path: root/Documentation/md.txt
2008-07-21md: Tidy up rdev_size_store a bit:Neil Brown
- used strict_strtoull in place of simple_strtoull - use my_mddev in place of rdev->mddev (they have the same value) and more significantly, - don't adjust mddev->size to fit, rather reject changes which make rdev->size smaller than mddev->size Adjusting mddev->size is a hangover from bind_rdev_to_array which does a similar thing. But it really is a better design to insist that mddev->size is set as required, then the rdev->sizes are set to allow for that. The previous way invites confusion. Signed-off-by: NeilBrown <neilb@suse.de>
2008-06-28Make sure all changes to md/dev-XX/state are notifiedNeil Brown
The important state change happens during an interrupt in md_error. So just set a flag there and call sysfs_notify later in process context. Signed-off-by: Neil Brown <neilb@suse.de>
2008-06-28Make sure all changes to md/degraded are notified.Neil Brown
When a device fails, when a spare is activated, when an array is reshaped, or when an array is started, the extent to which the array is degraded can change. Signed-off-by: Neil Brown <neilb@suse.de>
2008-06-28Make sure all changes to md/sync_action are notified.Neil Brown
When the 'resync' thread starts or stops, when we explicitly set sync_action, or when we determine that there is definitely nothing to do, we notify sync_action. To stop "sync_action" from occasionally showing the wrong value, we introduce a new flags - MD_RECOVERY_RECOVER - to say that a recovery is probably needed or happening, and we make sure that we set MD_RECOVERY_RUNNING before clearing MD_RECOVERY_NEEDED. Signed-off-by: Neil Brown <neilb@suse.de>
2008-06-28Make sure all changes to md/array_state are notified.Neil Brown
Changes in md/array_state could be of interest to a monitoring program. So make sure all changes trigger a notification. Exceptions: changing active_idle to active is not reported because it is frequent and not interesting. changing active to active_idle is only reported on arrays with externally managed metadata, as it is not interesting otherwise. Signed-off-by: Neil Brown <neilb@suse.de>
2008-04-28md: introduce get_priority_stripe() to improve raid456 write performanceDan Williams
Improve write performance by preventing the delayed_list from dumping all its stripes onto the handle_list in one shot. Delayed stripes are now further delayed by being held on the 'hold_list'. The 'hold_list' is bypassed when: * a STRIPE_IO_STARTED stripe is found at the head of 'handle_list' * 'handle_list' is empty and i/o is being done to satisfy full stripe-width write requests * 'bypass_count' is less than 'bypass_threshold'. By default the threshold is 1, i.e. every other stripe handled is a preread stripe provided the top two conditions are false. Benchmark data: System: 2x Xeon 5150, 4x SATA, mem=1GB Baseline: 2.6.24-rc7 Configuration: mdadm --create /dev/md0 /dev/sd[b-e] -n 4 -l 5 --assume-clean Test1: dd if=/dev/zero of=/dev/md0 bs=1024k count=2048 * patched: +33% (stripe_cache_size = 256), +25% (stripe_cache_size = 512) Test2: tiobench --size 2048 --numruns 5 --block 4096 --block 131072 (XFS) * patched: +13% * patched + preread_bypass_threshold = 0: +37% Changes since v1: * reduce bypass_threshold from (chunk_size / sectors_per_chunk) to (1) and make it configurable. This defaults to fairness and modest performance gains out of the box. Changes since v2: * [neilb@suse.de]: kill STRIPE_PRIO_HI and preread_needed as they are not necessary, the important change was clearing STRIPE_DELAYED in add_stripe_bio and this has been moved out to make_request for the hang fix. * [neilb@suse.de]: simplify get_priority_stripe * [dan.j.williams@intel.com]: reset the bypass_count when ->hold_list is sampled empty (+11%) * [dan.j.williams@intel.com]: decrement the bypass_count at the detection of stripes being naturally promoted off of hold_list +2%. Note, resetting bypass_count instead of decrementing on these events yields +4% but that is probably too aggressive. Changes since v3: * cosmetic fixups Tested-by: James W. Laferriere <babydr@baby-dragons.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06md: allow a maximum extent to be set for resyncingNeilBrown
This allows userspace to control resync/reshape progress and synchronise it with other activities, such as shared access in a SAN, or backing up critical sections during a tricky reshape. Writing a number of sectors (which must be a multiple of the chunk size if such is meaningful) causes a resync to pause when it gets to that point. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09md: allow reshape_position for md arrays to be set via sysfsNeilBrown
"reshape_position" records how much progress has been made on a "reshape" (adding drives, changing layout or chunksize). When it is set, the number of drives, layout and chunksize can have two possible values, an old an a new. So allow these different values to be visible, and allow both old and new to be set: Set the old ones first, then the reshape_position, then the new values. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03Fix typos in Documentation/: 'Q'-'R'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'Q'-'R'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix some typos in Documentation/: 'A'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letter 'A'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03[PATCH] md: fix duplicity of levels in md.txtNeilBrown
