path: root/Documentation/input
2011-10-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (68 commits) Input: adp5589-keys - add support for the ADP5585 derivatives Input: imx_keypad - add pm suspend and resume support Input: force feedback - potential integer wrap in input_ff_create() Input: tsc2007 - make sure that X plate resistance is specified Input: serio_raw - fix memory leak when closing char device Input: serio_raw - kick clients when disconnecting port Input: serio_raw - explicitly mark disconnected ports as dead Input: serio_raw - fix coding style issues Input: serio_raw - use dev_*() for messages Input: serio_raw - use bool for boolean data Input: serio_raw - perform proper locking when adding clients to list Input: serio_raw - rename serio_raw_list to serio_raw_client Input: serio_raw - use kref instead of rolling out its own refcounting Input: psmouse - switch to using dev_*() for messages Input: wacom - correct max Y value on medium bamboos Input: wacom - add ABS_DISTANCE to Bamboo Pen reports Input: wacom - remove unneeded touch pressure initialization Input: lm8323 - wrap suspend and resume in CONFIG_PM_SLEEP Input: ad7879-i2c - wrap suspend and resume in CONFIG_PM_SLEEP Input: synaptics_i2c - wrap suspend and resume in CONFIG_PM_SLEEP ...
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-09-09Input: elantech - add v4 hardware supportJJ Ding
v4 hardware is a true multitouch capable touchpad (up to 5 fingers). The packet format is quite complex, please see protocol document for reference. Signed-off-by: JJ Ding <jj_ding@emc.com.tw> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-09-09Input: elantech - add v3 hardware supportJJ Ding
v3 hardware's packet format is almost identical to v2 (one/three finger touch), except when sensing two finger touch, the hardware sends 12 bytes of data. Signed-off-by: JJ Ding <jj_ding@emc.com.tw> Acked-by: Daniel Kurtz <djkurtz@chromium.org> Acked-by: Éric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-09-09Input: elantech - correct x, y value range for v2 hardwareJJ Ding
x, y values are actually 12-bit long. Also update protocol document to reflect the change. Signed-off-by: JJ Ding <jj_ding@emc.com.tw> Acked-by: Daniel Kurtz <djkurtz@chromium.org> Acked-by: Éric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-08-23Input: mt - document devices reporting more touches than slotsDaniel Kurtz
Some devices are capable of identifying and/or tracking more contacts than they can report to the driver. Document how a driver should handle this, and what userspace should expect. Signed-off-by: Daniel Kurtz <djkurtz@chromium.org> Acked-by: Chase Douglas <chase.douglas@canonical.com> Acked-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-05-16Input: elantech - describe further the protocolÉric Piel
For some Dell laptops, Ubuntu had a special version of the elantech driver with more knowledge on the devices. It can be found there: http://zinc.ubuntu.com/git?p=mid-team/hardy-netbook.git;a=blob;f=drivers/input/mouse/elantech.c;h=d0e2cafed162428f72e3654f4dda85e08ea486b3;hb=refs/heads/abi-22 By inspecting the source code, and doing some test on a real hardware, I have completed the protocol specification (especially for the 6 bytes protocol). It also adds information about the mapping between the version reported by the device and the protocol to use. Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Reviewed-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-05-12Input: rotary-encoder - add support for half-period encodersJohan Hovold
Add support for encoders that have two detents per input signal period. Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-04-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: xen-kbdfront - fix mouse getting stuck after save/restore Input: estimate number of events per packet Input: evdev - indicate buffer overrun with SYN_DROPPED Input: document event types and codes and their intended use Input: add KEY_IMAGES specifically for AL Image Browser Input: twl4030_keypad - fix potential NULL dereference in twl4030_kp_probe() Input: h3600_ts - fix error handling at connect Input: twl4030_keypad - avoid potential NULL-pointer dereference
2011-04-12Input: evdev - indicate buffer overrun with SYN_DROPPEDJeff Brown
