path: root/Documentation/ioctl-number.txt
2006-06-26[PATCH] devfs: Last little devfs cleanups throughout the kernel tree.Greg Kroah-Hartman
Just removes a few unused #defines and fixes some comments due to devfs now being gone. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-23[PATCH] two additions to ./linux/Documentation/ioctl-number.txtbjdouma
Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] arch/i386/kernel/microcode.c: remove the obsolete microcode_ioctlAdrian Bunk
Nowadays, even Debian stable ships a microcode_ctl utility recent enough to no longer use this ioctl. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Tigran Aivazian <tigran_aivazian@symantec.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-22[PATCH] kernel Doc/ URL correctionsRandy Dunlap
Correct lots of URLs in Documentation/ Also a few minor whitespace cleanups and typo/spello fixes. Sadly there are still a lot of bad URLs remaining. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[SPARC]: Kill remaining kbio.h references.Christoph Hellwig
Would you mind applying the following patch that kills those two + the m68k and Documentation/ references? Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
