[ Upstream commit ebe96e641dee2cbd135ee802ae7e40c361640088 ]
AF_RDS, PF_RDS and SOL_RDS are available in header files,
and there is no need to get their values from /proc. Document
this correctly.
Fixes: 0c5f9b8830aa ("RDS: Documentation")
Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
SOF_TIMESTAMPING_OPT_ID puts the id in ee_data, not ee_info.
Cc: Willem de Bruijn <willemb@google.com>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Willem de Bruijn <willemb@google.com>
It was initially sent by Lorenzo Colitti, but was subsequently
lost in the final diff he submitted.
Signed-off-by: Loganaden Velvindron <logan@elandsys.com>
__sk_run_filter has been renamed as __bpf_prog_run, so replace them in comments
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
Pull networking updates from David Miller:
"Most notable changes in here:
1) By far the biggest accomplishment, thanks to a large range of
contributors, is the addition of multi-send for transmit. This is
the result of discussions back in Chicago, and the hard work of
several individuals.
Now, when the ->ndo_start_xmit() method of a driver sees
skb->xmit_more as true, it can choose to defer the doorbell
telling the driver to start processing the new TX queue entires.
skb->xmit_more means that the generic networking is guaranteed to
call the driver immediately with another SKB to send.
There is logic added to the qdisc layer to dequeue multiple
packets at a time, and the handling mis-predicted offloads in
software is now done with no locks held.
Finally, pktgen is extended to have a "burst" parameter that can
be used to test a multi-send implementation.
Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4,
virtio_net
Adding support is almost trivial, so export more drivers to
support this optimization soon.
I want to thank, in no particular or implied order, Jesper
Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal
Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann,
David Tat, Hannes Frederic Sowa, and Rusty Russell.
2) PTP and timestamping support in bnx2x, from Michal Kalderon.
3) Allow adjusting the rx_copybreak threshold for a driver via
ethtool, and add rx_copybreak support to enic driver. From
Govindarajulu Varadarajan.
4) Significant enhancements to the generic PHY layer and the bcm7xxx
driver in particular (EEE support, auto power down, etc.) from
Florian Fainelli.
5) Allow raw buffers to be used for flow dissection, allowing drivers
to determine the optimal "linear pull" size for devices that DMA
into pools of pages. The objective is to get exactly the
necessary amount of headers into the linear SKB area pre-pulled,
but no more. The new interface drivers use is eth_get_headlen().
From WANG Cong, with driver conversions (several had their own
by-hand duplicated implementations) by Alexander Duyck and Eric
Dumazet.
6) Support checksumming more smoothly and efficiently for
encapsulations, and add "foo over UDP" facility. From Tom
Herbert.
7) Add Broadcom SF2 switch driver to DSA layer, from Florian
Fainelli.
8) eBPF now can load programs via a system call and has an extensive
testsuite. Alexei Starovoitov and Daniel Borkmann.
9) Major overhaul of the packet scheduler to use RCU in several major
areas such as the classifiers and rate estimators. From John
Fastabend.
10) Add driver for Intel FM10000 Ethernet Switch, from Alexander
Duyck.
11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric
Dumazet.
12) Add Datacenter TCP congestion control algorithm support, From
Florian Westphal.
13) Reorganize sk_buff so that __copy_skb_header() is significantly
faster. From Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits)
netlabel: directly return netlbl_unlabel_genl_init()
net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers
net: description of dma_cookie cause make xmldocs warning
cxgb4: clean up a type issue
cxgb4: potential shift wrapping bug
i40e: skb->xmit_more support
net: fs_enet: Add NAPI TX
net: fs_enet: Remove non NAPI RX
r8169:add support for RTL8168EP
net_sched: copy exts->type in tcf_exts_change()
wimax: convert printk to pr_foo()
af_unix: remove 0 assignment on static
ipv6: Do not warn for informational ICMP messages, regardless of type.
Update Intel Ethernet Driver maintainers list
bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING
tipc: fix bug in multicast congestion handling
net: better IFF_XMIT_DST_RELEASE support
net/mlx4_en: remove NETDEV_TX_BUSY
3c59x: fix bad split of cpu_to_le32(pci_map_single())
net: bcmgenet: fix Tx ring priority programming
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Catalin Marinas:
- eBPF JIT compiler for arm64
- CPU suspend backend for PSCI (firmware interface) with standard idle
states defined in DT (generic idle driver to be merged via a
different tree)
- Support for CONFIG_DEBUG_SET_MODULE_RONX
- Support for unmapped cpu-release-addr (outside kernel linear mapping)
- set_arch_dma_coherent_ops() implemented and bus notifiers removed
- EFI_STUB improvements when base of DRAM is occupied
- Typos in KGDB macros
- Clean-up to (partially) allow kernel building with LLVM
- Other clean-ups (extern keyword, phys_addr_t usage)
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (51 commits)
arm64: Remove unneeded extern keyword
ARM64: make of_device_ids const
arm64: Use phys_addr_t type for physical address
aarch64: filter $x from kallsyms
arm64: Use DMA_ERROR_CODE to denote failed allocation
arm64: Fix typos in KGDB macros
arm64: insn: Add return statements after BUG_ON()
arm64: debug: don't re-enable debug exceptions on return from el1_dbg
Revert "arm64: dmi: Add SMBIOS/DMI support"
arm64: Implement set_arch_dma_coherent_ops() to replace bus notifiers
of: amba: use of_dma_configure for AMBA devices
arm64: Correct ftrace calls to aarch64_insn_gen_branch_imm()
arm64:mm: initialize max_mapnr using function set_max_mapnr
setup: Move unmask of async interrupts after possible earlycon setup
arm64: LLVMLinux: Fix inline arm64 assembly for use with clang
arm64: pageattr: Correctly adjust unaligned start addresses
net: bpf: arm64: fix module memory leak when JIT image build fails
arm64: add PSCI CPU_SUSPEND based cpu_suspend support
arm64: kernel: introduce cpu_init_idle CPU operation
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/doc
Pull documentation updates from Jiri Kosina:
"Updates to kernel documentation.
