path: root/Documentation/kbuild
2013-02-27Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig changes from Michal Marek: "I forgot to send a pull request in time for the v3.8-rc1 merge window, so the list is a bit longer this time: - menuconfig enables extended colors in ncurses if the wide-character version is used. - CONFIG_ prefix can be specified in the environment to make life easier for people using kconfig multiple times in a single tree (no functional change in the kernel kconfig usage). - kconfig aborts on OOM. - inputboxes in menuconfig allow to move the cursor. - menuconfig has Save/Load buttons now. - xconfig build fix with new g++ and Qt3. - nconfig color scheme fix and help text update. - make oldconfig prints newlines when output is redirected. - some other minor fixes." * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Fix missing '\n' for NEW symbols in yes "" | make oldconfig >conf.new kconfig: nconf: rewrite labels of function keys line kconfig: nconf: rewrite help texts kconfig: fix a compiliation error when using make xconfig nconf: function keys line, change background color for better readability menuconfig: Get rid of the top-level entries for "Load an Alternate/Save an Alternate" menuconfig: Add Save/Load buttons kconfig:lxdialog: remove duplicate code menuconfig:inputbox: support navigate input position kconfig: document use of CONFIG_ environment variable scripts/kconfig: ensure we use proper CONFIG_ prefix merge_config.sh: Add option to specify output dir Revert "kconfig-language: add to hints" kconfig: Regenerate lexer kconfig: Fix malloc handling in conf tools kconfig: get CONFIG_ prefix from the environment kconfig: add a function to get the CONFIG_ prefix kconfig: remove CONFIG_ from string constants menuconfig: fix extended colors ncurses support
2013-02-25Merge branch 'kbuild/rc-fixes' into kbuild/kconfigMichal Marek
There is one kconfig fix in the rc-fixes branch that I forgot to submit for 3.8, so let's add it to the kconfig branch for 3.9-rc1.
2013-02-08kbuild: create a rule to run the pre-processor on *.dts filesStephen Warren
Create cmd_dtc_cpp to run the C pre-processor on *.dts file before passing them to dtc for final compilation. This allows the use of #define and #include within the .dts file. Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Michal Marek <mmarek@suse.cz> Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-12-25kconfig: document use of CONFIG_ environment variableYann E. MORIN
Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-06Revert "kconfig-language: add to hints"Yann E. MORIN
This reverts commit 64b81ed7fb1e45c914317b20316f32827bc6444b. As Martin says about this paragraph: However, I can not reproduce this. The attached file contains both cases. [...] AFAICS, both versions behave equivalently. I suggest changing the documentation accordingly. [in http://marc.info/?l=linux-kbuild&m=134987006202410&w=2] Reported-by: Martin Walch <walch.martin@gmx.de> Cc: Martin Walch <walch.martin@gmx.de> Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-11-30kbuild: centralize .dts->.dtb ruleStephen Warren
All architectures that use cmd_dtc do so in almost the same way. Create a central build rule to avoid duplication. The one difference is that most current uses of dtc build $(obj)/%.dtb from $(src)/dts/%.dts rather than building the .dtb in the same directory as the .dts file. This difference will be eliminated arch-by-arch in future patches. MIPS is the exception here; it already uses the exact same rule as the new common rule, so the duplicate is removed in this patch to avoid any conflict. arch/mips changes courtesy of Ralf Baechle. Update Documentation/kbuild to remove the explicit call to cmd_dtc from the example, now that the rule exists in a centralized location. Cc: Arnd Bergmann <arnd@arndb.de> Cc: linux-arm-kernel@lists.infradead.org Cc: Olof Johansson <olof@lixom.net> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: linux@lists.openrisc.net Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: linux-c6x-dev@linux-c6x.org Cc: Mark Salter <msalter@redhat.com> Cc: Michal Simek <monstr@monstr.eu> Cc: microblaze-uclinux@itee.uq.edu.au Cc: Chris Zankel <chris@zankel.net> Cc: linux-xtensa@linux-xtensa.org Cc: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-11-19doc: fix quite a few typos within DocumentationMasanari Iida
Correct spelling typo in Documentations Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-02UAPI: Remove the objhdr-y export listDavid Howells
Remove the objhdr-y export list as it is no longer used. genhdr-y should be used instead. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-05-28Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig changes from Michal Marek: - Error handling for make KCONFIG_ALLCONFIG=<...> all*config plus a fix for a bug that was exposed by this - Fix for the script/config utility. * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/config: properly report and set string options kbuild: all{no,yes,mod,def,rand}config only read files when instructed to. kconfig: Add error handling to KCONFIG_ALLCONFIG
