path: root/Documentation/i2c
2017-06-19i2c: i801: Add support for Intel Cannon LakeSrinivas Pandruvada
Added SMBUS PCI Ids for SMBUS for Cannon Lake PCH. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> [jarkko.nikula@linux.intel.com: Add entries to Documentation and Kconfig. Cover Cannon Lake-H too] Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2017-05-31docs: i2c: dev-interface: adapt to new filenames of the i2c coreWolfram Sang
The I2C core files were renamed, adapt the textfile to it. Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2017-02-09i2c: i801: Add support for Intel Gemini LakeMika Westerberg
Intel Gemini Lake has the same SMBus host controller than Intel Broxton. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2017-02-09i2c: i2c-mux-gpio: rename i2c-gpio-mux to i2c-mux-gpioPeter Rosin
The rename did the wrong thing for this documentation file all those years ago. Fix that as well as the neglected rename of the platform data structure. Fixes: e7065e20d9a6 ("i2c: Rename last mux driver to standard pattern") Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2016-12-15Merge branch 'i2c/for-4.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: - the first series of making i2c_device_id optional instead of mandatory (in favor of alternatives like of_device_id). This involves adding a new probe callback (probe_new) which removes some peculiarities I2C had for a long time now. The new probe is matching the other subsystems now and the old one will be removed once all users are converted. It is expected to take a while but there is ongoing interest in that. - SMBus Host Notify introduced 4.9 got refactored. They are now using interrupts instead of the alert callback which solves multiple issues. - new drivers for iMX LowPower I2C, Mellanox CPLD and its I2C mux - significant refactoring for bcm2835 driver - the usual set of driver updates and improvements * 'i2c/for-4.10' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (46 commits) i2c: fsl-lpi2c: read lpi2c fifo size in probe() i2c: octeon: thunderx: Remove double-check after interrupt i2c: octeon: thunderx: TWSI software reset in recovery i2c: cadence: Allow Cadence I2C to be selected for Cadence Xtensa CPUs i2c: sh_mobile: Add per-Generation fallback bindings i2c: rcar: Add per-Generation fallback bindings i2c: imx-lpi2c: add low power i2c bus driver dt-bindings: i2c: imx-lpi2c: add devicetree bindings i2c: designware-pcidrv: Add 10bit address feature to medfield/merrifield i2c: pxa: Add support for the I2C units found in Armada 3700 i2c: pxa: Add definition of fast and high speed modes via the regs layout dt-bindings: i2c: pxa: Update the documentation for the Armada 3700 i2c: qup: support SMBus block read i2c: qup: add ACPI support i2c: designware: Consolidate default functionality bits i2c: i2c-mux-gpio: update mux with gpiod_set_array_value_cansleep i2c: mux: pca954x: Add ACPI support for pca954x i2c: use an IRQ to report Host Notify events, not alert i2c: i801: remove SMBNTFDDAT reads as they always seem to return 0 i2c: i801: use the BIT() macro for FEATURES_* also ...
