commit 778c14affaf94a9e4953179d3e13a544ccce7707 upstream.
A 3% of system memory bonus is sometimes too excessive in comparison to
other processes.
With commit a63d83f427fb ("oom: badness heuristic rewrite"), the OOM
killer tries to avoid killing privileged tasks by subtracting 3% of
overall memory (system or cgroup) from their per-task consumption. But
as a result, all root tasks that consume less than 3% of overall memory
are considered equal, and so it only takes 33+ privileged tasks pushing
the system out of memory for the OOM killer to do something stupid and
kill dhclient or other root-owned processes. For example, on a 32G
machine it can't tell the difference between the 1M agetty and the 10G
fork bomb member.
The changelog describes this 3% boost as the equivalent to the global
overcommit limit being 3% higher for privileged tasks, but this is not
the same as discounting 3% of overall memory from _every privileged task
individually_ during OOM selection.
Replace the 3% of system memory bonus with a 3% of current memory usage
bonus.
By giving root tasks a bonus that is proportional to their actual size,
they remain comparable even when relatively small. In the example
above, the OOM killer will discount the 1M agetty's 256 badness points
down to 179, and the 10G fork bomb's 262144 points down to 183500 points
and make the right choice, instead of discounting both to 0 and killing
agetty because it's first in the task list.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Johannes Weiner <hannes@cmpxchg.org>
attr2 format is always enabled for v5 superblock filesystems, so the
mount options to enable or disable it need to be cause mount errors.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
(cherry picked from commit d3eaace84e40bf946129e516dcbd617173c1cf14)
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs update from Chris Mason:
"These are mostly fixes. The biggest exceptions are Josef's skinny
extents and Jan Schmidt's code to rebuild our quota indexes if they
get out of sync (or you enable quotas on an existing filesystem).
The skinny extents are off by default because they are a new variation
on the extent allocation tree format. btrfstune -x enables them, and
the new format makes the extent allocation tree about 30% smaller.
I rebased this a few days ago to rework Dave Sterba's crc checks on
the super block, but almost all of these go back to rc6, since I
though 3.9 was due any minute.
The biggest missing fix is the tracepoint bug that was hit late in
3.9. I ran into problems with that in overnight testing and I'm still
tracking it down. I'll definitely have that fixed for rc2."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (101 commits)
Btrfs: allow superblock mismatch from older mkfs
btrfs: enhance superblock checks
btrfs: fix misleading variable name for flags
btrfs: use unsigned long type for extent state bits
Btrfs: improve the loop of scrub_stripe
btrfs: read entire device info under lock
btrfs: remove unused gfp mask parameter from release_extent_buffer callchain
btrfs: handle errors returned from get_tree_block_key
btrfs: make static code static & remove dead code
Btrfs: deal with errors in write_dev_supers
Btrfs: remove almost all of the BUG()'s from tree-log.c
Btrfs: deal with free space cache errors while replaying log
Btrfs: automatic rescan after "quota enable" command
Btrfs: rescan for qgroups
Btrfs: split btrfs_qgroup_account_ref into four functions
Btrfs: allocate new chunks if the space is not enough for global rsv
Btrfs: separate sequence numbers for delayed ref tracking and tree mod log
btrfs: move leak debug code to functions
Btrfs: return free space in cow error path
Btrfs: set UUID in root_item for created trees
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull f2fs updates from Jaegeuk Kim:
"This patch-set includes the following major enhancement patches.
- introduce a new gloabl lock scheme
- add tracepoints on several major functions
- fix the overall cleaning process focused on victim selection
- apply the block plugging to merge IOs as much as possible
- enhance management of free nids and its list
- enhance the readahead mode for node pages
- address several cretical deadlock conditions
- reduce lock_page calls
The other minor bug fixes and enhancements are as follows.
- calculation mistakes: overflow
- bio types: READ, READA, and READ_SYNC
- fix the recovery flow, data races, and null pointer errors"
* tag 'f2fs-for-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (68 commits)
f2fs: cover free_nid management with spin_lock
f2fs: optimize scan_nat_page()
f2fs: code cleanup for scan_nat_page() and build_free_nids()
f2fs: bugfix for alloc_nid_failed()
f2fs: recover when journal contains deleted files
f2fs: continue to mount after failing recovery
f2fs: avoid deadlock during evict after f2fs_gc
f2fs: modify the number of issued pages to merge IOs
f2fs: remove useless #include <linux/proc_fs.h> as we're now using sysfs as debug entry.
f2fs: fix inconsistent using of NM_WOUT_THRESHOLD
f2fs: check truncation of mapping after lock_page
f2fs: enhance alloc_nid and build_free_nids flows
f2fs: add a tracepoint on f2fs_new_inode
f2fs: check nid == 0 in add_free_nid
f2fs: add REQ_META about metadata requests for submit
f2fs: give a chance to merge IOs by IO scheduler
f2fs: avoid frequent background GC
f2fs: add tracepoints to debug checkpoint request
f2fs: add tracepoints for write page operations
f2fs: add tracepoints to debug the block allocation
Document all current btrfs mount options.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
Pull nfsd changes from J Bruce Fields:
"Highlights include:
- Some more DRC cleanup and performance work from Jeff Layton
- A gss-proxy upcall from Simo Sorce: currently krb5 mounts to the
server using credentials from Active Directory often fail due to
limitations of the svcgssd upcall interface. This replacement
lifts those limitations. The existing upcall is still supported
for backwards compatibility.
- More NFSv4.1 support: at this point, if a user with a current
client who upgrades from 4.0 to 4.1 should see no regressions. In
theory we do everything a 4.1 server is required to do. Patches
for a couple minor exceptions are ready for 3.11, and with those
and some more testing I'd like to turn 4.1 on by default in 3.11."
