path: root/Documentation/i2c
2008-05-11i2c: Improve the functionality documentationJean Delvare
Attempt to make the documentation about the I2C/SMBus functionality checking API clearer. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-11i2c: Improve smbus-protocol documentationDavid Brownell
Improve the smbus-protocol documentation file somewhat: - Use the names of the SMBus protocol operations (from the 2.0 specification), not made-up-for-Linux names. - Add the name of the call used to execute each operation ... and point out that there are mismatches, where functions execute different protocol operations than their names specify. The most confusing examples are that "Read Byte" isn't executed by i2c_smbus_read_byte(), and that "Write Byte" isn't executed by i2c_smbus_write_byte(). When coding, that's not as bad as it may seem; but that case would seem to be worth fixing. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-02-24i2c-i801: Add support for the ICH10Gaston, Jason D
Add the Intel ICH10 SMBus Controller DeviceID's and updates Tolapai support. Signed-off-by: Jason Gaston <jason.d.gaston@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-02-07hwmon: Update the lm-sensors website addressJean Delvare
It's about time to reflect the move of the lm-sensors project to lm-sensors.org. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-05deprecate obsolete pca9539 drivereric miao
Use drivers/gpio/pca9539.c instead. Signed-off-by: eric miao <eric.miao@marvell.com> Acked-by: Ben Gardner <bgardner@wabtec.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-27i2c-viapro: Add support for the VT8237SJean Delvare
Add support for another variant of the VT8237. I couldn't test I2C block support but I assume it is present as well. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c-i801: Implement I2C block read supportJean Delvare
I2C block read is supported since the ICH5. I couldn't get it to work using the block buffer, so it's using the old-style byte-by-byte mode for now. Note: I'm also updating the driver author... The i2c-i801 driver was really written by Mark Studebaker, even though he based his work on the i2c-piix4 driver which was written by Philip Edelbrock. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c: normal_i2c can be made const (remaining drivers)Jean Delvare
2008-01-27i2c-stub: Use a single array for byte and word operationsJean Delvare
This mimics the behavior of actual SMBus chips better. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Mark M. Hoffman <mhoffman@lightlink.com>
2008-01-27i2c-stub: Mention the existence of an helper scriptJean Delvare
There's a new script named i2c-stub-from-dump that can be very helpful when working with the i2c-stub driver. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c: Add support for the PCF8575 chipBart Van Assche
Signed-off-by: Bart Van Assche <bart.vanassche@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-12-12i2c: Delete an outdated piece of documentationJean Delvare
I'm amazed that this old piece of documentation managed to survive until today. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-10-19more UTF-8 conversionsMarcin Garski
Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-13i2c: Rename the PEC functionality bitDavid Brownell
Rename I2C_FUNC_SMBUS_HWPEC_CALC as I2C_FUNC_SMBUS_PEC, and list that functionality as always available through the software implementation. Update documentation accordingly (and list similar requirements). The way it's currently packaged doesn't present the capability in a useful way. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-10-13i2c-stub: Support multiple chipsJean Delvare
Add support for multiple chips to i2c-stub. I've changed the memory allocation scheme from static to dynamic, so that we don't waste too much memory. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-13i2c-i801: Add support for the Intel Tolapai SMBusJason Gaston
Add the Intel Tolapai SMBus Controller DID. Signed-off-by: Jason Gaston <jason.d.gaston@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-10-13i2c/pcf8574: No arbitrary initializationJean Delvare
Do not initialize the PCF8574 with an arbitrary value. Users will have to write the initial value to sysfs themselves. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Aurelien Jarno <aurelien@aurel32.net>
2007-08-31i2c-piix4: Fix SB700 PCI device IDShane Huang
We find that SB700 and SB800 use the same SMBus device ID as SB600, which is 0x4385, instead of the already submitted 0x4395. Besides removing the wrong SB700 device ID, add SB800 support to kernel, by renaming the PCI_DEVICE_ID_ATI_IXP600_SMBUS into PCI_DEVICE_ID_ATI_SBX00_SMBUS. Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-12i2c-rpx: RemoveJean Delvare
This driver has been broken forever. It depends on i2c-algo-8xx which has never been in the mainline kernel. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-07-12i2c: New bus driver for the TAOS evaluation modulesJean Delvare
This is a new I2C bus driver for the TAOS evaluation modules. Developped and tested on the TAOS TSL2550 EVM. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-07-12i2c-i801: Use the internal 32-byte buffer on ICH4+Oleg Ryjkov