2016-11-24i2c: use an IRQ to report Host Notify events, not alertBenjamin Tissoires
The current SMBus Host Notify implementation relies on .alert() to relay its notifications. However, the use cases where SMBus Host Notify is needed currently is to signal data ready on touchpads. This is closer to an IRQ than a custom API through .alert(). Given that the 2 touchpad manufacturers (Synaptics and Elan) that use SMBus Host Notify don't put any data in the SMBus payload, the concept actually matches one to one. Benefits are multiple: - simpler code and API: the client will just have an IRQ, and nothing needs to be added in the adapter beside internally enabling it. - no more specific workqueue, the threading is handled by IRQ core directly (when required) - no more races when removing the device (the drivers are already required to disable irq on remove) - simpler handling for drivers: use plain regular IRQs - no more dependency on i2c-smbus for i2c-i801 (and any other adapter) - the IRQ domain is created automatically when the adapter exports the Host Notify capability - the IRQ are assign only if ACPI, OF and the caller did not assign one already - the domain is automatically destroyed on remove - fewer lines of code (minus 20, yeah!) Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2016-11-24i2c: mlxcpld: add master driver for mellanox systemsVadim Pasternak
Device driver for Mellanox I2C controller logic, implemented in Lattice CPLD device. Device supports: - Master mode - One physical bus - Polling mode The Kconfig currently controlling compilation of this code is: drivers/i2c/busses/Kconfig:config I2C_MLXCPLD Signed-off-by: Michael Shych <michaelsh@mellanox.com> Signed-off-by: Vadim Pasternak <vadimp@mellanox.com> Reviewed-by: Jiri Pirko <jiri@mellanox.com> Reviewed-by: Vladimir Zapolskiy <vz@mleia.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2016-11-10i2c: Documentation: i2c-topology: fix minor whitespace nitPeter Rosin
2016-09-08Documentation: i2c: slave-interface: add note for driver developmentWolfram Sang
Make it clear that adding slave support shall not disable master functionality. We can have both, so we should. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2016-07-23Documentation: i2c: slave: give proper example for pm usageWolfram Sang
pm_runtime_forbid was the wrong knob, this is the better one. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2016-07-23Documentation: i2c: slave: describe buffer problems a bit betterWolfram Sang
2016-06-17i2c: smbus: add SMBus Host Notify supportBenjamin Tissoires
SMBus Host Notify allows a slave device to act as a master on a bus to notify the host of an interrupt. On Intel chipsets, the functionality is directly implemented in the firmware. We just need to export a function to call .alert() on the proper device driver. i2c_handle_smbus_host_notify() behaves like i2c_handle_smbus_alert(). When called, it schedules a task that will be able to sleep to go through the list of devices attached to the adapter. The current implementation allows one Host Notification to be scheduled while an other is running. Tested-by: Andrew Duggan <aduggan@synaptics.com> Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2016-05-04[media] rtl2832: change the i2c gate to be mux-lockedPeter Rosin
The root i2c adapter lock is then no longer held by the i2c mux during accesses behind the i2c gate, and such accesses need to take that lock just like any other ordinary i2c accesses do. So, declare the i2c gate mux-locked, and zap the regmap overrides that makes the i2c accesses unlocked and use plain old regmap accesses. This also removes the need for the regmap wrappers used by rtl2832_sdr, so deconvolute the code further and provide the regmap handle directly instead of the wrapper functions. Tested-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2016-05-04[media] si2168: change the i2c gate to be mux-lockedAntti Palosaari
The root i2c adapter lock is then no longer held by the i2c mux during accesses behind the i2c gate, and such accesses need to take that lock just like any other ordinary i2c accesses do. So, declare the i2c gate mux-locked, and zap the code that makes the i2c accesses unlocked. But add a mutex so that firmware commands are still serialized. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2016-05-04iio: imu: inv_mpu6050: change the i2c gate to be mux-lockedPeter Rosin
