path: root/Documentation/networking
2012-08-14netconsole.txt: revision of examples for the receiver of kernel messagesDirk Gouders
There are at least 4 implementations of netcat with the BSD-based being the only one that has to be used without the -p switch to specify the listening port. Jan Engelhardt suggested to add an example for socat(1). Signed-off-by: Dirk Gouders <gouders@et.bocholt.fh-gelsenkirchen.de> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-30ipv4: remove rt_cache_rebuild_countEric Dumazet
After IP route cache removal, rt_cache_rebuild_count is no longer used. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-22net-next: minor cleanups for bonding documentationRick Jones
The section titled "Configuring Bonding for Maximum Throughput" is actually section twelve not thirteen, and there are a couple of words spelled incorrectly. Signed-off-by: Rick Jones <rick.jones2@hp.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-22sctp: Implement quick failover draft from tsvwgNeil Horman
I've seen several attempts recently made to do quick failover of sctp transports by reducing various retransmit timers and counters. While its possible to implement a faster failover on multihomed sctp associations, its not particularly robust, in that it can lead to unneeded retransmits, as well as false connection failures due to intermittent latency on a network. Instead, lets implement the new ietf quick failover draft found here: http://tools.ietf.org/html/draft-nishida-tsvwg-sctp-failover-05 This will let the sctp stack identify transports that have had a small number of errors, and avoid using them quickly until their reliability can be re-established. I've tested this out on two virt guests connected via multiple isolated virt networks and believe its in compliance with the above draft and works well. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Vlad Yasevich <vyasevich@gmail.com> CC: Sridhar Samudrala <sri@us.ibm.com> CC: "David S. Miller" <davem@davemloft.net> CC: linux-sctp@vger.kernel.org CC: joe@perches.com Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-20Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jesse/openvswitch Jesse Gross says: ==================== A few bug fixes and small enhancements for net-next/3.6. ... Ansis Atteka (1): openvswitch: Do not send notification if ovs_vport_set_options() failed Ben Pfaff (1): openvswitch: Check gso_type for correct sk_buff in queue_gso_packets(). Jesse Gross (2): openvswitch: Enable retrieval of TCP flags from IPv6 traffic. openvswitch: Reset upper layer protocol info on internal devices. Leo Alterman (1): openvswitch: Fix typo in documentation. Pravin B Shelar (1): openvswitch: Check currect return value from skb_gso_segment() Raju Subramanian (1): openvswitch: Replace Nicira Networks. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-20openvswitch: Fix typo in documentation.Leo Alterman
Signed-off-by: Leo Alterman <lalterman@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2012-07-19net-tcp: Fast Open client - cookie-less modeYuchung Cheng
In trusted networks, e.g., intranet, data-center, the client does not need to use Fast Open cookie to mitigate DoS attacks. In cookie-less mode, sendmsg() with MSG_FASTOPEN flag will send SYN-data regardless of cookie availability. Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-19net-tcp: Fast Open client - sendmsg(MSG_FASTOPEN)Yuchung Cheng
sendmsg() (or sendto()) with MSG_FASTOPEN is a combo of connect(2) and write(2). The application should replace connect() with it to send data in the opening SYN packet. For blocking socket, sendmsg() blocks until all the data are buffered locally and the handshake is completed like connect() call. It returns similar errno like connect() if the TCP handshake fails. For non-blocking socket, it returns the number of bytes queued (and transmitted in the SYN-data packet) if cookie is available. If cookie is not available, it transmits a data-less SYN packet with Fast Open cookie request option and returns -EINPROGRESS like connect(). Using MSG_FASTOPEN on connecting or connected socket will result in simlar errno like repeating connect() calls. Therefore the application should only use this flag on new sockets. The buffer size of sendmsg() is independent of the MSS of the connection. Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-19bridge: update documentation referencesstephen hemminger
Update the references to bridge utilities and web pages to current locations Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-17tcp: implement RFC 5961 3.2Eric Dumazet
Implement the RFC 5691 mitigation against Blind Reset attack using RST bit. Idea is to validate incoming RST sequence, to match RCV.NXT value, instead of previouly accepted window : (RCV.NXT <= SEG.SEQ < RCV.NXT+RCV.WND) If sequence is in window but not an exact match, send a "challenge ACK", so that the other part can resend an RST with the appropriate sequence. Add a new sysctl, tcp_challenge_ack_limit, to limit number of challenge ACK sent per second. Add a new SNMP counter to count number of challenge acks sent. (netstat -s | grep TCPChallengeACK) Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Kiran Kumar Kella <kkiran@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-11tcp: TCP Small QueuesEric Dumazet
