path: root/Documentation/powerpc
2014-10-08cxl: Add documentation for userspace APIsIan Munsie
This documentation gives an overview of the hardware architecture, userspace APIs via /dev/cxl/afuM.N and the syfs files. It also adds a MAINTAINERS file entry for cxl. Signed-off-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-07-28KVM: PPC: Remove 440 supportAlexander Graf
The 440 target hasn't been properly functioning for a few releases and before I was the only one who fixes a very serious bug that indicates to me that nobody used it before either. Furthermore KVM on 440 is slow to the extent of unusable. We don't have to carry along completely unused code. Remove 440 and give us one less thing to worry about. Signed-off-by: Alexander Graf <agraf@suse.de>
2014-06-10Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Ben Herrenschmidt: "Here is the bulk of the powerpc changes for this merge window. It got a bit delayed in part because I wasn't paying attention, and in part because I discovered I had a core PCI change without a PCI maintainer ack in it. Bjorn eventually agreed it was ok to merge it though we'll probably improve it later and I didn't want to rebase to add his ack. There is going to be a bit more next week, essentially fixes that I still want to sort through and test. The biggest item this time is the support to build the ppc64 LE kernel with our new v2 ABI. We previously supported v2 userspace but the kernel itself was a tougher nut to crack. This is now sorted mostly thanks to Anton and Rusty. We also have a fairly big series from Cedric that add support for 64-bit LE zImage boot wrapper. This was made harder by the fact that traditionally our zImage wrapper was always 32-bit, but our new LE toolchains don't really support 32-bit anymore (it's somewhat there but not really "supported") so we didn't want to rely on it. This meant more churn that just endian fixes. This brings some more LE bits as well, such as the ability to run in LE mode without a hypervisor (ie. under OPAL firmware) by doing the right OPAL call to reinitialize the CPU to take HV interrupts in the right mode and the usual pile of endian fixes. There's another series from Gavin adding EEH improvements (one day we *will* have a release with less than 20 EEH patches, I promise!). Another highlight is the support for the "Split core" functionality on P8 by Michael. This allows a P8 core to be split into "sub cores" of 4 threads which allows the subcores to run different guests under KVM (the HW still doesn't support a partition per thread). And then the usual misc bits and fixes ..." [ Further delayed by gmail deciding that BenH is a dirty spammer. Google knows. ] * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (155 commits) powerpc/powernv: Add missing include to LPC code selftests/powerpc: Test the THP bug we fixed in the previous commit powerpc/mm: Check paca psize is up to date for huge mappings powerpc/powernv: Pass buffer size to OPAL validate flash call powerpc/pseries: hcall functions are exported to modules, need _GLOBAL_TOC() powerpc: Exported functions __clear_user and copy_page use r2 so need _GLOBAL_TOC() powerpc/powernv: Set memory_block_size_bytes to 256MB powerpc: Allow ppc_md platform hook to override memory_block_size_bytes powerpc/powernv: Fix endian issues in memory error handling code powerpc/eeh: Skip eeh sysfs when eeh is disabled powerpc: 64bit sendfile is capped at 2GB powerpc/powernv: Provide debugfs access to the LPC bus via OPAL powerpc/serial: Use saner flags when creating legacy ports powerpc: Add cpu family documentation powerpc/xmon: Fix up xmon format strings powerpc/powernv: Add calls to support little endian host powerpc: Document sysfs DSCR interface powerpc: Fix regression of per-CPU DSCR setting powerpc: Split __SYSFS_SPRSETUP macro arch: powerpc/fadump: Cleaning up inconsistent NULL checks ...
