path: root/Documentation/input
2017-08-30Documentation:input: fix typoJohn de la Garza
Signed-off-by: John de la Garza <john@jjdev.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2017-08-24docs: fix nested numbering in the TOCMarkus Heiser
With Sphinx 1.6 nested numbering is reported as warning:: ./input/joydev/index.rst:13: WARNING: input/joydev/joystick-api is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-func-open is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-func-close is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-func-ioctl is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-func-poll is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-ioc-adap-g-caps is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-ioc-adap-g-log-addrs is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-ioc-adap-g-phys-addr is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-ioc-dqevent is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-ioc-g-mode is already assigned section numbers (nested numbered toctree?) ./media/uapi/cec/cec-funcs.rst:8: WARNING: media/uapi/cec/cec-ioc-receive is already assigned section numbers (nested numbered toctree?) TOC numbering is already set in:: ./input/devices/index.rst:9: ./media/uapi/cec/cec-api.rst:19: I guess the nested numbering in: ./input/joydev/index.rst ./media/uapi/cec/cec-funcs.rst is just a C&P typo, so lets remove it. Signed-off-by: Markus Heiser <markus.heiser@darmarit.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2017-07-13Merge tag '4.13-fixes' of git://git.lwn.net/linuxLinus Torvalds
Pull documentation fixes from Jonathan Corbet: "A set of fixes for various warnings, including the one caused by the removal of kernel/rcu/srcu.c. Also correct a stray pointer in memory-barriers.txt" * tag '4.13-fixes' of git://git.lwn.net/linux: kokr/memory-barriers.txt: Fix obsolete link to atomic_ops.txt memory-barriers.txt: Fix broken link to atomic_ops.txt docs: Turn off section numbering for the input docs docs: Include uaccess docs from the right file docs: Do not include from kernel/rcu/srcu.c
2017-07-12docs: Turn off section numbering for the input docsJonathan Corbet
The input docs enable section numbering at multiple levels, leading to a lot of bright-red "nested numbered toctree" warnings in newer Sphinx versions. Just take that directive out for now to help alleviate the global red-pixel shortage. Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2017-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input layer fixes from Dmitry Torokhov: "Just a few fixups to a couple of drivers" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: elan_i2c - ignore signals when finishing updating firmware Input: elan_i2c - clear INT before resetting controller Input: atmel_mxt_ts - add T100 as a readable object Input: edt-ft5x06 - increase allowed data range for threshold parameter
2017-05-22Input: edt-ft5x06 - increase allowed data range for threshold parameterMartin Kepplinger
The datasheet and application note does not mention an allowed range for the M09_REGISTER_THRESHOLD parameter. One of our customers needs to set lower values than 20 and they seem to work just fine on EDT EP0xx0M09 with T5x06 touch. So, lacking a known lower limit, we increase the range for thresholds, and set the lower limit to 0. The documentation is updated accordingly. Signed-off-by: Schoefegger Stefan <stefan.schoefegger@ginzinger.com> Signed-off-by: Manfred Schlaegl <manfred.schlaegl@ginzinger.com> Signed-off-by: Martin Kepplinger <martin.kepplinger@ginzinger.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-05-09docs-rst: add input docs at main index and use kernel-figureMauro Carvalho Chehab
The input subsystem documentation got converted into ReST. Add it to the main documentation index and use kernel-figure for the two svg images there. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2017-05-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem updates from Dmitry Torokhov: - a big update from Mauro converting input documentation to ReST format - Synaptics PS/2 is now aware of SMBus companion devices, which means that we can now use native RMI4 protocol to handle touchpads, instead of relying on legacy PS/2 mode. - we removed support from BMA180 accelerometer from input devices as it is now handled properly by IIO - update to TSC2007 to corretcly report pressure - other miscellaneous driver fixes. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (152 commits) Input: ar1021_i2c - use BIT to check for a bit Input: twl4030-pwrbutton - use input_set_capability() helper Input: twl4030-pwrbutton - use correct device for irq request Input: ar1021_i2c - enable touch mode during open Input: add uinput documentation dt-bindings: input: add bindings document for ar1021_i2c driver dt-bindings: input: rotary-encoder: fix typo Input: xen-kbdfront - add module parameter for setting resolution ARM: pxa/raumfeld: fix compile error in rotary controller resources Input: xpad - do not suggest writing to Dominic Input: xpad - don't use literal blocks inside footnotes Input: xpad - note that usb/devices is now at /sys/kernel/debug/ Input: docs - freshen up introduction Input: docs - split input docs into kernel- and user-facing Input: docs - note that MT-A protocol is obsolete Input: docs - update joystick documentation a bit Input: docs - remove disclaimer/GPL notice Input: fix "Game console" heading level in joystick documentation Input: rotary-encoder - remove references to platform data from docs Input: move documentation for Amiga CD32 ...