I took this over (hopefully temporarily) from Randy who was not
willing to maintain it any longer. This pile mostly is a relay of
queue that Randy already had in his tree"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/doc:
Documentation: fix broken v4l-utils URL
Documentation: update include path for mpssd
Documentation: correct parameter error for dma_mapping_error
MAINTAINERS: update location of linux-doc tree
Documentation: remove networking/.gitignore
tools: add more endian.h macros
Make Documenation depend on headers_install
Docs: this_cpu_ops: remove redundant add forms
Documentation: disable vdso_test to avoid breakage with old glibc
Documentation: update vDSO makefile to build portable examples
Documentation: update .gitignore files
Documentation: support glibc versions without htole macros
v4l2-pci-skeleton: Only build if PCI is available
Documentation: fix misc. warnings
Documentation: make functions static to avoid prototype warnings
Documentation: add makefiles for more targets
Documentation: use subdir-y to avoid unnecessary built-in.o files
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine
Pull dmaengine updates from Dan Williams:
"Even though this has fixes marked for -stable, given the size and the
needed conflict resolutions this is 3.18-rc1/merge-window material.
These patches have been languishing in my tree for a long while. The
fact that I do not have the time to do proper/prompt maintenance of
this tree is a primary factor in the decision to step down as
dmaengine maintainer. That and the fact that the bulk of drivers/dma/
activity is going through Vinod these days.
The net_dma removal has not been in -next. It has developed simple
conflicts against mainline and net-next (for-3.18).
Continuing thanks to Vinod for staying on top of drivers/dma/.
Summary:
1/ Step down as dmaengine maintainer see commit 08223d80df38
"dmaengine maintainer update"
2/ Removal of net_dma, as it has been marked 'broken' since 3.13
(commit 77873803363c "net_dma: mark broken"), without reports of
performance regression.
3/ Miscellaneous fixes"
* tag 'dmaengine-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine:
net: make tcp_cleanup_rbuf private
net_dma: revert 'copied_early'
net_dma: simple removal
dmatest: prevent memory leakage on error path in thread
ioat: Use time_before_jiffies()
dmaengine: fix xor sources continuation
dma: mv_xor: Rename __mv_xor_slot_cleanup() to mv_xor_slot_cleanup()
dma: mv_xor: Remove all callers of mv_xor_slot_cleanup()
dma: mv_xor: Remove unneeded mv_xor_clean_completed_slots() call
ioat: Use pci_enable_msix_exact() instead of pci_enable_msix()
drivers: dma: Include appropriate header file in dca.c
drivers: dma: Mark functions as static in dma_v3.c
dma: mv_xor: Add DMA API error checks
ioat/dca: Use dev_is_pci() to check whether it is pci device
This patch demonstrates the effect of delaying update of HW tailptr.
(based on earlier patch by Jesper)
burst=1 is the default. It sends one packet with xmit_more=false
burst=2 sends one packet with xmit_more=true and
2nd copy of the same packet with xmit_more=false
burst=3 sends two copies of the same packet with xmit_more=true and
3rd copy with xmit_more=false
Performance with ixgbe (usec 30):
burst=1 tx:9.2 Mpps
burst=2 tx:13.5 Mpps
burst=3 tx:14.5 Mpps full 10G line rate
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
This work adds the DataCenter TCP (DCTCP) congestion control
algorithm [1], which has been first published at SIGCOMM 2010 [2],
resp. follow-up analysis at SIGMETRICS 2011 [3] (and also, more
recently as an informational IETF draft available at [4]).
DCTCP is an enhancement to the TCP congestion control algorithm for
data center networks. Typical data center workloads are i.e.
i) partition/aggregate (queries; bursty, delay sensitive), ii) short
messages e.g. 50KB-1MB (for coordination and control state; delay
sensitive), and iii) large flows e.g. 1MB-100MB (data update;
throughput sensitive). DCTCP has therefore been designed for such
environments to provide/achieve the following three requirements:
* High burst tolerance (incast due to partition/aggregate)
* Low latency (short flows, queries)
* High throughput (continuous data updates, large file
transfers) with commodity, shallow buffered switches
The basic idea of its design consists of two fundamentals: i) on the
switch side, packets are being marked when its internal queue
length > threshold K (K is chosen so that a large enough headroom
for marked traffic is still available in the switch queue); ii) the
sender/host side maintains a moving average of the fraction of marked
packets, so each RTT, F is being updated as follows:
F := X / Y, where X is # of marked ACKs, Y is total # of ACKs
alpha := (1 - g) * alpha + g * F, where g is a smoothing constant
The resulting alpha (iow: probability that switch queue is congested)
is then being used in order to adaptively decrease the congestion
window W:
W := (1 - (alpha / 2)) * W
The means for receiving marked packets resp. marking them on switch
side in DCTCP is the use of ECN.
RFC3168 describes a mechanism for using Explicit Congestion Notification
from the switch for early detection of congestion, rather than waiting
for segment loss to occur.
However, this method only detects the presence of congestion, not
the *extent*. In the presence of mild congestion, it reduces the TCP
congestion window too aggressively and unnecessarily affects the
throughput of long flows [4].
DCTCP, as mentioned, enhances Explicit Congestion Notification (ECN)
processing to estimate the fraction of bytes that encounter congestion,
rather than simply detecting that some congestion has occurred. DCTCP
then scales the TCP congestion window based on this estimate [4],
thus it can derive multibit feedback from the information present in
the single-bit sequence of marks in its control law. And thus act in
*proportion* to the extent of congestion, not its *presence*.
Switches therefore set the Congestion Experienced (CE) codepoint in
packets when internal queue lengths exceed threshold K. Resulting,
DCTCP delivers the same or better throughput than normal TCP, while
using 90% less buffer space.
