path: root/Documentation/input
2006-01-15Fix "stuct", "strut", "struc" typosAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-12-21Input: appletouch - add support for Geyser 2Michael Hanselmann
This patch adds support for the Geyser 2 touchpads used on post Oct 2005 Apple PowerBooks to the appletouch driver. Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Acked-by: Rene Nussbaumer <linux-kernel@killerfox.forkbomb.ch> Acked-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Stelian Pop <stelian@popies.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-10-28[PATCH] USB: Buffer overflow patch for Yealink driverHenk
Just a small patch that fixes a small parameter validation bug. drivers/usb/input/map_to_7segment.h: This patch fixes the broken parameter validation in the char to seg7 conversion. This could cause out-of-bounds memory references. MAINTAINERS: Yealink maintainer info now in sorted order. Documentation/input/yealink.txt: Added a Q&A section that answers some common questions. Signed-off-by: Henk <Henk.Vergonet@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> 006491df1a13f85ad245d1039dfdf20e49c394fd
2005-09-12[PATCH] USB: add apple usb touchpad driverStelian Pop
This is a driver for the USB touchpad which can be found on post-February 2005 Apple PowerBooks. This driver is derived from Johannes Berg's appletrackpad driver [1], but it has been improved in some areas: * appletouch is a full kernel driver, no userspace program is necessary * appletouch can be interfaced with the synaptics X11 driver[2], in order to have touchpad acceleration, scrolling, two/three finger tap, etc. This driver has been tested by the readers of the 'debian-powerpc' mailing list for a few weeks now and I believe it is now ready for inclusion into the mainline kernel. Credits go to Johannes Berg for reverse-engineering the touchpad protocol, Frank Arnold for further improvements, and Alex Harper for some additional information about the inner workings of the touchpad sensors. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] USB: yealink: fix htons usage, documentation updatesHenk
Signed-off-by: Henk Vergonet <henk.vergonet@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] input-driver-yealink-P1K-usb-phoneHenk
This patch aggregates all modifications in the -mm tree and adds complete ringtone support. The following features are supported: - keyboard full support - LCD full support - LED full support - dialtone full support - ringtone full support - audio playback via generic usb audio diver - audio record via generic usb audio diver For driver documentation see: Documentation/input/yealink.txt For vendor documentation see: http://yealink.com Signed-off-by: Henk <Henk.Vergonet@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
