path: root/Documentation/mips
2018-02-01Documentation: mips: Update AU1xxx_IDE Kconfig dependenciesCorentin Labbe
IDEDMA_AUTO IDEDMA_PCI_AUTO was removed in commit 120b9cfddff2 ("ide: remove CONFIG_IDEDMA_{ICS,PCI}_AUTO config") BLK_DEV_IDEDISK was removed in commit 806f80a6fc20 ("ide: add generic ATA/ATAPI disk driver") BLK_DEV_IDE_AU1XXX_BURSTABLE_ON was removed in commit 8f29e650bffc ("ide: AU1200 IDE update") Remove them from documentation Signed-off-by: Corentin Labbe <clabbe@baylibre.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2014-08-26Documentation: au1xxx-ide.c has movedPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-14ide: remove unused CONFIG_BLK_DEV_IDE_AU1XXX_SEQTS_PER_RQBartlomiej Zolnierkiewicz
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06documentation: update header file pathsRandy Dunlap
Update several Documentation/ files and a few sub-dir files (only one change in each) to reflect changed header files locations. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-26au1xxx-ide: fix MWDMA supportBartlomiej Zolnierkiewicz
Always use "fast" MWDMA support and remove dma_{black,white}_list (they were based on completely bogus ->ide_dma_check implementation which didn't set neither the host controller timings nor the device for the desired transfer mode). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-29[MIPS] remove Documentation/mips/GT64120.READMEDmitri Vorobiev
Based upon the 2.4 kernel, the information presented in the Documentation/mips/GT64120.README file is outdated. Worse, the document contents are plain misleading nowadays because the text mentions files and directories, which have been deleted, moved or restructured for 2.6. This patch removes the documentation, which is no more valid. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19[MIPS] Delete totally outdated Documentation/mips/time.READMERalf Baechle
2007-10-17Add a 00-INDEX file to Documentation/mips/Jesper Juhl
Add a 00-INDEX file to Documentation/mips/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: Rob Landley <rob@landley.net> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11[MIPS] Delete Documentation/mips/pci/pci.READMERalf Baechle
This file, and reality are different universes ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-31[MIPS] Fixup migration to GENERIC_TIMEAtsushi Nemoto
Since we already moved to GENERIC_TIME, we should implement alternatives of old do_gettimeoffset routines to get sub-jiffies resolution from gettimeofday(). This patch includes: * MIPS clocksource support (based on works by Manish Lachwani). * remove unused gettimeoffset routines and related codes. * remove unised 64bit do_div64_32(). * simplify mips_hpt_init. (no argument needed, __init tag) * simplify c0_hpt_timer_init. (no need to write to c0_count) * remove some hpt_init routines. * mips_hpt_mask variable to specify bitmask of hpt value. * convert jmr3927_do_gettimeoffset to jmr3927_hpt_read. * convert ip27_do_gettimeoffset to ip27_hpt_read. * convert bcm1480_do_gettimeoffset to bcm1480_hpt_read. * simplify sb1250 hpt functions. (no need to subtract and shift) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-21[MIPS] Cleanup remaining references to mips_counter_frequency.Ralf Baechle
Noticed by Samium Gromoff but his patch got stale in flight ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-02-14[MIPS] Update docs to reflect the latest status of the Alchemy IDE driver.Ralf Baechle
2005-10-29Cleaned up AMD Au1200 IDE driver:Pete Popov
- converted to platform bus - removed pci dependencies - removed virt_to_phys/phys_to_virt calls System now can root off of a disk. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> diff --git a/Documentation/mips/AU1xxx_IDE.README b/Documentation/mips/AU1xxx_IDE.README new file mode 100644
