path: root/Documentation/hwmon/abituguru-datasheet
2009-01-08fix similar typos to successfullColy Li
When I review ocfs2 code, find there are 2 typos to "successfull". After doing grep "successfull " in kernel tree, 22 typos found totally -- great minds always think alike :) This patch fixes all the similar typos. Thanks for Randy's ack and comments. Signed-off-by: Coly Li <coyli@suse.de> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jeremy Kerr <jk@ozlabs.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06trivial: fix then -> than typos in comments and documentationFrederik Schwarzer
- (better, more, bigger ...) then -> (...) than Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2006-06-22[PATCH] abituguru: New hardware monitoring driverHans de Goede
New hardware monitoring driver for the Abit uGuru Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