Fix up semantic conflict as per Stephen Rothwell and linux-next:
Commit 030d794bf498 ("SUNRPC: Use gssproxy upcall for server RPCGSS
authentication") adds two new users of "PDE(inode)->data", but we're
supposed to use "PDE_DATA(inode)" instead since commit d9dda78bad87
("procfs: new helper - PDE_DATA(inode)").
The old PDE() macro is no longer available since commit c30480b92cf4
("proc: Make the PROC_I() and PDE() macros internal to procfs")
* 'for-3.10' of git://linux-nfs.org/~bfields/linux: (60 commits)
NFSD: SECINFO doesn't handle unsupported pseudoflavors correctly
NFSD: Simplify GSS flavor encoding in nfsd4_do_encode_secinfo()
nfsd: make symbol nfsd_reply_cache_shrinker static
svcauth_gss: fix error return code in rsc_parse()
nfsd4: don't remap EISDIR errors in rename
svcrpc: fix gss-proxy to respect user namespaces
SUNRPC: gssp_procedures[] can be static
SUNRPC: define {create,destroy}_use_gss_proxy_proc_entry in !PROC case
nfsd4: better error return to indicate SSV non-support
nfsd: fix EXDEV checking in rename
SUNRPC: Use gssproxy upcall for server RPCGSS authentication.
SUNRPC: Add RPC based upcall mechanism for RPCGSS auth
SUNRPC: conditionally return endtime from import_sec_context
SUNRPC: allow disabling idle timeout
SUNRPC: attempt AF_LOCAL connect on setup
nfsd: Decode and send 64bit time values
nfsd4: put_client_renew_locked can be static
nfsd4: remove unused macro
nfsd4: remove some useless code
nfsd4: implement SEQ4_STATUS_RECALLABLE_STATE_REVOKED
Pull xfs update from Ben Myers:
"For 3.10-rc1 we have a number of bug fixes and cleanups and a
currently experimental feature from David Chinner, CRCs protection for
metadata. CRCs are enabled by using mkfs.xfs to create a filesystem
with the feature bits set.
- numerous fixes for speculative preallocation
- don't verify buffers on IO errors
- rename of random32 to prandom32
- refactoring/rearrangement in xfs_bmap.c
- removal of unused m_inode_shrink in struct xfs_mount
- fix error handling of xfs_bufs and readahead
- quota driven preallocation throttling
- fix WARN_ON in xfs_vm_releasepage
- add ratelimited printk for different alert levels
- fix spurious forced shutdowns due to freed Extent Free Intents
- remove some obsolete XLOG_CIL_HARD_SPACE_LIMIT() macros
- remove some obsoleted comments
- (experimental) CRC support for metadata"
* tag 'for-linus-v3.10-rc1' of git://oss.sgi.com/xfs/xfs: (46 commits)
xfs: fix da node magic number mismatches
xfs: Remote attr validation fixes and optimisations
xfs: Teach dquot recovery about CONFIG_XFS_QUOTA
xfs: add metadata CRC documentation
xfs: implement extended feature masks
xfs: add CRC checks to the superblock
xfs: buffer type overruns blf_flags field
xfs: add buffer types to directory and attribute buffers
xfs: add CRC protection to remote attributes
xfs: split remote attribute code out
xfs: add CRCs to attr leaf blocks
xfs: add CRCs to dir2/da node blocks
xfs: shortform directory offsets change for dir3 format
xfs: add CRC checking to dir2 leaf blocks
xfs: add CRC checking to dir2 data blocks
xfs: add CRC checking to dir2 free blocks
xfs: add CRC checks to block format directory blocks
xfs: add CRC checks to remote symlinks
xfs: split out symlink code into it's own file.
xfs: add version 3 inode format with CRCs
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Mostly performance and bug fixes, plus some cleanups. The one new
feature this merge window is a new ioctl EXT4_IOC_SWAP_BOOT which
allows installation of a hidden inode designed for boot loaders."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (50 commits)
ext4: fix type-widening bug in inode table readahead code
ext4: add check for inodes_count overflow in new resize ioctl
ext4: fix Kconfig documentation for CONFIG_EXT4_DEBUG
ext4: fix online resizing for ext3-compat file systems
jbd2: trace when lock_buffer in do_get_write_access takes a long time
ext4: mark metadata blocks using bh flags
buffer: add BH_Prio and BH_Meta flags
ext4: mark all metadata I/O with REQ_META
ext4: fix readdir error in case inline_data+^dir_index.
ext4: fix readdir error in the case of inline_data+dir_index
jbd2: use kmem_cache_zalloc instead of kmem_cache_alloc/memset
ext4: mext_insert_extents should update extent block checksum
ext4: move quota initialization out of inode allocation transaction
ext4: reserve xattr index for Rich ACL support
jbd2: reduce journal_head size
ext4: clear buffer_uninit flag when submitting IO
ext4: use io_end for multiple bios
ext4: make ext4_bio_write_page() use BH_Async_Write flags
ext4: Use kstrtoul() instead of parse_strtoul()
ext4: defragmentation code cleanup
Add descriptions about 'stale_rw' and 'nostale_ro' nfs options in
filesystem/vfat.txt
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Ravishankar N <ravi.n1@samsung.com>
Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com>
Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Acked-by: Rob Landley <rob@landley.net>
Add some documentation about the self describing metadata and the
code templates used to implement it.
Reviewed-by: Ben Myers <bpm@sgi.com>
The main advantge of this new upcall mechanism is that it can handle
big tickets as seen in Kerberos implementations where tickets carry
authorization data like the MS-PAC buffer with AD or the Posix Authorization
Data being discussed in IETF on the krbwg working group.
The Gssproxy program is used to perform the accept_sec_context call on the
kernel's behalf. The code is changed to also pass the input buffer straight
to upcall mechanism to avoid allocating and copying many pages as tokens can
be as big (potentially more in future) as 64KiB.
Signed-off-by: Simo Sorce <simo@redhat.com>
[bfields: containerization, negotiation api]
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Currently in ENOSPC condition when writing into unwritten space, or
punching a hole, we might need to split the extent and grow extent tree.