It was found in [2] that DCTCP enables the applications to handle 10x
the current background traffic, without impacting foreground traffic.
Moreover, a 10x increase in foreground traffic did not cause any
timeouts, and thus largely eliminates TCP incast collapse problems.
The algorithm itself has already seen deployments in large production
data centers since then.
We did a long-term stress-test and analysis in a data center, short
summary of our TCP incast tests with iperf compared to cubic:
This test measured DCTCP throughput and latency and compared it with
CUBIC throughput and latency for an incast scenario. In this test, 19
senders sent at maximum rate to a single receiver. The receiver simply
ran iperf -s.
The senders ran iperf -c <receiver> -t 30. All senders started
simultaneously (using local clocks synchronized by ntp).
This test was repeated multiple times. Below shows the results from a
single test. Other tests are similar. (DCTCP results were extremely
consistent, CUBIC results show some variance induced by the TCP timeouts
that CUBIC encountered.)
For this test, we report statistics on the number of TCP timeouts,
flow throughput, and traffic latency.
1) Timeouts (total over all flows, and per flow summaries):
CUBIC DCTCP
Total 3227 25
Mean 169.842 1.316
Median 183 1
Max 207 5
Min 123 0
Stddev 28.991 1.600
Timeout data is taken by measuring the net change in netstat -s
"other TCP timeouts" reported. As a result, the timeout measurements
above are not restricted to the test traffic, and we believe that it
is likely that all of the "DCTCP timeouts" are actually timeouts for
non-test traffic. We report them nevertheless. CUBIC will also include
some non-test timeouts, but they are drawfed by bona fide test traffic
timeouts for CUBIC. Clearly DCTCP does an excellent job of preventing
TCP timeouts. DCTCP reduces timeouts by at least two orders of
magnitude and may well have eliminated them in this scenario.
2) Throughput (per flow in Mbps):
CUBIC DCTCP
Mean 521.684 521.895
Median 464 523
Max 776 527
Min 403 519
Stddev 105.891 2.601
Fairness 0.962 0.999
Throughput data was simply the average throughput for each flow
reported by iperf. By avoiding TCP timeouts, DCTCP is able to
achieve much better per-flow results. In CUBIC, many flows
experience TCP timeouts which makes flow throughput unpredictable and
unfair. DCTCP, on the other hand, provides very clean predictable
throughput without incurring TCP timeouts. Thus, the standard deviation
of CUBIC throughput is dramatically higher than the standard deviation
of DCTCP throughput.
Mean throughput is nearly identical because even though cubic flows
suffer TCP timeouts, other flows will step in and fill the unused
bandwidth. Note that this test is something of a best case scenario
for incast under CUBIC: it allows other flows to fill in for flows
experiencing a timeout. Under situations where the receiver is issuing
requests and then waiting for all flows to complete, flows cannot fill
in for timed out flows and throughput will drop dramatically.
3) Latency (in ms):
CUBIC DCTCP
Mean 4.0088 0.04219
Median 4.055 0.0395
Max 4.2 0.085
Min 3.32 0.028
Stddev 0.1666 0.01064
Latency for each protocol was computed by running "ping -i 0.2
<receiver>" from a single sender to the receiver during the incast
test. For DCTCP, "ping -Q 0x6 -i 0.2 <receiver>" was used to ensure
that traffic traversed the DCTCP queue and was not dropped when the
queue size was greater than the marking threshold. The summary
statistics above are over all ping metrics measured between the single
sender, receiver pair.
The latency results for this test show a dramatic difference between
CUBIC and DCTCP. CUBIC intentionally overflows the switch buffer
which incurs the maximum queue latency (more buffer memory will lead
to high latency.) DCTCP, on the other hand, deliberately attempts to
keep queue occupancy low. The result is a two orders of magnitude
reduction of latency with DCTCP - even with a switch with relatively
little RAM. Switches with larger amounts of RAM will incur increasing
amounts of latency for CUBIC, but not for DCTCP.
4) Convergence and stability test:
This test measured the time that DCTCP took to fairly redistribute
bandwidth when a new flow commences. It also measured DCTCP's ability
to remain stable at a fair bandwidth distribution. DCTCP is compared
with CUBIC for this test.
At the commencement of this test, a single flow is sending at maximum
rate (near 10 Gbps) to a single receiver. One second after that first
flow commences, a new flow from a distinct server begins sending to
the same receiver as the first flow. After the second flow has sent
data for 10 seconds, the second flow is terminated. The first flow
sends for an additional second. Ideally, the bandwidth would be evenly
shared as soon as the second flow starts, and recover as soon as it
stops.
The results of this test are shown below. Note that the flow bandwidth
for the two flows was measured near the same time, but not
simultaneously.
DCTCP performs nearly perfectly within the measurement limitations
of this test: bandwidth is quickly distributed fairly between the two
flows, remains stable throughout the duration of the test, and
recovers quickly. CUBIC, in contrast, is slow to divide the bandwidth
fairly, and has trouble remaining stable.
CUBIC DCTCP
Seconds Flow 1 Flow 2 Seconds Flow 1 Flow 2
0 9.93 0 0 9.92 0
0.5 9.87 0 0.5 9.86 0
1 8.73 2.25 1 6.46 4.88
1.5 7.29 2.8 1.5 4.9 4.99
2 6.96 3.1 2 4.92 4.94
2.5 6.67 3.34 2.5 4.93 5
3 6.39 3.57 3 4.92 4.99
3.5 6.24 3.75 3.5 4.94 4.74
4 6 3.94 4 5.34 4.71
4.5 5.88 4.09 4.5 4.99 4.97
5 5.27 4.98 5 4.83 5.01
5.5 4.93 5.04 5.5 4.89 4.99
6 4.9 4.99 6 4.92 5.04
6.5 4.93 5.1 6.5 4.91 4.97
7 4.28 5.8 7 4.97 4.97
7.5 4.62 4.91 7.5 4.99 4.82
8 5.05 4.45 8 5.16 4.76
8.5 5.93 4.09 8.5 4.94 4.98
9 5.73 4.2 9 4.92 5.02
9.5 5.62 4.32 9.5 4.87 5.03
10 6.12 3.2 10 4.91 5.01
10.5 6.91 3.11 10.5 4.87 5.04
11 8.48 0 11 8.49 4.94
11.5 9.87 0 11.5 9.9 0
SYN/ACK ECT test:
This test demonstrates the importance of ECT on SYN and SYN-ACK packets
by measuring the connection probability in the presence of competing
flows for a DCTCP connection attempt *without* ECT in the SYN packet.
