path: root/Documentation/ia64/aliasing-test.c
2009-09-23Documentation/: fix warnings from -Wmissing-prototypes in HOSTCFLAGSLadinu Chandrasinghe
Fix up -Wmissing-prototypes in compileable userspace code, mainly under Documentation/. Signed-off-by: Ladinu Chandrasinghe <ladinu.pub@gmail.com> Signed-off-by: Trevor Keith <tsrk@tsrk.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04[IA64] aliasing-test: fix gcc warnings on non-ia64Randy Dunlap
Eliminate all build warnings. OK, these build warnings are from a build on x86_64. When I build on ia64, I don't see warnings. Now builds cleanly on ia64 and x86_64. Documentation/ia64/aliasing-test.c: In function 'map_mem': Documentation/ia64/aliasing-test.c:39: warning: implicit declaration of function 'ioctl' Documentation/ia64/aliasing-test.c: In function 'scan_rom': Documentation/ia64/aliasing-test.c:183: warning: format '%ld' expects type 'long int', but argument 4 has type 'int' Documentation/ia64/aliasing-test.c: At top level: Documentation/ia64/aliasing-test.c:208: warning: function declaration isn't a prototype Documentation/ia64/aliasing-test.c: In function 'main': Documentation/ia64/aliasing-test.c:259: warning: control reaches end of non-void function Documentation/ia64/aliasing-test.c: In function 'scan_rom': Documentation/ia64/aliasing-test.c:152: warning: 'rc' may be used uninitialized in this function Documentation/ia64/aliasing-test.c: In function 'scan_tree': Documentation/ia64/aliasing-test.c:68: warning: 'rc' may be used uninitialized in this function Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-11[IA64] prevent MCA when performing MMIO mmap to PCI config spaceAlex Chiang
Example memory map (HP rx7640 with 'default' acpiconfig setting, VGA disabled): 0x00000000 - 0x3FFFBFFF supports only WB (cacheable) access If a user attempts to perform an MMIO mmap (using the PCIIOC_MMAP_IS_MEM ioctl) to PCI config space (like mmap'ing and accessing memory at 0xA0000), we will MCA because the kernel will attempt to use a mapping with the UC attribute. So check the memory attribute in kern_mmap and the EFI memmap. If WC is requested, and WC or UC access is supported for the region, allow it. Otherwise, use the same attribute the kernel uses. Updates documentation and test cases as well. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-06-01parse errors in ifdefsYoann Padioleau
Fix various bits of obviously-busted code which we're not happening to compile, due to ifdefs. Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Jan Kara <jack@ucw.cz> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-30[IA64] update memory attribute aliasing documentation & test casesBjorn Helgaas
Updates documentation and adds some test cases. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
