path: root/Documentation/m68k
2005-10-29[PATCH] mm: m68k kill stram swapHugh Dickins
Please, please now delete the Atari CONFIG_STRAM_SWAP code. It may be excellent and ingenious code, but its reference to swap_vfsmnt betrays that it hasn't been built since 2.5.1 (four years old come December), it's delving deep into matters which are the preserve of core mm code, its only purpose is to give the more conscientious mm guys an anxiety attack from time to time; yet we keep on breaking it more and more. If you want to use RAM for swap, then if the MTD driver does not already provide just what you need, I'm sure David could be persuaded to add the extra. But you'd also like to be able to allocate extents of that swap for other use: we can give you a core interface for that if you need. But unbuilt for four years suggests to me that there's no need at all. I cannot swear the patch below won't break your build, but believe so. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
