path: root/Documentation/i386
2008-04-29x86: add more boot protocol documentationIan Campbell
Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86, boot: Document for linked list of struct setup_dataHuang, Ying
Documentation for linked list of struct setup_data. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17x86: boot protocol updatesIan Campbell
Also update field names to simply payload_{offset,length} so as to not rule out uncompressed images. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: virtualization@lists.linux-foundation.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: add a crc32 checksum to the kernel image.Ian Campbell
2008-04-17x86: use ELF format in compressed images.Ian Campbell
Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: virtualization@lists.linux-foundation.org Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: virtualization@lists.linux-foundation.org Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-03-26x86: Documentation/i386/IO-APIC.txt: fix descriptionNick Andrew
The description of the interrupt routing doesn't match the (nice) diagram. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-19x86: docs fixes to Documentation/i386/IO-APIC.txtNick Andrew
Clean up spelling and grammar of IO-APIC.txt Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-30x86 boot: document for 32 bit boot protocolHuang, Ying
This patch documents the 32-bit boot protocol of x86. It has been used by Kexec and LinuxBIOS. This patch is based on the proposal of Peter Anvin. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-22update boot spec to 2.07Rusty Russell
Updates for version 2.07 of the boot protocol. This includes: load_flags.KEEP_SEGMENTS- flag to request/inhibit segment reloads hardware_subarch - what subarchitecture we're booting under hardware_subarch_data - per-architecture data The intention of these changes is to make booting a paravirtualized kernel work via the normal Linux boot protocol. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11i386: Add warning in Documentation that zero-page is not a stable ABIAndi Kleen
Some people writing boot loaders seem to falsely belief the 32bit zero page is a stable interface for out of tree code like the real mode boot protocol. Add a comment clarifying that is not true. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-12Define zero-page offset 0x1e4 as a scratch field, and use itH. Peter Anvin
The relocatable kernel code needs a scratch field for the decompressor to determine its own location. It was using a location inside struct screen_info; reserve a free location and document it as scratch instead. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23boot documentation: clarificationsH. Peter Anvin
Textual clarifications (and fix an off-by-one error) based on feedback mostly from Jeremy Fitzhardinge. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-18Further update of the i386 boot documentationH. Peter Anvin
A number of items in the i386 boot documentation have been either vague, outdated or hard to read. This text revision adds several more examples, including a memory map for a modern kernel load. It also adds a field-by-field detailed description of the setup header, and a bootloader ID for Qemu. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Documentation/i386/boot.txt: update and correctH. Peter Anvin
In the process of rewriting the x86 setup code, I found a number of inaccuracies and outdated recommendations in the boot protocol documentation. Revamp to make it more up to date. In particular, the common use of the heap actually requires (slightly) more than 4K of heap plus stack, which is the recommended amount in the document; currently the code compensates by being smaller than specified, but we can't assume that will be true forever. Thus, recommend that if we have a modern bzImage kernel, that the bootloader maximizes the available space. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] x86: add command line length to boot protocolBernhard Walle
Because the command line is increased to 2048 characters after 2.6.21, it's not possible for boot loaders and userspace tools to determine the length of the command line the kernel can understand. The benefit of knowing the length is that users can be warned if the command line size is too long which prevents surprise if things don't work after bootup. This patch updates the boot protocol to contain a field called "cmdline_size" that contain the length of the command line (excluding the terminating zero). The patch also adds missing fields (of protocol version 2.05) to the x86_64 setup code. Signed-off-by: Bernhard Walle <bwalle@suse.de> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Alon Bar-Lev <alon.barlev@gmail.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-01-26[PATCH] Boot loader ID for GujinH. Peter Anvin
Add an official boot loader ID for Gujin. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] x86-64: Correct documentation for bzImage protocol v2.05Vivek Goyal
Correct the documentation for bzImage protocol extension due to relocatable bzImage. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-12-07[PATCH] i386: extend bzImage protocol for relocatable protected mode kernelVivek Goyal
Extend bzImage protocol to enable bootloaders to load a completely relocatable bzImage. Now protected mode component of kernel is also relocatable and a boot-loader can load the protected mode component at a differnt physical address than 1MB. (If kernel was built with CONFIG_RELOCATABLE) Kexec can make use of it to load this kernel at a different physical address to capture kernel crash dumps. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-09-13[PATCH] x86: reserve a boot-loader ID number for XenJeremy Fitzhardinge
Claim an ID number for Xen in the LOADER_TYPE field. Also, keep the table in zero-page.txt consistent with boot.txt. [hpa says: 6 was skipped because I couldn't rule out that it hadn't been unofficially used. It seemed easier to skip it for now.] Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Make the bzImage format self-terminatingH. Peter Anvin
Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Frank Sorenson <frank@tuxrocks.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Increase number of e820 entries hard limit from 32 to 128Venkatesh Pallipadi
The specifications that talk about E820 map doesn't have an upper limit on the number of e820 entries. But, today's kernel has a hard limit of 32. With increase in memory size, we are seeing the number of E820 entries reaching close to 32. Patch below bumps the number upto 128. The patch changes the location of EDDBUF in zero-page (as it comes after E820). As, EDDBUF is not used by boot loaders, this patch should not have any effect on bootloader-setup code interface. Patch covers both i386 and x86-64. Tested on: * grub booting bzImage * lilo booting bzImage with EDID info enabled * pxeboot of bzImage Side-effect: bss increases by ~ 2K and init.data increases by ~7.5K on all systems, due to increase in size of static arrays. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
