make ALLSOURCE_ARCHS=all tags
- Document this in kbuild.txt
Without this change you have to type each arch separately.
Signed-off-by: John Kacur <jkacur@redhat.com>
Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru>
To make it easier for module-init-tools and scripts like mkinitrd to
distinguish builtin and missing modules, install a modules.builtin file
listing all builtin modules. This is done by generating an additional
config file (tristate.conf) with tristate options set to uppercase 'Y'
or 'M'. If we source that config file, the builtin modules appear in
obj-Y.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
ld-option is used to check if $(LD) supports a specific option.
Based on patch from Andi Kleen.
First use is to check if option -X is supported (upcoming patch).
Theis is ne
ld-option is misnamed as it test options to gcc, not to ld.
Renamed it to reflect this.
Cc: Roland McGrath <roland@redhat.com>
Replace the use of CROSS_COMPILE to select a customized
installkernel script with the possibility to set INSTALLKERNEL
to select a custom installkernel script when running make:
make INSTALLKERNEL=arm-installkernel install
With this patch we are now more consistent across
different architectures - they did not all support use
of CROSS_COMPILE.
The use of CROSS_COMPILE was a hack as this really belongs
to gcc/binutils and the installkernel script does not change
just because we change toolchain.
The use of CROSS_COMPILE caused troubles with an upcoming patch
that saves CROSS_COMPILE when a kernel is built - it would no
longer be installable.
[Thanks to Peter Z. for this hint]
This patch undos what Ian did in commit:
0f8e2d62fa04441cd12c08ce521e84e5bd3f8a46
("use ${CROSS_COMPILE}installkernel in arch/*/boot/install.sh")
The patch has been lightly tested on x86 only - but all changes
looks obvious.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin]
Acked-by: Russell King <linux@arm.linux.org.uk> [arm]
Acked-by: Paul Mundt <lethal@linux-sh.org> [sh]
Acked-by: "H. Peter Anvin" <hpa@zytor.com> [x86]
Cc: Ian Campbell <icampbell@arcom.com>
Cc: Tony Luck <tony.luck@intel.com> [ia64]
Cc: Fenghua Yu <fenghua.yu@intel.com> [ia64]
Cc: Hirokazu Takata <takata@linux-m32r.org> [m32r]
Cc: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Cc: Kyle McMartin <kyle@mcmartin.ca> [parisc]
Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> [powerpc]
Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390]
Cc: Thomas Gleixner <tglx@linutronix.de> [x86]
Cc: Ingo Molnar <mingo@redhat.com> [x86]
All the KCONFIG_ environment variables were previously located in a
section "Environment variables in 'menuconfig'", but neither are they
restricted to 'menuconfig' nor are they all used by 'menuconfig'.
Introduce the following three sections for these variables:
* Environment variables for '*config'
* Environment variables for '{allyes/allmod/allno/rand}config'
* Environment variables for 'silentoldconfig'
Furthermore this puts MENUCONFIG_MODE next to MENUCONFIG_COLOR into a
common section "User interface options for 'menuconfig'".
Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de>
There is an error in the make syntax for one of the kbuild examples
Signed-off-by: David VomLehn <dvomlehn@cisco.com>
Following patch introduce support for setting options
to gcc that has effect for current directory and all
subdirectories.
The typical use case are an architecture or a subsystem that
decide to cover all files with -Werror.
Today alpha, mips and sparc uses -Werror in almost all their
Makefile- with subdir-ccflag-y it is now simpler to do so
as only the top-level directories needs to be covered.
Likewise if we decide to cover a full subsystem such
as net/ with -Werror this is done by adding a single
line to net/Makefile.
xtensa and arm have asked for a possibility to export headers
and locate them in a specific directory when exported.
Introduce destiantion-y to support this.
This patch in additiona adds some limited
documentation for the variables used for exported headers.
Cc: Oskar Schirmer <os@emlix.com>
Cc: Mikael Starvik <mikael.starvik@axis.com>
Fix typos in the new kbuild.txt file.
The text always mentions ...bin.o_shipped, just the example makefiles
actually use ...bin_shipped. It was corrected in one place some time
ago, these ones seem to have been forgotten.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
This patch reintroduce the ALLSOURCE_ARCHS support for tags/TAGS/
cscope targets. The Kbuild previously has this feature, but after
moving the targets into scripts/tags.sh, ALLSOURCE_ARCHS disappears.