2012-05-05kbuild: document KBUILD_LDS, KBUILD_VMLINUX_{INIT,MAIN} and LDFLAGS_vmlinuxSam Ravnborg
Newly exported variables - used by link-vmlinux.sh Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-05-05kconfig: Add error handling to KCONFIG_ALLCONFIGEric W. Biederman
- Only try to read the file specified if KCONFIG_ALL_CONFIG is set to something other than the empty string or "1". - Don't use stat to check the name passed to conf_read_simple so that zconf_fopen can find the file in the current directory or in SRCTREE removing a extremely source of confusing failure, where KCONFIG_ALL_CONFIG was not interpreted with respect to the directory make was called in. - If conf_read_simple fails complain clearly and stop processing. Allowing the simple debugging of typos. - Clearly document the behavior so it is clear to users which values are treated as flags and which values are treated as filenames. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-30Documentation: mention scripts/diffconfig toolJavi Merino
The kconfig documentation suggests using plain 'diff' to compare config files and then adds "Yes, we need something better here". Commit a717417e7f96 ("kconfig: add diffconfig utility") added what that comment was looking for. Signed-off-by: Javi Merino <javi.merino@arm.com> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-07Documentation: Fix multiple typo in DocumentationMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-17kbuild: Add support for an "archheaders" targetH. Peter Anvin
Add support for an "archheaders" target. This target can generate files that need to be installed for user space by "make headers_install" or "make headers_install_all". In order to support "make headers_install_all", it must be able to run without the tree having to be configured first. Cc: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-06-13doc: fix wrong arch/i386 referencesWanlong Gao
Change all "arch/i386" to "arch/x86" in Documentaion/, since the directory has changed. Also update the files which have changed their filename in the meantime accordingly. Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com> [jkosina@suse.cz: reword changelog] Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-25Merge branch 'kconfig-for-40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig-for-40' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: xconfig: merge code path to conf_write() kconfig: do not record timestamp in .config gconfig: Hide unused left treeview when start up the interface gconfig: enable rules hint for main treeviews MAINTAINERS: Update KCONFIG entry kconfig-language: add to hints kconfig: Document the new "visible if" syntax kconfig: quiet commands when V=0 kconfig: change update-po-config to reflect new layout of arch/um kconfig: make update-po-config work in KBUILD_OUTPUT kconfig: rearrange clean-files kconfig: change gconf to modify hostprogs-y like nconf and mconf kconfig: change qconf to modify hostprogs-y like nconf and mconf kconfig: only build kxgettext when needed nconfig: Silence unused return values from wattrset kconfig: Do not record timestamp in auto.conf and autoconf.h kconfig: get rid of unused flags kconfig: allow multiple inclusion of the same file kconfig: Avoid buffer underrun in choice input
2011-05-24Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: make KBUILD_NOCMDDEP=1 handle empty built-in.o scripts/kallsyms.c: fix potential segfault scripts/gen_initramfs_list.sh: Convert to a /bin/sh script kbuild: Fix GNU make v3.80 compatibility kbuild: Fix passing -Wno-* options to gcc 4.4+ kbuild: move scripts/basic/docproc.c to scripts/docproc.c kbuild: Fix Makefile.asm-generic for um kbuild: Allow to combine multiple W= levels kbuild: Disable -Wunused-but-set-variable for gcc 4.6.0 Fix handling of backlash character in LINUX_COMPILE_BY name kbuild: asm-generic support kbuild: implement several W= levels kbuild: Fix build with binutils <= 2.19 initramfs: Use KBUILD_BUILD_TIMESTAMP for generated entries kbuild: Allow to override LINUX_COMPILE_BY and LINUX_COMPILE_HOST macros kbuild: Drop unused LINUX_COMPILE_TIME and LINUX_COMPILE_DOMAIN macros kbuild: Use the deterministic mode of ar kbuild: Call gzip with -n kbuild: move KALLSYMS_EXTRA_PASS from Kconfig to Makefile Kconfig: improve KALLSYMS_ALL documentation Fix up trivial conflict in Makefile
2011-05-24kconfig: do not record timestamp in .configArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-03kbuild: Fix passing -Wno-* options to gcc 4.4+Michal Marek
Starting with 4.4, gcc will happily accept -Wno-<anything> in the cc-option test and complain later when compiling a file that has some other warning. This rather unexpected behavior is intentional as per http://gcc.gnu.org/PR28322, so work around it by testing for support of the opposite option (without the no-). Introduce a new Makefile function cc-disable-warning that does this and update two uses of cc-option in the toplevel Makefile. Reported-and-tested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-02kconfig-language: add to hintsRandy Dunlap