This introduce TSQ (TCP Small Queues) TSQ goal is to reduce number of TCP packets in xmit queues (qdisc & device queues), to reduce RTT and cwnd bias, part of the bufferbloat problem. sk->sk_wmem_alloc not allowed to grow above a given limit, allowing no more than ~128KB [1] per tcp socket in qdisc/dev layers at a given time. TSO packets are sized/capped to half the limit, so that we have two TSO packets in flight, allowing better bandwidth use. As a side effect, setting the limit to 40000 automatically reduces the standard gso max limit (65536) to 40000/2 : It can help to reduce latencies of high prio packets, having smaller TSO packets. This means we divert sock_wfree() to a tcp_wfree() handler, to queue/send following frames when skb_orphan() [2] is called for the already queued skbs. Results on my dev machines (tg3/ixgbe nics) are really impressive, using standard pfifo_fast, and with or without TSO/GSO. Without reduction of nominal bandwidth, we have reduction of buffering per bulk sender : < 1ms on Gbit (instead of 50ms with TSO) < 8ms on 100Mbit (instead of 132 ms) I no longer have 4 MBytes backlogged in qdisc by a single netperf session, and both side socket autotuning no longer use 4 Mbytes. As skb destructor cannot restart xmit itself ( as qdisc lock might be taken at this point ), we delegate the work to a tasklet. We use one tasklest per cpu for performance reasons. If tasklet finds a socket owned by the user, it sets TSQ_OWNED flag. This flag is tested in a new protocol method called from release_sock(), to eventually send new segments. [1] New /proc/sys/net/ipv4/tcp_limit_output_bytes tunable [2] skb_orphan() is usually called at TX completion time, but some drivers call it in their start_xmit() handler. These drivers should at least use BQL, or else a single TCP session can still fill the whole NIC TX ring, since TSQ will have no effect. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Dave Taht <dave.taht@bufferbloat.net> Cc: Tom Herbert <therbert@google.com> Cc: Matt Mathis <mattmathis@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Nandita Dukkipati <nanditad@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-10vxge/s2io: remove dead URLsJon Mason
URLs to neterion.com and s2io.com no longer resolve. Remove all references to these URLs in the driver source and documentation. Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-01stmmac: update the driver Documentation and add EEEGiuseppe CAVALLARO
This patch updates the stmmac's documentation adding some missing files in the section used to describe the internal driver's structure. Also the patch adds a new section to describe the EEE support. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-30ipv4: Clarify in docs that accept_local requires rp_filter.David S. Miller
2012-06-25Documentation/networking/caif: Update documentationSjur Brændeland
Update drawing and remove description of old features. Add HSI and USB link layers to the drawing. Reported-by: Joerg Reisenweber <joerg.reisenweber@stericssion.com> Signed-off-by: Sjur Brændeland <sjur.brandeland@stericssion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-19canfd: update documentation according to CAN FD extensionsOliver Hartkopp
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-06-18batman-adv: Add get_ethtool_stats() supportMartin Hundebøll
Added additional counters in a bat_stats structure, which are exported through the ethtool api. The counters are specific to batman-adv and includes: forwarded packets and bytes management packets and bytes (aggregated OGMs at this point) translation table packets New counters are added by extending "enum bat_counters" in types.h and adding corresponding descriptive string(s) to bat_counters_strings in soft-iface.c. Counters are increased by calling batadv_add_counter() and incremented by one by calling batadv_inc_counter(). Signed-off-by: Martin Hundebøll <martin@hundeboll.net> Signed-off-by: Sven Eckelmann <sven@narfation.org>
2012-06-12ipv4: Add interface option to enable routing of 127.0.0.0/8Thomas Graf
Routing of 127/8 is tradtionally forbidden, we consider packets from that address block martian when routing and do not process corresponding ARP requests. This is a sane default but renders a huge address space practically unuseable. The RFC states that no address within the 127/8 block should ever appear on any network anywhere but it does not forbid the use of such addresses outside of the loopback device in particular. For example to address a pool of virtual guests behind a load balancer. This patch adds a new interface option 'route_localnet' enabling routing of the 127/8 address block and processing of ARP requests on a specific interface. Note that for the feature to work, the default local route covering 127/8 dev lo needs to be removed. Example: $ sysctl -w net.ipv4.conf.eth0.route_localnet=1 $ ip route del 127.0.0.0/8 dev lo table local $ ip addr add 127.1.0.1/16 dev eth0 $ ip route flush cache V2: Fix invalid check to auto flush cache (thanks davem) Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-06-06Merge branch 'master' of git://gitorious.org/linux-can/linux-can-nextDavid S. Miller
