path: root/Documentation/gpu/conf.py
2016-10-26doc-rst: build PDF of 80211 and gpu sub-projectMarkus Heiser
This allows to build PDF of only the sub-projects, which reduce the roundtrip compared to build the PDF from the main documentation. Signed-off-by: Markus Heiser <markus.heiser@darmarit.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-18doc-rst: add index to sub-foldersMarkus Heiser
Add a index if only a sub-folder is build e.g.:: make SPHINXDIRS=media cleandocs htmldocs BTW: removed dead search link in the top-index file Signed-off-by: Markus Heiser <markus.heiser@darmarIT.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-14doc-rst: add stand-alone conf.py to gpu folderMarkus Heiser
With the gpu/conf.py, the gpu folder can be build and distributed stand-alone. To compile only the html of 'gpu' folder use:: make SPHINXDIRS="gpu" htmldocs Signed-off-by: Markus Heiser <markus.heiser@darmarIT.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