Explain a little about kconfig symbol dependencies and symbol existence given optional kconfig language scenarios. Yes, I was bitten by this. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-02kconfig: Document the new "visible if" syntaxMichal Marek
2011-04-28kbuild: asm-generic supportSam Ravnborg
There is an increasing amount of header files shared between individual architectures in asm-generic. To avoid a lot of dummy wrapper files that just include the corresponding file in asm-generic provide some basic support in kbuild for this. With the following patch an architecture can maintain a list of files in the file arch/$(ARCH)/include/asm/Kbuild To use a generic file just add: generic-y += <name-of-header-file.h> For each file listed kbuild will generate the necessary wrapper in arch/$(ARCH)/include/generated/asm. When installing userspace headers a wrapper is likewise created. The original inspiration for this came from the unicore32 patchset - although a different method is used. The patch includes several improvements from Arnd Bergmann. Michael Marek contributed Makefile.asm-generic. Remis Baima did an intial implementation along to achive the same - see https://patchwork.kernel.org/patch/13352/ Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Guan Xuetao <guanxuetao@mprc.pku.edu.cn> Tested-by: Guan Xuetao <guanxuetao@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-04-20kbuild: Fix build with binutils <= 2.19Michal Marek
The D option of ar is only available in newer versions. Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-04-18initramfs: Use KBUILD_BUILD_TIMESTAMP for generated entriesMichal Marek
gen_init_cpio gets the current time and uses it for each symlink, special file, and directory. Grab the current time once and make it possible to override it with the KBUILD_BUILD_TIMESTAMP variable for reproducible builds. Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-04-18kbuild: Allow to override LINUX_COMPILE_BY and LINUX_COMPILE_HOST macrosMichal Marek
Make it possible to override the user@host string displayed during boot and in /proc/version by the environment variables KBUILD_BUILD_USER and KBUILD_BUILD_HOST. Several distributions patch scripts/mkcompile_h to achieve this, so let's provide an official way. Also, document the KBUILD_BUILD_TIMESTAMP variable while at it. Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-21Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: Make DEBUG_SECTION_MISMATCH selectable, but not on by default genksyms: Regenerate lexer and parser genksyms: Track changes to enum constants genksyms: simplify usage of find_symbol() genksyms: Add helpers for building string lists genksyms: Simplify printing of symbol types genksyms: Simplify lexer genksyms: Do not paste the bison header file to lex.c modpost: fix trailing comma KBuild: silence "'scripts/unifdef' is up to date." kbuild: Add extra gcc checks kbuild: reenable section mismatch analysis unifdef: update to upstream version 2.5
2011-03-09kbuild: Add extra gcc checksBorislav Petkov
Add a 'W=1' Makefile switch which adds additional checking per build object. The idea behind this option is targeted at developers who, in the process of writing their code, want to do the occasional make W=1 [target.o] and let gcc do more extensive code checking for them. Then, they could eyeball the output for valid gcc warnings about various bugs/discrepancies which are not reported during the normal build process. For more background information and a use case, read through this thread: http://marc.info/?l=kernel-janitors&m=129802065918147&w=2 Cc: Michal Marek <mmarek@suse.cz> Cc: linux-kbuild@vger.kernel.org Acked-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-02-17kbuild, mtd, net: a few comment typo fixes and rewordingGilles Espinasse
Signed-off-by: Gilles Espinasse <g.esp@free.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-10Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (29 commits) of/flattree: forward declare struct device_node in of_fdt.h ipmi: explicitly include of_address.h and of_irq.h sparc: explicitly cast negative phandle checks to s32 powerpc/405: Fix missing #{address,size}-cells in i2c node powerpc/5200: dts: refactor dts files powerpc/5200: dts: Change combatible strings on localbus powerpc/5200: dts: remove unused properties powerpc/5200: dts: rename nodes to prepare for refactoring dts files of/flattree: Update dtc to current mainline. of/device: Don't register disabled devices powerpc/dts: fix syntax bugs in bluestone.dts of: Fixes for OF probing on little endian systems of: make drivers depend on CONFIG_OF instead of CONFIG_PPC_OF of/flattree: Add of_flat_dt_match() helper function of_serial: explicitly include of_irq.h of/flattree: Refactor unflatten_device_tree and add fdt_unflatten_tree of/flattree: Reorder unflatten_dt_node of/flattree: Refactor unflatten_dt_node of/flattree: Add non-boottime device tree functions of/flattree: Add Kconfig for EARLY_FLATTREE ... Fix up trivial conflict in arch/sparc/prom/tree_32.c as per Grant.
