path: root/Documentation/hwmon/ltc4215
2009-04-01hwmon: Add LTC4215 driverIra Snyder
Add Linux support for the Linear Technology LTC4215 Hot Swap controller I2C monitoring interface. I have tested the driver with my board, and it appears to work fine. With the power supplies disabled, it reads 11.93V input, 1.93V output, no current and no power. With the supplies enabled, it reads 11.93V input, 11.98V output, no current, no power. I'm not drawing any current at the moment, so this is reasonable. The value in the sense register never reads anything except 0, so I expect to get zero from the current and power calculations. I didn't attempt to support changing any of the chip's settings or enabling the FET. I'm not sure even how to do that and still fit within the hwmon framework. :) Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Cc: Jean Delvare <khali@linux-fr.org> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
