path: root/Documentation/kernel-parameters.txt
2013-03-04doc, kernel-parameters: Document 'console=hvc<n>'Konrad Rzeszutek Wilk
commit a2fd6419174470f5ae6383f5037d0ee21ed9833f upstream. Both the PowerPC hypervisor and Xen hypervisor can utilize the hvc driver. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/1361825650-14031-3-git-send-email-konrad.wilk@oracle.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04doc, xen: Mention 'earlyprintk=xen' in the documentation.Konrad Rzeszutek Wilk
commit 2482a92e7d17187301d7313cfe5021b13393a0b4 upstream. The earlyprintk for Xen PV guests utilizes a simple hypercall (console_io) to provide output to Xen emergency console. Note that the Xen hypervisor should be booted with 'loglevel=all' to output said information. Reported-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/1361825650-14031-2-git-send-email-konrad.wilk@oracle.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-29Merge branch 'for-3.4' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd changes from Bruce Fields: Highlights: - Benny Halevy and Tigran Mkrtchyan implemented some more 4.1 features, moving us closer to a complete 4.1 implementation. - Bernd Schubert fixed a long-standing problem with readdir cookies on ext2/3/4. - Jeff Layton performed a long-overdue overhaul of the server reboot recovery code which will allow us to deprecate the current code (a rather unusual user of the vfs), and give us some needed flexibility for further improvements. - Like the client, we now support numeric uid's and gid's in the auth_sys case, allowing easier upgrades from NFSv2/v3 to v4.x. Plus miscellaneous bugfixes and cleanup. Thanks to everyone! There are also some delegation fixes waiting on vfs review that I suppose will have to wait for 3.5. With that done I think we'll finally turn off the "EXPERIMENTAL" dependency for v4 (though that's mostly symbolic as it's been on by default in distro's for a while). And the list of 4.1 todo's should be achievable for 3.5 as well: http://wiki.linux-nfs.org/wiki/index.php/Server_4.0_and_4.1_issues though we may still want a bit more experience with it before turning it on by default. * 'for-3.4' of git://linux-nfs.org/~bfields/linux: (55 commits) nfsd: only register cld pipe notifier when CONFIG_NFSD_V4 is enabled nfsd4: use auth_unix unconditionally on backchannel nfsd: fix NULL pointer dereference in cld_pipe_downcall nfsd4: memory corruption in numeric_name_to_id() sunrpc: skip portmap calls on sessions backchannel nfsd4: allow numeric idmapping nfsd: don't allow legacy client tracker init for anything but init_net nfsd: add notifier to handle mount/unmount of rpc_pipefs sb nfsd: add the infrastructure to handle the cld upcall nfsd: add a header describing upcall to nfsdcld nfsd: add a per-net-namespace struct for nfsd sunrpc: create nfsd dir in rpc_pipefs nfsd: add nfsd4_client_tracking_ops struct and a way to set it nfsd: convert nfs4_client->cl_cb_flags to a generic flags field NFSD: Fix nfs4_verifier memory alignment NFSD: Fix warnings when NFSD_DEBUG is not defined nfsd: vfs_llseek() with 32 or 64 bit offsets (hashes) nfsd: rename 'int access' to 'int may_flags' in nfsd_open() ext4: return 32/64-bit dir name hash according to usage type fs: add new FMODE flags: FMODE_32bithash and FMODE_64bithash ...
2012-03-26nfsd4: allow numeric idmappingJ. Bruce Fields
Mimic the client side by providing a module parameter that turns off idmapping in the auth_sys case, for backwards compatibility with NFSv2 and NFSv3. Unlike in the client case, we don't have any way to negotiate, since the client can return an error to us if it doesn't like the id that we return to it in (for example) a getattr call. However, it has always been possible for servers to return numeric id's, and as far as we're aware clients have always been able to handle them. Also, in the auth_sys case clients already need to have numeric id's the same between client and server. Therefore we believe it's safe to default this to on; but the module parameter is available to return to previous behavior if this proves to be a problem in some unexpected setup. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-03-26module: add kernel param to force disable module loadDave Young
Sometimes we need to test a kernel of same version with code or config option changes. We already have sysctl to disable module load, but add a kernel parameter will be more convenient. Since modules_disabled is int, so here use bint type in core_param. TODO: make sysctl accept bool and change modules_disabled to bool Signed-off-by: Dave Young <dyoung@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-03-23Merge tag 'ia64-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull miscellaneous Itanium patches from Tony Luck. The conflicts in arch/ia64/hp/sim/simserial.c were due to patches to simserial that had alredy been included (with lots of further cleanups) in the serial tree. * tag 'ia64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: Documentation/kernel-parameters: remove inttest parameter [IA64] Fix ISA IRQ trigger model and polarity setting [IA64] Fix a couple of warnings for EXPORT_SYMBOL [IA64] Check return from device_register() in cx_device_register() [IA64] Fix warning from machine_kexec.c [IA64] simserial, bail out when request_irq fails [IA64] hpsim, initialize chip for assigned irqs [IA64] simserial, include some headers [IA64] hpsim, fix SAL handling in fw-emu [IA64] genirq fixup for SGI/SN [IA64] disable interrupts when exiting from ia64_mca_cmc_int_handler()
2012-03-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci Pull PCI changes (including maintainer change) from Jesse Barnes: "This pull has some good cleanups from Bjorn and Yinghai, as well as some more code from Yinghai to better handle resource re-allocation when enabled. There's also a new initcall_debug feature from Arjan which will print out quirk timing information to help identify slow quirks for fixing or refinement (Yinghai sent in a few patches to do just that once the new debug code landed). Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas. He's been a core PCI and Linux contributor for some time now, and has kindly volunteered to take over. I just don't feel I have the time for PCI review and work that it deserves lately (I've taken on some other projects), and haven't been as responsive lately as I'd like, so I approached Bjorn asking if he'd like to manage things. He's going to give it a try, and I'm confident he'll do at least as well as I have in keeping the tree managed, patches flowing, and keeping things stable." Fix up some fairly trivial conflicts due to other cleanups (mips device resource fixup cleanups clashing with list handling cleanup, ppc iseries removal clashing with pci_probe_only cleanup etc) * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits) PCI: Bjorn gets PCI hotplug too PCI: hand PCI maintenance over to Bjorn Helgaas unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h sparc/PCI: convert devtree and arch-probed bus addresses to resource powerpc/PCI: allow reallocation on PA Semi powerpc/PCI: convert devtree bus addresses to resource powerpc/PCI: compute I/O space bus-to-resource offset consistently arm/PCI: don't export pci_flags PCI: fix bridge I/O window bus-to-resource conversion x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()' PCI / PCIe: Introduce command line option to disable ARI PCI: make acpihp use __pci_remove_bus_device instead PCI: export __pci_remove_bus_device PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device PCI: print out PCI device info along with duration PCI: Move "pci reassigndev resource alignment" out of quirks.c PCI: Use class for quirk for usb host controller fixup PCI: Use class for quirk for ti816x class fixup PCI: Use class for quirk for intel e100 interrupt fixup ...
