path: root/Documentation/lockdep-design.txt
2011-12-11lockdep: Update documentation for lock-class leak detectionPaul E. McKenney
There are a number of bugs that can leak or overuse lock classes, which can cause the maximum number of lock classes (currently 8191) to be exceeded. However, the documentation does not tell you how to track down these problems. This commit addresses this shortcoming. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2009-08-07lockdep: Fix typos in documentationLi Zefan
s/head/held Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <4A7BD37E.9060806@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-26locking: Documentation: lockdep-design.txt, fix note of state bitsMing Lei
From source code of get_usage_char(), the previous note is not correct, so fix it. static char get_usage_char(struct lock_class *class, enum lock_usage_bit bit) { char c = '.'; if (class->usage_mask & lock_flag(bit + 2))/*LOCK_ENABLED_##STATE*/ c = '+'; if (class->usage_mask & lock_flag(bit)) {/*LOCK_USED_IN_##STATE*/ c = '-'; if (class->usage_mask & lock_flag(bit + 2)) c = '?'; } return c; } note: 1) The 'bit' parameter always is passed as LOCK_USED_IN_##STATE or LOCK_USED_IN_##STATE_READ , from get_usage_chars(). Signed-off-by: Ming Lei <tom.leiming@gmail.com> LKML-Reference: <1240585806-5744-1-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: get_user_chars() redoPeter Zijlstra
Generic, states independent, get_user_chars(). Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-10-11[PATCH] fix lockdep-design.txtAneesh Kumar
I was looking at lockdep-desing.txt and i guess i am confused with the changes with respect to fd7bcea35e7efb108c34ee2b3840942a3749cadb. It says + '.' acquired while irqs enabled + '+' acquired in irq context + '-' acquired in process context with irqs disabled + '?' read-acquired both with irqs enabled and in irq context + But the get_usage_chars() function does this for '-' if (class->usage_mask & LOCKF_ENABLED_HARDIRQS) *c1 = '-'; So i guess what would be correct would be '.' acquired while irqs disabled '+' acquired in irq context '-' acquired with irqs enabled '?' read acquired in irq context with irqs enabled. Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'F'-'G'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'F'-'G'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-01[PATCH] Doc/lockdep-design: explain display of {state-bits}Jim Cromie
Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: design docsIngo Molnar
Lock validator design documentation. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
