path: root/Documentation/kvm
2011-05-06Move kvm, uml, and lguest subdirectories under a common "virtual" directory, ↵Rob Landley
I.E: cd Documentation mkdir virtual git mv kvm uml lguest virtual Signed-off-by: Rob Landley <rlandley@parallels.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-17KVM: Start lock documentationJan Kiszka
The goal of this document shall be - overview of all locks used in KVM core - provide details on the scope of each lock - explain the lock type, specifically of a raw spin locks - provide a lock ordering guide Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-02-15doc: Fix numbering of KVM API description sectionsPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-13Merge branch 'kvm-updates/2.6.38' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.38' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (142 commits) KVM: Initialize fpu state in preemptible context KVM: VMX: when entering real mode align segment base to 16 bytes KVM: MMU: handle 'map_writable' in set_spte() function KVM: MMU: audit: allow audit more guests at the same time KVM: Fetch guest cr3 from hardware on demand KVM: Replace reads of vcpu->arch.cr3 by an accessor KVM: MMU: only write protect mappings at pagetable level KVM: VMX: Correct asm constraint in vmcs_load()/vmcs_clear() KVM: MMU: Initialize base_role for tdp mmus KVM: VMX: Optimize atomic EFER load KVM: VMX: Add definitions for more vm entry/exit control bits KVM: SVM: copy instruction bytes from VMCB KVM: SVM: implement enhanced INVLPG intercept KVM: SVM: enhance mov DR intercept handler KVM: SVM: enhance MOV CR intercept handler KVM: SVM: add new SVM feature bit names KVM: cleanup emulate_instruction KVM: move complete_insn_gp() into x86.c KVM: x86: fix CR8 handling KVM guest: Fix kvm clock initialization when it's configured out ...
2011-01-12KVM: Document device assigment APIJan Kiszka
Adds API documentation for KVM_[DE]ASSIGN_PCI_DEVICE, KVM_[DE]ASSIGN_DEV_IRQ, KVM_SET_GSI_ROUTING, KVM_ASSIGN_SET_MSIX_NR, and KVM_ASSIGN_SET_MSIX_ENTRY. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Let host know whether the guest can handle async PF in non-userspace ↵Gleb Natapov
context. If guest can detect that it runs in non-preemptable context it can handle async PFs at any time, so let host know that it can send async PF even if guest cpu is not in userspace. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Add PV MSR to enable asynchronous page faults delivery.Gleb Natapov
Guest enables async PF vcpu functionality using this MSR. Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-24KVM: Document that KVM_GET_SUPPORTED_CPUID may return emulated valuesAvi Kivity
2010-10-24KVM: PPC: Add documentation for magic page enhancementsAlexander Graf
This documents how to detect additional features inside the magic page when a guest maps it. Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: Document KVM_INTERRUPT ioctlAlexander Graf
This adds some documentation for the KVM_INTERRUPT special cases that PowerPC now implements. Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: Add mtsrin PV codeAlexander Graf
This is the guest side of the mtsr acceleration. Using this a guest can now call mtsrin with almost no overhead as long as it ensures that it only uses it with (MSR_IR|MSR_DR) == 0. Linux does that, so we're good. Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: x86: Add timekeeping documentationZachary Amsden
Basic informational document about x86 timekeeping and how KVM is affected. Signed-off-by: Zachary Amsden <zamsden@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: PPC: Add get_pvinfo interface to query hypercall instructionsAlexander Graf
We need to tell the guest the opcodes that make up a hypercall through interfaces that are controlled by userspace. So we need to add a call for userspace to allow it to query those opcodes so it can pass them on. This is required because the hypercall opcodes can change based on the hypervisor conditions. If we're running in hardware accelerated hypervisor mode, a hypercall looks different from when we're running without hardware acceleration. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: Add Documentation about PV interfaceAlexander Graf
We just introduced a new PV interface that screams for documentation. So here it is - a shiny new and awesome text file describing the internal works of the PPC KVM paravirtual interface. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-02KVM: Document KVM_GET_SUPPORTED_CPUID2 ioctlAvi Kivity
Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-02KVM: Document MCE banks non-exposure via KVM_GET_MSR_INDEX_LISTAvi Kivity
2010-08-01KVM: Document KVM specific review itemsAvi Kivity
2010-08-01KVM: Remove kernel-allocated memory regionsAvi Kivity
Equivalent (and better) functionality is provided by user-allocated memory regions. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: Remove memory alias supportAvi Kivity
As advertised in feature-removal-schedule.txt. Equivalent support is provided by overlapping memory regions. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: Fix typos in Documentation/kvm/mmu.txtJason Wang
Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: x86: XSAVE/XRSTOR live migration supportSheng Yang
This patch enable save/restore of xsave state. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Add Documentation/kvm/msr.txtGlauber Costa
This patch adds a file that documents the usage of KVM-specific MSRs. Signed-off-by: Glauber Costa <glommer@redhat.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: MMU: Document large pagesAvi Kivity
2010-08-01KVM: MMU: Document cr0.wp emulationAvi Kivity
2010-08-01KVM: MMU: Don't allocate gfns page for direct mmu pagesLai Jiangshan
When sp->role.direct is set, sp->gfns does not contain any essential information, leaf sptes reachable from this sp are for a continuous guest physical memory range (a linear range). So sp->gfns[i] (if it was set) equals to sp->gfn + i. (PT_PAGE_TABLE_LEVEL) Obviously, it is not essential information, we can calculate it when need. It means we don't need sp->gfns when sp->role.direct=1, Thus we can save one page usage for every kvm_mmu_page. Note: Access to sp->gfns must be wrapped by kvm_mmu_page_get_gfn() or kvm_mmu_page_set_gfn(). It is only exposed in FNAME(sync_page). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: update mmu documetation for role.nxeGui Jianfeng