2014-06-05powerpc: Add cpu family documentationMichael Ellerman
This patch adds some documentation on the different cpu families supported by arch/powerpc. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-05-05doc: spelling error changesCarlos Garcia
Fixed multiple spelling errors. Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Carlos E. Garcia <carlos@cgarcia.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-08-27powerpc: Update the 00-Index in Documentation/powerpcMichael Ellerman
People have been dropping things in here without updating the index, do it for them. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-07-01powerpc/perf: Core EBB support for 64-bit book3sMichael Ellerman
Add support for EBB (Event Based Branches) on 64-bit book3s. See the included documentation for more details. EBBs are a feature which allows the hardware to branch directly to a specified user space address when a PMU event overflows. This can be used by programs for self-monitoring with no kernel involvement in the inner loop. Most of the logic is in the generic book3s code, primarily to avoid a proliferation of PMU callbacks. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-06-01powerpc/tm: Fix userspace stack corruption on signal delivery for active ↵Michael Neuling
transactions When in an active transaction that takes a signal, we need to be careful with the stack. It's possible that the stack has moved back up after the tbegin. The obvious case here is when the tbegin is called inside a function that returns before a tend. In this case, the stack is part of the checkpointed transactional memory state. If we write over this non transactionally or in suspend, we are in trouble because if we get a tm abort, the program counter and stack pointer will be back at the tbegin but our in memory stack won't be valid anymore. To avoid this, when taking a signal in an active transaction, we need to use the stack pointer from the checkpointed state, rather than the speculated state. This ensures that the signal context (written tm suspended) will be written below the stack required for the rollback. The transaction is aborted becuase of the treclaim, so any memory written between the tbegin and the signal will be rolled back anyway. For signals taken in non-TM or suspended mode, we use the normal/non-checkpointed stack pointer. Tested with 64 and 32 bit signals Signed-off-by: Michael Neuling <mikey@neuling.org> Cc: <stable@vger.kernel.org> # v3.9 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-06-01powerpc/tm: Abort on emulation and alignment faultsMichael Neuling
If we are emulating an instruction inside an active user transaction that touches memory, the kernel can't emulate it as it operates in transactional suspend context. We need to abort these transactions and send them back to userspace for the hardware to rollback. We can service these if the user transaction is in suspend mode, since the kernel will operate in the same suspend context. This adds a check to all alignment faults and to specific instruction emulations (only string instructions for now). If the user process is in an active (non-suspended) transaction, we abort the transaction go back to userspace allowing the HW to roll back the transaction and tell the user of the failure. This also adds new tm abort cause codes to report the reason of the persistent error to the user. Crappy test case here http://neuling.org/devel/junkcode/aligntm.c Signed-off-by: Michael Neuling <mikey@neuling.org> Cc: <stable@vger.kernel.org> # v3.9 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-06-01powerpc/tm: Update cause codes documentationMichael Neuling
Signed-off-by: Michael Neuling <mikey@neuling.org> Cc: <stable@vger.kernel.org> # 3.9 only Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-18powerpc/ptrace: Add DAWR debug feature info for userspaceMichael Neuling
This adds new debug feature information so that the DAWR can be identified by userspace tools like GDB. Unfortunately the DAWR doesn't sit nicely into the current description that ptrace provides to userspace via struct ppc_debug_info. It doesn't allow for specifying that only some ranges are possible or even the end alignment constraints (DAWR only allows 512 byte wide ranges which can't cross a 512 byte boundary). After talking to Edjunior Machado (GDB ppc developer), it was decided this was the best approach. Just mark it as debug feature DAWR and tools like GDB can internally decide the constraints. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
2013-04-18powerpc: remove PReP platformPaul Bolle
PPC_PREP is marked as BROKEN since v2.6.15. Remove all PReP specific code now. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
2013-02-15powerpc: Documentation for transactional memory on powerpcMichael Neuling
Signed-off-by: Matt Evans <matt@ozlabs.org> Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-01-10Documentation/powerpc: Fix path to the powerpc directoryThomas Waldecker
ppc -> powerpc Signed-off-by: Thomas Waldecker <thomas.waldecker@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-11-15powerpc/hw-breakpoint: Use generic hw-breakpoint interfaces for new PPC ↵K.Prasad