However since we can not allocate any new metadata blocks we'll have to
zero out unwritten part of extent or punched out part of extent, or in
the worst case return ENOSPC even though use actually does not allocate
any space.
Also in delalloc path we do reserve metadata and data blocks for the
time we're going to write out, however metadata block reservation is
very tricky especially since we expect that logical connectivity implies
physical connectivity, however that might not be the case and hence we
might end up allocating more metadata blocks than previously reserved.
So in future, metadata reservation checks should be removed since we can
not assure that we do not under reserve.
And this is where reserved space comes into the picture. When mounting
the file system we slice off a little bit of the file system space (2%
or 4096 clusters, whichever is smaller) which can be then used for the
cases mentioned above to prevent costly zeroout, or unexpected ENOSPC.
The number of reserved clusters can be set via sysfs, however it can
never be bigger than number of free clusters in the file system.
Note that this patch fixes the failure of xfstest 274 as expected.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
Add a new ioctl, EXT4_IOC_SWAP_BOOT which swaps i_blocks and
associated attributes (like i_blocks, i_size, i_flags, ...) from the
specified inode with inode EXT4_BOOT_LOADER_INO (#5). This is
typically used to store a boot loader in a secure part of the
filesystem, where it can't be changed by a normal user by accident.
The data blocks of the previous boot loader will be associated with
the given inode.
This usercode program is a simple example of the usage:
int main(int argc, char *argv[])
int fd;
int err;
if ( argc != 2 ) {
printf("usage: ext4-swap-boot-inode FILE-TO-SWAP\n");
exit(1);
fd = open(argv[1], O_WRONLY);
if ( fd < 0 ) {
perror("open");
exit(1);
err = ioctl(fd, EXT4_IOC_SWAP_BOOT);
if ( err < 0 ) {
perror("ioctl");
exit(1);
close(fd);
exit(0);
[ Modified by Theodore Ts'o to fix a number of bugs in the original code.]
Signed-off-by: Dr. Tilmann Bubeck <t.bubeck@reinform.de>
o mkfs.f2fs supports no discard option.
o fixed volume label size in 512 bytes.
Signed-off-by: Changman Lee <cm224.lee@samsung.com>
Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
The following set of operations on a NFS client and server will cause
server# mkdir a
client# cd a
server# mv a a.bak
client# sleep 30 # (or whatever the dir attrcache timeout is)
client# stat .
stat: cannot stat `.': Stale NFS file handle
Obviously, we should not be getting an ESTALE error back there since the
inode still exists on the server. The problem is that the lookup code
will call d_revalidate on the dentry that "." refers to, because NFS has
FS_REVAL_DOT set.
nfs_lookup_revalidate will see that the parent directory has changed and
will try to reverify the dentry by redoing a LOOKUP. That of course
fails, so the lookup code returns ESTALE.
The problem here is that d_revalidate is really a bad fit for this case.
What we really want to know at this point is whether the inode is still
good or not, but we don't really care what name it goes by or whether
the dcache is still valid.
Add a new d_op->d_weak_revalidate operation and have complete_walk call
that instead of d_revalidate. The intent there is to allow for a
"weaker" d_revalidate that just checks to see whether the inode is still
good. This is also gives us an opportunity to kill off the FS_REVAL_DOT
special casing.
[AV: changed method name, added note in porting, fixed confusion re
having it possibly called from RCU mode (it won't be)]
Cc: NeilBrown <neilb@suse.de>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
document to reflect the layout generated by mkfs.f2fs .
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Pull VFS update from Al Viro:
"fscache fixes, ESTALE patchset, vmtruncate removal series, assorted
misc stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (79 commits)
vfs: make lremovexattr retry once on ESTALE error
vfs: make removexattr retry once on ESTALE
vfs: make llistxattr retry once on ESTALE error
vfs: make listxattr retry once on ESTALE error
vfs: make lgetxattr retry once on ESTALE
vfs: make getxattr retry once on an ESTALE error
vfs: allow lsetxattr() to retry once on ESTALE errors
vfs: allow setxattr to retry once on ESTALE errors
vfs: allow utimensat() calls to retry once on an ESTALE error
vfs: fix user_statfs to retry once on ESTALE errors
vfs: make fchownat retry once on ESTALE errors
vfs: make fchmodat retry once on ESTALE errors
vfs: have chroot retry once on ESTALE error
vfs: have chdir retry lookup and call once on ESTALE error
vfs: have faccessat retry once on an ESTALE error
vfs: have do_sys_truncate retry once on an ESTALE error
vfs: fix renameat to retry on ESTALE errors
vfs: make do_unlinkat retry once on ESTALE errors
vfs: make do_rmdir retry once on ESTALE errors
vfs: add a flags argument to user_path_parent
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into for-linus
Removed vmtruncate
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
Pull nfsd update from Bruce Fields:
"Included this time:
- more nfsd containerization work from Stanislav Kinsbursky: we're
not quite there yet, but should be by 3.9.
- NFSv4.1 progress: implementation of basic backchannel security
negotiation and the mandatory BACKCHANNEL_CTL operation. See
http://wiki.linux-nfs.org/wiki/index.php/Server_4.0_and_4.1_issues
for remaining TODO's
- Fixes for some bugs that could be triggered by unusual compounds.
Our xdr code wasn't designed with v4 compounds in mind, and it
shows. A more thorough rewrite is still a todo.
- If you've ever seen "RPC: multiple fragments per record not
supported" logged while using some sort of odd userland NFS client,
that should now be fixed.
- Further work from Jeff Layton on our mechanism for storing
information about NFSv4 clients across reboots.
- Further work from Bryan Schumaker on his fault-injection mechanism
(which allows us to discard selective NFSv4 state, to excercise
rarely-taken recovery code paths in the client.)
- The usual mix of miscellaneous bugs and cleanup.
