path: root/Documentation/input/joydev
2017-08-24docs: fix nested numbering in the TOCMarkus Heiser
With Sphinx 1.6 nested numbering is reported as warning:: ./input/joydev/index.rst:13: WARNING: input/joydev/joystick-api is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-func-open is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-func-close is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-func-ioctl is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-func-poll is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-ioc-adap-g-caps is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-ioc-adap-g-log-addrs is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-ioc-adap-g-phys-addr is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-ioc-dqevent is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-ioc-g-mode is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-ioc-receive is already assigned section numbers (nested numbered toctree?) TOC numbering is already set in:: ./input/devices/index.rst:9: ./media/uapi/cec/cec-api.rst:19: I guess the nested numbering in: ./input/joydev/index.rst ./media/uapi/cec/cec-funcs.rst is just a C&P typo, so lets remove it. Signed-off-by: Markus Heiser <markus.heiser@darmarit.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2017-04-17Input: docs - freshen up introductionDmitry Torokhov
Stop saying that API is experimental and that only USB is supported, acknowledge that evdev is the preferred interface, and remove paragraph encouraging people sending snail mail to Vojtech :) along with his email. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-17Input: docs - update joystick documentation a bitDmitry Torokhov
Consolidate use instructions and userspace API notes into the same chapter; remove completely obsolete references, move into a separate subdirectory. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