It's something like this:
$ make ALLSOURCE_ARCHS="x86 mips arm" tags cscope
Signed-off-by: Jike Song <albcamus@gmail.com>
Add kbuild.txt to Documentation/kbuild
More stuff can be added later - at least we have
som of the varous environment variables documented now.
Create a kconfig user assistance guide, with a few tips and hints
about using menuconfig, xconfig, and gconfig.
Mostly contains user interface, environment variables, and search topics,
along with mini.config/custom.config usage.
There is a bunch of places in the build system where we do 'echo' to show
some nice status lines. This means we still get output when running in
silent mode. So declare a new KECHO variable that only does 'echo' when we
are in a suitable verbose build mode.
[sam: added Documentation]
For the use case the hint describe a simple dependency is
enough.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
While select should be used with care, it is not actually evil.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
This patch adds a new (Kbuild) Makefile variable KBUILD_EXTRA_SYMBOLS.
The space separated list of file names assigned to KBUILD_EXTRA_SYMBOLS
is used when calling scripts/mod/modpost during stage 2 of the Kbuild
process for non-kernel-tree modules.
Signed-off-by: Richard Hacker <lerichi@gmx.net>
It has been discussed on lkml several times but we need
it documented as this is new stuff.
Add the possibility to import a value from the environment into kconfig
via the option syntax. Beside flexibility this has the advantage
providing proper dependencies.
Documented the options syntax.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Add a section on kconfig hints: how to do <something> in Kconfig files.
Fix a few typos/spellos.
Spelling fixes for cc-cross-prefix documentation
Add kconfig-language docs for mainmenu, def_bool, and def_tristate.
Remove "requires" as a synonym of "depends on" since it was removed
from the parser in commit 247537b9a270b52cc0375adcb0fb2605a160cba5.
cc-cross-prefix is useful for the architecture that like
to provide a default CROSS_COMPILE value,
but may have several to select between.
Sample usage:
ifneq ($(SUBARCH),$(ARCH))
ifeq ($(CROSS_COMPILE),)
CROSS_COMPILE := $(call cc-cross-prefix, m68k-linux-gnu- m68k-linux-)
endif
endif
Actual usage by the different archs will taken care of later.
Introduce ccflags-y, asflags-y and ldflags-y so we soon can
deprecate use of EXTRA_CFLAGS, EXTRA_AFLAGS and EXTRA_LDFLAGS.
This patch does not touch any in-tree users - thats next round.
Lets get this committed first and then fix the users of the
soon to be deprecated variants next.
The rationale behind this change is to introduce support for
makefile fragments like:
ccflags-$(CONFIG_WHATEVER_DEBUG) := -DDEBUG
As a replacement for the uglier:
ifeq ($(CONFIG_WHATEVER_DEBUG),y)
EXTRA_CFLAGS := -DDEBUG
endif
The variable CPPFLAGS is a wellknown variable and the usage by
kbuild may result in unexpected behaviour.
This patch replace use of CPPFLAGS with KBUILD_CPPFLAGS all over the
tree and enabling one to use:
make CPPFLAGS=...
to specify additional CPP commandline options.
Patch was tested on following architectures:
alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390
The variable AFLAGS is a wellknown variable and the usage by
On top of that several people over time has asked for a way to
pass in additional flags to gcc.
This patch replace use of AFLAGS with KBUILD_AFLAGS all over
the tree.
The variable CFLAGS is a wellknown variable and the usage by
This patch replace use of CFLAGS with KBUILD_CFLAGS all over the
make CFLAGS=...
to specify additional gcc commandline options.
One usecase is when trying to find gcc bugs but other
use cases has been requested too.
Test was simple to do a defconfig build, apply the patch and check
that nothing got rebuild.
EXTRA_ARFLAGS have never been used so no need to carry
around on this.
A google search did not reveal any external module
using this either.
Small error had sneaked in with respect to use
of LDFLAGS_$@. LDFLAGS_$@ is not valid in normal
kbuild files so do not say so.
Fix a reference bug too.
A warning note from Sam Ravnborg about kconfig's select evilness,
dependencies and the future (slightly corrected).