There's no member "cr4_nxe" in struct kvm_mmu_page_role, it names "nxe" now. Update mmu document. Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Document KVM_SET_BOOT_CPU_IDAvi Kivity
2010-08-01KVM: Document KVM_SET_IDENTITY_MAP ioctlAvi Kivity
2010-05-19KVM: MMU: Segregate shadow pages with different cr0.wpAvi Kivity
When cr0.wp=0, we may shadow a gpte having u/s=1 and r/w=0 with an spte having u/s=0 and r/w=1. This allows excessive access if the guest sets cr0.wp=1 and accesses through this spte. Fix by making cr0.wp part of the base role; we'll have different sptes for the two cases and the problem disappears. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-05-19KVM: Add cpuid.txt fileGlauber Costa
This file documents cpuid bits used by KVM. Signed-off-by: Glauber Costa <glommer@redhat.com> Acked-by: Zachary Amsden <zamsden@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-05-17KVM: Minor MMU documentation editsAvi Kivity
Reported by Andrew Jones. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-05-17KVM: Document KVM_GET_MP_STATE and KVM_SET_MP_STATEAvi Kivity
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-05-17KVM: Document mmuAvi Kivity
2010-05-17KVM: Document replacements for KVM_EXIT_HYPERCALLAvi Kivity
2010-05-17KVM: PPC: Add OSI hypercall interfaceAlexander Graf
MOL uses its own hypercall interface to call back into userspace when the guest wants to do something. So let's implement that as an exit reason, specify it with a CAP and only really use it when userspace wants us to. The only user of it so far is MOL. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: Add support for enabling capabilities per-vcpuAlexander Graf
Some times we don't want all capabilities to be available to all our vcpus. One example for that is the OSI interface, implemented in the next patch. In order to have a generic mechanism in how to enable capabilities individually, this patch introduces a new ioctl that can be used for this purpose. That way features we don't want in all guests or userspace configurations can just not be enabled and we're good. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: Document KVM_SET_TSS_ADDRAvi Kivity
2010-05-17KVM: Document KVM_SET_USER_MEMORY_REGIONAvi Kivity
2010-04-25KVM: x86: Add support for saving&restoring debug registersJan Kiszka
So far user space was not able to save and restore debug registers for migration or after reset. Plug this hole. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-25KVM: x86: Save&restore interrupt shadow maskJan Kiszka
The interrupt shadow created by STI or MOV-SS-like operations is part of the VCPU state and must be preserved across migration. Transfer it in the spare padding field of kvm_vcpu_events.interrupt. As a side effect we now have to make vmx_set_interrupt_shadow robust against both shadow types being set. Give MOV SS a higher priority and skip STI in that case to avoid that VMX throws a fault on next entry. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-25KVM: add doc note about PIO/MMIO completion APIMarcelo Tosatti
Document that partially emulated instructions leave the guest state inconsistent, and that the kernel will complete operations before checking for pending signals. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: trivial document fixesWu Fengguang
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-12-27KVM: x86: Extend KVM_SET_VCPU_EVENTS with selective updatesJan Kiszka
User space may not want to overwrite asynchronously changing VCPU event states on write-back. So allow to skip nmi.pending and sipi_vector by setting corresponding bits in the flags field of kvm_vcpu_events. [avi: advertise the bits in KVM_GET_VCPU_EVENTS] Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: x86: Add KVM_GET/SET_VCPU_EVENTSJan Kiszka
This new IOCTL exports all yet user-invisible states related to exceptions, interrupts, and NMIs. Together with appropriate user space changes, this fixes sporadic problems of vmsave/restore, live migration and system reset. [avi: future-proof abi by adding a flags field] Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: allow userspace to adjust kvmclock offsetGlauber Costa
When we migrate a kvm guest that uses pvclock between two hosts, we may suffer a large skew. This is because there can be significant differences between the monotonic clock of the hosts involved. When a new host with a much larger monotonic time starts running the guest, the view of time will be significantly impacted. Situation is much worse when we do the opposite, and migrate to a host with a smaller monotonic clock. This proposed ioctl will allow userspace to inform us what is the monotonic clock value in the source host, so we can keep the time skew short, and more importantly, never goes backwards. Userspace may also need to trigger the current data, since from the first migration onwards, it won't be reflected by a simple call to clock_gettime() anymore. [marcelo: future-proof abi with a flags field] [jan: fix KVM_GET_CLOCK by clearing flags field instead of checking it] Signed-off-by: Glauber Costa <glommer@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Xen PV-on-HVM guest supportEd Swierk
Support for Xen PV-on-HVM guests can be implemented almost entirely in userspace, except for handling one annoying MSR that maps a Xen hypercall blob into guest address space. A generic mechanism to delegate MSR writes to userspace seems overkill and risks encouraging similar MSR abuse in the future. Thus this patch adds special support for the Xen HVM MSR. I implemented a new ioctl, KVM_XEN_HVM_CONFIG, that lets userspace tell KVM which MSR the guest will write to, as well as the starting address and size of the hypercall blobs (one each for 32-bit and 64-bit) that userspace has loaded from files. When the guest writes to the MSR, KVM copies one page of the blob from userspace to the guest. I've tested this patch with a hacked-up version of Gerd's userspace code, booting a number of guests (CentOS 5.3 i386 and x86_64, and FreeBSD 8.0-RC1 amd64) and exercising PV network and block devices. [jan: fix i386 build warning] [avi: future proof abi with a flags field] Signed-off-by: Ed Swierk <eswierk@aristanetworks.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: Document KVM_CAP_IRQCHIPAvi Kivity
