path: root/Documentation/hwmon/ntc_thermistor
2016-03-05hwmon: (ntc_thermistor) Add support for ncpXXxh103Joseph McNally
This patch adds support for the Murata NCP15XH103 thermistor series. Signed-off-by: Joseph McNally <jmcna06@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-05-31hwmon: (ntc_thermistor) Add support for ncpXXwf104Beomho Seo
This patch adds support for the ntc thermistor NCPXXWF104 series. Cc: Jean Delvare <jdelvare@suse.de> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Beomho Seo <beomho.seo@samsung.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-08-04hwmon: (ntc_thermistor) Support B57330V2103 from EPCOSJohannes Pointner
This patch adds support for the ntc thermistor B57330V2103 from EPCOS. Signed-off-by: Johannes Pointner <johannes.pointner@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-06-25hwmon: (ntc_thermistor) Use the manufacturer name properlyNaveen Krishna Chatradhi
Murata Manufacturing Co., Ltd is the vendor for NTC (Negative Temperature coefficient) based Thermistors. But, the driver extensively uses "NTC" as the vendor name. This patch corrects the vendor name also updates the compatibility strings according to the vendor-prefix.txt Note: Drivers continue to support the previous compatible strings but further addition of these compatible strings in device tree is deprecated. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2011-07-28hwmon: Driver for NTC ThermistorsDonggeun Kim
Add support for NTC Thermistor series. In this release, the following thermistors are supported: NCP15WB473, NCP18WB473, NCP03WB473, and NCP15WL333. This driver is based on the datasheet of MURATA. The driver in the patch does conversion from the raw ADC value (either voltage or resistence) to temperature. In order to use voltage values as input, the circuit schematics should be provided with the platform data. A compensation table for each type of thermistor is provided for the conversion. Signed-off-by: Donggeun Kim <dg77.kim@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: KyungMin Park <kyungmin.park@samsung.com> Reviewed-by: Shubhrajyoti D <shubhrajyoti@ti.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
