path: root/Documentation/networking/bonding.txt
2008-01-28[BONDING]: Documentation updateJay Vosburgh
Update the bonding documentation: more discussion on initialization and configuration, changes to discussion of packet reordering in balance-rr, update some out of date information. Based in part on input from Rick Jones <rick.jones2@hp.com> and Andy Gospodarek <andy@greyhouse.net>. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Acked-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-07bonding: Add new layer2+3 hash for xor/802.3ad modesJay Vosburgh
Add new hash for balance-xor and 802.3ad modes. Originally submitted by "Glenn Griffin" <ggriffin.kernel@gmail.com>; modified by Jay Vosburgh to move setting of hash policy out of line, tweak the documentation update and add version update to 3.2.2. Glenn's original comment follows: Included is a patch for a new xmit_hash_policy for the bonding driver that selects slaves based on MAC and IP information. This is a middle ground between what currently exists in the layer2 only policy and the layer3+4 policy. This policy strives to be fully 802.3ad compliant by transmitting every packet of any particular flow over the same link. As documented the layer3+4 policy is not fully compliant for extreme cases such as ip fragmentation, so this policy is a nice compromise for environments that require full compliance but desire more than the layer2 only policy. Signed-off-by: "Glenn Griffin" <ggriffin.kernel@gmail.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-15net/bonding: Optionally allow ethernet slaves to keep own MACJay Vosburgh
Update the "don't change MAC of slaves" functionality added in previous changes to be a generic option, rather than something tied to IB devices, as it's occasionally useful for regular ethernet devices as well. Adds "fail_over_mac" option (which is automatically enabled for IB slaves), applicable only to active-backup mode. Includes documentation update. Updates bonding driver version to 3.2.0. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-26[NET]: bonding documentation fix for multiple bonding interfacesAlexandra N. Kossovsky
Fix bonding driver documentation for the case of multiple bonding interfaces. Signed-off-by: "Alexandra N. Kossovsky" <Alexandra.Kossovsky@oktetlabs.ru> Acked-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-25[PATCH] bonding: Validate probe replies in ARP monitorJay Vosburgh
Add logic to check ARP request / reply packets used for ARP monitor link integrity checking. The current method simply examines the slave device to see if it has sent and received traffic; this can be fooled by extraneous traffic. For example, if multiple hosts running bonding are behind a common switch, the probe traffic from the multiple instances of bonding will update the tx/rx times on each other's slave devices. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-08[DOC] Update bonding documentation with sysfs infoAuke Kok
Bonding documentation needed an update to include sysfs specific information. This patch adds information on how to change bonding parameters at runtime using the sysfs interface. Signed-off-by: Mitch Williams <mitch.a.williams@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2006-01-09[PATCH] update bonding.txt to not show ip address on slavesEric Paris
ifenslave, as of abi version 2, does not set the ip address on the slave interfaces. The documentation example however still shows that the ensalved interfaces should have the same IP as the master. The patch simply removes the lines from the example which should no longer appear. Signed-off-by: Eric Paris <eparis@redhat.com> bonding.txt | 2 -- 1 files changed, 2 deletions(-) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-18[PATCH] bonding: fix typos in bonding documentationJohn W. Linville
Fix some simple typos in the bonding.txt file. The typos are in areas relating to loading the bonding driver multiple times. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-10[PATCH] Spelling fixes for Documentation/Tobias Klauser
The attached patch fixes the following spelling errors in Documentation/ - double "the" - Several misspellings of function/functionality - infomation - memeory - Recieved - wether and possibly others which I forgot ;-) Trailing whitespaces on the same line as the typo are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-31[PATCH] bonding: documentation updateJay Vosburgh
Contains general updates (additional configuration info, hopefully better examples, updated some out of date info, and a bonus pass through ispell to banish the "paramters.") and info specific to gratuitous ARP and xmit policy functionality already in 2.6.13-rc2. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
