path: root/Documentation/hwmon
2011-11-04hwmon: (w83627ehf) Add support for the W83627UHGJean Delvare
This is essentially a stripped down version of the W83627DHG. Noticeable difference is that it is still powered with +5V, as older models, even though the ADC resolution is 8 mV as newer models have. Thanks to Ulf Bruman (Saab Group) for doing all the testing. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-10-24hwmon: (lm75) Document why clones are not detectedJean Delvare
Explain why clones of the LM75 are generally not detected by the driver, and why this isn't going to change. Also update the documentation to reflect the list of chip names currently supported by the driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-10-24hwmon: (lm75) Add support for Analog Devices ADT75Michael Hennerich
Add datasheet reference and device ID for ADT75. The ADT75, like some other LM75 derivatives, needs to be instantiated using methods 1, 2, or 4. For more information see Documentation/i2c/instantiating-devices. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-10-24hwmon: (pmbus) Add support for Lineage Power DC-DC convertersGuenter Roeck
Add device IDs and reference to datasheets for Lineage Power DC-DC converters. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-10-24hwmon: (pmbus/ltc2978) Add support for LTC3880 to LTC2978 driverGuenter Roeck
The LTC3880 PMBus command set is comparable to LTC2978. Add support for it to the LTC2978 driver. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-10-24hwmon: (pmbus/ltc2978) Explicit driver for LTC2978Guenter Roeck
Provide explicit driver for LTC2978 to enable support for minimum and peak attributes. Remove ltc2978 chip id from generic pmbus driver. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-10-24hwmon: AD7314 driver (ported from IIO)Jonathan Cameron
Driver for AD7314, ADT7301, and ADT7302, ported from IIO. Currently dropped power down mode support. Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> [guenter.roeck@ericsson.com: Added MODULE_DEVICE_TABLE] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-10-24hwmon: (pmbus) Add support for Intersil power management chipsGuenter Roeck
Add support for Intersil / Zilker Labs ZL2004, ZL2006, ZL2008, ZL2105, ZL2106, ZL6100, and ZL6105. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-10-24hwmon: (pmbus) Provide more documentationGuenter Roeck
Provide more documentation describing PMBus driver functionality and the API between the PMBus core driver and PMBus chip drivers. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-10-24hwmon: Add driver for EXYNOS4 TMUDonggeun Kim
This patch allows to read temperature from TMU(Thermal Management Unit) of SAMSUNG EXYNOS4 series of SoC. Signed-off-by: Donggeun Kim <dg77.kim@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-10-24hwmon: (pmbus/adm1275) Add support for ADM1276Guenter Roeck
ADM1276 is mostly compatible to ADM1275, with added support for input power measurement. Add support for it to the ADM1275 driver. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-10-24hwmon: (pmbus/adm1275) Add support for second current limitGuenter Roeck
ADM1275 supports a second current limit, which can be configured as either lower or upper limit. Add support for it and report it as either lower or upper critical current limit. Also replace error return code EINVAL for unsupported pages with ENXIO as this is more appropriate for the observed condition. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-09-21hwmon: (coretemp) Don't use threshold registers for tempX_maxGuenter Roeck
With commit c814a4c7c4aad795835583344353963a0a673eb0, the meaning of tempX_max was changed. It no longer returns the value of bits 8:15 of MSR_IA32_TEMPERATURE_TARGET, but instead returns the value of CPU threshold register T1. tempX_max_hyst was added to reflect the value of temperature threshold register T0. As it turns out, T0 and T1 are used on some systems, presumably by the BIOS. Also, T0 and T1 don't have a well defined meaning. The thresholds may be used as upper or lower limits, and it is not guaranteed that T0 <= T1. Thus, the new attribute mapping does not reflect the actual usage of the threshold registers. Also, register contents are changed during runtime by an entity other than the hwmon driver, meaning the values cached by the driver do not reflect actual register contents. Revert most of c814a4c7c4aad795835583344353963a0a673eb0 to address the problem. Support for T0 and T1 will be added back in with a separate commit, using new attribute names. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Durgadoss R <durgadoss.r@intel.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-09-21hwmon: (coretemp) Let the user force TjMaxJean Delvare