The test was repeated five times for each number of competing flows.
Competing Flows 1 | 2 | 4 | 8 | 16
Mean Connection Probability 1 | 0.67 | 0.45 | 0.28 | 0
Median Connection Probability 1 | 0.65 | 0.45 | 0.25 | 0
As the number of competing flows moves beyond 1, the connection
probability drops rapidly.
Enabling DCTCP with this patch requires the following steps:
DCTCP must be running both on the sender and receiver side in your
data center, i.e.:
sysctl -w net.ipv4.tcp_congestion_control=dctcp
Also, ECN functionality must be enabled on all switches in your
data center for DCTCP to work. The default ECN marking threshold (K)
heuristic on the switch for DCTCP is e.g., 20 packets (30KB) at
1Gbps, and 65 packets (~100KB) at 10Gbps (K > 1/7 * C * RTT, [4]).
In above tests, for each switch port, traffic was segregated into two
queues. For any packet with a DSCP of 0x01 - or equivalently a TOS of
0x04 - the packet was placed into the DCTCP queue. All other packets
were placed into the default drop-tail queue. For the DCTCP queue,
RED/ECN marking was enabled, here, with a marking threshold of 75 KB.
More details however, we refer you to the paper [2] under section 3).
There are no code changes required to applications running in user
space. DCTCP has been implemented in full *isolation* of the rest of
the TCP code as its own congestion control module, so that it can run
without a need to expose code to the core of the TCP stack, and thus
nothing changes for non-DCTCP users.
Changes in the CA framework code are minimal, and DCTCP algorithm
operates on mechanisms that are already available in most Silicon.
The gain (dctcp_shift_g) is currently a fixed constant (1/16) from
the paper, but we leave the option that it can be chosen carefully
to a different value by the user.
In case DCTCP is being used and ECN support on peer site is off,
DCTCP falls back after 3WHS to operate in normal TCP Reno mode.
ss {-4,-6} -t -i diag interface:
... dctcp wscale:7,7 rto:203 rtt:2.349/0.026 mss:1448 cwnd:2054
ssthresh:1102 ce_state 0 alpha 15 ab_ecn 0 ab_tot 735584
send 10129.2Mbps pacing_rate 20254.1Mbps unacked:1822 retrans:0/15
reordering:101 rcv_space:29200
... dctcp-reno wscale:7,7 rto:201 rtt:0.711/1.327 ato:40 mss:1448
cwnd:10 ssthresh:1102 fallback_mode send 162.9Mbps pacing_rate
325.5Mbps rcv_rtt:1.5 rcv_space:29200
More information about DCTCP can be found in [1-4].
[1] http://simula.stanford.edu/~alizade/Site/DCTCP.html
[2] http://simula.stanford.edu/~alizade/Site/DCTCP_files/dctcp-final.pdf
[3] http://simula.stanford.edu/~alizade/Site/DCTCP_files/dctcp_analysis-full.pdf
[4] http://tools.ietf.org/html/draft-bensley-tcpm-dctcp-00
Joint work with Florian Westphal and Glenn Judd.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Glenn Judd <glenn.judd@morganstanley.com>
Acked-by: Stephen Hemminger <stephen@networkplumber.org>
Per commit "77873803363c net_dma: mark broken" net_dma is no longer used
and there is no plan to fix it.
This is the mechanical removal of bits in CONFIG_NET_DMA ifdef guards.
Reverting the remainder of the net_dma induced changes is deferred to
subsequent patches.
Marked for stable due to Roman's report of a memory leak in
dma_pin_iovec_pages():
https://lkml.org/lkml/2014/9/3/177
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: David Whipple <whipple@securedatainnovations.ch>
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Cc: <stable@vger.kernel.org>
Reported-by: Roman Gushchin <klamm@yandex-team.ru>
this patch adds all of eBPF verfier documentation and empty bpf_check()
The end goal for the verifier is to statically check safety of the program.
Verifier will catch:
- loops
- out of range jumps
- unreachable instructions
- invalid instructions
- uninitialized register access
- uninitialized stack access
- misaligned stack access
- out of range stack access
- invalid calling convention
More details in Documentation/networking/filter.txt
BPF syscall is a multiplexor for a range of different operations on eBPF.
This patch introduces syscall with single command to create a map.
Next patch adds commands to access maps.
'maps' is a generic storage of different types for sharing data between kernel
and userspace.
Userspace example:
/* this syscall wrapper creates a map with given type and attributes
* and returns map_fd on success.
* use close(map_fd) to delete the map
int bpf_create_map(enum bpf_map_type map_type, int key_size,
int value_size, int max_entries)
union bpf_attr attr = {
.map_type = map_type,
.key_size = key_size,
.value_size = value_size,
.max_entries = max_entries
return bpf(BPF_MAP_CREATE, &attr, sizeof(attr));
'union bpf_attr' is backwards compatible with future extensions.
More details in Documentation/networking/filter.txt and in manpage
Remove empty networking/.gitignore
Signed-off-by: Peter Foley <pefoley2@pefoley.com>
Cc: rdunlap@infradead.org
Cc: linux-doc@vger.kernel.org
Add some missing files to .gitignore.
