path: root/Documentation/ide
2009-01-06ide: update warm-plug HOWTOBartlomiej Zolnierkiewicz
Reported-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27gayle: add "doubler" parameterBartlomiej Zolnierkiewicz
* Add "doubler" parameter to enable support for IDE doublers. * Obsolete "ide=doubler" kernel parameter. Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: add "cdrom=" and "chs=" parametersBartlomiej Zolnierkiewicz
* Add "cdrom=" and "chs=" parameters. * Obsolete "hdx=cdrom" and "hdx=cyls,heads,sects" kernel parameters. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: add "nodma|noflush|noprobe|nowerr=" parametersBartlomiej Zolnierkiewicz
* Add "nodma|noflush|noprobe|nowerr=" parameters. * Obsolete "hdx=noprobe|none|nowerr|nodma|noflush" kernel parameters. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: remove obsoleted "hdx=autotune" kernel parameterBartlomiej Zolnierkiewicz
* Remove obsoleted "hdx=autotune" kernel parameter (we always auto-tune PIO if possible nowadays). * Remove no longer needed ide_drive_t.autotune flag. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: mark "idebus=" kernel parameter as obsoleted (take 2)Bartlomiej Zolnierkiewicz
We have "vlb|pci_clock=" parameters now. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: remove comments markup from Documentation/ide/ide-tape.txtBorislav Petkov
Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: remove pipelined mode description from Documentation/ide/ide-tape.txtBorislav Petkov
2008-04-27ide: remove obsoleted "idex=" kernel parametersBartlomiej Zolnierkiewicz
* Remove obsoleted "idex=" kernel parameters. * Make probe_* and cmd640_vlb variables static. Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: remove obsoleted "idex=reset" kernel parameterBartlomiej Zolnierkiewicz
Remove obsoleted "idex=reset" kernel parameter (it has been obsoleted since 1 Nov 2004). Then remove corresponding code from ide_probe_port() and no longer used ->reset field from ide_hwif_t. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: remove obsoleted "idex=serialize" kernel parameterBartlomiej Zolnierkiewicz
Remove obsoleted "idex=serialize" kernel parameter (it has been obsoleted since 1 Nov 2004). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: add "ignore_cable" parameter (take 2)Bartlomiej Zolnierkiewicz
Add "ignore_cable" parameter: * "ide_core.ignore_cable=[interface_number]" boot option if IDE is built-in (i.e. "ide_core.ignore_cable=1" to force ignoring cable for "ide1") * "ignore_cable=[interface_number]" module parameter (for ide_core module) if IDE is compiled as module v2: * Add ide_port_apply_params() helper - use it in ide_device_add_all() and ide_scan_port(). * Make it possible to later disable ignoring cable detection by passing "[interface_number]:0" to /sys/module/ide_core/parameters/ignore_cable (however sysfs interface is not enabled yet since it needs some other IDE changes to make it work reliable). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: add ide-4drives host driver (take 3)Bartlomiej Zolnierkiewicz
CONFIG_BLK_DEV_4DRIVES deserves its own host driver: * Add drivers/ide/legacy/ide-4drives.c and move "4drives" support there. * Add ide-4drives.o in the link order after all other legacy host drivers enabled by "ide0=" options (they all are mutually exclusive). * Make ide-4drives host driver probe itself for IDE devices instead of indirectly depending on ide_generic host driver. * Add "probe" module parameter to ide-4drives and update documentation. v2: * s/paramater/parameter/ in ide.txt. (Noticed by Randy Dunlap) v3: * s/ide_4drives.probe/ide-4drives.probe/ in help entry. (Noticed by Sergei Shtylyov) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove obsoleted "idex=base[,ctl[,irq]]" kernel parameters (take 2)Bartlomiej Zolnierkiewicz
* Remove obsoleted "idex=base[,ctl[,irq]]" kernel parameters and update Documentation/ide/ide.txt. * Remove no longer needed ide_forced chipset type. v2: * is_chipset_set[] -> is_chipset_set in ide.c. * Documentation/ide/ide.txt fix. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove CONFIG_BLK_DEV_HD_IDE config option (take 2)Bartlomiej Zolnierkiewicz