Thanks to everyone who tested or contributed this cycle."
* 'for-3.8' of git://linux-nfs.org/~bfields/linux: (111 commits)
nfsd4: don't leave freed stateid hashed
nfsd4: free_stateid can use the current stateid
nfsd4: cleanup: replace rq_resused count by rq_next_page pointer
nfsd: warn on odd reply state in nfsd_vfs_read
nfsd4: fix oops on unusual readlike compound
nfsd4: disable zero-copy on non-final read ops
svcrpc: fix some printks
NFSD: Correct the size calculation in fault_inject_write
NFSD: Pass correct buffer size to rpc_ntop
nfsd: pass proper net to nfsd_destroy() from NFSd kthreads
nfsd: simplify service shutdown
nfsd: replace boolean nfsd_up flag by users counter
nfsd: simplify NFSv4 state init and shutdown
nfsd: introduce helpers for generic resources init and shutdown
nfsd: make NFSd service structure allocated per net
nfsd: make NFSd service boot time per-net
nfsd: per-net NFSd up flag introduced
nfsd: move per-net startup code to separated function
nfsd: pass net to __write_ports() and down
nfsd: pass net to nfsd_set_nrthreads()
Provide a proper invalidation method rather than relying on the netfs retiring
the cookie it has and getting a new one. The problem with this is that isn't
easy for the netfs to make sure that it has completed/cancelled all its
outstanding storage and retrieval operations on the cookie it is retiring.
Instead, have the cache provide an invalidation method that will cancel or wait
for all currently outstanding operations before invalidating the cache, and
will cause new operations to queue up behind that. Whilst invalidation is in
progress, some requests will be rejected until the cache can stack a barrier on
the operation queue to cause new operations to be deferred behind it.
Fix the state management of internal fscache operations and the accounting of
what operations are in what states.
This is done by:
(1) Give struct fscache_operation a enum variable that directly represents the
state it's currently in, rather than spreading this knowledge over a bunch
of flags, who's processing the operation at the moment and whether it is
queued or not.
This makes it easier to write assertions to check the state at various
points and to prevent invalid state transitions.
(2) Add an 'operation complete' state and supply a function to indicate the
completion of an operation (fscache_op_complete()) and make things call
it. The final call to fscache_put_operation() can then check that an op
in the appropriate state (complete or cancelled).
(3) Adjust the use of object->n_ops, ->n_in_progress, ->n_exclusive to better
govern the state of an object:
(a) The ->n_ops is now the number of extant operations on the object
and is now decremented by fscache_put_operation() only.
(b) The ->n_in_progress is simply the number of objects that have been
taken off of the object's pending queue for the purposes of being
run. This is decremented by fscache_op_complete() only.
(c) The ->n_exclusive is the number of exclusive ops that have been
submitted and queued or are in progress. It is decremented by
fscache_op_complete() and by fscache_cancel_op().
fscache_put_operation() and fscache_operation_gc() now no longer try to
clean up ->n_exclusive and ->n_in_progress. That was leading to double
decrements against fscache_cancel_op().
fscache_cancel_op() now no longer decrements ->n_ops. That was leading to
double decrements against fscache_put_operation().
fscache_submit_exclusive_op() now decides whether it has to queue an op
based on ->n_in_progress being > 0 rather than ->n_ops > 0 as the latter
will persist in being true even after all preceding operations have been
cancelled or completed. Furthermore, if an object is active and there are
runnable ops against it, there must be at least one op running.
(4) Add a remaining-pages counter (n_pages) to struct fscache_retrieval and
provide a function to record completion of the pages as they complete.
When n_pages reaches 0, the operation is deemed to be complete and
fscache_op_complete() is called.
Add calls to fscache_retrieval_complete() anywhere we've finished with a
page we've been given to read or allocate for. This includes places where
we just return pages to the netfs for reading from the server and where
accessing the cache fails and we discard the proposed netfs page.
The bugs in the unfixed state management manifest themselves as oopses like the
following where the operation completion gets out of sync with return of the
cookie by the netfs. This is possible because the cache unlocks and returns
all the netfs pages before recording its completion - which means that there's
nothing to stop the netfs discarding them and returning the cookie.
FS-Cache: Cookie 'NFS.fh' still has outstanding reads
kernel BUG at fs/fscache/cookie.c:519!
