path: root/Documentation/networking/ip-sysctl.txt
2010-05-31arp_notify: document that a gratuitous ARP request is sent when this option ↵Ian Campbell
is enabled This option causes a gratuitous ARP request, not a reply as the documentation currently suggests. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: David S. Miller <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15net: reserve ports for applications using fixed port numbersAmerigo Wang
(Dropped the infiniband part, because Tetsuo modified the related code, I will send a separate patch for it once this is accepted.) This patch introduces /proc/sys/net/ipv4/ip_local_reserved_ports which allows users to reserve ports for third-party applications. The reserved ports will not be used by automatic port assignments (e.g. when calling connect() or bind() with port number 0). Explicit port allocation behavior is unchanged. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-25Merge branch 'master' of ↵David S. Miller
2010-02-23IPv6: better document max_addresses parameterBrian Haley
Andrew Morton wrote: >> >From ip-sysctl.txt file in kernel documentation I can see following description >> for max_addresses: >> max_addresses - INTEGER >> Number of maximum addresses per interface. 0 disables limitation. >> It is recommended not set too large value (or 0) because it would >> be too easy way to crash kernel to allow to create too much of >> autoconfigured addresses. ^^^^^^^^^^^^^^ >> If this parameter applies only for auto-configured IP addressed, please state >> it more clearly in docs or rename the parameter to show that it refers to >> auto-configuration. It did mention autoconfigured in the text, but the below makes it more obvious. More clearly document IPv6 max_addresses parameter. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18net: TCP thin dupackAndreas Petlund
This patch enables fast retransmissions after one dupACK for TCP if the stream is identified as thin. This will reduce latencies for thin streams that are not able to trigger fast retransmissions due to high packet interarrival time. This mechanism is only active if enabled by iocontrol or syscontrol and the stream is identified as thin. Signed-off-by: Andreas Petlund <apetlund@simula.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18net: TCP thin linear timeoutsAndreas Petlund
This patch will make TCP use only linear timeouts if the stream is thin. This will help to avoid the very high latencies that thin stream suffer because of exponential backoff. This mechanism is only active if enabled by iocontrol or syscontrol and the stream is identified as thin. A maximum of 6 linear timeouts is tried before exponential backoff is resumed. Signed-off-by: Andreas Petlund <apetlund@simula.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ipv4: allow warming up the ARP cache with request type gratuitous ARPOctavian Purdila
If the per device ARP_ACCEPT option is enable, currently we only allow creating new ARP cache entries for response type gratuitous ARP. Allowing gratuitous ARP to create new ARP entries (not only to update existing ones) is useful when we want to avoid unnecessary delays for the first packet of a stream. This patch allows request type gratuitous ARP to create new ARP cache entries as well. This is useful when we want to populate the ARP cache entries for a large number of hosts on the same LAN. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07net: RFC3069, private VLAN proxy arp supportJesper Dangaard Brouer
This is to be used together with switch technologies, like RFC3069, that where the individual ports are not allowed to communicate with each other, but they are allowed to talk to the upstream router. As described in RFC 3069, it is possible to allow these hosts to communicate through the upstream router by proxy_arp'ing. This patch basically allow proxy arp replies back to the same interface (from which the ARP request/solicitation was received). Tunable per device via proc "proxy_arp_pvlan": /proc/sys/net/ipv4/conf/*/proxy_arp_pvlan This switch technology is known by different vendor names: - In RFC 3069 it is called VLAN Aggregation. - Cisco and Allied Telesyn call it Private VLAN. - Hewlett-Packard call it Source-Port filtering or port-isolation. - Ericsson call it MAC-Forced Forwarding (RFC Draft). Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03ipv4 05/05: add sysctl to accept packets with local source addressesPatrick McHardy
commit 8ec1e0ebe26087bfc5c0394ada5feb5758014fc8 Author: Patrick McHardy <kaber@trash.net> Date: Thu Dec 3 12:16:35 2009 +0100 ipv4: add sysctl to accept packets with local source addresses Change fib_validate_source() to accept packets with a local source address when the "accept_local" sysctl is set for the incoming inet device. Combined with the previous patches, this allows to communicate between multiple local interfaces over the wire. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02TCPCT part 1c: sysctl_tcp_cookie_size, socket option TCP_COOKIE_TRANSACTIONSWilliam Allen Simpson