2017-05-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID subsystem updates from Jiri Kosina: - The need for HID_QUIRK_NO_INIT_REPORTS per-device quirk has been growing dramatically during past years, so the time has come to switch over the default, and perform the pro-active reading only in cases where it's really needed (multitouch, wacom). The only place where this behavior is (in some form) preserved is hiddev so that we don't introduce userspace-visible change of behavior. From Benjamin Tissoires - HID++ support for power_supply / baterry reporting. From Benjamin Tissoires and Bastien Nocera - Vast improvements / rework of DS3 and DS4 in Sony driver. From Roderick Colenbrander - Improvment (in terms of getting closer to the Microsoft's interpretation of slightly ambiguous specification) of logical range interpretation in case null-state is set in the rdesc. From Valtteri Heikkilä and Tomasz Kramkowski - A lot of newly supported device IDs and small assorted fixes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (71 commits) HID: usbhid: Add HID_QUIRK_NOGET for Aten CS-1758 KVM switch HID: asus: support backlight on USB keyboards HID: wacom: Move wacom_remote_irq and wacom_remote_status_irq HID: wacom: generic: sync pad events only for actual packets HID: sony: remove redundant check for -ve err HID: sony: Make sure to unregister sensors on failure HID: sony: Make DS4 bt poll interval adjustable HID: sony: Set proper bit flags on DS4 output report HID: sony: DS4 use brighter LED colors HID: sony: Improve navigation controller axis/button mapping HID: sony: Use DS3 MAC address as unique identifier on USB HID: logitech-hidpp: add a sysfs file to tell we support power_supply HID: logitech-hidpp: enable HID++ 1.0 battery reporting HID: logitech-hidpp: add support for battery status for the K750 HID: logitech-hidpp: battery: provide CAPACITY_LEVEL HID: logitech-hidpp: rename battery level into capacity HID: logitech-hidpp: battery: provide ONLINE property HID: logitech-hidpp: notify battery on connect HID: logitech-hidpp: return an error if the queried feature is not present HID: logitech-hidpp: create the battery for all types of HID++ devices ...
2017-05-02Merge branch 'for-4.12/asus' into for-linusJiri Kosina
2017-04-24Input: add uinput documentationMarcos Paulo de Souza
Add description of uinput module with a few examples. Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-18Input: xpad - do not suggest writing to DominicDmitry Torokhov
Do not recommend people write to Dominic, rather everyone should be using linux-input mailing list. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-17Input: xpad - don't use literal blocks inside footnotesMauro Carvalho Chehab
Unfortunately, Sphinx (or LaTeX) can't handle literal blocks inside footnotes. So, just use normal text for the two literal code-blocks that documents the output of /sys/kernel/debug/usb/devices for xpad devices. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-17Input: xpad - note that usb/devices is now at /sys/kernel/debug/Mauro Carvalho Chehab
The /proc/bus/usb/devices got moved to sysfs. It is now sitting at: /sys/kernel/debug/usb/devices Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-17Input: docs - freshen up introductionDmitry Torokhov
Stop saying that API is experimental and that only USB is supported, acknowledge that evdev is the preferred interface, and remove paragraph encouraging people sending snail mail to Vojtech :) along with his email. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-17Input: docs - split input docs into kernel- and user-facingDmitry Torokhov
Split input documentation into several groups: kernel- and user-facing, and notes about individual device drivers. Move device drivers docs into a separate subdirectory. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-17Input: docs - note that MT-A protocol is obsoleteDmitry Torokhov
Everyone should be using multitouch protocol B (slotted) now. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-17Input: docs - update joystick documentation a bitDmitry Torokhov
Consolidate use instructions and userspace API notes into the same chapter; remove completely obsolete references, move into a separate subdirectory. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-17Input: docs - remove disclaimer/GPL noticeDmitry Torokhov
This is just a part of kernel documentation, it does not require explicit license notice. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-17Input: fix "Game console" heading level in joystick documentationDmitry Torokhov
The heading level should be the same as for other devices. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-17Input: rotary-encoder - remove references to platform data from docsDmitry Torokhov
The driver has been converted to use generic device properties, so stop referring to platform data. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-17Input: move documentation for Amiga CD32Dmitry Torokhov