invalid opcode: 0000 [#1] SMP
CPU 1
Modules linked in: cachefiles nfs fscache auth_rpcgss nfs_acl lockd sunrpc
Pid: 400, comm: kswapd0 Not tainted 3.1.0-rc7-fsdevel+ #1090 /DG965RY
RIP: 0010:[<ffffffffa007050a>] [<ffffffffa007050a>] __fscache_relinquish_cookie+0x170/0x343 [fscache]
RSP: 0018:ffff8800368cfb00 EFLAGS: 00010282
RAX: 000000000000003c RBX: ffff880023cc8790 RCX: 0000000000000000
RDX: 0000000000002f2e RSI: 0000000000000001 RDI: ffffffff813ab86c
RBP: ffff8800368cfb50 R08: 0000000000000002 R09: 0000000000000000
R10: ffff88003a1b7890 R11: ffff88001df6e488 R12: ffff880023d8ed98
R13: ffff880023cc8798 R14: 0000000000000004 R15: ffff88003b8bf370
FS: 0000000000000000(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00000000008ba008 CR3: 0000000023d93000 CR4: 00000000000006e0
Process kswapd0 (pid: 400, threadinfo ffff8800368ce000, task ffff88003b8bf040)
Stack:
ffff88003b8bf040 ffff88001df6e528 ffff88001df6e528 ffffffffa00b46b0
ffff88003b8bf040 ffff88001df6e488 ffff88001df6e620 ffffffffa00b46b0
ffff88001ebd04c8 0000000000000004 ffff8800368cfb70 ffffffffa00b2c91
Call Trace:
[<ffffffffa00b2c91>] nfs_fscache_release_inode_cookie+0x3b/0x47 [nfs]
[<ffffffffa008f25f>] nfs_clear_inode+0x3c/0x41 [nfs]
[<ffffffffa0090df1>] nfs4_evict_inode+0x2f/0x33 [nfs]
[<ffffffff810d8d47>] evict+0xa1/0x15c
[<ffffffff810d8e2e>] dispose_list+0x2c/0x38
[<ffffffff810d9ebd>] prune_icache_sb+0x28c/0x29b
[<ffffffff810c56b7>] prune_super+0xd5/0x140
[<ffffffff8109b615>] shrink_slab+0x102/0x1ab
[<ffffffff8109d690>] balance_pgdat+0x2f2/0x595
[<ffffffff8103e009>] ? process_timeout+0xb/0xb
[<ffffffff8109dba3>] kswapd+0x270/0x289
[<ffffffff8104c5ea>] ? __init_waitqueue_head+0x46/0x46
[<ffffffff8109d933>] ? balance_pgdat+0x595/0x595
[<ffffffff8104bf7a>] kthread+0x7f/0x87
[<ffffffff813ad6b4>] kernel_thread_helper+0x4/0x10
[<ffffffff81026b98>] ? finish_task_switch+0x45/0xc0
[<ffffffff813abcdd>] ? retint_restore_args+0xe/0xe
[<ffffffff8104befb>] ? __init_kthread_worker+0x53/0x53
[<ffffffff813ad6b0>] ? gs_change+0xb/0xb
Pull new F2FS filesystem from Jaegeuk Kim:
"Introduce a new file system, Flash-Friendly File System (F2FS), to
Linux 3.8.
Highlights:
- Add initial f2fs source codes
- Fix an endian conversion bug
- Fix build failures on random configs
- Fix the power-off-recovery routine
- Minor cleanup, coding style, and typos patches"
From the Kconfig help text:
F2FS is based on Log-structured File System (LFS), which supports
versatile "flash-friendly" features. The design has been focused on
addressing the fundamental issues in LFS, which are snowball effect
of wandering tree and high cleaning overhead.
Since flash-based storages show different characteristics according to
the internal geometry or flash memory management schemes aka FTL, F2FS
and tools support various parameters not only for configuring on-disk
layout, but also for selecting allocation and cleaning algorithms.
and there's an article by Neil Brown about it on lwn.net:
http://lwn.net/Articles/518988/
* tag 'for-3.8-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (36 commits)
f2fs: fix tracking parent inode number
f2fs: cleanup the f2fs_bio_alloc routine
f2fs: introduce accessor to retrieve number of dentry slots
f2fs: remove redundant call to f2fs_put_page in delete entry
f2fs: make use of GFP_F2FS_ZERO for setting gfp_mask
f2fs: rewrite f2fs_bio_alloc to make it simpler
f2fs: fix a typo in f2fs documentation
f2fs: remove unused variable
f2fs: move error condition for mkdir at proper place
f2fs: remove unneeded initialization
f2fs: check read only condition before beginning write out
f2fs: remove unneeded memset from init_once
f2fs: show error in case of invalid mount arguments
f2fs: fix the compiler warning for uninitialized use of variable
f2fs: resolve build failures
f2fs: adjust kernel coding style
f2fs: fix endian conversion bugs reported by sparse
f2fs: remove unneeded version.h header file from f2fs.h
f2fs: update the f2fs document
f2fs: update Kconfig and Makefile
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Andrey Vagin <avagin@openvz.org>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: James Bottomley <jbottomley@parallels.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Matthew Helsley <matt.helsley@gmail.com>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Tvrtko Ursulin <tvrtko.ursulin@onelan.co.uk>
[akpm@linux-foundation.org: tweak documentation]
It is currently impossible to examine the state of seccomp for a given
process. While attaching with gdb and attempting "call
prctl(PR_GET_SECCOMP,...)" will work with some situations, it is not
reliable. If the process is in seccomp mode 1, this query will kill the
process (prctl not allowed), if the process is in mode 2 with prctl not
allowed, it will similarly be killed, and in weird cases, if prctl is
filtered to return errno 0, it can look like seccomp is disabled.
When reviewing the state of running processes, there should be a way to
externally examine the seccomp mode. ("Did this build of Chrome end up
using seccomp?" "Did my distro ship ssh with seccomp enabled?")
This adds the "Seccomp" line to /proc/$pid/status.
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
During c/r sessions we've found that there is no way at the moment to
fetch some VMA associated flags, such as mlock() and madvise().
This leads us to a problem -- we don't know if we should call for mlock()
and/or madvise() after restore on the vma area we're bringing back to
life.
This patch intorduces a new field into "smaps" output called VmFlags,
where all set flags associated with the particular VMA is shown as two
letter mnemonics.
[ Strictly speaking for c/r we only need mlock/madvise bits but it has been
said that providing just a few flags looks somehow inconsistent. So all
flags are here now. ]
This feature is made available on CONFIG_CHECKPOINT_RESTORE=n kernels, as
other applications may start to use these fields.
The data is encoded in a somewhat awkward two letters mnemonic form, to
encourage userspace to be prepared for fields being added or removed in
the future.
[a.p.zijlstra@chello.nl: props to use for_each_set_bit]
[sfr@canb.auug.org.au: props to use array instead of struct]
[akpm@linux-foundation.org: overall redesign and simplification]
[akpm@linux-foundation.org: remove unneeded braces per sfr, avoid using bloaty for_each_set_bit()]
So far FAT either offsets time stamps by sys_tz.minuteswest or leaves them
as they are (when tz=UTC mount option is used). However in some cases it
is useful if one can specify time stamp offset on his own (e.g. when time
zone of the camera connected is different from time zone of the computer,
or when HW clock is in UTC and thus sys_tz.minuteswest == 0).
