path: root/Documentation/ia64
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix some typos in Documentation/: 'A'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letter 'A'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03[PATCH] ia64: note requirement for 8250_pnp, now that 8250_acpi is goneBjorn Helgaas
We removed 8250_acpi in 2.6.17. If we don't have PNPACPI turned on, we won't find any ACPI serial devices, so mention this requirement in the troubleshooting part of the documentation. CONFIG_PNPACPI is already turned on in all the relevant defconfigs. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-08[IA64] rework memory attribute aliasingBjorn Helgaas
This closes a couple holes in our attribute aliasing avoidance scheme: - The current kernel fails mmaps of some /dev/mem MMIO regions because they don't appear in the EFI memory map. This keeps X from working on the Intel Tiger box. - The current kernel allows UC mmap of the 0-1MB region of /sys/.../legacy_mem even when the chipset doesn't support UC access. This causes an MCA when starting X on HP rx7620 and rx8620 boxes in the default configuration. There's more detail in the Documentation/ia64/aliasing.txt file this adds, but the general idea is that if a region might be covered by a granule-sized kernel identity mapping, any access via /dev/mem or mmap must use the same attribute as the identity mapping. Otherwise, we fall back to using an attribute that is supported according to the EFI memory map, or to using UC if the EFI memory map doesn't mention the region. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-16[IA64] Add Documentation/ia64/mca.txtKeith Owens
Add Documentation/ia64/mca.txt, an ad-hoc collection of notes on IA64 MCA and INIT processing. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