Move the documentation for Amiga CD32 together with other parallel port joysticks. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: use svg files instead of xfig in force feedback documentationMauro Carvalho Chehab
Now that the images got converted to svg, add them at the ff.rst file. NOTE: After merging upstream, the "figure" tag should be replaced by the new "kernel-figure" tag, in order for the SVG images to be included at the PDF files. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: docs - convert interactive.fig from xfig to svgMauro Carvalho Chehab
We're using svg as the standard format for vectorial images. Convert it to .svg, in a way that it is easily editable. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: docs - convert shape.fig from xfig to svgMauro Carvalho Chehab
We're using svg as the standard format for vectorial images. Convert shape.fig to .svg, in a way that it is easily editable. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: create a book with Linux Input documentationMauro Carvalho Chehab
Now that all files under Documentation/input follows the ReST markup language, rename them to *.rst and create a book for the Linux Input subsystem. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: yealink - convert documentation into ReST formatMauro Carvalho Chehab
This file require minimum adjustments to be a valid ReST file. Do it, in order to be able to parse it with Sphinx. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: xpad - convert documentation into ReST formatMauro Carvalho Chehab
2017-04-05Input: walkera0701 - convert documentation into ReST formatMauro Carvalho Chehab
2017-04-05Input: userio - convert documentation into ReST formatMauro Carvalho Chehab
2017-04-05Input: sentelic - convert documentation into ReST formatMauro Carvalho Chehab
This file has its own particular format that doesn't match any markup one. Manually change it to get something that would be readable using ReST markup language. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: rotary-encoder - convert documentation into to ReST formatMauro Carvalho Chehab
2017-04-05Input: ntrig - convert documentation into ReST formatMauro Carvalho Chehab
2017-04-05Input: convert keyboard notifier docs into ReST formatMauro Carvalho Chehab
2017-04-05Input: convert multi-touch protocol spec into ReST formatMauro Carvalho Chehab
This file require minimum adjustments to be a valid ReST file. Do it, in order to be able to parse it with Sphinx Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: joystick-parport - convert documentation into ReST formatMauro Carvalho Chehab
2017-04-05Input: joystick - convert documentation into ReST formatMauro Carvalho Chehab
2017-04-05Input: convert joystick-api doc into ReST formatMauro Carvalho Chehab
This file require some adjustments to be a valid ReST file. Do it, in order to be able to parse it with Sphinx. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: convert input-programming doc into ReST formatMauro Carvalho Chehab
2017-04-05Input: iforce - convert documentation into ReST formatMauro Carvalho Chehab
This file seems to be using some other markup language, (maybe mediawiki?). Manually convert it to ReST markup, with is the one we're using along the Kernel documentaiton. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: gpio-tilt - convert documentation into ReST formatMauro Carvalho Chehab
2017-04-05Input: convert gameport programming documentation into ReST formatMauro Carvalho Chehab
This file require minimum adjustments to be a valid ReST. Do it, in order to be able to parse it with Sphinx. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: convert gamepad specification into ReST formatMauro Carvalho Chehab
2017-04-05Input: convert force feedback documentation into ReST formatMauro Carvalho Chehab
2017-04-05Input: convert event codes documentation into ReST formatMauro Carvalho Chehab
This file require minimum adjustments to be a valid ReST file. Do it, in order to be able to parse it with Sphinx. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Reviewed-by: Peter Hutterer <peter.hutterer@who-t.net> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: elantech - convert documentation into ReST formatMauro Carvalho Chehab
This file require minimum adjustments to be a valid ReST file. Do it, in order to be able to parse it with Sphinx. We opted to remove section numbers, as this can be automatically generated on Sphinx, by using :numbered: tag at index. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: cs461x - convert documentation into ReST formatMauro Carvalho Chehab
2017-04-05Input: cma3000_d0x - convert documentation into ReST formatMauro Carvalho Chehab
2017-04-05Input: db9/CD32 - convert documentation into ReST formatMauro Carvalho Chehab
Currently, it misses a title, and the table is not valid for ReST. Adjust them, in order for it to be able to parse on Sphinx. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-04-05Input: bcm5974 - convert documentation into ReST formatMauro Carvalho Chehab