Push Documentation/.gitignore down into subdirectories.
Add a bunch of previously unbuilt source files to the Documentation build
machinery.
Change the Documentation makefiles from obj-m to subdir-y
to avoid generating unnecessary built-in.o files since nothing
in Documentation/ is ever linked in to vmlinux.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Current ICMP rate limiting uses inetpeer cache, which is an RBL tree
protected by a lock, meaning that hosts can be stuck hard if all cpus
want to check ICMP limits.
When say a DNS or NTP server process is restarted, inetpeer tree grows
quick and machine comes to its knees.
iptables can not help because the bottleneck happens before ICMP
messages are even cooked and sent.
This patch adds a new global limitation, using a token bucket filter,
controlled by two new sysctl :
icmp_msgs_per_sec - INTEGER
Limit maximal number of ICMP packets sent per second from this host.
Only messages whose type matches icmp_ratemask are
controlled by this limit.
Default: 1000
icmp_msgs_burst - INTEGER
icmp_msgs_per_sec controls number of ICMP packets sent per second,
while icmp_msgs_burst controls the burst size of these packets.
Default: 50
Note that if we really want to send millions of ICMP messages per
second, we might extend idea and infra added in commit 04ca6973f7c1a
("ip: make IP identifiers less predictable") :
add a token bucket in the ip_idents hash and no longer rely on inetpeer.
arch/mips/net/bpf_jit.c
drivers/net/can/flexcan.c
Both the flexcan and MIPS bpf_jit conflicts were cases of simple
overlapping changes.
This reverts commit c801e3cc1925 ("ipv4: Clarify in docs that accept_local requires rp_filter.").
It is not needed anymore since commit 1dced6a85482 ("ipv4: Restore accept_local behaviour in fib_validate_source()").
Suggested-by: Julian Anastasov <ja@ssi.bg>
Cc: Gregory Detal <gregory.detal@uclouvain.be>
Cc: Christoph Paasch <christoph.paasch@uclouvain.be>
Cc: Hannes Frederic Sowa <hannes@redhat.com>
Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Signed-off-by: Sébastien Barré <sebastien.barre@uclouvain.be>
MIPS supports BPF JIT since v3.16-rc1
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Daniel Borkmann <dborkman@redhat.com>
Cc: Alexei Starovoitov <ast@plumgrid.com>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
add BPF_LD_IMM64 instruction to load 64-bit immediate value into a register.
All previous instructions were 8-byte. This is first 16-byte instruction.
Two consecutive 'struct bpf_insn' blocks are interpreted as single instruction:
insn[0].code = BPF_LD | BPF_DW | BPF_IMM
insn[0].dst_reg = destination register
insn[0].imm = lower 32-bit
insn[1].code = 0
insn[1].imm = upper 32-bit
All unused fields must be zero.
Classic BPF has similar instruction: BPF_LD | BPF_W | BPF_IMM
which loads 32-bit immediate value into a register.
x64 JITs it as single 'movabsq %rax, imm64'
arm64 may JIT as sequence of four 'movk x0, #imm16, lsl #shift' insn
Note that old eBPF programs are binary compatible with new interpreter.
It helps eBPF programs load 64-bit constant into a register with one
instruction instead of using two registers and 4 instructions:
BPF_MOV32_IMM(R1, imm32)
BPF_ALU64_IMM(BPF_LSH, R1, 32)
BPF_MOV32_IMM(R2, imm32)
BPF_ALU64_REG(BPF_OR, R1, R2)
User space generated programs will use this instruction to load constants only.
To tell kernel that user space needs a pointer the _pseudo_ variant of
this instruction may be added later, which will use extra bits of encoding
to indicate what type of pointer user space is asking kernel to provide.
For example 'off' or 'src_reg' fields can be used for such purpose.
src_reg = 1 could mean that user space is asking kernel to validate and
load in-kernel map pointer.
src_reg = 2 could mean that user space needs readonly data section pointer
src_reg = 3 could mean that user space needs a pointer to per-cpu local data
All such future pseudo instructions will not be carrying the actual pointer
as part of the instruction, but rather will be treated as a request to kernel
to provide one. The kernel will verify the request_for_a_pointer, then
will drop _pseudo_ marking and will store actual internal pointer inside
the instruction, so the end result is the interpreter and JITs never
see pseudo BPF_LD_IMM64 insns and only operate on generic BPF_LD_IMM64 that
loads 64-bit immediate into a register. User space never operates on direct
pointers and verifier can easily recognize request_for_pointer vs other
instructions.
The JIT compiler emits A64 instructions. It supports eBPF only.
Legacy BPF is supported thanks to conversion by BPF core.
JIT is enabled in the same way as for other architectures:
echo 1 > /proc/sys/net/core/bpf_jit_enable
Or for additional compiler output:
echo 2 > /proc/sys/net/core/bpf_jit_enable
See Documentation/networking/filter.txt for more information.
The implementation passes all 57 tests in lib/test_bpf.c
on ARMv8 Foundation Model :) Also tested by Will on Juno platform.
Signed-off-by: Zi Shen Lim <zlim.lnx@gmail.com>
Acked-by: Will Deacon <will.deacon@arm.com>
A buffer is incorrectly zeroed to the length of the pointer. If
cfg_payload_len < sizeof(void *) this can overwrites unrelated memory.
The buffer contents are never read, so no need to zero.
Fixes: 8fe2f761cae9 ("net-timestamp: expand documentation")
Reported-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
As in IPv6 people might increase the igmp query robustness variable to
make sure unsolicited state change reports aren't lost on the network. Add
and document this new knob to igmp code.
RFCs allow tuning this parameter back to first IGMP RFC, so we also use
this setting for all counters, including source specific multicast.
Also take over sysctl value when upping the interface and don't reuse
the last one seen on the interface.