Define sysctl (tcp_cookie_size) to turn on and off the cookie option default globally, instead of a compiled configuration option. Define per socket option (TCP_COOKIE_TRANSACTIONS) for setting constant data values, retrieving variable cookie values, and other facilities. Move inline tcp_clear_options() unchanged from net/tcp.h to linux/tcp.h, near its corresponding struct tcp_options_received (prior to changes). This is a straightforward re-implementation of an earlier (year-old) patch that no longer applies cleanly, with permission of the original author (Adam Langley): http://thread.gmane.org/gmane.linux.network/102586 These functions will also be used in subsequent patches that implement additional features. Requires: net: TCP_MSS_DEFAULT, TCP_MSS_DESIRED Signed-off-by: William.Allen.Simpson@gmail.com Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02Merge branch 'master' of ↵David S. Miller
2009-12-02ip: update the description of rp_filter in ip-sysctl.txtShan Wei
The commit 27fed4175acf81ddd91d9a4ee2fd298981f60295 (ip: fix logic of reverse path filter sysctl) has changed the logic of rp_filter. The document about rp_filter is out of date. Now, setting conf/all/rp_filte with 0 can also enable source validation. Update the document according to the commit. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07make TLLAO option for NA packets configurableOctavian Purdila
On Friday 02 October 2009 20:53:51 you wrote: > This is good although I would have shortened the name. Ah, I knew I forgot something :) Here is v4. tavi >From 24d96d825b9fa832b22878cc6c990d5711968734 Mon Sep 17 00:00:00 2001 From: Octavian Purdila <opurdila@ixiacom.com> Date: Fri, 2 Oct 2009 00:51:15 +0300 Subject: [PATCH] ipv6: new sysctl for sending TLLAO with unicast NAs Neighbor advertisements responding to unicast neighbor solicitations did not include the target link-layer address option. This patch adds a new sysctl option (disabled by default) which controls whether this option should be sent even with unicast NAs. The need for this arose because certain routers expect the TLLAO in some situations even as a response to unicast NS packets. Moreover, RFC 2461 recommends sending this to avoid a race condition (section 4.4, Target link-layer address) Signed-off-by: Cosmin Ratiu <cratiu@ixiacom.com> Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-04sctp: Sysctl configuration for IPv4 Address ScopingBhaskar Dutta
This patch introduces a new sysctl option to make IPv4 Address Scoping configurable <draft-stewart-tsvwg-sctp-ipv4-00.txt>. In networking environments where DNAT rules in iptables prerouting chains convert destination IP's to link-local/private IP addresses, SCTP connections fail to establish as the INIT chunk is dropped by the kernel due to address scope match failure. For example to support overlapping IP addresses (same IP address with different vlan id) a Layer-5 application listens on link local IP's, and there is a DNAT rule that maps the destination IP to a link local IP. Such applications never get the SCTP INIT if the address-scoping draft is strictly followed. This sysctl configuration allows SCTP to function in such unconventional networking environments. Sysctl options: 0 - Disable IPv4 address scoping draft altogether 1 - Enable IPv4 address scoping (default, current behavior) 2 - Enable address scoping but allow IPv4 private addresses in init/init-ack 3 - Enable address scoping but allow IPv4 link local address in init/init-ack Signed-off-by: Bhaskar Dutta <bhaskar.dutta@globallogic.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-09-01RTO connection timeout: sysctl documentation updateDamian Lukowski
This patch updates the sysctl documentation concerning the interpretation of tcp_retries{1,2} and tcp_orphan_retries. Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-01IPv6: Add 'autoconf' and 'disable_ipv6' module parametersBrian Haley
Add 'autoconf' and 'disable_ipv6' parameters to the IPv6 module. The first controls if IPv6 addresses are autoconfigured from prefixes received in Router Advertisements. The IPv6 loopback (::1) and link-local addresses are still configured. The second controls if IPv6 addresses are desired at all. No IPv6 addresses will be added to any interfaces. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/scsi/fcoe/fcoe.c
2009-05-17Doc: fixed descriptions on /proc/sys/net/core/* and /proc/sys/net/unix/*Wang Tinggong
Signed-off-by: Wang Tinggong <wangtinggong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-04tcp: extend ECN sysctl to allow server-side only ECNIlpo Järvinen