2012-06-06stmmac: update driver's docGiuseppe CAVALLARO
Fixed the driver's documentation that was obsolete and didn't report new platform fields (recently added). Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-23can: update documentation wording error frames -> error messagesOliver Hartkopp
As Heinz-Juergen Oertel pointed out 'CAN error frames' are a already defined term for the CAN protocol violation indication on the wire. To avoid confusion with the error messages created by CAN drivers available via CAN RAW sockets update the documentation and change the naming from 'error frames' to 'error messages' or 'error message frames'. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
2012-05-17drivers/net: delete all code/drivers depending on CONFIG_MCAPaul Gortmaker
The support for CONFIG_MCA is being removed, since the 20 year old hardware simply isn't capable of meeting today's software demands on CPU and memory resources. This commit removes any MCA specific net drivers, and removes any MCA specific probe/support code from drivers that were doing a dual ISA/MCA role. Cc: "David S. Miller" <davem@davemloft.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: netdev@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-05-16Documentation/networking/ieee802154: update MAC chapteralex.bluesman.smirnov@gmail.com
Update the documentation according to latest changes. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-15tokenring: delete all remaining driver supportPaul Gortmaker
This represents the mass deletion of the of the tokenring support. It gets rid of: - the net/tr.c which the drivers depended on - the drivers/net component - the Kbuild infrastructure around it - any tokenring related CONFIG_ settings in any defconfigs - the tokenring headers in the include/linux dir - the firmware associated with the tokenring drivers. - any associated token ring documentation. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-05-14batman-adv: README cleanupsSven Eckelmann
- Add routing_algo - Remove date from README: The date has to be updated when a patch touches the README. Therefore, nearly every feature will modify this date. It can happens quite often that not only one feature is currently in development or waiting on the mailinglist. This creates merge conflicts when applying a patchset. The date itself doesn't provide any additional information when this file is only available in a release tarball or as part of a SCM repository. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-05-08netfilter: bridge: optionally set indev to vlanPablo Neira Ayuso
if net.bridge.bridge-nf-filter-vlan-tagged sysctl is enabled, bridge netfilter removes the vlan header temporarily and then feeds the packet to ip(6)tables. When the new "bridge-nf-pass-vlan-input-device" sysctl is on (default off), then bridge netfilter will also set the in-interface to the vlan interface; if such an interface exists. This is needed to make iptables REDIRECT target work with "vlan-on-top-of-bridge" setups and to allow use of "iptables -i" to match the vlan device name. Also update Documentation with current brnf default settings. Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-05-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/intel/e1000e/param.c drivers/net/wireless/iwlwifi/iwl-agn-rx.c drivers/net/wireless/iwlwifi/iwl-trans-pcie-rx.c drivers/net/wireless/iwlwifi/iwl-trans.h Resolved the iwlwifi conflict with mainline using 3-way diff posted by John Linville and Stephen Rothwell. In 'net' we added a bug fix to make iwlwifi report a more accurate skb->truesize but this conflicted with RX path changes that happened meanwhile in net-next. In e1000e a conflict arose in the validation code for settings of adapter->itr. 'net-next' had more sophisticated logic so that logic was used. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-02tcp: change tcp_adv_win_scale and tcp_rmem[2]Eric Dumazet
tcp_adv_win_scale default value is 2, meaning we expect a good citizen skb to have skb->len / skb->truesize ratio of 75% (3/4) In 2.6 kernels we (mis)accounted for typical MSS=1460 frame : 1536 + 64 + 256 = 1856 'estimated truesize', and 1856 * 3/4 = 1392. So these skbs were considered as not bloated. With recent truesize fixes, a typical MSS=1460 frame truesize is now the more precise : 2048 + 256 = 2304. But 2304 * 3/4 = 1728. So these skb are not good citizen anymore, because 1460 < 1728 (GRO can escape this problem because it build skbs with a too low truesize.) This also means tcp advertises a too optimistic window for a given allocated rcvspace : When receiving frames, sk_rmem_alloc can hit sk_rcvbuf limit and we call tcp_prune_queue()/tcp_collapse() too often, especially when application is slow to drain its receive queue or in case of losses (netperf is fast, scp is slow). This is a major latency source. We should adjust the len/truesize ratio to 50% instead of 75% This patch : 1) changes tcp_adv_win_scale default to 1 instead of 2 2) increase tcp_rmem[2] limit from 4MB to 6MB to take into account better truesize tracking and to allow autotuning tcp receive window to reach same value than before. Note that same amount of kernel memory is consumed compared to 2.6 kernels. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Yuchung Cheng <ycheng@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-02tcp: early retransmitYuchung Cheng