2011-01-10Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: Documentation/kbuild: add info that 'choice' can have a symbol name kbuild: add numeric --set-val option to scripts/config headers_check: Fix warning text headers_check: better search for functions in headers scripts/coccinelle: update for compatability with Coccinelle 0.2.4 tags: put function prototypes back! Kconfig: fix single letter command in scripts/config gitignore: add scripts/recordmcount
2011-01-10Merge branch 'packaging' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'packaging' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: deb-pkg: s/hdr/kernel_headers_/ && s/header/libc_headers_/ deb-pkg: Make deb-pkg generate a seperate linux-libc-dev deb kbuild: create linux-headers package in deb-pkg kbuild, deb-pkg: support overriding userland architecture kbuild, deb-pkg: select userland architecture based on UTS_MACHINE kbuild, deb-pkg: Fix build with paranoid umask
2011-01-10Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: nconf: handle comment entries within choice/endchoice kconfig: fix warning kconfig: Make expr_copy() take a const argument kconfig: simplify select-with-unmet-direct-dependency warning kconfig: add more S_INT and S_HEX consistency checks kconfig: fix `zconfdebug' extern declaration kconfig/conf: merge duplicate switch's case kconfig: fix typos kbuild/gconf: add dummy inline for bind_textdomain_codeset() kbuild/nconf: fix spaces damage kconfig: nuke second argument of conf_write_symbol() kconfig: do not define AUTOCONF_INCLUDED kconfig: the day kconfig warns about "select"-abuse has come
2010-12-23of: Add support for linking device tree blobs into vmlinuxDirk Brandewie
This patch adds support for linking device tree blob(s) into vmlinux. Modifies asm-generic/vmlinux.lds.h to add linking .dtb sections into vmlinux. To maintain compatiblity with the of/fdt driver code platforms MUST copy the blob to a non-init memory location before the kernel frees the .init.* sections in the image. Modifies scripts/Makefile.lib to add a kbuild command to compile DTS files to device tree blobs and a rule to create objects to wrap the blobs for linking. STRUCT_ALIGNMENT is defined in vmlinux.lds.h for use in the rule to create wrapper objects for the dtb in Makefile.lib. The STRUCT_ALIGN() macro in vmlinux.lds.h is modified to use the STRUCT_ALIGNMENT definition. The DTB's are placed on 32 byte boundries to allow parsing the blob with driver/of/fdt.c during early boot without having to copy the blob to get the structure alignment GCC expects. A DTB is linked in by adding the DTB object to the list of objects to be linked into vmlinux in the archtecture specific Makefile using obj-y += foo.dtb.o Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Acked-by: Michal Marek <mmarek@suse.cz> [grant.likely@secretlab.ca: cleaned up whitespace inconsistencies] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-21Documentation/kbuild: add info that 'choice' can have a symbol nameYann E. MORIN
Changeset 5a1aa8a1 added the possibility to name a choice, and to have the same choice be defined multiple times. But the documentation was forgotten, so this updates it accordingly. Thanks to Arnaud Lacombe for pointing it to me in the first place: http://www.spinics.net/lists/linux-kbuild/msg03940.html Signed-off-by: "Yann E. MORIN" <yann.morin.1998@anciens.enib.fr> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-20kbuild, deb-pkg: support overriding userland architectureAsbjoern Sloth Toennesen
Usefull if building for sparc64 userland, because the sparc and sparc64 userlands use the same 64-bit kernel, making it impossible to always select the correct userland architecture for the resulting debian package. Might also be usefull, if you want a i386 userland with a amd64 kernel. Example usage: make KBUILD_DEBARCH=i386 deb-pkg LKML-reference: <alpine.DEB.2.02.1011051437500.13287@aurora.sdinet.de> Signed-off-by: Asbjoern Sloth Toennesen <asbjorn@asbjorn.biz> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-02kconfig: the day kconfig warns about "select"-abuse has comeArnaud Lacombe
CC: catalin.marinas@arm.com Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-28Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (39 commits) Revert "namespace: add source file location exceptions" Coccinelle: Add contextual message Coccinelle: Fix documentation Coccinelle: Find doubled arguments to boolean or bit operators. Coccinelle: Find nested lock+irqsave functions that use the same flags variables. namespace: add source file location exceptions scripts/extract-ikconfig: add support for bzip2, lzma and lzo kbuild: check return value of asprintf() scripts/namespace.pl: improve to get more correct results scripts/namespace.pl: some bug fixes scripts/namespace.pl: update file exclusion list scripts/namespace.pl: fix wrong source path Coccinelle: Use the -no_show_diff option for org and report mode Coccinelle: Add a new mode named 'chain' Coccinelle: Use new comment format to explain kfree.cocci Coccinelle: Improve user information with a new kind of comment Coccinelle: Update documentation MAINTAINERS: Coccinelle: Update email address Documentation/kbuild: modules.txt cleanup Documentation/kbuild: major edit of modules.txt sections 5-8 ...