2012-03-23Merge tag 'nfs-for-3.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates for Linux 3.4 from Trond Myklebust: "New features include: - Add NFS client support for containers. This should enable most of the necessary functionality, including lockd support, and support for rpc.statd, NFSv4 idmapper and RPCSEC_GSS upcalls into the correct network namespace from which the mount system call was issued. - NFSv4 idmapper scalability improvements Base the idmapper cache on the keyring interface to allow concurrent access to idmapper entries. Start the process of migrating users from the single-threaded daemon-based approach to the multi-threaded request-key based approach. - NFSv4.1 implementation id. Allows the NFSv4.1 client and server to mutually identify each other for logging and debugging purposes. - Support the 'vers=4.1' mount option for mounting NFSv4.1 instead of having to use the more counterintuitive 'vers=4,minorversion=1'. - SUNRPC tracepoints. Start the process of adding tracepoints in order to improve debugging of the RPC layer. - pNFS object layout support for autologin. Important bugfixes include: - Fix a bug in rpc_wake_up/rpc_wake_up_status that caused them to fail to wake up all tasks when applied to priority waitqueues. - Ensure that we handle read delegations correctly, when we try to truncate a file. - A number of fixes for NFSv4 state manager loops (mostly to do with delegation recovery)." * tag 'nfs-for-3.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (224 commits) NFS: fix sb->s_id in nfs debug prints xprtrdma: Remove assumption that each segment is <= PAGE_SIZE xprtrdma: The transport should not bug-check when a dup reply is received pnfs-obj: autologin: Add support for protocol autologin NFS: Remove nfs4_setup_sequence from generic rename code NFS: Remove nfs4_setup_sequence from generic unlink code NFS: Remove nfs4_setup_sequence from generic read code NFS: Remove nfs4_setup_sequence from generic write code NFS: Fix more NFS debug related build warnings SUNRPC/LOCKD: Fix build warnings when CONFIG_SUNRPC_DEBUG is undefined nfs: non void functions must return a value SUNRPC: Kill compiler warning when RPC_DEBUG is unset SUNRPC/NFS: Add Kbuild dependencies for NFS_DEBUG/RPC_DEBUG NFS: Use cond_resched_lock() to reduce latencies in the commit scans NFSv4: It is not safe to dereference lsp->ls_state in release_lockowner NFS: ncommit count is being double decremented SUNRPC: We must not use list_for_each_entry_safe() in rpc_wake_up() Try using machine credentials for RENEW calls NFSv4.1: Fix a few issues in filelayout_commit_pagelist NFSv4.1: Clean ups and bugfixes for the pNFS read/writeback/commit code ...
2012-03-22Documentation/kernel-parameters: remove inttest parameterSebastian Andrzej Siewior
According to grep I see no users: | #git grep inttest | Documentation/kernel-parameters.txt: inttest= [IA-64] The parameters itself has no description what it supposed to do. According to the history tree, it was introduced in "[PATCH] Updated Documentation/kernel-parameters.txt" ("10414c6ddb"). By that time that parameter had an user. It was removed later by "[PATCH] ia64: SGI SN update" ("c6bacd5010ec") by Jesse Barnes himself. Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-03-22Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm main changes from Dave Airlie: "This is the main drm pull request, I'm probably going to send two more smaller ones, will explain below. This contains a patch that is also in the fbdev tree, but it should be the same patch, it added an API for hot unplugging framebuffer devices, and I need that API for a new driver. It also contains some changes to the i2c tree which Jean has acked, and one change to moorestown platform stuff in x86. Highlights: - new drivers: UDL driver for USB displaylink devices, kms only, should support correct hotplug operations. - core: i2c speedups + better hotplug support, EDID overriding via firmware interface - allows user to load a firmware for a broken monitor/kvm from userspace, it even has documentation for it. - exynos: new HDMI audio + hdmi 1.4 + virtual output driver - gma500: code cleanup - radeon: cleanups, CS optimisations, streamout support and pageflip fix - nouveau: NVD9 displayport support + more reclocking work - i915: re-enabling GMBUS, finish gpu patch (might help hibernation who knows), missed irq fixes, stencil tiling fixes, interlaced support, aliasesd PPGTT support for SNB/IVB, swizzling for SNB/IVB, semaphore fixes As well as the usual bunch of cleanups and fixes all over the place. I've got two things I'd like to merge a bit later: a) AMD support for all their new radeonhd 7000 series GPU and APUs. AMD dropped this a bit late due to insane internal review processes, (please AMD just follow Intel and let open source guys ship stuff early) however I don't want to penalise people who own this hardware (since its been on sale for 3-4 months and GPU hw doesn't exactly have a lifetime in years) and consign them to using closed drivers for longer than necessary. The changes are well contained and just plug into the driver new gpu functionality so they should be fairly regression proof. I just want to give