The root i2c adapter lock is then no longer held by the i2c mux during accesses behind the i2c gate, and such accesses need to take that lock just like any other ordinary i2c accesses do. So, declare the i2c gate mux-locked, and zap the code that makes the unlocked i2c accesses and just use ordinary regmap_write accesses. This also happens to fix the deadlock described in http://patchwork.ozlabs.org/patch/584776/ authored by Adriana Reus <adriana.reus@intel.com> and submitted by Daniel Baluta <daniel.baluta@intel.com> ----------8<---------- iio: imu: inv_mpu6050: Fix deadlock between i2c adapter lock and mpu lock This deadlock occurs if the accel/gyro and the sensor on the auxiliary I2C (in my setup it's an ak8975) are working at the same time. Scenario: T1 T2 ==== ==== inv_mpu6050_read_fifo aux sensor op (eg. ak8975_read_raw) | | mutex_lock(&indio_dev->mlock) i2c_transfer | | i2c transaction i2c adapter lock | | i2c adapter lock i2c_mux_master_xfer | inv_mpu6050_select_bypass | mutex_lock(&indio_dev->mlock) When we operate on an mpu sensor the order of locking is mpu lock followed by the i2c adapter lock. However, when we operate the auxiliary sensor the order of locking is the other way around. ... ----------8<---------- The reason this patch fixes the deadlock is that T2 does not grab the i2c adapter lock until the very end (and grabs the newfangled i2c mux lock where it previously grabbed the i2c adapter lock). Acked-by: Jonathan Cameron <jic23@kernel.org> Acked-by: Daniel Baluta <daniel.baluta@intel.com> Tested-by: Crestez Dan Leonard <leonard.crestez@intel.com> Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2016-05-04i2c: mux: document i2c muxes and elaborate on parent-/mux-locked muxesPeter Rosin
2016-02-10Doc: i2c: Fix typo in Documentation/i2cMasanari Iida
This path fix spelling typos found in Documentation/i2c. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2015-11-20i2c: i801: add Intel Lewisburg device IDsAlexandra Yates
Adding Intel codename Lewisburg platform device IDs for SMBus. Signed-off-by: Alexandra Yates <alexandra.yates@linux.intel.com> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2015-10-26i2c: i801: Document Intel DNV and BroxtonJarkko Nikula
Add missing entries into i2c-i801 documentation and Kconfig about recently added Intel DNV and Broxton. Reported-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2015-08-24i2c: support 10 bit and slave addresses in sysfs 'new_device'Wolfram Sang
We now have seperate address spaces for 10 bit and we-are-slave clients. Update the sysfs device instantiation method to support these types by accepting the address offsets that are assigned to the extra address spaces. Update the documentation, too. Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2015-08-10i2c: parport: Add VCT-jig adapterOndrej Zary
Add support for VCT-jig parallel port I2C adapter to i2c-parport. The adapter schematic can be found here (in the RAR file): http://remont-aud.net/shop/22/desc/vct-jig-komplekt-dlja-samostojatelnoj-sborki Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2015-06-25Merge branch 'i2c/for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: "Highlights: - new drivers for Mediatek I2C, APM X-Gene, Broadcom Settop - major updates to at91, davinci - bugfixes to the mux infrastructure when dealing with the new quirk mechanism - more users for the bus recovery feature - further improvements to the slave framework Plus the usual bunch of smaller driver and core improvements and fixes. There is one patch removing old code from an ARM platform. This has been acked by the sh_mobile maintainer Simon Horman" * 'i2c/for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (48 commits) i2c: busses: i2c-bcm2835: limits cdiv to allowed values i2c: sh_mobile: use proper type for timeout i2c: sh_mobile: use adapter default for timeout i2c: rcar: use proper type for timeout i2c: rcar: use adapter default for timeout i2c: designware: Make sure the device is suspended before disabling runtime PM i2c: tegra: apply size limit quirk i2c: tegra: don't advertise SMBUS_QUICK i2c: octeon: remove unused signal handling i2c: davinci: Optimize SCL generation i2c: mux: pca954x: Use __i2c_transfer because of quirks i2c: mux: Use __i2c_transfer() instead of calling parent's master_xfer() i2c: use parent adapter quirks in mux i2c: bcm2835: clear reserved bits in S-Register ARM: shmobile: r8a7740: remove I2C errata handling i2c: sh_mobile: add errata workaround i2c: at91: fix code checker warnings i2c: busses: xgene-slimpro: fix incorrect __init declation for probe i2c: davinci: Avoid sending to own address i2c: davinci: Refactor i2c_davinci_wait_bus_not_busy() ...
