path: root/Documentation/kobject.txt
2008-06-11kobject: Documentation Spelling PatchDavid Brigada
Signed-off-by: David Brigada <brigad@rpi.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: update the kobject/kset documentationGreg Kroah-Hartman
This provides a much-needed kobject and kset documentation update. Thanks to Kay Sievers, Alan Stern, Jonathan Corbet, Randy Dunlap, Jan Engelhardt, and others for reviewing and providing help with this document. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove old, outdated documentation.Greg Kroah-Hartman
As we are replacing the documentation, it's easier to do this in a two stage pass, delete the old file and add the new one. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12driver core: remove subsystem_init()Greg Kroah-Hartman
There is only one user of it, and it is only a wrapper for kset_init(). Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: clean up removed functions from the documentationCornelia Huck
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-30kobject: update documentationCornelia Huck
Update kobject documentation: - Update structure definitions. - Remove documentation of removed struct subsystem. (First shot, uevent_ops probably need some documentation as well.) Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-11genhd.c reference in Documentation/kobjects.txtBrandon Philips
block/genhd.c no longer in drivers/. Update Documentation/kobjects.txt Signed-off-by: Brandon Philips <brandon@ifup.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
