path: root/Documentation/power/power_supply_class.txt
2008-05-13power_supply: add CHARGE_COUNTER property and olpc_battery support for itAndres Salomon
This adds PROP_CHARGE_COUNTER to the power supply class (documenting it as well). The OLPC battery driver uses this for spitting out its ACR values (in uAh). We have some rounding errors (the data sheet claims 416.7, the math actually works out to 416.666667, so we're forced to choose between overflows or precision loss. I chose precision loss, and stuck w/ data sheet values), but I don't think anyone will care that much. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2008-03-12documentation: Move power-related files to Documentation/power/Randy Dunlap
Move 00-INDEX entries to power/00-INDEX (and add entry for pm_qos_interface.txt). Update references to moved filenames. Fix some trailing whitespace. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Len Brown <len.brown@intel.com>