Add a new EV_SYN code, SYN_DROPPED, to inform the client when input events have been dropped from the evdev input buffer due to a buffer overrun. The client should use this event as a hint to reset its state or ignore all following events until the next packet begins. Signed-off-by: Jeff Brown <jeffbrown@android.com> [dtor@mail.ru: Implement Henrik's suggestion and drop old events in case of overflow.] Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-04-12Input: document event types and codes and their intended useChase Douglas
This commit adds the file Documentation/input/event-codes.txt. Acked-by: Henrik Rydberg <rydberg@euromail.se> Reviewed-by: Peter Hutterer <peter.hutterer@who-t.net> Signed-off-by: Chase Douglas <chase.douglas@canonical.com> Signed-off-by: Chris Bagwell <chris@cnpbagwell.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-01-11Input: fix force feedback capability query exampleAlexander Stein
'features' is a bit array, not byte array Signed-off-by: Alexander Stein <alexander.stein@informatik.tu-chemnitz.de> Acked-by: Anssi Hannula <anssi.hannula@iki.fi> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-12-27Merge branch 'next' of ↵Dmitry Torokhov
git://git.kernel.org/pub/scm/linux/kernel/git/rydberg/input-mt into next
2010-12-20input: mt: Document interface updatesHenrik Rydberg
This patch documents the recent input-mt interface changes. Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-16Merge branch 'next' of ↵Dmitry Torokhov
git://git.kernel.org/pub/scm/linux/kernel/git/rydberg/input-mt into next Conflicts: drivers/input/Makefile
2010-12-16input: mt: Add hovering distance axisHenrik Rydberg
Touch devices capable of hovering, i.e., fingers detected a distance from the surface, are not supported by the current input MT protocol. This patch adds ABS_MT_DISTANCE, which may be used to indicate the distance between the contact and the surface. Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-11-30Input: add CMA3000 accelerometer driverHemanth V
Add support for CMA3000 Tri-axis accelerometer, which supports Motion detect, Measurement and Free fall modes. CMA3000 supports both I2C/SPI bus for communication, currently the driver supports I2C based communication. Signed-off-by: Hemanth V <hemanthv@ti.com> Reviewed-by: Jonathan Cameron <jic23@cam.ac.uk> Reviewed-by: Sergio Aguirre <saaguirre@ti.com> Reviewed-by: Shubhrajyoti <Shubhrajyoti@ti.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-08-30HID: ntrig: add documentionRafi Rubin
The doctumentation includes a brief introduction to the driver and explanations of the filtering parameters as well as a discussion of the need for and working of the filters. Signed-off-by: Rafi Rubin <rafi@seas.upenn.edu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-15Input: document the MT event slot protocolHenrik Rydberg
This patch adds documentation for the ABS_MT_SLOT event and gives examples of how to use the event slot protocol. Reviewed-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-05-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: joydev - allow binding to button-only devices Input: elantech - ignore high bits in the position coordinates Input: elantech - allow forcing Elantech protocol Input: elantech - fix firmware version check Input: ati_remote - add some missing devices from lirc_atiusb Input: eeti_ts - cancel pending work when going to suspend Input: Add support of Synaptics Clickpad device Revert "Input: ALPS - add signature for HP Pavilion dm3 laptops" Input: psmouse - ignore parity error for basic protocols
2010-05-03Input: elantech - ignore high bits in the position coordinatesFlorian Ragwitz
In older versions of the elantech hardware/firmware those bits always were unset, so it didn't actually matter, but newer versions seem to use those high bits for something else, screwing up the coordinates we report to the input layer for those devices. Signed-off-by: Florian Ragwitz <rafl@debian.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: wacom - switch mode upon system resume Revert "Input: wacom - merge out and in prox events" Input: matrix_keypad - allow platform to disable key autorepeat Input: ALPS - add signature for HP Pavilion dm3 laptops Input: i8042 - spelling fix Input: sparse-keymap - implement safer freeing of the keymap Input: update the status of the Multitouch X driver project Input: clarify the no-finger event in multitouch protocol Input: bcm5974 - retract efi-broken suspend_resume Input: sparse-keymap - free the right keymap on error
2010-03-21Input: update the status of the Multitouch X driver projectHenrik Rydberg
The Multitouch X driver project has moved to alpha status. This patch updates the documentation accordingly. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-21Input: clarify the no-finger event in multitouch protocolHenrik Rydberg