This should be very safe compared with full enabled, so I see no reason why it shouldn't be done right away. As ECN can only be negotiated if the SYN sending party is also supporting it, somebody in the loop probably knows what he/she is doing. If SYN does not ask for ECN, the server side SYN-ACK is identical to what it is without ECN. Thus it's quite safe. The chosen value is safe w.r.t to existing configs which choose to currently set manually either 0 or 1 but silently upgrades those who have not explicitly requested ECN off. Whether to just enable both sides comes up time to time but unless that gets done now we can at least make the servers aware of ECN already. As there are some known problems to occur if ECN is enabled, it's currently questionable whether there's any real gain from enabling clients as servers mostly won't support it anyway (so we'd hit just the negative sides). After enabling the servers and getting that deployed, the client end enable really has some potential gain too. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-18ipv6: Fix incorrect disable_ipv6 behaviorBrian Haley
Fix the behavior of allowing both sysctl and addrconf_dad_failure() to set the disable_ipv6 parameter without any bad side-effects. If DAD fails and accept_dad > 1, we will still set disable_ipv6=1, but then instead of allowing an RA to add an address then immediately fail DAD, we simply don't allow the address to be added in the first place. This also lets the user set this flag and disable all IPv6 addresses on the interface, or on the entire system. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-24Doc: Cleanup whitespaces in ip-sysctl.txtJesper Dangaard Brouer
Fix up whitespaces while going though ip-sysctl.txt anyway. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-24Doc: Fix typos in ip-sysctl.txt about rp_filter.Jesper Dangaard Brouer
First fix a typo in Stephens patch ;-) Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-22ip: add loose reverse path filteringStephen Hemminger
Extend existing reverse path filter option to allow strict or loose filtering. (See http://en.wikipedia.org/wiki/Reverse_path_filtering). For compatibility with existing usage, the value 1 is chosen for strict mode and 2 for loose mode. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: add ARP notify option for devicesStephen Hemminger
This adds another inet device option to enable gratuitous ARP when device is brought up or address change. This is handy for clusters or virtualization. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: implement emergency route cache rebulds when gc_elasticity is exceededNeil Horman
This is a patch to provide on demand route cache rebuilding. Currently, our route cache is rebulid periodically regardless of need. This introduced unneeded periodic latency. This patch offers a better approach. Using code provided by Eric Dumazet, we compute the standard deviation of the average hash bucket chain length while running rt_check_expire. Should any given chain length grow to larger that average plus 4 standard deviations, we trigger an emergency hash table rebuild for that net namespace. This allows for the common case in which chains are well behaved and do not grow unevenly to not incur any latency at all, while those systems (which may be being maliciously attacked), only rebuild when the attack is detected. This patch take 2 other factors into account: 1) chains with multiple entries that differ by attributes that do not affect the hash value are only counted once, so as not to unduly bias system to rebuilding if features like QOS are heavily used 2) if rebuilding crosses a certain threshold (which is adjustable via the added sysctl in this patch), route caching is disabled entirely for that net namespace, since constant rebuilding is less efficient that no caching at all Tested successfully by me. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/netfilter/nf_conntrack_proto_tcp.c
2008-07-10ip: sysctl documentation cleanupStephen Hemminger
Reduced version of the spelling cleanup patch. Take out the confusing language in tcp_frto, and organize the undocumented values. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-10Documentation: clarify tcp_{r,w}mem sysctl docsJ. Bruce Fields
Fix some of the defaults and attempt to clarify some language. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08sctp: Add documentation for sctp sysctl variableVlad Yasevich
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wan/hdlc_fr.c drivers/net/wireless/iwlwifi/iwl-4965.c drivers/net/wireless/iwlwifi/iwl3945-base.c
2008-07-03ipv6 addrconf: add accept_dad sysctl to control DAD operation.YOSHIFUJI Hideaki
- If 0, disable DAD. - If 1, perform DAD (default). - If >1, perform DAD and disable IPv6 operation if DAD for MAC-based link-local address has been failed (RFC4862 5.4.5). We do not follow RFC4862 by default. Refer to the netdev thread entitled "Linux IPv6 DAD not full conform to RFC 4862 ?" http://www.spinics.net/lists/netdev/msg52027.html Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-07-03ipv6: Add disable_ipv6 sysctl to disable IPv6 operaion on specific interface.YOSHIFUJI Hideaki
2008-07-01icmp: fix units for ratelimitStephen Hemminger
Convert the sysctl values for icmp ratelimit to use milliseconds instead of jiffies which is based on kernel configured HZ. Internal kernel jiffies are not a proper unit for any userspace API. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-01ipv4: fix sysctl documentation of time related valuesStephen Hemminger
