path: root/Documentation/hwmon/lm90
2011-04-29hwmon: (lm90) Fix update interval information in driver documentationGuenter Roeck
The lm90 driver's attribute update interval is configurable. Reflect this information in the driver documentation. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-04-29hwmon: (lm90) Add support for ADT7461A and NCT1008Guenter Roeck
This patch adds support for ADT7461A and NCT1008 to the lm90 driver. Both chips have identical functionality and report the same manufacturing ID and device ID values. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-10-28hwmon: (lm90) Add support for the W83L771W/GJean Delvare
I was wondering if that chip ever existed publicly... Apparently yes, so add support for it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Alexander Stein <alexander.stein@informatik.tu-chemnitz.de> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-10-28hwmon: (lm90) Add support for max6695 and max6696Guenter Roeck
2010-10-28hwmon: (lm90) Add support for extra features of max6659Guenter Roeck
2010-10-28hwmon: (lm90) Add explicit support for max6659Guenter Roeck
2010-03-05hwmon: (lm90) Add SMBus alert supportJean Delvare
Tested successfully with an ADM1032 chip on its evaluation board. It should work fine with all other chips as well. At this point this is more of a proof-of-concept, we don't do anything terribly useful on SMBus alert: we simply log the event. But this could later evolve into libsensors signaling so that user-space applications can take an appropriate action. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Trent Piepho <tpiepho@freescale.com>
2010-03-05hwmon: (lm90) Add support for the Winbond/Nuvoton W83L771AWG/ASGJean Delvare
This chips is found on several Zotac Ion ITX boards, amongst others. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: MC Matti <mcmatti17@googlemail.com> Cc: Manuel Lamotte-Schubert <mls@pronego.com>
2009-03-12hwmon: (lm90) Document support for the MAX6648/6692 chipsDarrick J. Wong
Update documentation to prevent further confusion/duplication. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-26hwmon: (lm90) Add support for the LM99 16 degree offsetJean Delvare
The LM99 differs from the LM86, LM89 and LM90 in that it reports remote temperatures (temp2) 16 degrees lower than they really are. So far we have been cheating and handled this in userspace but it really should be handled by the driver directly. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Matthew Garrett <mjg59@srcf.ucam.org>
2008-10-17hwmon: (lm90) Support MAX6646, MAX6647 and MAX6649Ben Hutchings
These Maxim chips are similar to MAX6657 but use unsigned temperature values to allow for readings up to 145 degrees. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-17hwmon: (lm90) Support ADT7461 in extended modeNate Case
Support ADT7461 in extended temperature range mode, which will change the range of readings from 0..127 to -64..191 degC. Adjust the register conversion functions accordingly. Signed-off-by: Nate Case <ncase@xes-inc.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Martyn Welch <martyn.welch@gefanuc.com>
2008-10-17hwmon: (lm90) Update datasheet linksJean Delvare
Update the links to the datasheet of some of the devices supported by the lm90 driver. Also remove the links from the driver itself, so that we don't have to update them twice each time they change. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Martyn Welch <martyn.welch@gefanuc.com>
2008-10-17hwmon: (lm90) Support the extra resolution bits of MAX6657Jean Delvare
The Maxim MAX6657, MAX6658 and MAX6659 have extra resolution bits for the local temperature measurement. Let the lm90 driver read them and export them to user-space. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Martyn Welch <martyn.welch@gefanuc.com>
2007-07-19hwmon/lm90: Add support for the Maxim MAX6680/MAX6681Rainer Birkenmaier
Signed-off-by: Rainer Birkenmaier <rainer.birkenmaier@siemens.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-07-19hwmon/lm90: Spelling fix: explicitlyJean Delvare
2005-10-28[PATCH] hwmon: lm90 documentation updateJean Delvare
Update the I2C addresses for the ADM1032 and ADT7461 chips. Also update the links to the Analog Devices web site. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: Add PEC support to the lm90 driverJean Delvare
Add PEC support to the lm90 driver. Only the ADM1032 chip supports it, and in a rather tricky way, which is why this patch comes with documentation reinforcements. At least, this demonstrates that the new PEC support logic in i2c-core can properly deal with chips with partial PEC support. As enabling PEC causes a significant performance drop, it can be disabled through a sysfs file (unsurprisingly named "pec"). Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-11[PATCH] I2C: Move hwmon drivers (3/3)Jean Delvare
Part 3: Move the drivers documentation, plus two general documentation files. Note that the patch "adds trailing whitespace", because it does move the files as-is, and some files happen to have trailing whitespace. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
