path: root/Documentation/perf/qcom_l2_pmu.txt
2017-02-08perf: add qcom l2 cache perf events driverNeil Leeder
Adds perf events support for L2 cache PMU. The L2 cache PMU driver is named 'l2cache_0' and can be used with perf events to profile L2 events such as cache hits and misses on Qualcomm Technologies processors. Reviewed-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Neil Leeder <nleeder@codeaurora.org> [will: minimise nesting in l2_cache_associate_cpu_with_cluster] [will: use kstrtoul for unsigned long, remove redunant .owner setting] Signed-off-by: Will Deacon <will.deacon@arm.com>