Add an ability to utilize the internal SRAM buffer on ICH4 and newer host controllers to speed up execution of block operations. I've split the code so that it is more clear which block transaction is performed. First of all the host controller's type is identified. isich4 is set when we think that the controller has the internal buffer. Then, before every block transaction, if isich4 is set, we attempt to enable the E32B bit in SMBAUXCTL register. Signed-off-by: Oleg Ryjkov <olegr@google.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-07-12i2c-piix4: Add support for the ATI SB700Henry Su
Add the SMBus device ID for ATI SB700. Signed-off-by: Henry Su <Henry.su@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-07-12i2c: Fix the i2c_smbus_read_i2c_block_data() prototypeJean Delvare
Let the drivers specify how many bytes they want to read with i2c_smbus_read_i2c_block_data(). So far, the block count was hard-coded to I2C_SMBUS_BLOCK_MAX (32), which did not make much sense. Many driver authors complained about this before, and I believe it's about time to fix it. Right now, authors have to do technically stupid things, such as individual byte reads or full-fledged I2C messaging, to work around the problem. We do not want to encourage that. I even found that some bus drivers (e.g. i2c-amd8111) already implemented I2C block read the "right" way, that is, they didn't follow the old, broken standard. The fact that it was never noticed before just shows how little i2c_smbus_read_i2c_block_data() was used, which isn't that surprising given how broken its prototype was so far. There are some obvious compatiblity considerations: * This changes the i2c_smbus_read_i2c_block_data() prototype. Users outside the kernel tree will notice at compilation time, and will have to update their code. * User-space has access to i2c_smbus_xfer() directly using i2c-dev, so the changed expectations would affect tools such as i2cdump. In order to preserve binary compatibility, we give I2C_SMBUS_I2C_BLOCK_DATA a new numeric value, and define I2C_SMBUS_I2C_BLOCK_BROKEN with the old numeric value. When i2c-dev receives a transaction with the old value, it can convert it to the new format on the fly. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-07-12i2c: Delete outdated x1205 driver documentationJean Delvare
The x1205 driver moved to the RTC subsystem and was significantly modified since then, so just delete the outdated documentation. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Alessandro Zummo <alessandro.zummo@towertech.it>
2007-05-09documentation: convert the Documentation directory to UTF-8John Anthony Kazos Jr
Convert files within the Documentation directory to UTF-8. Adrian Bunk: small additional fixes Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-01i2c: Documentation updateJean Delvare
Make the documentation on how to write and port i2c drivers more in line with the current state of things: * i2c-isa is deprecated and soon gone, so stop advertising it. * Drop many sensors-specific references. Most of them were outdated anyway. * Update the example code to reflect the recent and not-so-recent API and coding style preference changes. * Simplify the example init and cleanup functions. This should make things less complex to understand for newcomers. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-01i2c: Make i2c_del_driver a void functionJean Delvare
Make i2c_del_driver a void function, like all other driver removal functions. It always returned 0 even when errors occured, and nobody ever actually checked the return value anyway. And we cannot fail a module removal anyway. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-01i2c: Document i2c_new_device()Jean Delvare
Document the new i2c_new_device(), i2c_new_probed_device() and i2c_unregister_device() functions. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-01i2c: i2c probe() and remove() documentedDavid Brownell
Update Documentation/i2c to match previous patches updating probe() and remove() logic. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-01i2c-nforce2: Add support for the MCP61 and MCP65Jean Delvare
Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Hans-Frieder Vogt <hfvogt@gmx.net>
2007-02-13i2c-parport: Add support for One For All remote JP1 interfaceJonathan McDowell
This simple patch adds support to i2c-parport for the One For All remote JP1 parallel port interfaces which can be found detailed at: http://www.hifi-remote.com/jp1/hardware.shtml These allow access to the internal configuration EEPROM on various remote controls and there are a variety of Windows tools that make use of this hardware. I have tested this patch with the "simple" parallel port device and a One For All URC-7562 and confirmed that the data read using the eeprom i2c driver matches that returned by the Windows "IR" JP1 tool. Signed-off-by: Jonathan McDowell <noodles@earth.li> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c-viapro: Add support for the VIA CX700 south bridgeJean Delvare
We do not have any documentation for the CX700, but it was reported to work fine. Thanks to Claas Langbehn for testing. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c: Add driver suspend/resume/shutdown supportDavid Brownell
Driver model updates for the I2C core: - Add new suspend(), resume(), and shutdown() methods. Use them in the standard driver model style; document them. - Minor doc updates to highlight zero-initialized fields in drivers, and the driver model accessors for "clientdata". If any i2c drivers were previously using the old suspend/resume calls in "struct driver", they were getting warning messages ... and will now no longer work. Other than that, this patch changes no behaviors; and it lets I2C drivers use conventional PM and shutdown support. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c-i801: Document the SMBus unhiding quirkJean Delvare
