path: root/Documentation/pcmcia
2014-09-26Documentation: use subdir-y to avoid unnecessary built-in.o filesPeter Foley
Change the Documentation makefiles from obj-m to subdir-y to avoid generating unnecessary built-in.o files since nothing in Documentation/ is ever linked in to vmlinux. Signed-off-by: Peter Foley <pefoley2@pefoley.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-29pcmcia: use autoconfiguration feature for ioports and iomemDominik Brodowski
When CONF_AUTO_SET_IO or CONF_AUTO_SET_IOMEM are set, the corresponding fields in struct pcmcia_device *p_dev->resource[0,1,2] are set accordinly. Drivers wishing to override certain settings may do so in the callback function, but they no longer need to parse the CIS entries stored in cistpl_cftable_entry_t themselves. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: linux-bluetooth@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: convert pcmcia_request_configuration to pcmcia_enable_deviceDominik Brodowski
pcmcia_enable_device() now replaces pcmcia_request_configuration(). Instead of config_req_t, all necessary flags are either passed as a parameter to pcmcia_enable_device(), or (in rare circumstances) set in struct pcmcia_device -> flags. With the last remaining user of include/pcmcia/cs.h gone, remove all references. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: do not use win_req_t when calling pcmcia_request_window()Dominik Brodowski
Instead of win_req_t, drivers are now requested to fill out struct pcmcia_device *p_dev->resource[2,3,4,5] for up to four iomem ranges. After a call to pcmcia_request_window(), the windows found there are reserved and may be used until pcmcia_release_window() is called. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-mtd@lists.infradead.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: do not use io_req_t when calling pcmcia_request_io()Dominik Brodowski
Instead of io_req_t, drivers are now requested to fill out struct pcmcia_device *p_dev->resource[0,1] for up to two ioport ranges. After a call to pcmcia_request_io(), the ports found there are reserved, after calling pcmcia_request_configuration(), they may be used. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Michael Buesch <mb@bu3sch.de> Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove cs_types.hDominik Brodowski
Remove cs_types.h which is no longer needed: Most definitions aren't used at all, a few can be made away with, and two remaining definitions (typedefs, unfortunatley) may be moved to more specific places. CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: dev_node removal (core)Dominik Brodowski
Remove the dev_node declaration. We now only pass the device name to the deprecated userspace tools. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: re-work pcmcia_request_irq()Dominik Brodowski
Instead of the old pcmcia_request_irq() interface, drivers may now choose between: - calling request_irq/free_irq directly. Use the IRQ from *p_dev->irq. - use pcmcia_request_irq(p_dev, handler_t); the PCMCIA core will clean up automatically on calls to pcmcia_disable_device() or device ejection. - drivers still not capable of IRQF_SHARED (or not telling us so) may use the deprecated pcmcia_request_exclusive_irq() for the time being; they might receive a shared IRQ nonetheless. CC: linux-bluetooth@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-usb@vger.kernel.org CC: linux-ide@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-02-17pcmcia: use ops_mutex for rsrc_{mgr,nonstatic} lockingDominik Brodowski
2010-02-17pcmcia: assert locking to struct pcmcia_deviceDominik Brodowski
2010-02-17pcmcia: add locking documentationDominik Brodowski
2009-11-09pcmcia: remove now-defunct cs_error, pcmcia_error_{func,ret}Dominik Brodowski
As all in-tree drivers have been converted to not use cs_error() any more, drop these functions and definitions, and update the Documentation. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-08pcmcia: add new CIS access helpersDominik Brodowski
As a replacement to pcmcia_get_{first,next}_tuple() and pcmcia_get_tuple_data(), three new -- and easier to use -- functions are added: - pcmcia_get_tuple() to get the very first CIS entry of one type. - pcmcia_loop_tuple() to loop over all CIS entries of one type. - pcmcia_get_mac_from_cis() to read out the hardware MAC address from CISTPL_FUNCE. Only a handful of drivers need these functions anyway, as most CIS access is already handled by pcmcia_loop_config(), which now shares the same backed (pccard_loop_tuple()) with pcmcia_loop_tuple(). A pcmcia_get_mac_from_cis() bug noted by Komuro <komurojun-mbn@nifty.com> has been fixed in this revision. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-09-23Documentation/: fix warnings from -Wmissing-prototypes in HOSTCFLAGSLadinu Chandrasinghe
Fix up -Wmissing-prototypes in compileable userspace code, mainly under Documentation/. Signed-off-by: Ladinu Chandrasinghe <ladinu.pub@gmail.com> Signed-off-by: Trevor Keith <tsrk@tsrk.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30.gitignore updatesAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (49 commits) pcmcia: ioctl-internal definitions pcmcia: cistpl header cleanup pcmcia: remove unused argument to pcmcia_parse_tuple() pcmcia: card services header cleanup pcmcia: device_id header cleanup pcmcia: encapsulate ioaddr_t pcmcia: cleanup device driver header file pcmcia: cleanup socket services header file pcmcia: merge ds_internal.h into cs_internal.h pcmcia: cleanup cs_internal.h pcmcia: cs_internal.h is internal pcmcia: use dev_printk for cs_error() pcmcia: remove CS_ error codes alltogether pcmcia: deprecate CS_BAD_TUPLE pcmcia: deprecate CS_BAD_ARGS pcmcia: deprecate CS_BAD_BASE, CS_BAD_IRQ, CS_BAD_OFFSET and CS_BAD_SIZE pcmcia: deprecate CS_BAD_ATTRIBUTE, CS_BAD_TYPE and CS_BAD_PAGE pcmcia: deprecate CS_NO_MORE_ITEMS pcmcia: deprecate CS_IN_USE pcmcia: deprecate CS_CONFIGURATION_LOCKED ... Fix trivial conflict in drivers/pcmcia/ds.c manually
2008-08-23pcmcia: add pcmcia_loop_config() helperDominik Brodowski