2015-06-17i2c: slave: fix the example how to instantiate from userspaceWolfram Sang
I copied the wrong shell code into the documentation. Sorry to all who tried to get sense out of this current example :/ Slight rewording while we are here. Reported-by: Tim Bakker <bakkert@mymail.vcu.edu> Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Cc: stable@kernel.org
2015-06-01i2c: slave: docs: be more precise about the prerequsitesWolfram Sang
There was some confusion what was needed to utilize the slave support, so let's be more precise about this. Add an introductory paragraph to the development section while we are here. Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2015-03-27i2c: slave: add documentation for i2c-slave-eepromWolfram Sang
2015-03-27Documentation: i2c: describe the new slave modeWolfram Sang
2015-02-19i2c: fix reference to functionality constants definitionBaruch Siach
Since commit 607ca46e97 ('UAPI: (Scripted) Disintegrate include/linux') the list of functionality constants moved to include/uapi/linux/i2c.h. Update the reference accordingly. Fixes: 607ca46e97 ('UAPI: (Scripted) Disintegrate include/linux') Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-12-04Documentation: i2c: Use PM ops instead of legacy suspend/resumeLars-Peter Clausen
New drivers should use PM ops instead of the legacy suspend/resume callbacks. Update the I2C device driver guides to reflect this. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-11-12i2c: i801: Add DeviceIDs for SunrisePoint LPDevin Ryles
Signed-off-by: Devin Ryles <devin.ryles@intel.com> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-10-16i2c: i801: Add Device IDs for Intel Sunrise Point PCHjames.d.ralston@intel.com
This patch adds the I2C/SMBus Device IDs for the Intel Sunrise Point PCH. Signed-off-by: James Ralston <james.d.ralston@intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-09-07Documentation: i2c: rename variable "register" to "reg"Jose Manuel Alarcon Roldan
The example code provided with the i2c device interface documentation won't compile since it uses the reserved word "register" to name a variable. The compiler fails with this error message: error: expected identifier or '(' before '=' token __u8 register = 0x20; /* Device register to access */ ^ Rename the variable "register" to simply "reg" in the example code. Another couple of typos has been fixed as well. [Change "! =" to "!=".] Signed-off-by: Jose Alarcon Roldan <jose.alarcon.roldan@gmail.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-17i2c: i801: Add device ID for Intel Wildcat Point PCHJean Delvare
2014-07-17i2c: stub: Add support for banked register rangesJean Delvare
Some chips implement banked register ranges. This allows implementing more registers than the limited 8-bit address space originally allows. In order to access a register on these chips, you must first select the proper bank. Add support for this mechanism to the i2c-stub driver so that such chips can be emulated. All the bank settings are passed as module parameters. Signed-off-by: Jean Delvare <jdelvare@suse.de> Tested-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-07-17i2c: stub: Add support for SMBus block commandsGuenter Roeck
SMBus block commands are different to I2C block commands since the returned data is not normally accessible with byte or word commands on other command offsets. Add linked list of 'block' commands to support those commands. Access mechanism is quite simple: Block commands must be written before they can be read. Subsequent writes can be partial. Block read commands always return the number of bytes associated with the longest previous write. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-04-06Documentation: i2c: improve section about flags mangling the protocolWolfram Sang
Sort the entries alphabetically. Make the introductory paragraph more precise. Skip useless 'Flag' introduction from the entries. Remove trailing white spaces from the file. Add missing I2C_M_STOP entry. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-03-12i2c: Spelling s/than/that/Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-03-09i2c: i801: enable Intel BayTrail SMBUSChew, Kean ho
Add Device ID of Intel BayTrail SMBus Controller. Signed-off-by: Chew, Kean ho <kean.ho.chew@intel.com> Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-02-15Documentation: i2c: mention ACPI method for instantiating devicesWolfram Sang
Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Guenter Roeck <linux@roeck-us.net>
2014-02-15Documentation: i2c: describe devicetree method for instantiating devicesWolfram Sang
2014-01-29Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull more i2c updates from Wolfram Sang: "Mostly bugfixes, small but wanted cleanups, and Paul's init.h removal applied" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: rcar: fix NACK error code i2c: update i2c_algorithm documentation i2c: rcar: use devm_clk_get to ensure clock is properly ref-counted i2c: rcar: do not print error if device nacks transfer i2c: rely on driver core when sanitizing devices i2c: delete non-required instances of include <linux/init.h> i2c: acorn: is tristate and should use module.h i2c: piix4: Standardize log messages i2c: piix4: Use different message for AMD Auxiliary SMBus Controller i2c: piix4: Add support for AMD ML and CZ SMBus changes