them a bit of a run on the hw AMD kindly sent me. b) drm prime/dma-buf interface code. This is just infrastructure code to expose the dma-buf stuff to drm drivers and to userspace. I'm not planning on pushing any driver support in this cycle (except maybe exynos), but I'd like to get the infrastructure code in so for the next cycle I can start getting the driver support into the individual drivers. We have started driver support for i915, nouveau and udl along with I think exynos and omap in staging. However this code relies on the dma-buf tree being pulled into your tree first since it needs the latest interfaces from that tree. I'll push to get that tree sent asap. (oh and any warnings you see in i915 are gcc's fault from what anyone can see)." Fix up trivial conflicts in arch/x86/platform/mrst/mrst.c due to the new msic_thermal_platform_data() thermal function being added next to the tc35876x_platform_data() i2c device function.. * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (326 commits) drm/i915: use DDC_ADDR instead of hard-coding it drm/radeon: use DDC_ADDR instead of hard-coding it drm: remove unneeded redefinition of DDC_ADDR drm/exynos: added virtual display driver. drm: allow loading an EDID as firmware to override broken monitor drm/exynos: enable hdmi audio feature drm/exynos: add default pixel format for plane drm/exynos: cleanup exynos_hdmi.h drm/exynos: add is_local member in exynos_drm_subdrv struct drm/exynos: add subdrv open/close functions drm/exynos: remove module of exynos drm subdrv drm/exynos: release pending pageflip events when closed drm/exynos: added new funtion to get/put dma address. drm/exynos: update gem and buffer framework. drm/exynos: added mode_fixup feature and code clean. drm/exynos: add HDMI version 1.4 support drm/exynos: remove exynos_mixer.h gma500: Fix mmap frambuffer drm/radeon: Drop radeon_gem_object_(un)pin. drm/radeon: Restrict offset for legacy display engine. ...
2012-03-21thp: documentation: 'transparent_hugepage=' can also be specified on cmdlineJiri Kosina
The behavior of THP can either be toggled through sysfs in runtime or using a kernel cmdline parameter 'transparent_hugepage='. Document the latter in kernel-parameters.txt Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21pnfs-obj: autologin: Add support for protocol autologinSachin Bhamare
The pnfs-objects protocol mandates that we autologin into devices not present in the system, according to information specified in the get_device_info returned from the server. The Protocol specifies two login hints. 1. An IP address:port combination 2. A string URI which is constructed as a URL with a protocol prefix followed by :// and a string as address. For each protocol prefix the string-address format might be different. We only support the second option. The first option is just redundant to the second one. NOTE: The Kernel part of autologin does not parse the URI string. It just channels it to a user-mode script. So any new login protocols should only update the user-mode script which is a part of the nfs-utils package, but the Kernel need not change. We implement the autologin by using the call_usermodehelper() API. (Thanks to Steve Dickson <steved@redhat.com> for pointing it out) So there is no running daemon needed, and/or special setup. We Add the osd_login_prog Kernel module parameters which defaults to: /sbin/osd_login Kernel try's to upcall the program specified in osd_login_prog. If the file is not found or the execution fails Kernel will disable any farther upcalls, by zeroing out osd_login_prog, Until Admin re-enables it by setting the osd_login_prog parameter to a proper program. Also add text about the osd_login program command line API to: Documentation/filesystems/nfs/pnfs.txt and documentation of the new osd_login_prog module parameter to: Documentation/kernel-parameters.txt TODO: Add timeout option in the case osd_login program gets stuck Signed-off-by: Sachin Bhamare <sbhamare@panasas.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-03-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "It's indeed trivial -- mostly documentation updates and a bunch of typo fixes from Masanari. There are also several linux/version.h include removals from Jesper." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits) kcore: fix spelling in read_kcore() comment constify struct pci_dev * in obvious cases Revert "char: Fix typo in viotape.c" init: fix wording error in mm_init comment usb: gadget: Kconfig: fix typo for 'different' Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c" writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header writeback: fix typo in the writeback_control comment Documentation: Fix multiple typo in Documentation tpm_tis: fix tis_lock with respect to RCU Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c" Doc: Update numastat.txt qla4xxx: Add missing spaces to error messages compiler.h: Fix typo security: struct security_operations kerneldoc fix Documentation: broken URL in libata.tmpl Documentation: broken URL in filesystems.tmpl mtd: simplify return logic in do_map_probe() mm: fix comment typo of truncate_inode_pages_range power: bq27x00: Fix typos in comment ...