By calling pcmcia_loop_config(), a pcmcia driver can iterate over all available configuration options. During a driver's probe() phase, one doesn't need to use pcmcia_get_{first,next}_tuple, pcmcia_get_tuple_data and pcmcia_parse_tuple directly in most if not all cases. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-12docsrc: fix crc32hash typeRandy Dunlap
Fix differing signedness warning: Documentation/pcmcia/crc32hash.c:29: warning: pointer targets in passing argument 1 of 'crc32' differ in signedness Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12docsrc: build Documentation/ sourcesRandy Dunlap
Currently source files in the Documentation/ sub-dir can easily bit-rot since they are not generally buildable, either because they are hidden in text files or because there are no Makefile rules for them. This needs to be fixed so that the source files remain usable and good examples of code instead of bad examples. Add the ability to build source files that are in the Documentation/ dir. Add to Kconfig as "BUILD_DOCSRC" config symbol. Use "CONFIG_BUILD_DOCSRC=1 make ..." to build objects from the Documentation/ sources. Or enable BUILD_DOCSRC in the *config system. However, this symbol depends on HEADERS_CHECK since the header files need to be installed (for userspace builds). Built (using cross-tools) for x86-64, i386, alpha, ia64, sparc32, sparc64, powerpc, sh, m68k, & mips. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05pcmcia: replace kio_addr_t with unsigned int everywhereOlof Johansson
Remove kio_addr_t, and replace it with unsigned int. No known architecture needs more than 32 bits for IO addresses and ports and having a separate type for it is just messy. Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07add new_id to PCMCIA driversBernhard Walle
PCI drivers have the new_id file in sysfs which allows new IDs to be added at runtime. The advantage is to avoid re-compilation of a driver that works for a new device, but it's ID table doesn't contain the new device. This mechanism is only meant for testing, after the driver has been tested successfully, the ID should be added in source code so that new revisions of the kernel automatically detect the device. The implementation follows the PCI implementation. The interface is documented in Documentation/pcmcia/driver.txt. Computations should be done in userspace, so the sysfs string contains the raw structure members for matching. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-30[PATCH] pcmcia: expose tool in pcmcia/Documentation/pcmcia/Randy Dunlap
Expose example and tool source files in the Documentation/ directory in their own files instead of being buried (almost hidden) in readme/txt files. This will make them more visible/usable to users who may need to use them, to developers who may need to test with them, and to janitors who would update them if they were more visible. Also, if any of these possibly should not be in the kernel tree at all, it will be clearer that they are here and we can discuss if they should be removed. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: convert remaining users of pcmcia_release_io and _irqDominik Brodowski
Convert the remaining drivers which use pcmcia_release_io or pcmcia_release_irq, and remove the EXPORT of these symbols. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add pcmcia_disable_deviceDominik Brodowski
pcmcia_disable_device(struct pcmcia_device *p_dev) performs the necessary cleanups upon device or driver removal: it calls the appropriate pcmcia_release_* functions, and can replace (most) of the current drivers' _release() functions. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: unify attach, EVENT_CARD_INSERTION handlers into one probe ↵Dominik Brodowski
callback Unify the EVENT_CARD_INSERTION and "attach" callbacks to one unified probe() callback. As all in-kernel drivers are changed to this new callback, there will be no temporary backwards-compatibility. Inside a probe() function, each driver _must_ set struct pcmcia_device *p_dev->instance and instance->handle correctly. With these patches, the basic driver interface for 16-bit PCMCIA drivers now has the classic four callbacks known also from other buses: int (*probe) (struct pcmcia_device *dev); void (*remove) (struct pcmcia_device *dev); int (*suspend) (struct pcmcia_device *dev); int (*resume) (struct pcmcia_device *dev); Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: unify detach, REMOVAL_EVENT handlers into one remove callbackDominik Brodowski
Unify the "detach" and REMOVAL_EVENT handlers to one "remove" function. Old functionality is preserved, for the moment. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[PATCH] pcmcia: new suspend coreDominik Brodowski
Move the suspend and resume methods out of the event handler, and into special functions. Also use these functions for pre- and post-reset, as almost all drivers already do, and the remaining ones can easily be converted. Bugfix to include/pcmcia/ds.c Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2005-07-28[PATCH] pcmcia: update documentationDominik Brodowski
Update the PCMCIA documentation to reflect some more, though older, changes. Parts extracted from an e-mail from Randy Dunlap with his consent. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] pcmcia: Documentation updateDominik Brodowski
Update PCMCIA driver changes for patches merged in 2.6.13 Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] pcmcia: update DocumentationDominik Brodowski
As the information is now exported via sysfs, there's no need for an userspace tool any longer. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] pcmcia: documentation fixJar
Fix example hash generator in Documentation. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] pcmcia: add some DocumentationDominik Brodowski
Add some information useful for PCMCIA device driver authors to Documentation/pcmcia/, and reference it in dmesg in case of hash mismatches. Also add a reference to pcmciautils to Documentation/Changes. With recent changes, you don't need to concern yourself with pcmcia-cs even if you have PCMCIA hardware, so the example above the list needed to be adapted as well. Signed-off-by: Dominik Brodowski <linux@dominikbrodowksi.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