md.txt has two sections describing the 'level' sysfs attribute, and some of the text is out-of-date. So make just one section, and make it right. Cc: Christian Kujau <evil@g-house.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: new sysfs interface for setting bits in the write-intent-bitmapPaul Clements
Add a new sysfs interface that allows the bitmap of an array to be dirtied. The interface is write-only, and is used as follows: echo "1000" > /sys/block/md2/md/bitmap (dirty the bit for chunk 1000 [offset 0] in the in-memory and on-disk bitmaps of array md2) echo "1000-2000" > /sys/block/md1/md/bitmap (dirty the bits for chunks 1000-2000 in md1's bitmap) This is useful, for example, in cluster environments where you may need to combine two disjoint bitmaps into one (following a server failure, after a secondary server has taken over the array). By combining the bitmaps on the two servers, a full resync can be avoided (This was discussed on the list back on March 18, 2005, "[PATCH 1/2] md bitmap bug fixes" thread). Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] md: Allow the write_mostly flag to be set via sysfsNeilBrown
It appears in /sys/mdX/md/dev-YYY/state and can be set or cleared by writing 'writemostly' or '-writemostly' respectively. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] md: Allow resync_start to be set and queried via sysfsNeilBrown
2006-06-26[PATCH] md: Allow raid 'layout' to be read and set via sysfsNeilBrown
2006-06-26[PATCH] md: Allow rdev state to be set via sysfsNeilBrown
The md/dev-XXX/state file can now be written: "faulty" simulates an error on the device "remove" removes the device from the array (if it is not busy) Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] md: Set/get state of array via sysfsNeilBrown
This allows the state of an md/array to be directly controlled via sysfs and adds the ability to stop and array without tearing it down. Array states/settings: clear No devices, no size, no level Equivalent to STOP_ARRAY ioctl inactive May have some settings, but array is not active all IO results in error When written, doesn't tear down array, but just stops it suspended (not supported yet) All IO requests will block. The array can be reconfigured. Writing this, if accepted, will block until array is quiescent readonly no resync can happen. no superblocks get written. write requests fail read-auto like readonly, but behaves like 'clean' on a write request. clean - no pending writes, but otherwise active. When written to inactive array, starts without resync If a write request arrives then if metadata is known, mark 'dirty' and switch to 'active'. if not known, block and switch to write-pending If written to an active array that has pending writes, then fails. active fully active: IO and resync can be happening. When written to inactive array, starts with resync write-pending (not supported yet) clean, but writes are blocked waiting for 'active' to be written. active-idle like active, but no writes have been seen for a while (100msec). Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] md: increase the delay before marking metadata clean, and make it ↵NeilBrown
configurable When a md array has been idle (no writes) for 20msecs it is marked as 'clean'. This delay turns out to be too short for some real workloads. So increase it to 200msec (the time to update the metadata should be a tiny fraction of that) and make it sysfs-configurable. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow sync-speed to be controlled per-deviceNeilBrown
Also export current (average) speed and status in sysfs. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: support adding new devices to md arrays via sysfsNeilBrown
Writing major:minor to md/new_dev will bind that device to the array. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow available size of component devices to be set via sysfsNeilBrown
2006-01-06[PATCH] md: export rdev->data_offset via sysfsNeilBrown
2006-01-06[PATCH] md: expose device slot information via sysfsNeilBrown
This the role that a device has in an array can be viewed and set. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow md/raid_disks to be settableNeilBrown
If array is active, try to reshape, else just set the value. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: count corrected read errors per driveNeilBrown
Store this total in superblock (As appropriate), and make it available to userspace via sysfs. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow array level to be set textually via sysfsNeilBrown
2006-01-06[PATCH] md: expose md metadata format in sysfsNeilBrown
Allow it to be set to a particular version, or 'none'. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow md array component size to be accessed and set via sysfsNeilBrown
2006-01-06[PATCH] md: allow chunk_size to be settable through sysfsNeilBrown
... only before array is started of course. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow dirty raid[456] arrays to be started at bootNeilBrown
See patch to md.txt for more details Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] md: document sysfs usage of md, and make a couple of small refinementsNeilBrown
Document in Documentation/md.txt the files that now appear in sysfs, and make a couple of small refinements to exactly when 'level' and 'raid_disks' are empty, to make it match the documentation. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