These sysctl values are time related and all use the same routine (proc_dointvec_jiffies) that internally converts from seconds to jiffies. The code is fine, the documentation is just wrong. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[UDP]: Add memory accounting.Hideo Aoki
Signed-off-by: Takahiro Yasui <tyasui@redhat.com> Signed-off-by: Hideo Aoki <haoki@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-25[TCP]: Fix inconsistency of terms.Ryousei Takano
Fix inconsistency of terms: 1) D-SACK 2) F-RTO Signed-off-by: Ryousei Takano <takano-ryousei@aist.go.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-20spelling fixes: Documentation/Simon Arlott
Spelling fixes in Documentation/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-10[TCP] FRTO: Update sysctl documentationIlpo Järvinen
Since the SACK enhanced FRTO was added, the code has been under test numerous times so remove "experimental" claim from the documentation. Also be a bit more verbose about the usage. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-13Merge branch 'ioat-md-accel-for-linus' of ↵Linus Torvalds
git://lost.foo-projects.org/~dwillia2/git/iop * 'ioat-md-accel-for-linus' of git://lost.foo-projects.org/~dwillia2/git/iop: (28 commits) ioatdma: add the unisys "i/oat" pci vendor/device id ARM: Add drivers/dma to arch/arm/Kconfig iop3xx: surface the iop3xx DMA and AAU units to the iop-adma driver iop13xx: surface the iop13xx adma units to the iop-adma driver dmaengine: driver for the iop32x, iop33x, and iop13xx raid engines md: remove raid5 compute_block and compute_parity5 md: handle_stripe5 - request io processing in raid5_run_ops md: handle_stripe5 - add request/completion logic for async expand ops md: handle_stripe5 - add request/completion logic for async read ops md: handle_stripe5 - add request/completion logic for async check ops md: handle_stripe5 - add request/completion logic for async compute ops md: handle_stripe5 - add request/completion logic for async write ops md: common infrastructure for running operations with raid5_run_ops md: raid5_run_ops - run stripe operations outside sh->lock raid5: replace custom debug PRINTKs with standard pr_debug raid5: refactor handle_stripe5 and handle_stripe6 (v3) async_tx: add the async_tx api xor: make 'xor_blocks' a library routine for use with async_tx dmaengine: make clients responsible for managing channels dmaengine: refactor dmaengine around dma_async_tx_descriptor ...
2007-07-11I/OAT: Add documentation for the tcp_dma_copybreak sysctlChris Leech
Signed-off-by: Chris Leech <christopher.leech@intel.com>
2007-07-10[IPV6]: Do not send RH0 anymore.YOSHIFUJI Hideaki
Based on <draft-ietf-ipv6-deprecate-rh0-00.txt>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: bridge-nf: filter bridged IPv4/IPv6 encapsulated in pppoe trafficMichael Milner
The attached patch by Michael Milner adds support for using iptables and ip6tables on bridged traffic encapsulated in ppoe frames, similar to what's already supported for vlan. Signed-off-by: Michael Milner <milner@blissisland.ca> Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP] Sysctl documentation: tcp_frto_responseIlpo Järvinen
In addition, fixed minor things in tcp_frto sysctl. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP] FRTO: Sysctl documentation for SACK enhanced versionIlpo Järvinen
The description is overly verbose to avoid ambiguity between "SACK enabled" and "SACK enhanced FRTO" Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-24[IPV6]: Disallow RH0 by default.YOSHIFUJI Hideaki
A security issue is emerging. Disallow Routing Header Type 0 by default as we have been doing for IPv4. Note: We allow RH2 by default because it is harmless. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-28[TCP]: Document several sysctls.John Heffner
This adds documentation for tcp_moderate_rcvbuf, tcp_no_metrics_save, tcp_base_mss, and tcp_mtu_probing. Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET] ip-sysctl.txt: Alphabetize.Stephen Hemminger
Rearrange TCP entries in alpha order. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[TCP]: Restrict congestion control choices.Stephen Hemminger
Allow normal users to only choose among a restricted set of congestion control choices. The default is reno and what ever has been configured as default. But the policy can be changed by administrator at any time. For example, to allow any choice: cp /proc/sys/net/ipv4/tcp_available_congestion_control \ /proc/sys/net/ipv4/tcp_allowed_congestion_control Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[TCP]: Add tcp_available_congestion_control sysctl.Stephen Hemminger
Create /proc/sys/net/ipv4/tcp_available_congestion_control that reflects currently available TCP choices. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-03Fix typos in Documentation/: 'Q'-'R'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'Q'-'R'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
