path: root/Documentation/networking/s2io.txt
2008-07-07netdev: remove unused S2IO_NAPIFrancois Romieu
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-27s2io: fix documentation about intr_typeMichal Schmidt
The documentation for intr_type module parameter of the s2io driver is not consistent with the code. The comments in drivers/net/s2io.c are OK, but Documentation/networking/s2io.txt is wrong. Pointed out by Andrew Hecox. Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-05[PATCH] S2io: Updated documentationRavinandan Arakali
Hi, This patch provides updated documentation on the Neterion(S2io) driver. Please review the patch. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