The current documentation does not explicitly specify how to report zero fingers, leaving a potential problem in the driver implementations and giving no parsing directive to userland. This patch defines two equally valid ways. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-28Merge branch 'next' into for-linusDmitry Torokhov
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-28Input: update multi-touch protocol documentationHenrik Rydberg
This patch documents a new ABS_MT parameter and adds further text to clarify some points around the MT protocol. Requested-by: Yoonyoung Shim <jy0922.shim@samsung.com> Requested-by: Mika Kuoppala <mika.kuoppala@nokia.com> Requested-by: Peter Hutterer <peter.hutterer@who-t.net> Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-13Input: update Sentelic protocol documentationTai-hwa Liang
iSigned-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-08-19Input: add new driver for Sentelic Finger Sensing PadTai-hwa Liang
This is the driver for Sentelic Finger Sensing Pad which can be found on MSI WIND Netbook. Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-06-11Merge commit 'v2.6.30' into nextDmitry Torokhov
2009-05-23Input: multitouch - augment event semantics documentationHenrik Rydberg
Through the collaboration to adapt the N-trig and Stantum HID drivers to the MT protocol, some semantic clarifications to the protocol have been made. This patch adds them to the MT documentation. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Tested-by: Stéphane Chatty <chatty@enac.fr> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-05-08Merge commit 'v2.6.30-rc5' into nextDmitry Torokhov
2009-04-30Input: document the multi-touch (MT) protocolHenrik Rydberg
This patchs adds documentation for the multi-touch protocol to Documentation/input/. [randy.dunlap@oracle.com: grammar fixes] Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-04-28Input: bcm5974 - add documentation for the driverHenrik Rydberg
This patch adds documentation for the bcm5974 to Documentation/input/. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-04-17Input: fix typo in documentationThadeu Lima de Souza Cascardo
Event type for key presses is EV_KEY, not REL_KEY. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-04-17Input: rotary_encoder - add support for REL_* axesH Hartley Sweeten
The rotary encoder driver only supports returning input events for ABS_* axes, this adds support for REL_* axes. The relative axis input event is reported as -1 for each counter-clockwise step and +1 for each clockwise step. The ability to clamp the position of ABS_* axes between 0 and a maximum of "steps" has also been added. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-03-08Input: generic driver for rotary encoders on GPIOsDaniel Mack
This patch adds a generic driver for rotary encoders connected to GPIO pins of a system. It relies on gpiolib and generic hardware irqs. The documentation that also comes with this patch explains the concept and how to use the driver. Signed-off-by: Daniel Mack <daniel@caiaq.de> Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-12-20Merge commit 'v2.6.28-rc9' into nextDmitry Torokhov
2008-11-19Input: add joystick driver for Walkera WK-0701 RC transmitterPeter Popovec
Signed-off-by: Peter Popovec <popovec@fei.tuke.sk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-11-11Input: fix the example of an input device driverDmitri Vorobiev
This patch fixes a wrong interrupt handler example given in the "Hello, world!"-like input driver in Documentation/input/input-programming.txt. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-10-16Input: psmouse - add support for Elantech touchpadsArjan Opmeer
This is version 5 of the driver. Relative mode support has been dropped (users wishing to use touchpad in relative mode can use standard PS/2 protocol emulation done in hardware). The driver supports both original version of Elantech protocol and the newer one used by touchpads installed in EeePC. Signed-off-by: Arjan Opmeer <arjan@opmeer.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-26Documentation cleanup: trivial misspelling, punctuation, and grammar ↵Matt LaPlante
corrections. Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20Input: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-14Input: add keyboard notifier documentationSamuel Thibault
Document the keyboard notifier. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> SIgned-off-by: Dmitry Torokhov <dtor@mail.ru>