This patch implements RFC 5827 early retransmit (ER) for TCP. It reduces DUPACK threshold (dupthresh) if outstanding packets are less than 4 to recover losses by fast recovery instead of timeout. While the algorithm is simple, small but frequent network reordering makes this feature dangerous: the connection repeatedly enter false recovery and degrade performance. Therefore we implement a mitigation suggested in the appendix of the RFC that delays entering fast recovery by a small interval, i.e., RTT/4. Currently ER is conservative and is disabled for the rest of the connection after the first reordering event. A large scale web server experiment on the performance impact of ER is summarized in section 6 of the paper "Proportional Rate Reduction for TCP”, IMC 2011. http://conferences.sigcomm.org/imc/2011/docs/p155.pdf Note that Linux has a similar feature called THIN_DUPACK. The differences are THIN_DUPACK do not mitigate reorderings and is only used after slow start. Currently ER is disabled if THIN_DUPACK is enabled. I would be happy to merge THIN_DUPACK feature with ER if people think it's a good idea. ER is enabled by sysctl_tcp_early_retrans: 0: Disables ER 1: Reduce dupthresh to packets_out - 1 when outstanding packets < 4. 2: (Default) reduce dupthresh like mode 1. In addition, delay entering fast recovery by RTT/4. Note: mode 2 is implemented in the third part of this patch series. Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-27net: doc: merge /proc/sys/net/core/* documents into one placeShan Wei
All parameter descriptions in /proc/sys/net/core/* now is separated two places. So, merge them into Documentation/sysctl/net.txt. Signed-off-by: Shan Wei <davidshan@tencent.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-16Documentation: Fix typo in multiple files in DocumentationMasanari Iida
Correct multiple spelling typo in Documentation. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Rob Landley <rob@landley.net> Reported-by: Anders Larsen <al@alarsen.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-04-12Merge branch 'master' into for-davemJohn W. Linville
Conflicts: drivers/net/wireless/iwlwifi/iwl-testmode.c net/wireless/nl80211.c
2012-04-12Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
2012-04-11batman-adv: export claim tables through debugfsSimon Wunderlich
Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-04-11batman-adv: add basic bridge loop avoidance codeSimon Wunderlich
This second version of the bridge loop avoidance for batman-adv avoids loops between the mesh and a backbone (usually a LAN). By connecting multiple batman-adv mesh nodes to the same ethernet segment a loop can be created when the soft-interface is bridged into that ethernet segment. A simple visualization of the loop involving the most common case - a LAN as ethernet segment: node1 <-- LAN --> node2 | | wifi <-- mesh --> wifi Packets from the LAN (e.g. ARP broadcasts) will circle forever from node1 or node2 over the mesh back into the LAN. With this patch, batman recognizes backbone gateways, nodes which are part of the mesh and backbone/LAN at the same time. Each backbone gateway "claims" clients from within the mesh to handle them exclusively. By restricting that only responsible backbone gateways may handle their claimed clients traffic, loops are effectively avoided. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-04-10mac80211: set HT channel before associationJohannes Berg
Changing the channel type during operation is confusing to some drivers and will be hard to handle in multi-channel scenarios. Instead of changing the channel, set it to the right HT channel before authenticating/associating and don't change it -- just update the 20/40 MHz restrictions in rate control as needed when changed by the AP. This also fixes a problem that Paul missed in his fix for the "regulatory makes us deaf" issue -- when we couldn't use 40 MHz we still associated saying we were using 40 MHz, which could in similarly broken APs make us never even connect successfully. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-04-06doc, net: Update ndo_start_xmit return type and valuesBen Hutchings
Commit dc1f8bf68b311b1537cb65893430b6796118498a ('netdev: change transmit to limited range type') changed the required return type and 9a1654ba0b50402a6bd03c7b0fe9b0200a5ea7b1 ('net: Optimize hard_start_xmit() return checking') changed the valid numerical return values. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-06doc, net: Remove instruction to set net_device::trans_startBen Hutchings
