path: root/Documentation/infiniband
2009-12-09IB: Fix typo in ipoib.txtBart Van Assche
Delete extra words in "is to takes advantage of". Signed-off-by: Bart Van Assche <bart.vanassche@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-10-07IB: Fix typo in udev rule documentationBart Van Assche
The proper syntax for udev rules is KERNEL==... instead of KERNEL=... Signed-off-by: Bart Van Assche <bart.vanassche@gmail.com> Reported-by: Lukasz Jurewicz <lukasz.jurewicz@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-08IPoIB: Document newish featuresOr Gerlitz
Update the documentation to include connected mode, stateless offloads and interrupt moderation, and add a reference to the connected mode RFC. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-09IB/umad: Add P_Key index supportRoland Dreier
Add support for setting the P_Key index of sent MADs and getting the P_Key index of received MADs. This requires a change to the layout of the ABI structure struct ib_user_mad_hdr, so to avoid breaking compatibility, we default to the old (unchanged) ABI and add a new ioctl IB_USER_MAD_ENABLE_PKEY that allows applications that are aware of the new ABI to opt into using it. We plan on switching to the new ABI by default in a year or so, and this patch adds a warning that is printed when an application uses the old ABI, to push people towards converting to the new ABI. Signed-off-by: Roland Dreier <rolandd@cisco.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Reviewed-by: Hal Rosenstock <hal@xsigo.com>
2007-04-24IB/umad: Clarify documentation of transaction IDHal Rosenstock
Signed-off-by: Hal Rosenstock <halr@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-08-03IB/ipoib: Remove broken link from Kconfig and documentationOr Gerlitz
Remove references to the IPoIB IETF working group as it has been closed. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-06-17IPoIB: Mention RFC numbers in documentationRoland Dreier
Now that the IETF has released RFCs covering IPoIB, give the numbers in the documentation for IPoIB. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-07-27[PATCH] IB: Add core locking documentation to InfinibandHal Rosenstock
Add core locking documentation to Infiniband Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Hal Rosenstock <halr@voltaire.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] IB: User MAD ABI changes to support RMPPHal Rosenstock
User MAD ABI changes to support RMPP Signed-off-by: Hal Rosenstock <halr@voltaire.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] IB uverbs: add documentation fileRoland Dreier
Add documentation for InfiniBand userspace verbs. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] IPoIB: document conversion to debugfsRoland Dreier
Update IPoIB documentation now that multicast debugging files have moved from ipoibdebugfs to debugfs. Signed-off-by: Roland Dreier <roland@topspin.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