On old CPUs (and even some recent Atom CPUs) TjMax can't be read from the CPU registers, so it is guessed by the driver using a complex heuristic which isn't reliable. So let users who know their CPU's TjMax pass it as a module parameter. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: "R, Durgadoss" <durgadoss.r@intel.com> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Alexander Stein <alexander.stein@systec-electronic.com> Acked-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-09-06hwmon: (max16065) Add chip access warning to documentationGuenter Roeck
The chips supported by the max16065 driver should not be accessed using direct i2ctools commands. Add warning to driver documentation to alert users. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-07-30Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: (24 commits) hwmon: (lm90) Refactor reading of config2 register hwmon: (lm90) Make SA56004 detection more robust hwmon: (lm90) Simplify handling of extended local temp register hwmon: (pmbus) Add client driver for LM25066, LM5064, and LM5066 hwmon: (max34440) Add support for peak attributes hwmon: (max8688) Add support for peak attributes hwmon: (max16064) Add support for peak attributes hwmon: (adm1275) Add support for peak attributes hwmon: (pmbus) Add support for peak attributes hwmon: Add new attributes to sysfs ABI hwmon: (pmbus) Strengthen check for status register existence hwmon: (pmbus) Add support for virtual pages hwmon: (pmbus) Support reading and writing of word registers in device specific code hwmon: (pmbus) Increase attribute name size hwmon: (pmbus) Add ADP4000, NCP4200 and NCP4208 to list of supported devices hwmon: (pmbus) Add support for VID output voltage mode hwmon: (pmbus) Move PMBus drivers to drivers/hwmon/pmbus hwmon: (coretemp) Add core/pkg threshold support to Coretemp hwmon: (lm95241) Add support for LM95231 hwmon: LM95245 driver ...
2011-07-28hwmon: (pmbus) Add client driver for LM25066, LM5064, and LM5066Guenter Roeck
PMBus client driver supporting National Semiconductor LM25066, LM5064, and LM5066. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-07-28hwmon: (max34440) Add support for peak attributesGuenter Roeck
Add support for voltage, current, and temperature peak (historic maximum) attributes. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-07-28hwmon: (max8688) Add support for peak attributesGuenter Roeck
2011-07-28hwmon: (max16064) Add support for peak attributesGuenter Roeck
Add support for voltage and temperature peak (historic maximum) attributes. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-07-28hwmon: (adm1275) Add support for peak attributesGuenter Roeck
Add support for voltage and current peak (historic maximum) attributes. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-07-28hwmon: Add new attributes to sysfs ABIGuenter Roeck
Add the following attributes to the sysfs ABI. in[0-*]_average in[0-*]_lowest in[0-*]_highest in[0-*]_reset_history in_reset_history curr[1-*]_average curr[1-*]_lowest curr[1-*]_highest curr[1-*]_reset_history curr_reset_history Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-07-28hwmon: (pmbus) Add ADP4000, NCP4200 and NCP4208 to list of supported devicesGuenter Roeck
Add ADP4000, NCP4200 and NCP4208 to the list of devices supported by the generic PMBus driver, and add device IDs to enable explicit instantiation. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-07-28hwmon: (coretemp) Add core/pkg threshold support to CoretempDurgadoss R
This patch adds the core and pkg support to coretemp. These thresholds can be configured via the sysfs interfaces tempX_max and tempX_max_hyst. An interrupt is generated when CPU temperature reaches or crosses above tempX_max OR drops below tempX_max_hyst. This patch is based on the documentation in IA Manual vol 3A, that can be downloaded from here: http://download.intel.com/design/processor/manuals/253668.pdf Signed-off-by: Durgadoss R <durgadoss.r@intel.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-28hwmon: LM95245 driverAlexander Stein