2012-03-20drm: allow loading an EDID as firmware to override broken monitorCarsten Emde
Broken monitors and/or broken graphic boards may send erroneous or no EDID data. This also applies to broken KVM devices that are unable to correctly forward the EDID data of the connected monitor but invent their own fantasy data. This patch allows to specify an EDID data set to be used instead of probing the monitor for it. It contains built-in data sets of frequently used screen resolutions. In addition, a particular EDID data set may be provided in the /lib/firmware directory and loaded via the firmware interface. The name is passed to the kernel as module parameter of the drm_kms_helper module either when loaded options drm_kms_helper edid_firmware=edid/1280x1024.bin or as kernel commandline parameter drm_kms_helper.edid_firmware=edid/1280x1024.bin It is also possible to restrict the usage of a specified EDID data set to a particular connector. This is done by prepending the name of the connector to the name of the EDID data set using the syntax edid_firmware=[<connector>:]<edid> such as, for example, edid_firmware=DVI-I-1:edid/1920x1080.bin in which case no other connector will be affected. The built-in data sets are Resolution Name -------------------------------- 1024x768 edid/1024x768.bin 1280x1024 edid/1280x1024.bin 1680x1050 edid/1680x1050.bin 1920x1080 edid/1920x1080.bin They are ignored, if a file with the same name is available in the /lib/firmware directory. The built-in EDID data sets are based on standard timings that may not apply to a particular monitor and even crash it. Ideally, EDID data of the connected monitor should be used. They may be obtained through the drm/cardX/cardX-<connector>/edid entry in the /sys/devices PCI directory of a correctly working graphics adapter. It is even possible to specify the name of an EDID data set on-the-fly via the /sys/module interface, e.g. echo edid/myedid.bin >/sys/module/drm_kms_helper/parameters/edid_firmware The new screen mode is considered when the related kernel function is called for the first time after the change. Such calls are made when the X server is started or when the display settings dialog is opened in an already running X server. Signed-off-by: Carsten Emde <C.Emde@osadl.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-05kmsg_dump: don't run on non-error paths by defaultMatthew Garrett
Since commit 04c6862c055f ("kmsg_dump: add kmsg_dump() calls to the reboot, halt, poweroff and emergency_restart paths"), kmsg_dump() gets run on normal paths including poweroff and reboot. This is less than ideal given pstore implementations that can only represent single backtraces, since a reboot may overwrite a stored oops before it's been picked up by userspace. In addition, some pstore backends may have low performance and provide a significant delay in reboot as a result. This patch adds a printk.always_kmsg_dump kernel parameter (which can also be changed from userspace). Without it, the code will only be run on failure paths rather than on normal paths. The option can be enabled in environments where there's a desire to attempt to audit whether or not a reboot was cleanly requested or not. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Seiji Aguchi <seiji.aguchi@hds.com> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Marco Stornelli <marco.stornelli@gmail.com> Cc: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Don Zickus <dzickus@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-01NFSv4: Send implementation id with exchange_idWeston Andros Adamson
Send the nfs implementation id in EXCHANGE_ID requests unless the module parameter nfs.send_implementation_id is 0. This adds a CONFIG variable for the nii_domain that defaults to "kernel.org". Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-03-01PCI / PCIe: Introduce command line option to disable ARIRafael J. Wysocki
There are PCIe devices on the market that report ARI support but then fail to initialize correctly when ARI is actually used. This leads to situations in which kernels 2.6.34 and newer fail to handle systems where the previous kernels worked without any apparent problems. Unfortunately, it is currently unknown how many such devices are there. For this reason, introduce a new kernel command line option, pci=noari, allowing users to disable PCIe ARI altogether if they see problems with PCIe device initialization. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-02-24PCI: prepare pci=realloc for multiple optionsYinghai Lu
Let the user could enable and disable with pci=realloc=on or pci=realloc=off Also 1. move variable and functions near the place they are used. 2. change macro to function 3. change related functions and variable to static and _init 4. update parameter description accordingly. This will let us add a config option to control default behavior, and still allow the user to turn off automatic reallocation if it fails on their platform until a permanent solution is found. -v2: still honor pci=realloc, and treat it as pci=realloc=on also use enum instead of ... -v3: update kernel-paramenters.txt according to Jesse. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-02-23PCI: Add pcie_hp=nomsi to disable MSI/MSI-X for pciehp driverMUNEDA Takahiro
