path: root/Documentation/leds/leds-lp5521.txt
2012-03-23drivers/leds/leds-lp5521.c: support led pattern dataKim, Milo
The lp5521 has autonomous operation mode without external control. Using lp5521_platform_data, various led patterns can be configurable. For supporting this feature, new functions and device attribute are added. Structure of lp5521_led_pattern: 3 channels are supported - red, green and blue. Pattern(s) of each channel and numbers of pattern(s) are defined in the pla= tform data. Pattern data are hexa codes which include pattern commands such like set pwm, wait, ramp up/down, branch and so on. Pattern mode functions: * lp5521_clear_program_memory Before running new led pattern, program memory should be cleared. * lp5521_write_program_memory Pattern data updated in the program memory via the i2c. * lp5521_get_pattern Get pattern from predefined in the platform data. * lp5521_run_led_pattern Stop current pattern or run new pattern. Transition time is required between different operation mode. Device attribute - 'led_pattern': To load specific led pattern, new device attribute is added. When the lp5521 driver is unloaded, stop current led pattern mode. Documentation updated : description about how to define the led patterns and example. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Arun MURTHY <arun.murthy@stericsson.com> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23drivers/leds/leds-lp5521.c: add 'update_config' in the lp5521_platform_dataKim, Milo
The value of CONFIG register(Addr 08h) is configurable. For supporting this feature, update_config is added in the platform data. If 'update_config' is not defined, the default value is 'LP5521_PWRSAVE_EN | LP5521_CP_MODE_AUTO | LP5521_R_TO_BATT'. To define CONFIG register in the platform data, the bit definitions were mo= ved to the header file. Documentation updated : description about 'update_config' and example. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Arun MURTHY <arun.murthy@stericsson.com> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23drivers/leds/leds-lp5521.c: add 'name' in the lp5521_led_configKim, Milo
The name of each led channel can be configurable. For the compatibility, the name is set to default value(xx:channelN) when 'name' is not defined. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Arun MURTHY <arun.murthy@stericsson.com> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-12Documentation: led drivers lp5521 and lp5523Samu Onkalo
Create sub directory Documentation/leds and add short documentation for LP5521 and LP5523 drivers. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