A hwmon driver for the National Semiconductor LM95245 dual temperature sensors chip. Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-28hwmon: (lm90) Add support for Philips SA56004Stijn Devriendt
Add support for Philips SA56004, an LM86 compatible temperature sensor. Signed-off-by: Stijn Devriendt <sdevrien@cisco.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-28hwmon: Driver for NTC ThermistorsDonggeun Kim
Add support for NTC Thermistor series. In this release, the following thermistors are supported: NCP15WB473, NCP18WB473, NCP03WB473, and NCP15WL333. This driver is based on the datasheet of MURATA. The driver in the patch does conversion from the raw ADC value (either voltage or resistence) to temperature. In order to use voltage values as input, the circuit schematics should be provided with the platform data. A compensation table for each type of thermistor is provided for the conversion. Signed-off-by: Donggeun Kim <dg77.kim@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: KyungMin Park <kyungmin.park@samsung.com> Reviewed-by: Shubhrajyoti D <shubhrajyoti@ti.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-28hwmon: Driver for MAX1668David George
This patch adds support for MAX1668 and compatible temperature sensors. Signed-off-by: David George <david.george@ska.ac.za> [guenter.roeck@ericsson.com: minor cleanup of probe error path] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-25hwmon: (lm78) Become the maintainerJean Delvare
Declare myself the maintainer of the lm78 driver. I still have a running system with one of these chips. Also count myself as a co-author of the driver. With 34 commits over 6 years, it seems fair. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-07-25hwmon: (it87) Add chassis intrusion detection supportJean Delvare
Add chassis intrusion detection support for all supported devices, using the standard interface. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-07-25hwmon: New driver sch5636Hans de Goede
This patch adds a new driver for SMSC SCH5636 Super I/O chips. The chips include an embedded microcontroller for hardware monitoring solutions, allowing motherboard manufacturers to create their own custom hwmon solution based upon the SCH5636. Currently the sch5636 driver only supports the Fujitsu Theseus SCH5636 based hwmon solution. The sch5636 driver runs a sanity check on loading to ensure it is dealing with a Fujitsu Theseus and not with another custom SCH5636 based hwmon solution. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-07-03hwmon: (k10temp) Update documentation for Fam12hClemens Ladisch
Add some CPU series IDs and links to the Fam12h datasheets. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-07-03hwmon: (f71882fg) Add support for the F71869AHans de Goede
The F71869A is almost the same as the F71869F/E, except that it has the normal number of temp and pwm zones for a F71882FG derived chip, rather then the limited number of the F71869F/E. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Max Baldwin <archerseven@gmail.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-05-25hwmon: New driver for the SMSC EMC6W201Jean Delvare
This is a new driver for the SMSC EMC6W201 hardware monitoring device. The device is functionally close to the EMC6D100 series, but is register-incompatible. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Harry G McGavran Jr <w5pny@arrl.net> Tested-by: Jeff Rickman <jrickman@myamigos.us> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-05-25hwmon: (max6650) Properly support the MAX6650Jean Delvare
The MAX6650 has only one fan input. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: "Hans J. Koch" <hjk@hansjkoch.de> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-05-25hwmon: (max6650) Drop device detectionJean Delvare
MAX6650 device detection is unreliable, we got reports of false positives. We now have many ways to let users instantiate the devices explicitly, so unreliable detection should be dropped. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: "Hans J. Koch" <hjk@hansjkoch.de> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-05-25hwmon: (f71882fg) Add support for F71808AHans de Goede
2011-05-25hwmon: Add driver for AMD family 15h processor power informationAndreas Herrmann