Cc: Flavio Leitner <fbl@redhat.com>
Acked-by: Flavio Leitner <fbl@redhat.com>
This patch adds a new sysctl_mld_qrv knob to configure the mldv1/v2 query
robustness variable. It specifies how many retransmit of unsolicited mld
retransmit should happen. Admins might want to tune this on lossy links.
Also reset mld state on interface down/up, so we pick up new sysctl
settings during interface up event.
IPv6 certification requests this knob to be available.
I didn't make this knob netns specific, as it is mostly a setting in a
physical environment and should be per host.
Expand Documentation/networking/timestamping.txt with new
interfaces and bytestream timestamping. Also minor
cleanup of the other text.
Import txtimestamp.c test of the new features.
Missing documentation for gc_thresh2 sysctl.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Adds newly added FCoE files to the build but only if FCoE module is configured.
Also, updates i40e document for added FCoE support.
Signed-off-by: Vasu Dev <vasu.dev@intel.com>
Tested-by: Jack Morgan<jack.morgan@intel.com>
Signed-off-by: Aaron Brown <aaron.f.brown@intel.com>
clean up names related to socket filtering and bpf in the following way:
- everything that deals with sockets keeps 'sk_*' prefix
- everything that is pure BPF is changed to 'bpf_*' prefix
split 'struct sk_filter' into
struct sk_filter {
atomic_t refcnt;
struct rcu_head rcu;
struct bpf_prog *prog;
and
struct bpf_prog {
u32 jited:1,
len:31;
struct sock_fprog_kern *orig_prog;
unsigned int (*bpf_func)(const struct sk_buff *skb,
const struct bpf_insn *filter);
union {
struct sock_filter insns[0];
struct bpf_insn insnsi[0];
struct work_struct work;
so that 'struct bpf_prog' can be used independent of sockets and cleans up
'unattached' bpf use cases
split SK_RUN_FILTER macro into:
SK_RUN_FILTER to be used with 'struct sk_filter *' and
BPF_PROG_RUN to be used with 'struct bpf_prog *'
__sk_filter_release(struct sk_filter *) gains
__bpf_prog_release(struct bpf_prog *) helper function
also perform related renames for the functions that work
with 'struct bpf_prog *', since they're on the same lines:
sk_filter_size -> bpf_prog_size
sk_filter_select_runtime -> bpf_prog_select_runtime
sk_filter_free -> bpf_prog_free
sk_unattached_filter_create -> bpf_prog_create
sk_unattached_filter_destroy -> bpf_prog_destroy
sk_store_orig_filter -> bpf_prog_store_orig_filter
sk_release_orig_filter -> bpf_release_orig_filter
__sk_migrate_filter -> bpf_migrate_filter
__sk_prepare_filter -> bpf_prepare_filter
API for attaching classic BPF to a socket stays the same:
sk_attach_filter(prog, struct sock *)/sk_detach_filter(struct sock *)
and SK_RUN_FILTER(struct sk_filter *, ctx) to execute a program
which is used by sockets, tun, af_packet
API for 'unattached' BPF programs becomes:
bpf_prog_create(struct bpf_prog **)/bpf_prog_destroy(struct bpf_prog *)
and BPF_PROG_RUN(struct bpf_prog *, ctx) to execute a program
which is used by isdn, ppp, team, seccomp, ptp, xt_bpf, cls_bpf, test_bpf
trivial rename to indicate that this functions performs classic BPF checking
Update the PHY library documentation to describe how a specific PHY
driver can use the PAL MMD register access routines or override those
routines with it's own in the event the PHY does not support the IEEE
standard for reading and writing MMD phy registers.
Signed-off-by: Vince Bridgers <vbridgers2013@gmail.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
The SO_TIMESTAMPING API defines three types of timestamps: software,
hardware in raw format (hwtstamp) and hardware converted to system
format (syststamp). The last has been deprecated in favor of combining
hwtstamp with a PTP clock driver. There are no active users in the
kernel.
The option was device driver dependent. If set, but without hardware
support, the correct behavior is to return zero in the relevant field
in the SCM_TIMESTAMPING ancillary message. Without device drivers
implementing the option, this field is effectively always zero.
Remove the internal plumbing to dissuage new drivers from implementing
the feature. Keep the SOF_TIMESTAMPING_SYS_HARDWARE flag, however, to
avoid breaking existing applications that request the timestamp.
No device driver will ever return an skb_shared_info structure with
syststamp non-zero, so remove the branch that tests for this and
optionally marks the packet timestamp as TP_STATUS_TS_SYS_HARDWARE.
Do not remove the definition TP_STATUS_TS_SYS_HARDWARE, as processes
may refer to it.
This patch makes init_net's high_thresh limit to be the maximum for all
namespaces, thus introducing a global memory limit threshold equal to the
sum of the individual high_thresh limits which are capped.
It also introduces some sane minimums for low_thresh as it shouldn't be
able to drop below 0 (or > high_thresh in the unsigned case), and
overall low_thresh should not ever be above high_thresh, so we make the
following relations for a namespace:
init_net:
high_thresh - max(not capped), min(init_net low_thresh)
low_thresh - max(init_net high_thresh), min (0)
all other namespaces:
high_thresh = max(init_net high_thresh), min(namespace's low_thresh)
low_thresh = max(namespace's high_thresh), min(0)
The major issue with having low_thresh > high_thresh is that we'll
schedule eviction but never evict anything and thus rely only on the
timers.
Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com>
merge functionality into the eviction workqueue.
Instead of rebuilding every n seconds, take advantage of the upper
hash chain length limit.
If we hit it, mark table for rebuild and schedule workqueue.
To prevent frequent rebuilds when we're completely overloaded,
don't rebuild more than once every 5 seconds.
ipfrag_secret_interval sysctl is now obsolete and has been marked as
deprecated, it still can be changed so scripts won't be broken but it
won't have any effect. A comment is left above each unused secret_timer
variable to avoid confusion.