Add a parameter to avoid using MSI/MSI-X for PCIe native hotplug; it's known to be buggy on some platforms. In my environment, while shutting down, following stack trace is shown sometimes. irq 16: nobody cared (try booting with the "irqpoll" option) Pid: 1081, comm: reboot Not tainted 3.2.0 #1 Call Trace: <IRQ> [<ffffffff810cec1d>] __report_bad_irq+0x3d/0xe0 [<ffffffff810cee1c>] note_interrupt+0x15c/0x210 [<ffffffff810cc485>] handle_irq_event_percpu+0xb5/0x210 [<ffffffff810cc621>] handle_irq_event+0x41/0x70 [<ffffffff810cf675>] handle_fasteoi_irq+0x55/0xc0 [<ffffffff81015356>] handle_irq+0x46/0xb0 [<ffffffff814fbe9d>] do_IRQ+0x5d/0xe0 [<ffffffff814f146e>] common_interrupt+0x6e/0x6e [<ffffffff8106b040>] ? __do_softirq+0x60/0x210 [<ffffffff8108aeb1>] ? hrtimer_interrupt+0x151/0x240 [<ffffffff814fb5ec>] call_softirq+0x1c/0x30 [<ffffffff810152d5>] do_softirq+0x65/0xa0 [<ffffffff8106ae9d>] irq_exit+0xbd/0xe0 [<ffffffff814fbf8e>] smp_apic_timer_interrupt+0x6e/0x99 [<ffffffff814f9e5e>] apic_timer_interrupt+0x6e/0x80 <EOI> [<ffffffff814f0fb1>] ? _raw_spin_unlock_irqrestore+0x11/0x20 [<ffffffff812629fc>] pci_bus_write_config_word+0x6c/0x80 [<ffffffff81266fc2>] pci_intx+0x52/0xa0 [<ffffffff8127de3d>] pci_intx_for_msi+0x1d/0x30 [<ffffffff8127e4fb>] pci_msi_shutdown+0x7b/0x110 [<ffffffff81269d34>] pci_device_shutdown+0x34/0x50 [<ffffffff81326c4f>] device_shutdown+0x2f/0x140 [<ffffffff8107b981>] kernel_restart_prepare+0x31/0x40 [<ffffffff8107b9e6>] kernel_restart+0x16/0x60 [<ffffffff8107bbfd>] sys_reboot+0x1ad/0x220 [<ffffffff814f4b90>] ? do_page_fault+0x1e0/0x460 [<ffffffff811942d0>] ? __sync_filesystem+0x90/0x90 [<ffffffff8105c9aa>] ? __cond_resched+0x2a/0x40 [<ffffffff814ef090>] ? _cond_resched+0x30/0x40 [<ffffffff81169e17>] ? iterate_supers+0xb7/0xd0 [<ffffffff814f9382>] system_call_fastpath+0x16/0x1b handlers: [<ffffffff8138a0f0>] usb_hcd_irq [<ffffffff8138a0f0>] usb_hcd_irq [<ffffffff8138a0f0>] usb_hcd_irq Disabling IRQ #16 An un-wanted interrupt is generated when PCI driver switches from MSI/MSI-X to INTx while shutting down the device. The interrupt does not happen if MSI/MSI-X is not used on the device. I confirmed that this problem does not happen if pcie_hp=nomsi was specified and hotplug operation worked fine as usual. v2: Automatically disable MSI/MSI-X against following device: PCI bridge: Integrated Device Technology, Inc. Device 807f (rev 02) v3: Based on the review comment, combile the if statements. v4: Removed module parameter. Move some code to build pciehp as a module. Move device specific code to driver/pci/quirks.c. v5: Drop a device specific code until getting a vendor statement. Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: MUNEDA Takahiro <muneda.takahiro@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-02-21Documentation: Fix typo in kernel-parameters.txtMasanari Iida
Correct spelling "mininum" to "minimum", "conroller" to "controller" and "explicitely" to "explicitly" in Documentation/kernel-parameters.txt Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-02-15NFSv4.1: Add a module parameter to set the number of session slotsTrond Myklebust
Add the module parameter 'max_session_slots' to set the initial number of slots that the NFSv4.1 client will attempt to negotiate with the server. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-01-18Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux This includes initial support for the recently published ACPI 5.0 spec. In particular, support for the "hardware-reduced" bit that eliminates the dependency on legacy hardware. APEI has patches resulting from testing on real hardware. Plus other random fixes. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (52 commits) acpi/apei/einj: Add extensions to EINJ from rev 5.0 of acpi spec intel_idle: Split up and provide per CPU initialization func ACPI processor: Remove unneeded variable passed by acpi_processor_hotadd_init V2 ACPI processor: Remove unneeded cpuidle_unregister_driver call intel idle: Make idle driver more robust intel_idle: Fix a cast to pointer from integer of different size warning in intel_idle ACPI: kernel-parameters.txt : Add intel_idle.max_cstate intel_idle: remove redundant local_irq_disable() call ACPI processor: Fix error path, also remove sysdev link ACPI: processor: fix acpi_get_cpuid for UP processor intel_idle: fix API misuse ACPI APEI: Convert atomicio routines ACPI: Export interfaces for ioremapping/iounmapping ACPI registers ACPI: Fix possible alignment issues with GAS 'address' references ACPI, ia64: Use SRAT table rev to use 8bit or 16/32bit PXM fields (ia64) ACPI, x86: Use SRAT table rev to use 8bit or 32bit PXM fields (x86/x86-64) ACPI: Store SRAT table revision ACPI, APEI, Resolve false conflict between ACPI NVS and APEI ACPI, Record ACPI NVS regions ACPI, APEI, EINJ, Refine the fix of resource conflict ...
2012-01-17ACPI: kernel-parameters.txt : Add intel_idle.max_cstateMasanari Iida
Add missing intel_idle.max_cstate in kernel-parameters.txt Signed-off-by Masanari Iida <standby24x7@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-15Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (39 commits) perf tools: Fix compile error on x86_64 Ubuntu perf report: Fix --stdio output alignment when --showcpuutilization used perf annotate: Get rid of field_sep check perf annotate: Fix usage string perf kmem: Fix a memory leak perf kmem: Add missing closedir() calls perf top: Add error message for EMFILE perf test: Change type of '-v' option to INCR perf script: Add missing closedir() calls tracing: Fix compile error when static ftrace is enabled recordmcount: Fix handling of elf64 big-endian objects. perf tools: Add const.h to MANIFEST to make perf-tar-src-pkg work again perf tools: Add support for guest/host-only profiling perf kvm: Do guest-only counting by default perf top: Don't update total_period on process_sample perf hists: Stop using 'self' for struct hist_entry perf hists: Rename total_session to total_period x86: Add counter when debug stack is used with interrupts enabled x86: Allow NMIs to hit breakpoints in i386 x86: Keep current stack in NMI breakpoints ...
