path: root/Documentation/networking/mac80211-injection.txt
2009-04-22mac80211: update injection documentationJohannes Berg
We don't currently support antenna or rate setting, so remove that. Also update the link -- the current one is dead and the wiki can be kept updated easier. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[MAC80211]: improve radiotap injectionJohannes Berg
This improves radiotap injection by removing the shortcut over TX handlers that led to BUGS when injecting frames without setting a rate and also resulted in various other quirks. Now, TX handlers are run but some information that was present in the radiotap header is used instead of automatic settings. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Andy Green <andy@warmcat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-12[PATCH] mac80211: Monitor mode radiotap injection docsAndy Green
Add monitor mode radiotap injection docs. Signed-off-by: Andy Green <andy@warmcat.com> Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