Joint work with Nikolay Aleksandrov.
When the high_thresh limit is reached we try to toss the 'oldest'
incomplete fragment queues until memory limits are below the low_thresh
value. This happens in softirq/packet processing context.
This has two drawbacks:
1) processors might evict a queue that was about to be completed
by another cpu, because they will compete wrt. resource usage and
resource reclaim.
2) LRU list maintenance is expensive.
But when constantly overloaded, even the 'least recently used' element is
recent, so removing 'lru' queue first is not 'fairer' than removing any
other fragment queue.
This moves eviction out of the fast path:
When the low threshold is reached, a work queue is scheduled
which then iterates over the table and removes the queues that exceed
the memory limits of the namespace. It sets a new flag called
INET_FRAG_EVICTED on the evicted queues so the proper counters will get
incremented when the queue is forcefully expired.
When the high threshold is reached, no more fragment queues are
created until we're below the limit again.
The LRU list is now unused and will be removed in a followup patch.
Suggested-by: Eric Dumazet <edumazet@google.com>
Document the Layer 2 hash factors with packet type ID field.
CC: Jay Vosburgh <j.vosburgh@gmail.com>
CC: Veaceslav Falico <vfalico@gmail.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: David S. Miller <davem@davemloft.net>
CC: Pan Jiafei <Jiafei.Pan@freescale.com>
Signed-off-by: Jianhua Xie <jianhua.xie@freescale.com>
The SO_TIMESTAMPING API defines option SOF_TIMESTAMPING_SYS_HW.
This feature is deprecated. It should not be implemented by new
device drivers. Existing drivers do not implement it, either --
with one exception.
Driver developers are encouraged to expose the NIC hw clock as a
PTP HW clock source, instead, and synchronize system time to the
HW source.
The control flag cannot be removed due to being part of the ABI, nor
can the structure scm_timestamping that is returned. Due to the one
legacy driver, the internal datapath and structure are not removed.
This patch only clearly marks the interface as deprecated. Device
drivers should always return a syststamp value of zero.
We can consider adding a WARN_ON_ONCE in__sock_recv_timestamp
if non-zero syststamp is encountered
Acked-by: Richard Cochran <richardcochran@gmail.com>
Automatically generate flow labels for IPv6 packets on transmit.
The flow label is computed based on skb_get_hash. The flow label will
only automatically be set when it is zero otherwise (i.e. flow label
manager hasn't set one). This supports the transmit side functionality
of RFC 6438.
Added an IPv6 sysctl auto_flowlabels to enable/disable this behavior
system wide, and added IPV6_AUTOFLOWLABEL socket option to enable this
functionality per socket.
By default, auto flowlabels are disabled to avoid possible conflicts
with flow label manager, however if this feature proves useful we
may want to enable it by default.
It should also be noted that FreeBSD has already implemented automatic
flow labels (including the sysctl and socket option). In FreeBSD,
automatic flow labels default to enabled.
Performance impact:
Running super_netperf with 200 flows for TCP_RR and UDP_RR for
IPv6. Note that in UDP case, __skb_get_hash will be called for
every packet with explains slight regression. In the TCP case
the hash is saved in the socket so there is no regression.
Automatic flow labels disabled:
TCP_RR:
86.53% CPU utilization
127/195/322 90/95/99% latencies
1.40498e+06 tps
UDP_RR:
90.70% CPU utilization
118/168/243 90/95/99% latencies
1.50309e+06 tps
Automatic flow labels enabled:
TCP_RR:
85.90% CPU utilization
128/199/337 90/95/99% latencies
1.40051e+06
UDP_RR
92.61% CPU utilization
115/164/236 90/95/99% latencies
1.4687e+06
Signed-off-by: Tom Herbert <therbert@google.com>
Using pktgen I'm seeing the ixgbe driver "push-back", due TX ring
running full. Thus, the TX ring is artificially limiting pktgen.
(Diagnose via "ethtool -S", look for "tx_restart_queue" or "tx_busy"
counters.)
Using ixgbe, the real reason behind the TX ring running full, is due
to TX ring not being cleaned up fast enough. The ixgbe driver combines
TX+RX ring cleanups, and the cleanup interval is affected by the
ethtool --coalesce setting of parameter "rx-usecs".
Do not increase the default NIC TX ring buffer or default cleanup
interval. Instead simply document that pktgen needs special NIC
tuning for maximum packet per sec performance.
Performance results with pktgen with clone_skb=100000.
TX ring size 512 (default), adjusting "rx-usecs":
(Single CPU performance, E5-2630, ixgbe)
- 3935002 pps - rx-usecs: 1 (irqs: 9346)
- 5132350 pps - rx-usecs: 10 (irqs: 99157)
- 5375111 pps - rx-usecs: 20 (irqs: 50154)
- 5454050 pps - rx-usecs: 30 (irqs: 33872)
- 5496320 pps - rx-usecs: 40 (irqs: 26197)
- 5502510 pps - rx-usecs: 50 (irqs: 21527)
TX ring size adjusting (ethtool -G), "rx-usecs==1" (default):
- 3935002 pps - tx-size: 512
- 5354401 pps - tx-size: 768
- 5356847 pps - tx-size: 1024
- 5327595 pps - tx-size: 1536
- 5356779 pps - tx-size: 2048
- 5353438 pps - tx-size: 4096
Notice after commit 6f25cd47d (pktgen: fix xmit test for BQL enabled
devices) pktgen uses netif_xmit_frozen_or_drv_stopped() and ignores
the BQL "stack" pause (QUEUE_STATE_STACK_XOFF) flag. This allow us to put
more pressure on the TX ring buffers.
It is the ixgbe_maybe_stop_tx() call that stops the transmits, and
pktgen respecting this in the call to netif_xmit_frozen_or_drv_stopped(txq).
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
This can be used in virtual networking applications, and
may have other uses as well. The option is disabled by
default.