2012-01-11Merge branch 'x86-debug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, reboot: Fix typo in nmi reboot path x86, NMI: Add to_cpumask() to silence compile warning x86, NMI: NMI selftest depends on the local apic x86: Add stack top margin for stack overflow checking x86, NMI: NMI-selftest should handle the UP case properly x86: Fix the 32-bit stackoverflow-debug build x86, NMI: Add knob to disable using NMI IPIs to stop cpus x86, NMI: Add NMI IPI selftest x86, reboot: Use NMI instead of REBOOT_VECTOR to stop cpus x86: Clean up the range of stack overflow checking x86: Panic on detection of stack overflow x86: Check stack overflow in detail
2012-01-11Merge branch 'slab/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux * 'slab/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: slub: disallow changing cpu_partial from userspace for debug caches slub: add missed accounting slub: Extract get_freelist from __slab_alloc slub: Switch per cpu partial page support off for debugging slub: fix a possible memleak in __slab_alloc() slub: fix slub_max_order Documentation slub: add missed accounting slab: add taint flag outputting to debug paths. slub: add taint flag outputting to debug paths slab: introduce slab_max_order kernel parameter slab: rename slab_break_gfp_order to slab_max_order
2012-01-11Merge branch 'slab/urgent' into slab/for-linusPekka Enberg
2012-01-10Merge branch 'akpm' (aka "Andrew's patch-bomb")Linus Torvalds
Andrew elucidates: - First installmeant of MM. We have a HUGE number of MM patches this time. It's crazy. - MAINTAINERS updates - backlight updates - leds - checkpatch updates - misc ELF stuff - rtc updates - reiserfs - procfs - some misc other bits * akpm: (124 commits) user namespace: make signal.c respect user namespaces workqueue: make alloc_workqueue() take printf fmt and args for name procfs: add hidepid= and gid= mount options procfs: parse mount options procfs: introduce the /proc/<pid>/map_files/ directory procfs: make proc_get_link to use dentry instead of inode signal: add block_sigmask() for adding sigmask to current->blocked sparc: make SA_NOMASK a synonym of SA_NODEFER reiserfs: don't lock root inode searching reiserfs: don't lock journal_init() reiserfs: delay reiserfs lock until journal initialization reiserfs: delete comments referring to the BKL drivers/rtc/interface.c: fix alarm rollover when day or month is out-of-range drivers/rtc/rtc-twl.c: add DT support for RTC inside twl4030/twl6030 drivers/rtc/: remove redundant spi driver bus initialization drivers/rtc/rtc-jz4740.c: make jz4740_rtc_driver static drivers/rtc/rtc-mc13xxx.c: make mc13xxx_rtc_idtable static rtc: convert drivers/rtc/* to use module_platform_driver() drivers/rtc/rtc-wm831x.c: convert to devm_kzalloc() drivers/rtc/rtc-wm831x.c: remove unused period IRQ handler ...
2012-01-10mm: more intensive memory corruption debuggingStanislaw Gruszka
With CONFIG_DEBUG_PAGEALLOC configured, the CPU will generate an exception on access (read,write) to an unallocated page, which permits us to catch code which corrupts memory. However the kernel is trying to maximise memory usage, hence there are usually few free pages in the system and buggy code usually corrupts some crucial data. This patch changes the buddy allocator to keep more free/protected pages and to interlace free/protected and allocated pages to increase the probability of catching corruption. When the kernel is compiled with CONFIG_DEBUG_PAGEALLOC, debug_guardpage_minorder defines the minimum order used by the page allocator to grant a request. The requested size will be returned with the remaining pages used as guard pages. The default value of debug_guardpage_minorder is zero: no change from current behaviour. [akpm@linux-foundation.org: tweak documentation, s/flg/flag/] Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10Merge branch 'nfs-for-3.3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
* 'nfs-for-3.3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFSv4: Change the default setting of the nfs4_disable_idmapping parameter NFSv4: Save the owner/group name string when doing open NFS: Remove pNFS bloat from the generic write path pnfs-obj: Must return layout on IO error pnfs-obj: pNFS errors are communicated on iodata->pnfs_error NFS: Cache state owners after files are closed NFS: Clean up nfs4_find_state_owners_locked() NFSv4: include bitmap in nfsv4 get acl data nfs: fix a minor do_div portability issue NFSv4.1: cleanup comment and debug printk NFSv4.1: change nfs4_free_slot parameters for dynamic slots NFSv4.1: cleanup init and reset of session slot tables NFSv4.1: fix backchannel slotid off-by-one bug nfs: fix regression in handling of context= option in NFSv4 NFS - fix recent breakage to NFS error handling. NFS: Retry mounting NFSROOT SUNRPC: Clean up the RPCSEC_GSS service ticket requests
2012-01-10Merge branch 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommuLinus Torvalds
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (53 commits) iommu/amd: Set IOTLB invalidation timeout iommu/amd: Init stats for iommu=pt iommu/amd: Remove unnecessary cache flushes in amd_iommu_resume iommu/amd: Add invalidate-context call-back iommu/amd: Add amd_iommu_device_info() function iommu/amd: Adapt IOMMU driver to PCI register name changes iommu/amd: Add invalid_ppr callback iommu/amd: Implement notifiers for IOMMUv2 iommu/amd: Implement IO page-fault handler iommu/amd: Add routines to bind/unbind a pasid iommu/amd: Implement device aquisition code for IOMMUv2 iommu/amd: Add driver stub for AMD IOMMUv2 support iommu/amd: Add stat counter for IOMMUv2 events iommu/amd: Add device errata handling iommu/amd: Add function to get IOMMUv2 domain for pdev iommu/amd: Implement function to send PPR completions iommu/amd: Implement functions to manage GCR3 table iommu/amd: Implement IOMMUv2 TLB flushing routines iommu/amd: Add support for IOMMUv2 domain mode iommu/amd: Add amd_iommu_domain_direct_map function ...
2012-01-10Merge branch 'kvm-updates/3.3' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/3.3' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (74 commits) KVM: PPC: Whitespace fix for kvm.h KVM: Fix whitespace in kvm_para.h KVM: PPC: annotate kvm_rma_init as __init KVM: x86 emulator: implement RDPMC (0F 33) KVM: x86 emulator: fix RDPMC privilege check KVM: Expose the architectural performance monitoring CPUID leaf KVM: VMX: Intercept RDPMC KVM: SVM: Intercept RDPMC KVM: Add generic RDPMC support KVM: Expose a version 2 architectural PMU to a guests KVM: Expose kvm_lapic_local_deliver() KVM: x86 emulator: Use opcode::execute for Group 9 instruction KVM: x86 emulator: Use opcode::execute for Group 4/5 instructions KVM: x86 emulator: Use opcode::execute for Group 1A instruction KVM: ensure that debugfs entries have been created KVM: drop bsp_vcpu pointer from kvm struct KVM: x86: Consolidate PIT legacy test KVM: x86: Do not rely on implicit inclusions KVM: Make KVM_INTEL depend on CPU_SUP_INTEL KVM: Use memdup_user instead of kmalloc/copy_from_user ...
