path: root/Documentation/ia64
2007-10-20typo fixesMatt LaPlante
Most of these fixes were already submitted for old kernel versions, and were approved, but for some reason they never made it into the releases. Because this is a consolidation of a couple old missed patches, it touches both Kconfigs and documentation texts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-11[IA64] prevent MCA when performing MMIO mmap to PCI config spaceAlex Chiang
Example memory map (HP rx7640 with 'default' acpiconfig setting, VGA disabled): 0x00000000 - 0x3FFFBFFF supports only WB (cacheable) access If a user attempts to perform an MMIO mmap (using the PCIIOC_MMAP_IS_MEM ioctl) to PCI config space (like mmap'ing and accessing memory at 0xA0000), we will MCA because the kernel will attempt to use a mapping with the UC attribute. So check the memory attribute in kern_mmap and the EFI memmap. If WC is requested, and WC or UC access is supported for the region, allow it. Otherwise, use the same attribute the kernel uses. Updates documentation and test cases as well. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-06-01parse errors in ifdefsYoann Padioleau
Fix various bits of obviously-busted code which we're not happening to compile, due to ifdefs. Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Jan Kara <jack@ucw.cz> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30Pull mem-attribute into release branchTony Luck
2007-03-30[IA64] update memory attribute aliasing documentation & test casesBjorn Helgaas
Updates documentation and adds some test cases. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-05[IA64] Fix example error injection programTony Luck
Progam accessed using /sys/devices/system/node/node0/cpu%d/err_inject/ This path only exists for CONFIG_NUMA=y systems. Better to use /sys/devices/system/cpu/cpu%d/err_inject/ which is available on all systems. Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-01-29[IA64] Itanium MC Error Injection Tool: Doc and sample applicationFenghua Yu
This patch contains a documention and sample application. Since the sample application has ~1000 lines of code, it might not be suitable in a kernel documention in kenrel tree. If you think this is not good place to hold the sample application, please let me know and I'm open to other choices e.g. sourceforge etc. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix some typos in Documentation/: 'A'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letter 'A'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03[PATCH] ia64: note requirement for 8250_pnp, now that 8250_acpi is goneBjorn Helgaas
We removed 8250_acpi in 2.6.17. If we don't have PNPACPI turned on, we won't find any ACPI serial devices, so mention this requirement in the troubleshooting part of the documentation. CONFIG_PNPACPI is already turned on in all the relevant defconfigs. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-08[IA64] rework memory attribute aliasingBjorn Helgaas
This closes a couple holes in our attribute aliasing avoidance scheme: - The current kernel fails mmaps of some /dev/mem MMIO regions because they don't appear in the EFI memory map. This keeps X from working on the Intel Tiger box. - The current kernel allows UC mmap of the 0-1MB region of /sys/.../legacy_mem even when the chipset doesn't support UC access. This causes an MCA when starting X on HP rx7620 and rx8620 boxes in the default configuration. There's more detail in the Documentation/ia64/aliasing.txt file this adds, but the general idea is that if a region might be covered by a granule-sized kernel identity mapping, any access via /dev/mem or mmap must use the same attribute as the identity mapping. Otherwise, we fall back to using an attribute that is supported according to the EFI memory map, or to using UC if the EFI memory map doesn't mention the region. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-16[IA64] Add Documentation/ia64/mca.txtKeith Owens
Add Documentation/ia64/mca.txt, an ad-hoc collection of notes on IA64 MCA and INIT processing. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