2014-01-29Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging Pull hwmon updates from Jean Delvare: "This include it87 driver improvements, and a tree-wide change of my e-mail address" * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: Update Jean Delvare's e-mail address hwmon: (it87) Print proper names for the IT8771E and IT8772E hwmon: (it87) Add support for the ITE IT8603E
2014-01-29Update Jean Delvare's e-mail addressJean Delvare
2014-01-24i2c: piix4: Add support for AMD ML and CZ SMBus changesShane Huang
The locations of SMBus register base address and enablement bit are changed from AMD ML, which need this patch to be supported. Signed-off-by: Shane Huang <shane.huang@amd.com> Reviewed-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Cc: stable@vger.kernel.org
2014-01-09Documentation: i2c: Remove obsolete exampleHelia Correia
Documentation/i2c/fault-codes illustrates EINVAL error code as follows: "One example would be a driver trying an SMBus Block Write with block size outside the range of 1-32 bytes." However, the actual implementation of i2c subsystem truncates data length to be 32 bytes. Hence this example cannot happen anymore, and since it's obsolete, let's simply remove it from Documentation/i2c/fault-codes. Signed-off-by: Helia Correia <helia.correia@intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-11-14i2c: i801: Add Device IDs for Intel Wildcat Point-LP PCHJames Ralston
This patch adds the SMBus Device IDs for the Intel Wildcat Point-LP PCH. Signed-off-by: James Ralston <james.d.ralston@intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-09-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "The usual trivial updates all over the tree -- mostly typo fixes and documentation updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits) doc: Documentation/cputopology.txt fix typo treewide: Convert retrun typos to return Fix comment typo for init_cma_reserved_pageblock Documentation/trace: Correcting and extending tracepoint documentation mm/hotplug: fix a typo in Documentation/memory-hotplug.txt power: Documentation: Update s2ram link doc: fix a typo in Documentation/00-INDEX Documentation/printk-formats.txt: No casts needed for u64/s64 doc: Fix typo "is is" in Documentations treewide: Fix printks with 0x%# zram: doc fixes Documentation/kmemcheck: update kmemcheck documentation doc: documentation/hwspinlock.txt fix typo PM / Hibernate: add section for resume options doc: filesystems : Fix typo in Documentations/filesystems scsi/megaraid fixed several typos in comments ppc: init_32: Fix error typo "CONFIG_START_KERNEL" treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks page_isolation: Fix a comment typo in test_pages_isolated() doc: fix a typo about irq affinity ...
2013-08-19Documentation: i2c: Fix example in instantiating-devicesSachin Kamat
__initdata should be placed between the variable name and equal sign for the variable to be placed in the intended section. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-08-15i2c: piix4: Add support for secondary SMBus on AMD SB800 and AMD FCH chipsetsRudolf Marek
Add support for the secondary SMBus controller on the AMD SB800 and AMD FCH chipsets. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Tested-by: Paul Menzel <paulepanter@users.sourceforge.net> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-07-25doc: Fix typo in doucmentationsMasanari Iida
Correct typo (double words) in documentations. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-04Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: - new drivers: Kontron PLD, Wondermedia VT - mv64xxx driver gained sun4i support and a bigger cleanup - duplicate driver 'intel-mid' removed - added generic device tree binding for sda holding time (and designware driver already uses it) - we tried to allow driver probing with only device tree and no i2c ids, but I had to revert it because of side effects. Needs some rethinking. - driver bugfixes, cleanups... * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (34 commits) i2c-designware: use div_u64 to fix link i2c: Kontron PLD i2c bus driver i2c: iop3xxx: fix build failure after waitqueue changes i2c-designware: make SDA hold time configurable i2c: mv64xxx: Set bus frequency to 100kHz if clock-frequency is not provided i2c: imx: allow autoloading on dt ids i2c: mv64xxx: Fix transfer error code i2c: i801: SMBus patch for Intel Coleto Creek DeviceIDs i2c: omap: correct usage of the interrupt enable register i2c-pxa: prepare clock before use Revert "i2c: core: make it possible to match a pure device tree driver" i2c: nomadik: allocate adapter number dynamically i2c: nomadik: support elder Nomadiks i2c: mv64xxx: Add Allwinner sun4i compatible i2c: mv64xxx: make the registers offset configurable i2c: mv64xxx: Add macros to access parts of registers i2c: vt8500: Add support for I2C bus on Wondermedia SoCs i2c: designware: fix race between subsequent xfers i2c: bfin-twi: Read and write the FIFO in loop i2c: core: make it possible to match a pure device tree driver ...