So provide a mount option time_offset= which allows user to specify offset
in minutes that should be applied to time stamps on the filesystem.
akpm: this code would work incorrectly when used via `mount -o remount',
because cached inodes would not be updated. But fatfs's fat_remount() is
basically a no-op anyway.
Pull ext4 update from Ted Ts'o:
"There are two major features for this merge window. The first is
inline data, which allows small files or directories to be stored in
the in-inode extended attribute area. (This requires that the file
system use inodes which are at least 256 bytes or larger; 128 byte
inodes do not have any room for in-inode xattrs.)
The second new feature is SEEK_HOLE/SEEK_DATA support. This is
enabled by the extent status tree patches, and this infrastructure
will be used to further optimize ext4 in the future.
Beyond that, we have the usual collection of code cleanups and bug
fixes."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (63 commits)
ext4: zero out inline data using memset() instead of empty_zero_page
ext4: ensure Inode flags consistency are checked at build time
ext4: Remove CONFIG_EXT4_FS_XATTR
ext4: remove unused variable from ext4_ext_in_cache()
ext4: remove redundant initialization in ext4_fill_super()
ext4: remove redundant code in ext4_alloc_inode()
ext4: use sync_inode_metadata() when syncing inode metadata
ext4: enable ext4 inline support
ext4: let fallocate handle inline data correctly
ext4: let ext4_truncate handle inline data correctly
ext4: evict inline data out if we need to strore xattr in inode
ext4: let fiemap work with inline data
ext4: let ext4_rename handle inline dir
ext4: let empty_dir handle inline dir
ext4: let ext4_delete_entry() handle inline data
ext4: make ext4_delete_entry generic
ext4: let ext4_find_entry handle inline data
ext4: create a new function search_dir
ext4: let ext4_readdir handle inline data
ext4: let add_dir_entry handle inline data properly
Pull x86 EFI update from Peter Anvin:
"EFI tree, from Matt Fleming. Most of the patches are the new efivarfs
filesystem by Matt Garrett & co. The balance are support for EFI
wallclock in the absence of a hardware-specific driver, and various
fixes and cleanups."
* 'core-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits)
efivarfs: Make efivarfs_fill_super() static
x86, efi: Check table header length in efi_bgrt_init()
efivarfs: Use query_variable_info() to limit kmalloc()
efivarfs: Fix return value of efivarfs_file_write()
efivarfs: Return a consistent error when efivarfs_get_inode() fails
efivarfs: Make 'datasize' unsigned long
efivarfs: Add unique magic number
efivarfs: Replace magic number with sizeof(attributes)
efivarfs: Return an error if we fail to read a variable
efi: Clarify GUID length calculations
efivarfs: Implement exclusive access for {get,set}_variable
efivarfs: efivarfs_fill_super() ensure we clean up correctly on error
efivarfs: efivarfs_fill_super() ensure we free our temporary name
efivarfs: efivarfs_fill_super() fix inode reference counts
efivarfs: efivarfs_create() ensure we drop our reference on inode on error
efivarfs: efivarfs_file_read ensure we free data in error paths
x86-64/efi: Use EFI to deal with platform wall clock (again)
x86/kernel: remove tboot 1:1 page table creation code
x86, efi: 1:1 pagetable mapping for virtual EFI calls
x86, mm: Include the entire kernel memory map in trampoline_pgd
"There is plenty going on, including the cleanup of xfssyncd, metadata
verifiers, CRC infrastructure for the log, tracking of inodes with
speculative allocation, a cleanup of xfs_fs_subr.c, fixes for
XFS_IOC_ZERO_RANGE, and important fix related to log replay (only
update the last_sync_lsn when a transaction completes), a fix for
deadlock on AGF buffers, documentation and comment updates, and a few
more cleanups and fixes.
Details:
- remove the xfssyncd mess
- only update the last_sync_lsn when a transaction completes
- zero allocation_args on the kernel stack
- fix AGF/alloc workqueue deadlock
- silence uninitialised f.file warning
- Update inode alloc comments
- Update mount options documentation
- report projid32bit feature in geometry call
- speculative preallocation inode tracking
- fix attr tree double split corruption
- fix broken error handling in xfs_vm_writepage
- drop buffer io reference when a bad bio is built
- add more attribute tree trace points
- growfs infrastructure changes for 3.8
- fs/xfs/xfs_fs_subr.c die die die
- add CRC infrastructure
- add CRC checks to the log
- Remove description of nodelaylog mount option from xfs.txt
- inode allocation should use unmapped buffers
- byte range granularity for XFS_IOC_ZERO_RANGE
- fix direct IO nested transaction deadlock
- fix stray dquot unlock when reclaiming dquots
- fix sparse reported log CRC endian issue"
Fix up trivial conflict in fs/xfs/xfs_fsops.c due to the same patch
having been applied twice (commits eaef854335ce and 1375cb65e87b: "xfs:
growfs: don't read garbage for new secondary superblocks") with later
updates to the affected code in the XFS tree.
* tag 'for-linus-v3.8-rc1' of git://oss.sgi.com/xfs/xfs: (78 commits)
xfs: fix sparse reported log CRC endian issue
xfs: fix stray dquot unlock when reclaiming dquots
xfs: fix direct IO nested transaction deadlock.
xfs: byte range granularity for XFS_IOC_ZERO_RANGE
xfs: inode allocation should use unmapped buffers.
xfs: Remove the description of nodelaylog mount option from xfs.txt
xfs: add CRC checks to the log
xfs: add CRC infrastructure
xfs: convert buffer verifiers to an ops structure.
xfs: connect up write verifiers to new buffers
xfs: add pre-write metadata buffer verifier callbacks
xfs: add buffer pre-write callback
xfs: Add verifiers to dir2 data readahead.
xfs: add xfs_da_node verification
xfs: factor and verify attr leaf reads
xfs: factor dir2 leaf read
xfs: factor out dir2 data block reading
xfs: factor dir2 free block reading
xfs: verify dir2 block format buffers
xfs: factor dir2 block read operations
In f2fs_fs.h, one f2fs inode contains 923 data block pointers, while
f2fs documentation says it is 929. Fix this inconsistence.
