dotdot*() does not handle automounts as you don't want to trigger them whilst following "..". I've also extracted the mount/don't-mount logic from autofs4 and included it here. It makes the mount go ahead anyway if someone calls open() or creat(), tries to traverse the directory, tries to chdir/chroot/etc. into the directory, or sticks a '/' on the end of the pathname. If they do a stat(), however, they'll only trigger the automount if they didn't also say O_NOFOLLOW. I've also added an inode flag (S_AUTOMOUNT) so that filesystems can mark their inodes as automount points. This flag is automatically propagated to the dentry as DCACHE_NEED_AUTOMOUNT by __d_instantiate(). This saves NFS and could save AFS a private flag bit apiece, but is not strictly necessary. It would be preferable to do the propagation in d_set_d_op(), but that doesn't normally have access to the inode. [AV: fixed breakage in case if __follow_mount_rcu() fails and nameidata_drop_rcu() succeeds in RCU case of do_lookup(); we need to fall through to non-RCU case after that, rather than just returning with ungrabbed *path] Signed-off-by: David Howells <dhowells@redhat.com> Was-Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-14Merge branch 'for-2.6.38' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.38' of git://linux-nfs.org/~bfields/linux: (62 commits) nfsd4: fix callback restarting nfsd: break lease on unlink, link, and rename nfsd4: break lease on nfsd setattr nfsd: don't support msnfs export option nfsd4: initialize cb_per_client nfsd4: allow restarting callbacks nfsd4: simplify nfsd4_cb_prepare nfsd4: give out delegations more quickly in 4.1 case nfsd4: add helper function to run callbacks nfsd4: make sure sequence flags are set after destroy_session nfsd4: re-probe callback on connection loss nfsd4: set sequence flag when backchannel is down nfsd4: keep finer-grained callback status rpc: allow xprt_class->setup to return a preexisting xprt rpc: keep backchannel xprt as long as server connection rpc: move sk_bc_xprt to svc_xprt nfsd4: allow backchannel recovery nfsd4: support BIND_CONN_TO_SESSION nfsd4: modify session list under cl_lock Documentation: fl_mylease no longer exists ... Fix up conflicts in fs/nfsd/vfs.c with the vfs-scale work. The vfs-scale work touched some msnfs cases, and this merge removes support for that entirely, so the conflict was trivial to resolve.
2011-01-13Merge branch 'vfs-scale-working' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin * 'vfs-scale-working' of git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin: fs: fix do_last error case when need_reval_dot nfs: add missing rcu-walk check fs: hlist UP debug fixup fs: fix dropping of rcu-walk from force_reval_path fs: force_reval_path drop rcu-walk before d_invalidate fs: small rcu-walk documentation fixes Fixed up trivial conflicts in Documentation/filesystems/porting
2011-01-14fs: small rcu-walk documentation fixesNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-13oom: allow a non-CAP_SYS_RESOURCE proces to oom_score_adj downMandeep Singh Baines
We'd like to be able to oom_score_adj a process up/down as it enters/leaves the foreground. Currently, it is not possible to oom_adj down without CAP_SYS_RESOURCE. This patch allows a task to decrease its oom_score_adj back to the value that a CAP_SYS_RESOURCE thread set it to or its inherited value at fork. Assuming the thread that has forked it has oom_score_adj of 0, each process could decrease it back from 0 upon activation unless a CAP_SYS_RESOURCE thread elevated it to something higher. Alternative considered: * a setuid binary * a daemon with CAP_SYS_RESOURCE Since you don't wan't all processes to be able to reduce their oom_adj, a setuid or daemon implementation would be complex. The alternatives also have much higher overhead. This patch updated from original patch based on feedback from David Rientjes. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Acked-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: smaps: export mlock informationNikanth Karthikesan
Currently there is no way to find whether a process has locked its pages in memory or not. And which of the memory regions are locked in memory. Add a new field "Locked" to export this information via the smaps file. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (41 commits) fs: add documentation on fallocate hole punching Gfs2: fail if we try to use hole punch Btrfs: fail if we try to use hole punch Ext4: fail if we try to use hole punch Ocfs2: handle hole punching via fallocate properly XFS: handle hole punching via fallocate properly fs: add hole punching to fallocate vfs: pass struct file to do_truncate on O_TRUNC opens (try #2) fix signedness mess in rw_verify_area() on 64bit architectures fs: fix kernel-doc for dcache::prepend_path fs: fix kernel-doc for dcache::d_validate sanitize ecryptfs ->mount() switch afs move internal-only parts of ncpfs headers to fs/ncpfs switch ncpfs switch 9p pass default dentry_operations to mount_pseudo() switch hostfs switch affs switch configfs ...
