path: root/Documentation/ja_JP
2014-06-07Documentation: Update stable address in Chinese and Japanese translationsGeert Uytterhoeven
commit 98b0f811aade1b7c6e7806c86aa0befd5919d65f upstream. The English and Korean translations were updated, the Chinese and Japanese weren't. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-07-25Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: updated Documentation/ja_JP/SubmittingPatches debugfs: add documentation for debugfs_create_x64 uio: uio_pdrv_genirq: Add OF support firmware: gsmi: remove sysfs entries when unload the module Documentation/zh_CN: Fix messy code file email-clients.txt driver core: add more help description for "path to uevent helper" driver-core: modify FIRMWARE_IN_KERNEL help message driver-core: Kconfig grammar corrections in firmware configuration DOCUMENTATION: Replace create_device() with device_create(). DOCUMENTATION: Update overview.txt in Doc/driver-model. pti: pti_tty_install documentation mispelling.
2011-07-18updated Documentation/ja_JP/SubmittingPatchesKeiichi Kii
Updated Documentaion/ja_JP/SubmittingPatches due to changes from upstream version(2.6.39) of the file. And also, this translated SubmittingPatches is already reviewed by JF project. The JF project is the Japanese equivalent of LDP. Signed-off-by: Keiichi Kii <k-keiichi@bx.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23sched: Generalize sleep inside spinlock detectionFrederic Weisbecker
The sleeping inside spinlock detection is actually used for more general sleeping inside atomic sections debugging: preemption disabled, rcu read side critical sections, interrupts, interrupt disabled, etc... Change the name of the config and its help section to reflect its more general role. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu>
2011-04-19HOWTO: sync up Documentaion/ja_JP/HOWTOTsugikazu Shibata
Signed-off-by: Tsugikazu Shibata <tshibata@ab.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-19block: rename CONFIG_LBD to CONFIG_LBDAFBartlomiej Zolnierkiewicz
Follow-up to "block: enable by default support for large devices and files on 32-bit archs". Rename CONFIG_LBD to CONFIG_LBDAF to: - allow update of existing [def]configs for "default y" change - reflect that it is used also for large files support nowadays Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-01-28Sync patch for jp_JP/stable_kernel_rules.txtTsugikazu Shibata
Updated jp_JP/stable_kernel_rules.txt due to changes in the main version of the file. Also, this patch is already reviewed by Japanese translation community called JF. Signed-off-by: Tsugikazu Shibata <tshibata@ab.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-29HOWTO: Sync patch for jp_JP/HOWTOTsugikazu Shibata
Sync the jp_JP version of HOWTO to contain the latest updates From: Tsugikazu Shibata <tshibata@ab.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-21Documentation: HOWTO-ja_JP-sync patchTsugikazu Shibata
Here is a patch for Documentation/ja_JP/HOWTO sync with latest Documentation/HOWTO. It includes translation of changes done by Jon Corbet,Jiri Pirko and me: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=history;f=Documentation/HOWTO;h=c2371c5a98f99b5eaa785bd0affd6c40187e84e3;hb=HEAD Singed-off-by: Tsugikazu Shibata <tshibata@ab.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-21Japanese translation of Documentation/SubmitChecklistTakenori Nagano
Hi, This patch adds SubmitChecklist translated into Japanese to Documentation/ja_JP directory. The translated SubmitChecklist has already been reviewed by JF project. SubmitChecklist is one of the important policy documents. So, I would like to merge into 2.6.27. Signed-off-by: Takenori Nagano <t-nagano@ah.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-21Fix broken utf-8 encodings in ja_JP translation of stable_kernel_rules.txtTsugikazu Shibata
Fix the UTF-8 broken encodings in the ja_JP version of stable_kernel_rules.txt From: Tsugikazu Shibata <tshibata@ab.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-02Add ja_JP translation of stable_kernel_rules.txtTsugikazu Shibata
Contents are reviewed by Japanese translation community called "JF". Thanks a lot! Singed-off-by: Tsugikazu Shibata <tshibata@ab.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-12-17HOWTO: Change man-page maintainer address for Japanese HOWTOTsugikazu Shibata
Below is a patch to change email address of man-page maintainer for Japanese HOWTO document (Documentation/ja_JP/HOWTO). This is for sync to Documentation/HOWTO that Michael Kerrisk mentioned to me. From: Tsugikazu Shibata <tshibata@ab.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-30add SubmittingPatches to Documentation/ja_JPKeiichi Kii
This patch adds SubmittingPatches translated into Japanese to Documentation/ja_JP directory. I attach the patch because there is a possibility that MUA will change the character encoding sometimes. Signed-off-by: Keiichi KII <k-keiichi@bx.jp.nec.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12HOWTO: update ja_JP/HOWTO with latest changesTsugikazu Shibata
Here is another sync patch of Documentation/ja_JP/HOWTO Japanese developer sent me some cosmetic changes and also follow changes of HOWTO Cross reference URL (sosdg.org/qiyong/lxr) known_regression explanations on kernel dev. process Signed-off-by: Tsugikazu Shibata <tshibata@ab.jp.nec.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-30HOWTO: sync Japanese HOWTOTsugikazu Shibata
2007-07-30HOWTO: adjust translation header of Japanese stable_api_nonsense.txtIKEDA, Munehiro
Signed-off-by: IKEDA, Munehiro <m-ikeda@ds.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-18Documentation: add Japanese translated stable_api_nonsense.txtIKEDA, Munehiro
2007-07-18HOWTO: add Japanese translation of Documentation/HOWTOTsugikazu Shibata
Add the japanese translation of the Documentation/HOWTO file. Signed-off-by: Tsugikazu Shibata <tshibata@ab.jp.nec.com> Cc: IKEDA Munehiro <m-ikeda@ds.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