Signed-off-by: Jarek Poplawski <jarkao2@o2.pl>
Cc: Roman Zippel <zippel@linux-m68k.org>
The Makefile fragment in Documentation/kbuild/modules.txt looks to be
missing some braces.
Fix typos/spellos in kbuild/makefiles.txt.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Standardize the miniscule percentage of occurrences of "depends" in
Kconfig files to "depends on", and update kconfig-language.txt to
reflect that.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
This patch fixes typos in various Documentation txts. The patch addresses some
misc words.
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
While reading this I noticed that the contents of this document list
section "3.8 Command line dependency" but it doesn't exist in the document.
Signed-off-by: Daniel Walker <dwalker@mvista.com>
some words starting with the letter 'S'.
Acked-by: Alan Cox <alan@redhat.com>
Signed-off-by: "Robert P. J. Day" <rpjday@mindspring.com>
... instead of using a CONFIG option. The config option still controls
if the resulting executable actually has unwind information.
This is useful to prevent compilation errors when users select
CONFIG_STACK_UNWIND on old binutils and also allows to use
CFI in the future for non kernel debugging applications.
Cc: jbeulich@novell.com
Cc: sam@ravnborg.org
Signed-off-by: Andi Kleen <ak@suse.de>
I noticed a few typos while reading makefiles.txt to learn about the
kbuild system. Attached is a patch against 2.6.18 to fix them.
Remove trailing whitespace while we are there..
Signed-off-by: Bryce Harrington <bryce@osdl.org>
I have done a look-through through Documentation/kbuild/ and my corrections
(proposed) are attached.
Cc'ed are original author Michael (responsible for comitting changes to
these files?), Sam (kbuild maintainer), Adrian (-trivial maintainer).
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
The latest toolchains can produce a new ELF section in DSOs and
dynamically-linked executables. The new section ".gnu.hash" replaces
".hash", and allows for more efficient runtime symbol lookups by the
dynamic linker. The new ld option --hash-style={sysv|gnu|both} controls
whether to produce the old ".hash", the new ".gnu.hash", or both. In some
new systems such as Fedora Core 6, gcc by default passes --hash-style=gnu
to the linker, so that a standard invocation of "gcc -shared" results in
producing a DSO with only ".gnu.hash". The new ".gnu.hash" sections need
to be dealt with the same way as ".hash" sections in all respects; only the
dynamic linker cares about their contents. To work with older dynamic
linkers (i.e. preexisting releases of glibc), a binary must have the old
".hash" section. The --hash-style=both option produces binaries that a new
dynamic linker can use more efficiently, but an old dynamic linker can
still handle.
The new section runs afoul of the custom linker scripts used to build vDSO
images for the kernel. On ia64, the failure mode for this is a boot-time
panic because the vDSO's PT_IA_64_UNWIND segment winds up ill-formed.
This patch addresses the problem in two ways.
First, it mentions ".gnu.hash" in all the linker scripts alongside ".hash".
This produces correct vDSO images with --hash-style=sysv (or old tools),
with --hash-style=gnu, or with --hash-style=both.
Second, it passes the --hash-style=sysv option when building the vDSO
images, so that ".gnu.hash" is not actually produced. This is the most
conservative choice for compatibility with any old userland. There is some
concern that some ancient glibc builds (though not any known old production
system) might choke on --hash-style=both binaries. The optimizations
provided by the new style of hash section do not really matter for a DSO
with a tiny number of symbols, as the vDSO has. If someone wants to use
=gnu or =both for their vDSO builds and worry less about that
compatibility, just change the option and the linker script changes will
make any choice work fine.
Signed-off-by: Roland McGrath <roland@redhat.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Andi Kleen <ak@muc.de>
Add option for stripping modules while installing them.
This function adds support for stripping modules while they are being
installed. CONFIG_DEBUG_KERNEL (which will probably become more
popular as developers use kdump) causes the size of the installed
modules to grow by a factor of 9 or so.
Some kernel package systems solve this problem by stripping the debug
information from /lib/modules after running "make modules_install",
but that may not work for people who are installing directly into
/lib/modules --- root partitions that were sized to handle 16 megs
worth of modules may not be quite so happy with 145 megs of modules,
so the "make modules_install" never succeeds.
This patch allows such users to request modules_install to strip the
modules as they are installed.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Signed-off-by: Brian Gerst <bgerst@didntduck.org>