2012-01-09Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (232 commits) USB: Add USB-ID for Multiplex RC serial adapter to cp210x.c xhci: Clean up 32-bit build warnings. USB: update documentation for usbmon usb: usb-storage doesn't support dynamic id currently, the patch disables the feature to fix an oops drivers/usb/class/cdc-acm.c: clear dangling pointer drivers/usb/dwc3/dwc3-pci.c: introduce missing kfree drivers/usb/host/isp1760-if.c: introduce missing kfree usb: option: add ZD Incorporated HSPA modem usb: ch9: fix up MaxStreams helper USB: usb-skeleton.c: cleanup open_count USB: usb-skeleton.c: fix open/disconnect race xhci: Properly handle COMP_2ND_BW_ERR USB: remove dead code from suspend/resume path USB: add quirk for another camera drivers: usb: wusbcore: Fix dependency for USB_WUSB xhci: Better debugging for critical host errors. xhci: Be less verbose during URB cancellation. xhci: Remove debugging about ring structure allocation. xhci: Remove debugging about toggling cycle bits. xhci: Remove debugging for individual transfers. ...
2012-01-09NFSv4: Change the default setting of the nfs4_disable_idmapping parameterTrond Myklebust
Now that the use of numeric uids/gids is officially sanctioned in RFC3530bis, it is time to change the default here to 'enabled'. By doing so, we ensure that NFSv4 copies the behaviour of NFSv3 when we're using the default AUTH_SYS authentication (i.e. when the client uses the numeric uids/gids as authentication tokens), so that when new files are created, they will appear to have the correct user/group. It also fixes a number of backward compatibility issues when migrating from NFSv3 to NFSv4 on a platform where the server uses different uid/gid mappings than the client. Note also that this setting has been successfully tested against servers that do not support numeric uids/gids at several Connectathon/Bakeathon events at this point, and the fall back to using string names/groups has been shown to work well in all those test cases. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-01-09Merge branches 'iommu/page-sizes' and 'iommu/group-id' into nextJoerg Roedel
Conflicts: drivers/iommu/amd_iommu.c drivers/iommu/intel-iommu.c include/linux/iommu.h
2012-01-08Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/core
2012-01-06Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) x86: Fix atomic64_xxx_cx8() functions x86: Fix and improve cmpxchg_double{,_local}() x86_64, asm: Optimise fls(), ffs() and fls64() x86, bitops: Move fls64.h inside __KERNEL__ x86: Fix and improve percpu_cmpxchg{8,16}b_double() x86: Report cpb and eff_freq_ro flags correctly x86/i386: Use less assembly in strlen(), speed things up a bit x86: Use the same node_distance for 32 and 64-bit x86: Fix rflags in FAKE_STACK_FRAME x86: Clean up and extend do_int3() x86: Call do_notify_resume() with interrupts enabled x86/div64: Add a micro-optimization shortcut if base is power of two x86-64: Cleanup some assembly entry points x86-64: Slightly shorten line system call entry and exit paths x86-64: Reduce amount of redundant code generated for invalidate_interruptNN x86-64: Slightly shorten int_ret_from_sys_call x86, efi: Convert efi_phys_get_time() args to physical addresses x86: Default to vsyscall=emulate x86-64: Set siginfo and context on vsyscall emulation faults x86: consolidate xchg and xadd macros ...
2012-01-04Merge commit 'v3.2-rc7' into x86/asmIngo Molnar
Merge reason: Update from -rc4 to -rc7. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-27Merge remote-tracking branch 'tip/perf/core' into kvm-updates/3.3Avi Kivity
* tip/perf/core: (66 commits) perf, x86: Expose perf capability to other modules perf, x86: Implement arch event mask as quirk x86, perf: Disable non available architectural events jump_label: Provide jump_label_key initializers jump_label, x86: Fix section mismatch perf, core: Rate limit perf_sched_events jump_label patching perf: Fix enable_on_exec for sibling events perf: Remove superfluous arguments perf, x86: Prefer fixed-purpose counters when scheduling perf, x86: Fix event scheduler for constraints with overlapping counters perf, x86: Implement event scheduler helper functions perf: Avoid a useless pmu_disable() in the perf-tick x86/tools: Add decoded instruction dump mode x86: Update instruction decoder to support new AVX formats x86/tools: Fix insn_sanity message outputs x86/tools: Fix instruction decoder message output x86: Fix instruction decoder to handle grouped AVX instructions x86/tools: Fix Makefile to build all test tools perf test: Soft errors shouldn't stop the "Validate PERF_RECORD_" test perf test: Validate PERF_RECORD_ events and perf_sample fields ... Signed-off-by: Avi Kivity <avi@redhat.com> * commit 'b3d9468a8bd218a695e3a0ff112cd4efd27b670a': (66 commits) perf, x86: Expose perf capability to other modules perf, x86: Implement arch event mask as quirk x86, perf: Disable non available architectural events jump_label: Provide jump_label_key initializers jump_label, x86: Fix section mismatch perf, core: Rate limit perf_sched_events jump_label patching perf: Fix enable_on_exec for sibling events perf: Remove superfluous arguments perf, x86: Prefer fixed-purpose counters when scheduling perf, x86: Fix event scheduler for constraints with overlapping counters perf, x86: Implement event scheduler helper functions perf: Avoid a useless pmu_disable() in the perf-tick x86/tools: Add decoded instruction dump mode x86: Update instruction decoder to support new AVX formats x86/tools: Fix insn_sanity message outputs x86/tools: Fix instruction decoder message output x86: Fix instruction decoder to handle grouped AVX instructions x86/tools: Fix Makefile to build all test tools perf test: Soft errors shouldn't stop the "Validate PERF_RECORD_" test perf test: Validate PERF_RECORD_ events and perf_sample fields ...
