path: root/Documentation/powerpc
2007-06-07[POWERPC] Add table of contents to booting-without-of.txtStuart Yoder
Add table of contents. Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-07[POWERPC] Fix typo in booting-without-of-txt section numberingStuart Yoder
Fix typo in section numbering. Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-09misc doc and kconfig typosMatt LaPlante
Fix various typos in kernel docs and Kconfigs, 2.6.21-rc4. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-02[POWERPC] Document phy-connection-type propertyKim Phillips
Since ucc_geth is being migrated to use the phylib, the existing (undocumented) 'interface' property is being deprecated in favour of 'phy-connection-type'. phy-connection-type is now maintained one-to-one with definitions in include/linux/phy.h, albeit in the form of a string. If not specified, "mii" is assumed. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-27[POWERPC] Fix typos in booting-without-of.txtDomen Puncer
Fix typos + some cosmetic changes. Signed-off-by: Domen Puncer <domen.puncer@telargo.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-21[POWERPC] Document the linux,network-index property.Scott Wood
To allow more robust association of each network device node with an index (such as is used by the firmware or an EEPROM to indicate MAC addresses), a network device's node may specify the index explicitly. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: David Gibson david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-16[POWERPC] Update documentation for flat device tree format v17David Gibson
This patch updates booting-without-of.txt to describe version 17 of the flattened device tree format. Version 17 is a small, backwards compatible change from version 16, adding an extra field giving the size of the device tree's structure block. At this time, the kernel has no use for the extra information, however its presence can make life easier for bootloaders or other software manipulating the tree. In addition this patch adds information on the size_dt_strings field of the device tree header, present since version 3 of the flattened tree format, but omitted from the documentation. It also makes changes to consistently refer to versions 16 and 17 as versions 16 and 17 in decimal, rather than version 0x10 which was occasionally used for version 16 previously. Finally, we also add the new field to the definition of the device tree header structure in prom.h Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Acked-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-09[POWERPC] Update interrupt info in booting-without-of.txtStuart Yoder
Create a new section descrbing how interrupts are represented in the device tree. Added more detail. Clarified some things. Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-08[POWERPC] Remove interrupt-controller as a property under /chosenStuart Yoder
Remove interrupt-controller as a valid property under /chosen in the documentation. There is a consensus that an interrupt-controller property does not belong under /chosen. /chosen is specifically for dynamic properties set at runtime. Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-17[POWERPC] powerpc: remove references to the obsolete linux,platform propertyStuart Yoder
Remove references to the linux,platform property from booting-without-of.txt since it is obsolete. Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-16[POWERPC] Delete boot-cpu property from all DTS filesTimur Tabi
The 'linux,boot-cpu' property is obsolete, so remove it from all of the DTS files and from booting-without-of.txt. The boot CPU is actually defined in the device tree header, and U-Boot sets that field. The device tree compiler also complains if the property exists. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Acked-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] mpc5200 device tree bindings refinementGrant Likely
Much needed refinement of mpc5200 device tree binding specifications. Short list: - drop mpc52xx designator; only two supported chips exist, 5200 and 5200b. It's premature to refer to them as '52xx'. - Specify optional 'model' and 'revision' properties in the soc5200 node - Specify reqiured 'cell-index' property to identify between multiple SOC devices of the same type. (Useful for arbitrating shared register access) - Specify optional 'port-number' property for adjusting the logical serial port assignments. - Specify optional 'has-wdt' property for gpt0 node. - Add system-frequency property to soc5200 node Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-08[POWERPC] 83xx: Added new dr_mode property for usb controller on 83xxLi Yang
Added a new dr_mode property to describe what mode the DR controller is being used in (host, device, OTG). Updated the MPC8349E MDS dts with this new property. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-01-22[POWERPC] Make it blatantly clear; mpc5200 device tree is not yet stableGrant Likely
Documentation-only change. The 5200 device tree layout has not yet stablized, so nobody should depend on the layout of the tree. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-01-09[POWERPC] Fix mpc52xx fdt to use correct device_type for sound devicesGrant Likely
This corrects the documented interface for mpc52xx device trees. Sound devices should be using 'sound' for the device_type field, not the type of sound interface. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-20[POWERPC] Update MTD OF documentationVitaly Wool
This updates the Documentation/powerpc part of the MTD OF implementation with the new field probe-type. Its support has already been implemented in MTD part (drivers/mtd/maps/physmap_of.c). Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[POWERPC] Document describing mpc52xx device tree binding conventionsGrant Likely
This document describes the device tree expectations for mpc52xx based boards. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[POWERPC] Add of_platform support for ROM devicesVitaly Wool
This adds support for flash device descriptions to the OF device tree. It's inspired by and partially borrowed from Sergei's patch "[RFC] Adding MTD to device tree.patch". Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-30Fix typos in /Documentation : MiscMatt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some misc words. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (25 commits) [POWERPC] Add support for the mpc832x mds board [POWERPC] Add initial support for the e300c2 core [POWERPC] Add MPC8360EMDS default dts file [POWERPC] Add MPC8360EMDS board support [POWERPC] Add QUICC Engine (QE) infrastructure [POWERPC] Add QE device tree node definition [POWERPC] Don't try to just continue if xmon has no input device [POWERPC] Fix a printk in pseries_mpic_init_IRQ [POWERPC] Get default baud rate in udbg_scc [POWERPC] Fix zImage.coff on oldworld PowerMac [POWERPC] Fix xmon=off and cleanup xmon initialisation [POWERPC] Cleanup include/asm-powerpc/xmon.h [POWERPC] Update swim3 printk after blkdev.h change [POWERPC] Cell interrupt rework POWERPC: mpc82xx merge: board-specific/platform stuff(resend) POWERPC: 8272ads merge to powerpc: common stuff POWERPC: Added devicetree for mpc8272ads board [POWERPC] iSeries has no legacy I/O [POWERPC] implement BEGIN/END_FW_FTR_SECTION [POWERPC] iSeries does not need pcibios_fixup_resources ...
