path: root/Documentation/ioctl-number.txt
2008-04-27KVM: Register ioctl rangeAvi Kivity
Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-25ocfs2: Reserve ioctl rangeTao Ma
We need to reserve at least two ioctls for online-resize. Reserve a small range of ioctls for Ocfs2 use in Documentation/ioctl-number.txt. This should give us enough room for future growth. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-16Remove the last few UMSDOS leftoversJesper Juhl
The UMSDOS filesystem was removed back in 2.6.11, but some tiny bits stuck around. This patch removes the few remaining leftovers. The only things left behind after this are the entries in the CREDITS file and the ioctl number in Documentation/ioctl-number.txt as documentation. This third (hopefully final) version of the patch doesn't edit the arch/um/config.release file, since Jeff Dike pointed out to me that it should die completely, and asked me to remove it from my patch as he'll send in a seperate patch removing the file completely. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Misc: add sensable phantom driverJiri Slaby
Add sensable phantom driver Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Doc: isicom, remove reserved ioctl-numberJiri Slaby
Isicom driver no longer registers chardev with ioctl function. It used to use for firmware loading. Remove the reserved letter (M) from ioctl-number, so that the conflict get away. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] mbxfb: Document the new ioctlRaphael Assenat
This patch adds a new ioctl range for the mbxfb driver. Signed-off-by: Raphael Assenat <raph@8d.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Acked-by: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Last little devfs cleanups throughout the kernel tree.Greg Kroah-Hartman
Just removes a few unused #defines and fixes some comments due to devfs now being gone. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-23[PATCH] two additions to ./linux/Documentation/ioctl-number.txtbjdouma
Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] arch/i386/kernel/microcode.c: remove the obsolete microcode_ioctlAdrian Bunk
Nowadays, even Debian stable ships a microcode_ctl utility recent enough to no longer use this ioctl. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Tigran Aivazian <tigran_aivazian@symantec.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-22[PATCH] kernel Doc/ URL correctionsRandy Dunlap
Correct lots of URLs in Documentation/ Also a few minor whitespace cleanups and typo/spello fixes. Sadly there are still a lot of bad URLs remaining. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[SPARC]: Kill remaining kbio.h references.Christoph Hellwig
Would you mind applying the following patch that kills those two + the m68k and Documentation/ references? Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