A specific use case is setting up virtual routers, bridges, and
hosts on a single OS without the use of network namespaces or
virtual machines. With proper use of ip rules, routing tables,
veth interface pairs and/or other virtual interfaces,
and applications that can bind to interfaces and/or IP addresses,
it is possibly to create one or more virtual routers with multiple
hosts attached. The host interfaces can act as IPv6 systems,
with radvd running on the ports in the virtual routers. With the
option provided in this patch enabled, those hosts can now properly
obtain IPv6 addresses from the radvd.
Signed-off-by: Ben Greear <greearb@candelatech.com>
1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov.
2) Multiqueue support in xen-netback and xen-netfront, from Andrew J
Benniston.
3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn
Mork.
4) BPF now has a "random" opcode, from Chema Gonzalez.
5) Add more BPF documentation and improve test framework, from Daniel
Borkmann.
6) Support TCP fastopen over ipv6, from Daniel Lee.
7) Add software TSO helper functions and use them to support software
TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia.
8) Support software TSO in fec driver too, from Nimrod Andy.
9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli.
10) Handle broadcasts more gracefully over macvlan when there are large
numbers of interfaces configured, from Herbert Xu.
11) Allow more control over fwmark used for non-socket based responses,
from Lorenzo Colitti.
12) Do TCP congestion window limiting based upon measurements, from Neal
Cardwell.
13) Support busy polling in SCTP, from Neal Horman.
14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru.
15) Bridge promisc mode handling improvements from Vlad Yasevich.
16) Don't use inetpeer entries to implement ID generation any more, it
performs poorly, from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits)
rtnetlink: fix userspace API breakage for iproute2 < v3.9.0
tcp: fixing TLP's FIN recovery
net: fec: Add software TSO support
net: fec: Add Scatter/gather support
net: fec: Increase buffer descriptor entry number
net: fec: Factorize feature setting
net: fec: Enable IP header hardware checksum
net: fec: Factorize the .xmit transmit function
bridge: fix compile error when compiling without IPv6 support
bridge: fix smatch warning / potential null pointer dereference
via-rhine: fix full-duplex with autoneg disable
bnx2x: Enlarge the dorq threshold for VFs
bnx2x: Check for UNDI in uncommon branch
bnx2x: Fix 1G-baseT link
bnx2x: Fix link for KR with swapped polarity lane
sctp: Fix sk_ack_backlog wrap-around problem
net/core: Add VF link state control policy
net/fsl: xgmac_mdio is dependent on OF_MDIO
net/fsl: Make xgmac_mdio read error message useful
net_sched: drr: warn when qdisc is not work conserving
This patch adds a description of eBPFs instruction encoding in order
to bring the documentation in line with the implementation.
Since the term eBPF is used anyway on mailing list discussions, lets
also document that in the main BPF documentation file and replace a
couple of occurrences with eBPF terminology to be more clear.
The macro 'A' used in internal BPF interpreter:
#define A regs[insn->a_reg]
was easily confused with the name of classic BPF register 'A', since
'A' would mean two different things depending on context.
This patch is trying to clean up the naming and clarify its usage in the
following way:
- A and X are names of two classic BPF registers
- BPF_REG_A denotes internal BPF register R0 used to map classic register A
in internal BPF programs generated from classic
- BPF_REG_X denotes internal BPF register R7 used to map classic register X
- internal BPF instruction format:
struct sock_filter_int {
__u8 code; /* opcode */
__u8 dst_reg:4; /* dest register */
__u8 src_reg:4; /* source register */
__s16 off; /* signed offset */
__s32 imm; /* signed immediate constant */
- BPF_X/BPF_K is 1 bit used to encode source operand of instruction
In classic:
BPF_X - means use register X as source operand
BPF_K - means use 32-bit immediate as source operand
In internal:
BPF_X - means use 'src_reg' register as source operand
Suggested-by: Chema Gonzalez <chema@google.com>
Acked-by: Chema Gonzalez <chema@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial into next
Pull trivial tree changes from Jiri Kosina:
"Usual pile of patches from trivial tree that make the world go round"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits)
staging: go7007: remove reference to CONFIG_KMOD
aic7xxx: Remove obsolete preprocessor define
of: dma: doc fixes
doc: fix incorrect formula to calculate CommitLimit value
doc: Note need of bc in the kernel build from 3.10 onwards
mm: Fix printk typo in dmapool.c
modpost: Fix comment typo "Modules.symvers"
Kconfig.debug: Grammar s/addition/additional/
wimax: Spelling s/than/that/, wording s/destinatary/recipient/
aic7xxx: Spelling s/termnation/termination/
arm64: mm: Remove superfluous "the" in comment
of: Spelling s/anonymouns/anonymous/
dma: imx-sdma: Spelling s/determnine/determine/
ath10k: Improve grammar in comments
ath6kl: Spelling s/determnine/determine/
of: Improve grammar for of_alias_get_id() documentation
drm/exynos: Spelling s/contro/control/
radio-bcm2048.c: fix wrong overflow check
doc: printk-formats: do not mention casts for u64/s64
doc: spelling error changes
drivers/net/bonding/bond_alb.c
drivers/net/ethernet/altera/altera_msgdma.c
drivers/net/ethernet/altera/altera_sgdma.c
net/ipv6/xfrm6_output.c
Several cases of overlapping changes.
The xfrm6_output.c has a bug fix which overlaps the renaming
of skb->local_df to skb->ignore_df.
In the Altera TSE driver cases, the register access cleanups
in net-next overlapped with bug fixes done in net.
Similarly a bug fix to send ALB packets in the bonding driver using
the right source address overlaps with cleanups in net-next.
Mention the recently added test suite in the documentation file.
In commit 61b905da33 ("net: Rename skb->rxhash to skb->hash"), skb->rxhash
was renamed to skb->hash. Update references in Documentation
accordingly.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
