path: root/Documentation/intel_txt.txt
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-19x86, tboot: Add support for S3 memory integrity protectionShane Wang
This patch adds support for S3 memory integrity protection within an Intel(R) TXT launched kernel, for all kernel and userspace memory. All RAM used by the kernel and userspace, as indicated by memory ranges of type E820_RAM and E820_RESERVED_KERN in the e820 table, will be integrity protected. The MAINTAINERS file is also updated to reflect the maintainers of the TXT-related code. All MACing is done in tboot, based on a complexity analysis and tradeoff. v3: Compared with v2, this patch adds a check of array size in tboot.c, and a note to specify which c/s of tboot supports this kind of MACing in intel_txt.txt. Signed-off-by: Shane Wang <shane.wang@intel.com> LKML-Reference: <4B973DDA.6050902@intel.com> Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-07-21x86, intel_txt: Intel TXT boot supportJoseph Cihula
This patch adds kernel configuration and boot support for Intel Trusted Execution Technology (Intel TXT). Intel's technology for safer computing, Intel Trusted Execution Technology (Intel TXT), defines platform-level enhancements that provide the building blocks for creating trusted platforms. Intel TXT was formerly known by the code name LaGrande Technology (LT). Intel TXT in Brief: o Provides dynamic root of trust for measurement (DRTM) o Data protection in case of improper shutdown o Measurement and verification of launched environment Intel TXT is part of the vPro(TM) brand and is also available some non-vPro systems. It is currently available on desktop systems based on the Q35, X38, Q45, and Q43 Express chipsets (e.g. Dell Optiplex 755, HP dc7800, etc.) and mobile systems based on the GM45, PM45, and GS45 Express chipsets. For more information, see http://www.intel.com/technology/security/. This site also has a link to the Intel TXT MLE Developers Manual, which has been updated for the new released platforms. A much more complete description of how these patches support TXT, how to configure a system for it, etc. is in the Documentation/intel_txt.txt file in this patch. This patch provides the TXT support routines for complete functionality, documentation for TXT support and for the changes to the boot_params structure, and boot detection of a TXT launch. Attempts to shutdown (reboot, Sx) the system will result in platform resets; subsequent patches will support these shutdown modes properly. Documentation/intel_txt.txt | 210 +++++++++++++++++++++ Documentation/x86/zero-page.txt | 1 arch/x86/include/asm/bootparam.h | 3 arch/x86/include/asm/fixmap.h | 3 arch/x86/include/asm/tboot.h | 197 ++++++++++++++++++++ arch/x86/kernel/Makefile | 1 arch/x86/kernel/setup.c | 4 arch/x86/kernel/tboot.c | 379 +++++++++++++++++++++++++++++++++++++++ security/Kconfig | 30 +++ 9 files changed, 827 insertions(+), 1 deletion(-) Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Gang Wei <gang.wei@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