I moved the f2fs-tools.git into kernel.org.
And I added a new mailing list, linux-f2fs-devel@lists.sourceforge.net.
This adds a document describing the mount options, proc entries, usage, and
design of Flash-Friendly File System, namely F2FS.
Ted has sent out a RFC about removing this feature. Eric and Jan
confirmed that both RedHat and SUSE enable this feature in all their
product. David also said that "As far as I know, it's enabled in all
Android kernels that use ext4." So it seems OK for us.
And what's more, as inline data depends its implementation on xattr,
and to be frank, I don't run any test again inline data enabled while
xattr disabled. So I think we should add inline data and remove this
config option in the same release.
[ The savings if you disable CONFIG_EXT4_FS_XATTR is only 27k, which
isn't much in the grand scheme of things. Since no one seems to be
testing this configuration except for some automated compile farms, on
balance we are better removing this config option, and so that it is
effectively always enabled. -- tytso ]
Cc: David Brown <davidb@codeaurora.org>
Cc: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Tao Ma <boyu.mt@taobao.com>
nodelaylog mount option is removed by commit 93b8a585. But there still be
the description about it in the xfs document. This patch removes it.
Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com>
Our server rejects compounds containing more than one write operation.
It's unclear whether this is really permitted by the spec; with 4.0,
it's possibly OK, with 4.1 (which has clearer limits on compound
parameters), it's probably not OK. No client that we're aware of has
ever done this, but in theory it could be useful.
The source of the limitation: we need an array of iovecs to pass to the
write operation. In the worst case that array of iovecs could have
hundreds of elements (the maximum rwsize divided by the page size), so
it's too big to put on the stack, or in each compound op. So we instead
keep a single such array in the compound argument.
We fill in that array at the time we decode the xdr operation.
But we decode every op in the compound before executing any of them. So
once we've used that array we can't decode another write.
If we instead delay filling in that array till the time we actually
perform the write, we can reuse it.
Another option might be to switch to decoding compound ops one at a
time. I considered doing that, but it has a number of other side
effects, and I'd rather fix just this one problem for now.
This is mostly a revert of 01dc52ebdf47 ("oom: remove deprecated oom_adj")
from Davidlohr Bueso.
It reintroduces /proc/pid/oom_adj for backwards compatibility with earlier
kernels. It simply scales the value linearly when /proc/pid/oom_score_adj
is written.
The major difference is that its scheduled removal is no longer included
in Documentation/feature-removal-schedule.txt. We do warn users with a
single printk, though, to suggest the more powerful and supported
/proc/pid/oom_score_adj interface.
Reported-by: Artem S. Tashkinov <t.artem@lycos.com>
This operation is mandatory for servers to implement.
Once inode64 is the default allocation mode now, kernel documentation should be
updated to match this behaviour.
Signed-off-by: Carlos Maiolino <cmaiolino@redhat.com>
Reviewed-by: Mark Tinguely <tinguely@sgi.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Pull nfsd update from J Bruce Fields:
"Another relatively quiet cycle. There was some progress on my
remaining 4.1 todo's, but a couple of them were just of the form
"check that we do X correctly", so didn't have much affect on the
code.
Other than that, a bunch of cleanup and some bugfixes (including an
annoying NFSv4.0 state leak and a busy-loop in the server that could
cause it to peg the CPU without making progress)."
* 'for-3.7' of git://linux-nfs.org/~bfields/linux: (46 commits)
UAPI: (Scripted) Disintegrate include/linux/sunrpc
UAPI: (Scripted) Disintegrate include/linux/nfsd
nfsd4: don't allow reclaims of expired clients
nfsd4: remove redundant callback probe
nfsd4: expire old client earlier
nfsd4: separate session allocation and initialization
nfsd4: clean up session allocation
nfsd4: minor free_session cleanup
nfsd4: new_conn_from_crses should only allocate
nfsd4: separate connection allocation and initialization
nfsd4: reject bad forechannel attrs earlier
nfsd4: enforce per-client sessions/no-sessions distinction
nfsd4: set cl_minorversion at create time
nfsd4: don't pin clientids to pseudoflavors
nfsd4: fix bind_conn_to_session xdr comment
nfsd4: cast readlink() bug argument
NFSD: pass null terminated buf to kstrtouint()
nfsd: remove duplicate init in nfsd4_cb_recall
nfsd4: eliminate redundant nfs4_free_stateid
fs/nfsd/nfs4idmap.c: adjust inconsistent IS_ERR and PTR_ERR
Pull NFS client updates from Trond Myklebust:
"Features include:
- Remove CONFIG_EXPERIMENTAL dependency from NFSv4.1
Aside from the issues discussed at the LKS, distros are shipping
NFSv4.1 with all the trimmings.
- Fix fdatasync()/fsync() for the corner case of a server reboot.
- NFSv4 OPEN access fix: finally distinguish correctly between
open-for-read and open-for-execute permissions in all situations.
- Ensure that the TCP socket is closed when we're in CLOSE_WAIT
- More idmapper bugfixes
- Lots of pNFS bugfixes and cleanups to remove unnecessary state and
make the code easier to read.
- In cases where a pNFS read or write fails, allow the client to
resume trying layoutgets after two minutes of read/write-
through-mds.
- More net namespace fixes to the NFSv4 callback code.
- More net namespace fixes to the NFSv3 locking code.
- More NFSv4 migration preparatory patches.
Including patches to detect network trunking in both NFSv4 and
NFSv4.1
- pNFS block updates to optimise LAYOUTGET calls."