* Remove CONFIG_BLK_DEV_HD hack from init_hwif_default() ("hda=noprobe hdb=noprobe" kernel parameters should be used instead if somebody wishes to use the old "hd" driver). * Make CONFIG_BLK_DEV_HD_ONLY config option available also when IDE subsystem is used and update help entry. * Remove no longer needed CONFIG_BLK_DEV_HD_IDE config option. v2: * Update documentation to suggest "hda=noprobe hdb=noprobe" instead of obsoleted "ide0=noprobe". * Update Documentation/ide/ide.txt. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: add warm-plug support for IDE devices (take 2)Bartlomiej Zolnierkiewicz
* Add 'struct class ide_port_class' ('ide_port' class) and a 'struct device *portdev' ('ide_port' class device) in ide_hwif_t. * Register 'ide_port' class in ide_init() and unregister it in cleanup_module(). * Create ->portdev in ide_register_port () and unregister it in ide_unregister(). * Add "delete_devices" class device attribute for unregistering IDE devices on a port and "scan" one for probing+registering IDE devices on a port. * Add ide_sysfs_register_port() helper for registering "delete_devices" and "scan" attributes with ->portdev. Call it in ide_device_add_all(). * Document IDE warm-plug support in Documentation/ide/warm-plug-howto.txt. v2: * Convert patch from using 'struct class_device' to use 'struct device'. (thanks to Kay Sievers for doing it) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18IDE: remove ide=reverse IDE coreGreg Kroah-Hartman
This option is obsolete and can be removed safely. It allows us to remove the pci_get_device_reverse() function from the PCI core. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-03-22ide: mark "hdx=remap" and "hdx=remap63" kernel parameters as obsoletedBartlomiej Zolnierkiewicz
Mark "hdx=remap" and "hdx=remap63" kernel parameters as obsoleted (they are layering violation and should be dealt with in the same way as done by libata - device-mapper should be used instead). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-03-22ide: mark "hdx=[driver_name]" and "hdx=scsi" kernel parameters as obsoletedBartlomiej Zolnierkiewicz
Mark "hdx=[driver_name]" and "hdx=scsi" kernel parameters as obsoleted (nowadays device-driver binding can be changed at runtime through sysfs and it can also be dealt with using per device driver parameters). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-03-22ide: Documentation/ide/ide.txt fixesBartlomiej Zolnierkiewicz
* "hdx=cyls,heads,sects,wpcom,irq" should be "hdx=cyls,heads,sects". * "hdx=" is for "x" from 'a' to 'u', "idex=" is for "x" from '0' to '9'. * "idex=noautotune" is long gone. * Obsoleted "ide0=" parameters were already removed from the documentation. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-03-07ide: update references to Documentation/ide/ide.txt (v2)Randy Dunlap
Fix all references to Documentation/ide/ide.txt. Add/update ide/00-INDEX file. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-03-07ide: move ide.txt to Documentation/ide/Randy Dunlap
Cleanup some of Documentation directory: Move Documentation/ide.txt to the ide/ sub-directory. Fix trailing whitespace while there. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: move historical changelog to ↵Borislav Petkov
Documentation/ide/ChangeLog.ide-tape.1995-2002 Also, cleanup whitespace and update comments. Bart: - remove reference to drivers/block/ide.c - move driver documentation to Documentation/ide/ide-tape.txt Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-floppy: cleanup headerBorislav Petkov
Move ide-floppy historical changelog to Documentation/ide/ChangeLog.ide-floppy.1996-2002 Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: move historical changelog to ↵Bartlomiej Zolnierkiewicz
Documentation/ide/ChangeLog.ide-cd.1994-2004 Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
