Add documentation for core and hardware specific infiniband interfaces.
The descriptions have been collected from git commit logs, reading
through code and data sheets. Some drivers have incomplete doc and are
annotated with the comment '[to be documented]'.
Signed-off-by: Aishwarya Pant <aishpant@gmail.com>
Reviewed-by: Hal Rosenstock <hal@mellanox.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
This patch adds description for the sdma engine related sysfs entries
for the HFI1 driver.
Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Reviewed-by: Sebastian Sanchez <sebastian.sanchez@intel.com>
Reviewed-by: Jianxin Xiong <jianxin.xiong@intel.com>
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
In practice, each RDMA device has a unique set of counters that the
hardware implements. Having a central set of counters that they must
all adhere to is limiting and causes many useful counters to not be
available.
Therefore we create a dynamic counter registration infrastructure.
The driver must implement a stats structure allocation routine, in
which the driver must place the directory name it wants, a list of
names for all of the counters, an array of u64 counters themselves,
plus a few generic configuration options.
We then implement a core routine to create a sysfs file for each
of the named stats elements, and a core routine to retrieve the
stats when any of the sysfs attribute files are read.
To avoid excessive beating on the stats generation routine in the
drivers, the core code also caches the stats for a short period of
time so that someone attempting to read all of the stats in a
given device's directory will not result in a stats generation
call per file read.
Future work will attempt to standardize just the shared stats
elements, and possibly add a method to get the stats via netlink
in addition to sysfs.
Signed-off-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Mark Bloch <markb@mellanox.com>
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
[ Add caching, make structure names more informative, add i40iw support,
other significant rewrites from the original patch ]
Add a per port sysfs paramter to toggle cc_prescan/Fast ECN Detection and
remove the Kconfig option which was previously used to control this.
While am updating the sysfs documentation, fix the name of CCMgtA.
Reviewed-by: Arthur Kepner <arthur.kepner@intel.com>
Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Signed-off-by: Vennila Megavannan <vennila.megavannan@intel.com>
Signed-off-by: Ira Weiny <ira.weiny@intel.com>
Signed-off-by: Andrew Friedley <andrew.friedley@intel.com>
Signed-off-by: Arthur Kepner <arthur.kepner@intel.com>
Signed-off-by: Brendan Cunningham <brendan.cunningham@intel.com>
Signed-off-by: Brian Welty <brian.welty@intel.com>
Signed-off-by: Caz Yokoyama <caz.yokoyama@intel.com>
Signed-off-by: Dean Luick <dean.luick@intel.com>
Signed-off-by: Easwar Hariharan <easwar.hariharan@intel.com>
Signed-off-by: Harish Chegondi <harish.chegondi@intel.com>
Signed-off-by: Jim Snow <jim.m.snow@intel.com>
Signed-off-by: John Gregor <john.a.gregor@intel.com>
Signed-off-by: Jubin John <jubin.john@intel.com>
Signed-off-by: Kaike Wan <kaike.wan@intel.com>
Signed-off-by: Kevin Pine <kevin.pine@intel.com>
Signed-off-by: Kyle Liddell <kyle.liddell@intel.com>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Signed-off-by: Mitko Haralanov <mitko.haralanov@intel.com>
Signed-off-by: Ravi Krishnaswamy <ravi.krishnaswamy@intel.com>
Signed-off-by: Sadanand Warrier <sadanand.warrier@intel.com>
Signed-off-by: Sanath Kumar <sanath.s.kumar@intel.com>
Signed-off-by: Sudeep Dutt <sudeep.dutt@intel.com>
Signed-off-by: Vlad Danushevsky <vladimir.danusevsky@intel.com>
infrastructure for it.
Let it rip!