2006-10-04[POWERPC] Add QE device tree node definitionLi Yang
OF device tree node spec used in QE/8360 support patches. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jiang Bo <Tanya.jiang@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-03Fix typos in Documentation/: 'S'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letter 'S'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'Q'-'R'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'Q'-'R'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'F'-'G'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'F'-'G'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'B'-'C'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'B'-'C'. There are also a few grammar fixes thrown in for Randy. ;) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-30[POWERPC] Fix MPIC sense codes in documentationBenjamin Herrenschmidt
The booting-without-of.txt had incorrect definition for the sense codes for an OpenPIC controller Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-08-18[POWERPC] Convert to mac-address for ethernet MAC address data.Jon Loeliger
Also accept "local-mac-address". However the old "address" is now obsolete, but accepted for backwards compatibility. It should be removed after all device trees have been converted to use "mac-address". Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-03Documentation: correct values in MPC8548E SEC example nodeKim Phillips
Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-03-28[PATCH] powerpc: Kill _machine and hard-coded platform numbersBenjamin Herrenschmidt
This removes statically assigned platform numbers and reworks the powerpc platform probe code to use a better mechanism. With this, board support files can simply declare a new machine type with a macro, and implement a probe() function that uses the flattened device-tree to detect if they apply for a given machine. We now have a machine_is() macro that replaces the comparisons of _machine with the various PLATFORM_* constants. This commit also changes various drivers to use the new macro instead of looking at _machine. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-23[PATCH] powerpc: Add FSL SEC node to documentationKim Phillips
Documentation: Added FSL SOC SEC node definition Updated the documentation to include the definition of the SEC device node format for Freescale SOC devices. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-22[PATCH] powerpc: update mailing list addressesStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-10[PATCH] powerpc: trivial: modify comments to refer to new location of filesJon Mason
This patch removes all self references and fixes references to files in the now defunct arch/ppc64 tree. I think this accomplises everything wanted, though there might be a few references I missed. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-10[PATCH] powerpc: Add FSL USB node to documentationBecky Bruce
Updated the documentation to include the definition of the USB device node format for Freescale SOC devices. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-07[PATCH] documentation/powerpc: add bus-frequency property to SOC nodeBecky Bruce
Updated SOC node definition in documentation to include bus-frequency property. Also extended mdio example to match specification. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@gate.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-01[PATCH] powerpc: Add flattened device tree documentationDavid Gibson
The flattened device tree is the only supported way of booting ARCH=powerpc kernels on non Open Firmware machines. The documentation for the flattened tree format and contents has been discussed on mailing lists and lately has been living in the dtc git tree. Really, it ought to go in the kernel's Documentation directory for maximum visibility. Signed-off-by: David Gibson <dwg@au1.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] Documentation/powerpc: index updateNicolas Kaiser
Add three files not mentioned in Documentation/powerpc/00-INDEX. Sort alphabetically. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-10[PATCH] Spelling fixes for Documentation/Tobias Klauser
The attached patch fixes the following spelling errors in Documentation/ - double "the" - Several misspellings of function/functionality - infomation - memeory - Recieved - wether and possibly others which I forgot ;-) Trailing whitespaces on the same line as the typo are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] Driver Core: remove driver model detach_stateDavid Brownell
The driver model has a "detach_state" mechanism that: - Has never been used by any in-kernel drive; - Is superfluous, since driver remove() methods can do the same thing; - Became buggy when the suspend() parameter changed semantics and type; - Could self-deadlock when called from certain suspend contexts; - Is effectively wasted documentation, object code, and headspace. This removes that "detach_state" mechanism; net code shrink, as well as a per-device saving in the driver model and sysfs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
