Add a 'W=1' Makefile switch which adds additional checking per build
object.
The idea behind this option is targeted at developers who, in the
process of writing their code, want to do the occasional
make W=1 [target.o]
and let gcc do more extensive code checking for them. Then, they
could eyeball the output for valid gcc warnings about various
bugs/discrepancies which are not reported during the normal build
process.
For more background information and a use case, read through this
thread: http://marc.info/?l=kernel-janitors&m=129802065918147&w=2
Cc: Michal Marek <mmarek@suse.cz>
Cc: linux-kbuild@vger.kernel.org
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Signed-off-by: Borislav Petkov <bp@alien8.de>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'packaging' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
deb-pkg: s/hdr/kernel_headers_/ && s/header/libc_headers_/
deb-pkg: Make deb-pkg generate a seperate linux-libc-dev deb
kbuild: create linux-headers package in deb-pkg
kbuild, deb-pkg: support overriding userland architecture
kbuild, deb-pkg: select userland architecture based on UTS_MACHINE
kbuild, deb-pkg: Fix build with paranoid umask
Usefull if building for sparc64 userland, because the
sparc and sparc64 userlands use the same 64-bit kernel,
making it impossible to always select the correct userland
architecture for the resulting debian package.
Might also be usefull, if you want a i386 userland with a amd64 kernel.
Example usage:
make KBUILD_DEBARCH=i386 deb-pkg
LKML-reference: <alpine.DEB.2.02.1011051437500.13287@aurora.sdinet.de>
Signed-off-by: Asbjoern Sloth Toennesen <asbjorn@asbjorn.biz>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
Acked-by: maximilian attems <max@stro.at>
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
modpost: support objects with more than 64k sections
trivial: fix a typo in a filename
frv: clean up arch/frv/Makefile
kbuild: allow assignment to {A,C}FLAGS_KERNEL on the command line
kbuild: allow assignment to {A,C,LD}FLAGS_MODULE on the command line
Kbuild: Add option to set -femit-struct-debug-baseonly
Makefile: "make kernelrelease" should show the correct full kernel version
Makefile.build: make KBUILD_SYMTYPES work again
Fixed some typos and wording.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
It is now possible to assign options to AS and CC
on the command line - which is only used for built-in code.
{A,C}FLAGS_KERNEL was used both in the top-level Makefile
in the arch makefiles, thus users had no way to specify
additional options to AS, CC without overriding
the original value.
Introduce a new set of variables KBUILD_{A,C}FLAGS_KERNEL
that is used by arch specific files and free up
{A,C}FLAGS_KERNEL so they can be assigned on
the command line.
All arch Makefiles that used the old variables has been updated.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Hirokazu Takata <takata@linux-m32r.org>
It is now possible to assign options to AS, CC and LD
on the command line - which is only used when building modules.
{A,C,LD}FLAGS_MODULE was all used both in the top-level Makefile
additional options to AS, CC, LD when building modules
without overriding the original value.
Introduce a new set of variables KBUILD_{A,C,LD}FLAGS_MODULE
{A,C,LD}FLAGS_MODULE so they can be assigned on
the command line.
Note: Previously we had a MODFLAGS variable for both
AS and CC. But in favour of consistency this was dropped.
So in some cases arch Makefile has one assignmnet replaced by
two assignmnets.
Note2: MODFLAGS was not documented and is dropped
without any notice. I do not expect much/any breakage
from this.
Cc: Denys Vlasenko <vda.linux@googlemail.com>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin]
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [avr32]
make ALLSOURCE_ARCHS=all tags
- Document this in kbuild.txt
Without this change you have to type each arch separately.
Signed-off-by: John Kacur <jkacur@redhat.com>
Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru>
To make it easier for module-init-tools and scripts like mkinitrd to
distinguish builtin and missing modules, install a modules.builtin file
listing all builtin modules. This is done by generating an additional
config file (tristate.conf) with tristate options set to uppercase 'Y'
or 'M'. If we source that config file, the builtin modules appear in
obj-Y.
Replace the use of CROSS_COMPILE to select a customized
installkernel script with the possibility to set INSTALLKERNEL
to select a custom installkernel script when running make:
make INSTALLKERNEL=arm-installkernel install
With this patch we are now more consistent across
different architectures - they did not all support use
of CROSS_COMPILE.
The use of CROSS_COMPILE was a hack as this really belongs
to gcc/binutils and the installkernel script does not change
just because we change toolchain.
The use of CROSS_COMPILE caused troubles with an upcoming patch
that saves CROSS_COMPILE when a kernel is built - it would no
longer be installable.
[Thanks to Peter Z. for this hint]
This patch undos what Ian did in commit:
0f8e2d62fa04441cd12c08ce521e84e5bd3f8a46
("use ${CROSS_COMPILE}installkernel in arch/*/boot/install.sh")
The patch has been lightly tested on x86 only - but all changes
looks obvious.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Russell King <linux@arm.linux.org.uk> [arm]
Acked-by: Paul Mundt <lethal@linux-sh.org> [sh]
Acked-by: "H. Peter Anvin" <hpa@zytor.com> [x86]
Cc: Ian Campbell <icampbell@arcom.com>
Cc: Tony Luck <tony.luck@intel.com> [ia64]
Cc: Fenghua Yu <fenghua.yu@intel.com> [ia64]
Cc: Hirokazu Takata <takata@linux-m32r.org> [m32r]
Cc: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Cc: Kyle McMartin <kyle@mcmartin.ca> [parisc]
Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> [powerpc]
Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390]
Cc: Thomas Gleixner <tglx@linutronix.de> [x86]
Cc: Ingo Molnar <mingo@redhat.com> [x86]
Fix typos in the new kbuild.txt file.
This patch reintroduce the ALLSOURCE_ARCHS support for tags/TAGS/
cscope targets. The Kbuild previously has this feature, but after
moving the targets into scripts/tags.sh, ALLSOURCE_ARCHS disappears.
It's something like this:
$ make ALLSOURCE_ARCHS="x86 mips arm" tags cscope
Signed-off-by: Jike Song <albcamus@gmail.com>
Add kbuild.txt to Documentation/kbuild
More stuff can be added later - at least we have
som of the varous environment variables documented now.