Commit 08baf561083bc27a953aa087dd8a664bb2b88e8e ('net: txq_trans_update() helper') made it unnecessary for most drivers to set net_device::trans_start (or netdev_queue::trans_start). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-06doc, net: Update netdev operation namesBen Hutchings
Commits d314774cf2cd5dfeb39a00d37deee65d4c627927 ('netdev: network device operations infrastructure') and 008298231abbeb91bc7be9e8b078607b816d1a4a ('netdev: add more functions to netdevice ops') moved and renamed net device operation pointers. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-06doc, net: Update documentation of synchronisation for TX multiqueueBen Hutchings
Commits e308a5d806c852f56590ffdd3834d0df0cbed8d7 ('netdev: Add netdev->addr_list_lock protection.') and e8a0464cc950972824e2e128028ae3db666ec1ed ('netdev: Allocate multiple queues for TX.') introduced more fine-grained locks. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-06doc, net: Remove obsolete reference to dev->pollBen Hutchings
Commit bea3348eef27e6044b6161fd04c3152215f96411 ('[NET]: Make NAPI polling independent of struct net_device objects.') removed the automatic disabling of NAPI polling by dev_close(), and drivers must now do this themselves. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-04stmmac: MDC clock dynamically based on the csr clock inputGiuseppe CAVALLARO
If a specific clk_csr value is passed from the platform this means that the CSR Clock Range selection cannot be changed at run-time and it is fixed (as reported in the driver documentation). Viceversa the driver will try to set the MDC clock dynamically according to the actual clock input. Signed-off-by: Deepak Sikri <deepak.sikri@st.com> Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Reviewed-by: Francesco Virlinzi <francesco.virlinzi@st.com> Reviewed-by: David Laight <david.laight@aculab.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-04stmmac: re-work the internal GMAC DMA platf parametersDeepak SIKRI
This patch re-works the internal GMAC DMA parameters passed from the platform. In the past, we only passed the pbl but, with new core, other parameters can be passed and are mandatory on some platforms. New parameters are documented in stmmac.txt because this patch has an impact for many platforms. Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Signed-off-by: Deepak Sikri <deepak.sikri@st.com> Hacked-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-04stmmac: Define CSUM offload engine TypesDeepak SIKRI
This patch explicitly defines the CSUM offload engine type which need (not mandatory) to be passed from the platform code. STMMAC core supports two check sum offload engine types- Type-1 & Type-2. Also, there are STMMAC cores that do not have the check sum offload capabilities. The behaviour of Type-1 & Type-2 cores related to provision of checksum increases the packet length for Type-1 cores by 2, as the checksum is appended at the end of data packet and the same is made accountable in the DMA status. The STMMAC cores beyond Version-3.5 provide HW interface registers which allows the user to read the HW capabilities, while to support the previous cores the information related to HW capabilities has to be provided from the platform code. The Type-1 cores which do not have the HW register interface need this information. This patch also updates the driver's doc. Signed-off-by: Deepak Sikri <deepak.sikri@st.com> Hacked-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-03TCP: update ip_local_port_range documentationFernando Luis Vazquez Cao
The explanation of ip_local_port_range in Documentation/networking/ip-sysctl.txt contains several factual errors: - The default value of ip_local_port_range does not depend on the amount of memory available in the system. - tcp_tw_recycle is not enabled by default. - 1024-4999 is not the default value. - Etc. Clean up the mess. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-30Documentation: replace install commands with softdepsLucas De Marchi
Install commands should not be used to specify soft dependencies among modules. When loading modules it's much better to have a softdep that modprobe knows what's being done than having to fork/exec another instance of modprobe to load the other module. By using a softdep user has also an option to remove the dependencies when removing the module (and if its refcount dropped to 0) Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-30Documentation: remove references to /etc/modprobe.confLucas De Marchi
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and is no longer parsed by new kmod tool. References to this file are replaced in Documentation, comments and Kconfig according to the context. There are also some references to the old /etc/modules.conf from 2.4 kernels that are being removed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