This CPU family provides NB register values to gather following TDP information * ProcessorPwrWatts: Specifies in Watts the maximum amount of power the processor can support. * CurrPwrWatts: Specifies in Watts the current amount of power being consumed by the processor. This driver provides * power1_crit (ProcessorPwrWatts) * power1_input (CurrPwrWatts) Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-05-25hwmon: (k10temp) Add support for Fam15h (Bulldozer)Andre Przywara
AMDs upcoming CPUs use the same mechanism for the internal temperature reporting as the Fam10h CPUs, so we just needed to add the appropriate PCI-ID to the list. This allows to use the k10temp driver on those CPUs. While at it change the Kconfig entry to be more generic. Signed-off-by: Andre Przywara <andre.przywara@amd.com> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-05-21hwmon: Remove pkgtemp driverGuenter Roeck
After the merge of pkgtemp functionality into the coretemp driver, the pkgtemp driver is no longer necessary. Remove it. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-05-20hwmon: (coretemp) Merge pkgtemp with coretempDurgadoss R
This patch merges the pkgtemp with coretemp driver. The sysfs interfaces for all cores in the same pkg are shown under one directory, in hwmon. It also supports CONFIG_HOTPLUG_CPU. So, the sysfs interfaces are created when each core comes online and are removed when it goes offline. Signed-off-by: Durgadoss R <durgadoss.r@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> [guenter.roeck@ericsson.com: Fixed section reference errors] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-05-19hwmon: (pmbus) Add support for Analog Devices ADM1275Guenter Roeck
Add support for Analog Devices ADM1275 Hot-Swap Controller and Digital Power Monitor Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Tom Grennan <tom.grennan@ericsson.com>
2011-05-19hwmon: (pmbus) Support for TI UCD90xxx series Sequencer and System Health ↵Guenter Roeck
Controllers Hardware monitoring support for TI UCD90120, UCD90124, UCD9090, and UCD90910 Sequencer and System Health Controllers. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Tom Grennan <tom.grennan@ericsson.com>
2011-05-19hwmon: (pmbus) Add support for TI UCD9200 series of PWM System ControllersGuenter Roeck
This patch adds hardware monitoring support for TI UCD9220, UCD9222, UCD9224, UCD9240, UCD9244, UCD9246, and UCD9248 Digital PWM System Controllers. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Tom Grennan <tom.grennan@ericsson.com>
2011-05-19hwmon: Driver for MAX16065 System Manager and compatiblesGuenter Roeck
This patch adds hardware monitoring support for Maxim MAX16065, MAX16066, MAX16067, MAX16068, MAX16070, and MAX16071 flash-configurable system managers with nonvolatile fault registers. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Jean Delvare <khali@linux-fr.org>
2011-05-19hwmon: (sht15) add support for CRC validationJerome Oufella
The sht15 sensor allows validating exchanges to and from the device using a crc8 function. An utility function to reverse a byte has also been added. Signed-off-by: Jerome Oufella <jerome.oufella@savoirfairelinux.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-05-19hwmon: (sht15) add support for the status registerVivien Didelot
* Add support for: - Heater. - End of battery notice. - Ability not to reload from OTP. - Low resolution (12bit temp, 8bit humidity). * Add an utility function to read individual bytes from the device. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-05-19hwmon: (sht15) general code clean-upVivien Didelot
* Add a documentation file for the device. * Respect a bit more the kernel-doc syntax. * Rename some variables for clarity. * Use bool type for flags. * Use an enum for states (actions being done). Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-05-19hwmon: Add support for MAX6642Per Dalén
MAX6642 is a SMBus-Compatible Remote/Local Temperature Sensor with Overtemperature Alarm from Maxim. Signed-off-by: Per Dalen <per.dalen@appeartv.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-04-29hwmon: (adm1021) Clarify documentation regarding Xeon processorsJean Delvare
Recent Xeon processor thermal sensors are supported by the coretemp driver and not the adm1021 driver. Only one old generation of Xeon processors (the first Netburst ones) are supported by the adm1021 driver. Reported-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