This is a frequently asked question so it deserves a paragraph in the driver documentation. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c: Fix typo in SMBus Write Word Data descriptionMike Frysinger
Write data, don't read it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c-piix4: Add support for the ATI SB600Jean Delvare
Add support for the ATI SB600 SMBus controller. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-10i2c: i2c-i801 documentation updateJason Gaston
Add the Intel ICH9/ICH8/ESB2 SMBus Controller text to i2c-i801 documentation. Signed-off-by: Jason Gaston <jason.d.gaston@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-10i2c: Cleanups to the i2c-nforce2 bus driverHans-Frieder Vogt
Summary of changes: - fixes: o legacy I/O region size is 64 bytes, not 8 bytes - general cleanup: o removed code for the unsupported I2C block data, block data, proc call and block proc call transfer modes o removed detail warnings about unsupported modes that are covered in a general warning (unsupported transaction...) anyway o removed necessity of a definition of struct i2c_adapter o moved definition of struct i2c_algorithm, making forward declarations of nforce2_access and nforce2_func unnecessary - minor changes: o in the description mention the nForce 5xx chipsets o changes my e-mail address in MODULE_AUTHOR Theses cleanups shrink the driver binary size from 4.0 kB to 2.7 kB on i386. Signed-off-by: Hans-Frieder Vogt <hfvogt@gmx.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-10i2c: Fix documentation typosJean Delvare
Fix typos in i2c bus drivers documentation. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-09-26i2c-viapro: Add support for the VT8237A and VT8251Rudolf Marek
i2c-viapro: Add support for the VT8237A and VT8251 Documentation update included. Compile tested. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c-stub: Chip address as a module parameterJean Delvare
i2c-stub: Chip address as a module parameter Add a mandatory chip_addr parameter to i2c-stub. This parameter defines to which chip address the driver will respond, instead of reponding to all addresses as before. The idea is to prevent the users from loading i2c-stub at random and being then confused by the results of sensors-detect or other user-space tools. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-12[PATCH] i2c: New mailing listJean Delvare
We have a new mailing list dedicated to linux i2c: http://lists.lm-sensors.org/mailman/listinfo/i2c Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] i2c-i801: Remove force_addr parameterJean Delvare
i2c-i801: Remove force_addr parameter Remove the force_addr module parameter. It doesn't appear to ever have been needed, and PCI resources shouldn't be arbitrarily changed anyway. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] scx200_acb: Documentation updateJean Delvare
Documentation update for the scx200_acb driver. Hopefully this will help future users. References: [lm-sensors] Support of i2c-nscacb (April, May 2005) http://lists.lm-sensors.org/pipermail/lm-sensors/2005-April/011756.html http://lists.lm-sensors.org/pipermail/lm-sensors/2005-May/012043.html [lm-sensors] making a geode i2c slave driver (April 2006) http://lists.lm-sensors.org/pipermail/lm-sensors/2006-April/015998.html Kernel bug #6445 http://bugzilla.kernel.org/show_bug.cgi?id=6445 Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] i2c: New bus driver for the OpenCores I2C controllerPeter Korsgaard
The following patch adds support for the OpenCores I2C controller IP core (See http://www.opencores.org/projects.cgi/web/i2c/overview). Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] I2C: i2c-nforce2: Add support for the nForce4 MCP51 and MCP55Jean Delvare
Add support for the new nForce4 MCP51 (also known as nForce 410 or 430) and nForce4 MCP55 to the i2c-nforce2 driver. Some code changes were required because the base I/O address registers have changed in these versions. Standard BARs are now being used, while the original nForce2 chips used non-standard ones. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] I2C: i2c-piix4: Document the IBM problem more clearlyJean Delvare
Properly document on which systems the i2c-piix4 SMBus driver will refuse to load. Hopefully this will make it clearer for users, which were often wondering why their destop or server systems were detected as laptops. Closes bug #6429. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] I2C: i2c-piix4: Fix typo in documentationJean Delvare
Fix i2c-piix4 documentation typo. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] I2C: i2c-piix4: Remove the fix_hstcfg parameterRudolf Marek
This patch removes the fix_hstcfg option from the driver and related SMBus Interrupt Select register magic because now we know what are valid values for this register. This patch updates the documentation and adds new IRQ mode check so we are sure not to miss any new "unusual" value. The PCI quirk for users of fix_hstcfg was not developed because the chipset lacks of subsystem ID registers and DMI is stated "To be filled". Impact to existing systems is minimal because the problem showed up on motherboards like 10 years back. On the other hand users of newer Serverworks and HT1000 systems won't be misleaded by the message suggesting to try the fix_hstcfg any more. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