2011-12-27KVM: MMU: remove oos_shadow parameterXiao Guangrong
The unsync code should be stable now, maybe it is the time to remove this parameter to cleanup the code a little bit Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-21tracing: Have stack tracing set filtered functions at bootSteven Rostedt
Add stacktrace_filter= to the kernel command line that lets the user pick specific functions to check the stack on. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-12-20Merge commit 'v3.2-rc6' into perf/coreIngo Molnar
Merge reason: Update with the latest fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-20Merge branch 'for-tip' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/core
2011-12-12Merge branch 'for-next/dwc3' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next * 'for-next/dwc3' of git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb: (392 commits) usb: dwc3: ep0: fix for possible early delayed_status usb: dwc3: gadget: fix stream enable bit usb: dwc3: ep0: fix GetStatus handling (again) usb: dwc3: ep0: use dwc3_request for ep0 requsts instead of usb_request usb: dwc3: use correct hwparam register for power mgm check usb: dwc3: omap: move to module_platform_driver usb: dwc3: workaround: missing disconnect event usb: dwc3: workaround: missing USB3 Reset event usb: dwc3: workaround: U1/U2 -> U0 transiton usb: dwc3: gadget: return early in dwc3_cleanup_done_reqs() usb: dwc3: ep0: handle delayed_status again usb: dwc3: ep0: push ep0state into xfernotready processing usb: dwc3: fix sparse errors usb: dwc3: fix few coding style problems usb: dwc3: move generic dwc3 code from gadget into core usb: dwc3: use a helper function for operation mode setting usb: dwc3: ep0: don't use ep0in for transfers usb: dwc3: ep0: use proper endianess in SetFeature for wIndex usb: dwc3: core: drop DWC3_EVENT_BUFFERS_MAX usb: dwc3: omap: add multiple instances support to OMAP ...
2011-12-12iommu/amd: Put IOMMUv2 capable devices in pt_domainJoerg Roedel
If the device starts to use IOMMUv2 features the dma handles need to stay valid. The only sane way to do this is to use a identity mapping for the device and not translate it by the iommu. This is implemented with this patch. Since this lifts the device-isolation there is also a new kernel parameter which allows to disable that feature. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-12-09Merge branch 'iommu/fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu * 'iommu/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: MAINTAINERS: Update amd-iommu F: patterns iommu/amd: Fix typo in kernel-parameters.txt iommu/msm: Fix compile error in mach-msm/devices-iommu.c Fix comparison using wrong pointer variable in dma debug code
2011-12-07oprofile, s390: Add event interface to the System z hardware sampling moduleAndreas Krebbel
With this patch the OProfile Basic Mode Sampling support for System z is enhanced with a counter file system. That way hardware sampling can be configured using the user space tools with only little modifications. With the patch by default new cpu_types (s390/z10, s390/z196) are returned in order to indicate that we are running a CPU which provides the hardware sampling facility. Existing user space tools will complain about an unknown cpu type. In order to be compatible with existing user space tools the `cpu_type' module parameter has been added. Setting the parameter to `timer' will force the module to return `timer' as cpu_type. The module will still try to use hardware sampling if available and the hwsampling virtual filesystem will be also be available for configuration. So this has a different effect than using the generic oprofile module parameter `timer=1'. If the basic mode sampling is enabled on the machine and the cpu_type=timer parameter is not used the kernel module will provide the following virtual filesystem: /dev/oprofile/0/enabled /dev/oprofile/0/event /dev/oprofile/0/count /dev/oprofile/0/unit_mask /dev/oprofile/0/kernel /dev/oprofile/0/user In the counter file system only the values of 'enabled', 'count', 'kernel', and 'user' are evaluated by the kernel module. Everything else must contain fixed values. The 'event' value only supports a single event - HWSAMPLING with value 0. The 'count' value specifies the hardware sampling rate as it is passed to the CPU measurement facility. The 'kernel' and 'user' flags can now be used to filter for samples when using hardware sampling. Additionally also the following file will be created: /dev/oprofile/timer/enabled This will always be the inverted value of /dev/oprofile/0/enabled. 0 is not accepted without hardware sampling. Signed-off-by: Andreas Krebbel <krebbel@linux.vnet.ibm.com> Signed-off-by: Robert Richter <robert.richter@amd.com>
2011-12-06iommu/amd: Fix typo in kernel-parameters.txtSedat Dilek
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-12-05x86, AMD: Correct align_va_addr documentationBorislav Petkov
Commit dfb09f9b7ab0 ("x86, amd: Avoid cache aliasing penalties on AMD family 15h") introduced a kernel command line parameter called 'align_va_addr' which still refers to arguments used in an earlier version of the patch and which got changed without updating the documentation. Correct that omission. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Frank Arnold <frank.arnold@amd.com> Link: http://lkml.kernel.org/r/1321873819-29541-1-git-send-email-bp@amd64.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05x86: Default to vsyscall=emulateAndy Lutomirski
This essentially reverts: 2b666859ec32: x86: Default to vsyscall=native for now The ABI breakage should now be fixed by: commit 48c4206f5b02f28c4c78a1f5b491d3772fb64fb9 Author: Andy Lutomirski <luto@mit.edu> Date: Thu Oct 20 08:48:19 2011 -0700 x86-64: Set siginfo and context on vsyscall emulation faults Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: richard -rw- weinberger <richard.weinberger@gmail.com> Cc: Adrian Bunk <bunk@stusta.de> Cc: H. Peter Anvin <hpa@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/93154af3b2b6d208906ae02d80d92cf60c6fa94f.1320712291.git.luto@amacapital.net Signed-off-by: Ingo Molnar <mingo@elte.hu>