2011-01-12fs: add documentation on fallocate hole punchingJosef Bacik
This patch simply adds documentation on how to handle the hole punching mode of fallocate for any filesystem wishing to use it. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-12NTFS: writev() fix and maintenance/contact details updateAnton Altaparmakov
Fix writev() to not keep writing the first segment over and over again instead of moving onto subsequent segments and update the NTFS entry in MAINTAINERS to reflect that Tuxera Inc. now supports the NTFS driver. Signed-off-by: Anton Altaparmakov <anton@tuxera.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-11Documentation: fl_mylease no longer existsJ. Bruce Fields
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-07Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (36 commits) serial: apbuart: Fixup apbuart_console_init() TTY: Add tty ioctl to figure device node of the system console. tty: add 'active' sysfs attribute to tty0 and console device drivers: serial: apbuart: Handle OF failures gracefully Serial: Avoid unbalanced IRQ wake disable during resume tty: fix typos/errors in tty_driver.h comments pch_uart : fix warnings for 64bit compile 8250: fix uninitialized FIFOs ip2: fix compiler warning on ip2main_pci_tbl specialix: fix compiler warning on specialix_pci_tbl rocket: fix compiler warning on rocket_pci_ids 8250: add a UPIO_DWAPB32 for 32 bit accesses 8250: use container_of() instead of casting serial: omap-serial: Add support for kernel debugger serial: fix pch_uart kconfig & build drivers: char: hvc: add arm JTAG DCC console support RS485 documentation: add 16C950 UART description serial: ifx6x60: fix memory leak serial: ifx6x60: free IRQ on error Serial: EG20T: add PCH_UART driver ... Fixed up conflicts in drivers/serial/apbuart.c with evil merge that makes the code look fairly sane (unlike either side).
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: rcu-walk for path lookupNick Piggin
Perform common cases of path lookups without any stores or locking in the ancestor dentry elements. This is called rcu-walk, as opposed to the current algorithm which is a refcount based walk, or ref-walk. This results in far fewer atomic operations on every path element, significantly improving path lookup performance. It also avoids cacheline bouncing on common dentries, significantly improving scalability. The overall design is like this: * LOOKUP_RCU is set in nd->flags, which distinguishes rcu-walk from ref-walk. * Take the RCU lock for the entire path walk, starting with the acquiring of the starting path (eg. root/cwd/fd-path). So now dentry refcounts are not required for dentry persistence. * synchronize_rcu is called when unregistering a filesystem, so we can access d_ops and i_ops during rcu-walk. * Similarly take the vfsmount lock for the entire path walk. So now mnt refcounts are not required for persistence. Also we are free to perform mount lookups, and to assume dentry mount points and mount roots are stable up and down the path. * Have a per-dentry seqlock to protect the dentry name, parent, and inode, so we can load this tuple atomically, and also check whether any of its members have changed. * Dentry lookups (based on parent, candidate string tuple) recheck the parent sequence after the child is found in case anything changed in the parent during the path walk. * inode is also RCU protected so we can load d_inode and use the inode for limited things. * i_mode, i_uid, i_gid can be tested for exec permissions during path walk. * i_op can be loaded. When we reach the destination dentry, we lock it, recheck lookup sequence, and increment its refcount and mountpoint refcount. RCU and vfsmount locks are dropped. This is termed "dropping rcu-walk". If the dentry refcount does not match, we can not drop rcu-walk gracefully at the current point in the lokup, so instead return -ECHILD (for want of a better errno). This signals the path walking code to re-do the entire lookup with a ref-walk. Aside from the final dentry, there are other situations that may be encounted where we cannot continue rcu-walk. In that case, we drop rcu-walk (ie. take a reference on the last good dentry) and continue with a ref-walk. Again, if we can drop rcu-walk gracefully, we return -ECHILD and do the whole lookup using ref-walk. But it is very important that we can continue with ref-walk for most cases, particularly to avoid the overhead of double lookups, and to gain the scalability advantages on common path elements (like cwd and root). The cases where rcu-walk cannot continue are: * NULL dentry (ie. any uncached path element) * parent with d_inode->i_op->permission or ACLs * dentries with d_revalidate * Following links In future patches, permission checks and d_revalidate become rcu-walk aware. It may be possible eventually to make following links rcu-walk aware. Uncached path elements will always require dropping to ref-walk mode, at the very least because i_mutex needs to be grabbed, and objects allocated. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove dcache_lockNick Piggin
dcache_lock no longer protects anything. remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_hash for rcu-walkNick Piggin
Change d_hash so it may be called from lock-free RCU lookups. See similar patch for d_compare for details. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_compare for rcu-walkNick Piggin
Change d_compare so it may be called from lock-free RCU lookups. This does put significant restrictions on what may be done from the callback, however there don't seem to have been any problems with in-tree fses. If some strange use case pops up that _really_ cannot cope with the rcu-walk rules, we can just add new rcu-unaware callbacks, which would cause name lookup to drop out of rcu-walk mode. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-04remove trim_fs method from Documentation/filesystems/LockingChristoph Hellwig
The ->trim_fs has been removed meanwhile, so remove it from the documentation as well. Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