2010-10-28Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits) kbuild: convert `arch/tile' to the kconfig mainmenu upgrade README: cite nconfig Revert "kconfig: Temporarily disable dependency warnings" kconfig: Use PATH_MAX instead of 128 for path buffer sizes. kconfig: Fix realloc usage() kconfig: Propagate const kconfig: Don't go out from read config loop when you read new symbol kconfig: fix menuconfig on debian lenny kbuild: migrate all arch to the kconfig mainmenu upgrade kconfig: expand file names kconfig: use the file's name of sourced file kconfig: constify file name kconfig: don't emit warning upon rootmenu's prompt redefinition kconfig: replace KERNELVERSION usage by the mainmenu's prompt kconfig: delay gconf window initialization kconfig: expand by default the rootmenu's prompt kconfig: add a symbol string expansion helper kconfig: regen parser kconfig: implement the `mainmenu' directive kconfig: allow PACKAGE to be defined on the compiler's command-line ... Fix up trivial conflict in arch/mn10300/Kconfig
2010-10-28Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: initramfs: Fix build break on symbol-prefixed archs initramfs: fix initramfs size calculation initramfs: generalize initramfs_data.xxx.S variants scripts/kallsyms: Enable error messages while hush up unnecessary warnings scripts/setlocalversion: update comment kbuild: Use a single clean rule for kernel and external modules kbuild: Do not run make clean in $(srctree) scripts/mod/modpost.c: fix commentary accordingly to last changes kbuild: Really don't clean bounds.h and asm-offsets.h
2010-10-28Merge commit 'v2.6.36' into kbuild/miscMichal Marek
Update to be able to fix a recent change to scripts/basic/docproc.c (commit eda603f).
2010-10-12Merge branch 'kbuild/rc-fixes' into kbuild/kconfigMichal Marek
We need to revert the temporary hack in 71ebc01, hence the merge.
2010-10-05Documentation/kbuild: modules.txt cleanupmatt mooney
A few modifications done for consistency, such as adding the shell prompt for command line examples and trailing slash for directories. Also corrects the module include header and fixes a few grammar issues that I introduced. Signed-off-by: matt mooney <mfm@muteddisk.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-09-29Documentation/kbuild: major edit of modules.txt sections 5-8matt mooney
A follow-up to my edit of the first 4 sections. Shift sections down by one due to the deletion of section 3; grammar corrections along with some rewording; margin width cleanup; and change EXTRA_CFLAGS -> ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-09-29Documentation/kbuild: major edit of modules.txt sections 1-4matt mooney
Omit needless words and sentences; reorganize and tighten sentence structure; swap sections 2.2 and 2.3 for a more logical flow; remove section 3, therefore shifting 4->3; add to explanations; and add section on building multiple modules. Signed-off-by: matt mooney <mfm@muteddisk.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-09-19kconfig: implement the `mainmenu' directiveArnaud Lacombe
If specified, the directive must be placed at the top of the Kconfig file. We need to change the grammar to make the mainmenu directive set the `rootmenu' prompt. This reflect how menu_add_prompt() works internally, ie. set the prompt of the `current_entry', pointing originally to `rootmenu'. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Reviewed-by: Michal Marek <mmarek@suse.cz>
2010-09-13Merge branch 'kbuild/clean' into kbuild/kbuildMichal Marek
2010-08-14kbuild: drop unifdef-y supportSam Ravnborg
unifdef-y is not used anymore - drop remaining references Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-05Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (26 commits) kconfig: add savedefconfig kconfig: code refactoring in confdata.c kconfig: refactor code in symbol.c kconfig: add alldefconfig kconfig: print more info when we see a recursive dependency kconfig: save location of config symbols kconfig: change nonint_oldconfig to listnewconfig kconfig: rename loose_nonint_oldconfig => oldnoconfig kconfig: use long options in conf kconfig: fix MODULES-related bug in case of no .config kconfig: make randconfig fair for booleans kconfig: Don't write invisible choice values kbuild: Warn on selecting symbols with unmet direct dependencies scripts:conf.c Fix warning: variable 'type' set but not used menuconfig: truncate list items menuconfig: fix to center checklist correctly in a corner case xconfig: add support to show hidden options which have prompts xconfig: remove unused function xconfig: clean up gconfig: fix null pointer warning ...