* tag 'nfs-for-3.7-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (113 commits)
pnfsblock: cleanup nfs4_blkdev_get
NFS41: send real read size in layoutget
NFS41: send real write size in layoutget
NFS: track direct IO left bytes
NFSv4.1: Cleanup ugliness in pnfs_layoutgets_blocked()
NFSv4.1: Ensure that the layout sequence id stays 'close' to the current
NFSv4.1: Deal with seqid wraparound in the pNFS return-on-close code
NFSv4 set open access operation call flag in nfs4_init_opendata_res
NFSv4.1: Remove the dependency on CONFIG_EXPERIMENTAL
NFSv4 reduce attribute requests for open reclaim
NFSv4: nfs4_open_done first must check that GETATTR decoded a file type
NFSv4.1: Deal with wraparound when updating the layout "barrier" seqid
NFSv4.1: Deal with wraparound issues when updating the layout stateid
NFSv4.1: Always set the layout stateid if this is the first layoutget
NFSv4.1: Fix another refcount issue in pnfs_find_alloc_layout
NFSv4: don't put ACCESS in OPEN compound if O_EXCL
NFSv4: don't check MAY_WRITE access bit in OPEN
NFS: Set key construction data for the legacy upcall
NFSv4.1: don't do two EXCHANGE_IDs on mount
NFS: nfs41_walk_client_list(): re-lock before iterating
This is to complete part of the Userspace API (UAPI) disintegration for which
the preparatory patches were pulled recently. After these patches, userspace
headers will be segregated into:
include/uapi/linux/.../foo.h
for the userspace interface stuff, and:
include/linux/.../foo.h
for the strictly kernel internal stuff.
The deprecated /proc/<pid>/oom_adj is scheduled for removal this month.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
Acked-by: David Rientjes <rientjes@google.com>
"The big new feature added this time is supporting online resizing
using the meta_bg feature. This allows us to resize file systems
which are greater than 16TB. In addition, the speed of online
resizing has been improved in general.
We also fix a number of races, some of which could lead to deadlocks,
in ext4's Asynchronous I/O and online defrag support, thanks to good
work by Dmitry Monakhov.
There are also a large number of more minor bug fixes and cleanups
from a number of other ext4 contributors, quite of few of which have
submitted fixes for the first time."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (69 commits)
ext4: fix ext4_flush_completed_IO wait semantics
ext4: fix mtime update in nodelalloc mode
ext4: fix ext_remove_space for punch_hole case
ext4: punch_hole should wait for DIO writers
ext4: serialize truncate with owerwrite DIO workers
ext4: endless truncate due to nonlocked dio readers
ext4: serialize unlocked dio reads with truncate
ext4: serialize dio nonlocked reads with defrag workers
ext4: completed_io locking cleanup
ext4: fix unwritten counter leakage
ext4: give i_aiodio_unwritten a more appropriate name
ext4: ext4_inode_info diet
ext4: convert to use leXX_add_cpu()
ext4: ext4_bread usage audit
fs: reserve fallocate flag codepoint
ext4: remove redundant offset check in mext_check_arguments()
ext4: don't clear orphan list on ro mount with errors
jbd2: fix assertion failure in commit code due to lacking transaction credits
ext4: release donor reference when EXT4_IOC_MOVE_EXT ioctl fails
ext4: enable FITRIM ioctl on bigalloc file system
Pull JFS update from Dave Kleikamp:
"JFS TRIM support and some minor fixes"
* tag 'jfs-3.7' of git://github.com/kleikamp/linux-shaggy:
jfs: Fix do_div precision in commit b40c2e66
JFS: use list_move instead of list_del/list_add
jfs: Remove obsolete email address
fs/jfs: TRIM support for JFS Filesystem
Pull networking changes from David Miller:
1) GRE now works over ipv6, from Dmitry Kozlov.
2) Make SCTP more network namespace aware, from Eric Biederman.
3) TEAM driver now works with non-ethernet devices, from Jiri Pirko.
4) Make openvswitch network namespace aware, from Pravin B Shelar.
5) IPV6 NAT implementation, from Patrick McHardy.
6) Server side support for TCP Fast Open, from Jerry Chu and others.
7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel
Borkmann.
8) Increate the loopback default MTU to 64K, from Eric Dumazet.
9) Use a per-task rather than per-socket page fragment allocator for
outgoing networking traffic. This benefits processes that have very
many mostly idle sockets, which is quite common.
From Eric Dumazet.
10) Use up to 32K for page fragment allocations, with fallbacks to
smaller sizes when higher order page allocations fail. Benefits are
a) less segments for driver to process b) less calls to page
allocator c) less waste of space.
From Eric Dumazet.
11) Allow GRO to be used on GRE tunnels, from Eric Dumazet.
12) VXLAN device driver, one way to handle VLAN issues such as the
limitation of 4096 VLAN IDs yet still have some level of isolation.
From Stephen Hemminger.
13) As usual there is a large boatload of driver changes, with the scale
perhaps tilted towards the wireless side this time around.
Fix up various fairly trivial conflicts, mostly caused by the user
namespace changes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits)
hyperv: Add buffer for extended info after the RNDIS response message.
hyperv: Report actual status in receive completion packet
hyperv: Remove extra allocated space for recv_pkt_list elements
hyperv: Fix page buffer handling in rndis_filter_send_request()
hyperv: Fix the missing return value in rndis_filter_set_packet_filter()
hyperv: Fix the max_xfer_size in RNDIS initialization
vxlan: put UDP socket in correct namespace
vxlan: Depend on CONFIG_INET
sfc: Fix the reported priorities of different filter types
sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP
sfc: Fix loopback self-test with separate_tx_channels=1
sfc: Fix MCDI structure field lookup
sfc: Add parentheses around use of bitfield macro arguments
sfc: Fix null function pointer in efx_sriov_channel_type
vxlan: virtual extensible lan
igmp: export symbol ip_mc_leave_group
netlink: add attributes to fdb interface
tg3: unconditionally select HWMON support when tg3 is enabled.
Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT"
gre: fix sparse warning