ptrace flags PPC_PTRACE_GETHWDBGINFO, PPC_PTRACE_SETHWDEBUG and PPC_PTRACE_DELHWDEBUG are PowerPC specific ptrace flags that use the watchpoint register. While they are targeted primarily towards BookE users, user-space applications such as GDB have started using them for BookS too. This patch enables the use of generic hardware breakpoint interfaces for these new flags. Apart from the usual benefits of using generic hw-breakpoint interfaces, these changes allow debuggers (such as GDB) to use a common set of ptrace flags for their watchpoint needs and allow more precise breakpoint specification (length of the variable can be specified). Mikey added: rebased and added dbginfo.features around #ifdef CONFIG_HAVE_HW_BREAKPOINT Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-03-18Documentation/powerpc/mpc52xx.txt: Checkpatch cleanupAndrea Gelmini
Fix all trailing whitespace errors reported by checkpatch. Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-02-23fadump: Remove the phyp assisted dump code.Mahesh Salgaonkar
Remove the phyp assisted dump implementation which is not is use. Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-02-23fadump: Add documentation for firmware-assisted dump.Mahesh Salgaonkar
Documentation for firmware-assisted dump. This document is based on the original documentation written for phyp assisted dump by Linas Vepstas and Manish Ahuja, with few changes to reflect the current implementation. Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-16Documentation: add devicetree docs index fileRob Landley
The device tree infrastructure is being genericized so its documentation moved out of the PowerPC directory. Signed-off-by: Rob Landley <rlandley@parallels.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-31dt: Move device tree documentation out of powerpc directoryGrant Likely
The device tree is used by more than just PowerPC. Make the documentation directory available to all. v2: reorganized files while moving to create arch and driver specific directories. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-11Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (72 commits) powerpc/pseries: Fix build of topology stuff without CONFIG_NUMA powerpc/pseries: Fix VPHN build errors on non-SMP systems powerpc/83xx: add mpc8308_p1m DMA controller device-tree node powerpc/83xx: add DMA controller to mpc8308 device-tree node powerpc/512x: try to free dma descriptors in case of allocation failure powerpc/512x: add MPC8308 dma support powerpc/512x: fix the hanged dma transfer issue powerpc/512x: scatter/gather dma fix powerpc/powermac: Make auto-loading of therm_pm72 possible of/address: Use propper endianess in get_flags powerpc/pci: Use printf extension %pR for struct resource powerpc: Remove unnecessary casts of void ptr powerpc: Disable VPHN polling during a suspend operation powerpc/pseries: Poll VPA for topology changes and update NUMA maps powerpc: iommu: Add device name to iommu error printks powerpc: Record vma->phys_addr in ioremap() powerpc: Update compat_arch_ptrace powerpc: Fix PPC_PTRACE_SETHWDEBUG on PPC_BOOK3S powerpc/time: printk time stamp init not correct powerpc: Minor cleanups for machdep.h ...
2010-12-24misc/at24: parse device tree dataWolfram Sang
Information about the pagesize and read-only-status may also come from the devicetree. Parse this data, too, and act accordingly. While we are here, change the initialization printout a bit. write_max is useful to know to detect performance bottlenecks, the rest is superfluous. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-11-29powerpc/4xx: Add suspend and idle supportVictor Gallardo
Add suspend/resume support for 4xx compatible CPUs. See /sys/power/state for available power states configured in. Add two different idle states (idle-wait and idle-doze) controlled via sysfs. Default is idle-wait. cat /sys/devices/system/cpu/cpu0/idle [wait] doze To save additional power, use idle-doze. echo doze > /sys/devices/system/cpu/cpu0/idle cat /sys/devices/system/cpu/cpu0/idle wait [doze] Signed-off-by: Victor Gallardo <vgallardo@apm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2010-11-29powerpc: Fix two typos in Documentation/powerpc/booting-without-of.txtLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (141 commits) USB: mct_u232: fix broken close USB: gadget: amd5536udc.c: fix error path USB: imx21-hcd - fix off by one resource size calculation usb: gadget: fix Kconfig warning usb: r8a66597-udc: Add processing when USB was removed. mxc_udc: add workaround for ENGcm09152 for i.MX35 USB: ftdi_sio: add device ids for ScienceScope USB: musb: AM35x: Workaround for fifo read issue USB: musb: add musb support for AM35x USB: AM35x: Add musb support usb: Fix linker errors with CONFIG_PM=n USB: ohci-sh - use resource_size instead of defining its own resource_len macro USB: isp1362-hcd - use resource_size instead of defining its own resource_len macro USB: isp116x-hcd - use resource_size instead of defining its own resource_len macro USB: xhci: Fix compile error when CONFIG_PM=n USB: accept some invalid ep0-maxpacket values USB: xHCI: PCI power management implementation USB: xHCI: bus power management implementation USB: xHCI: port remote wakeup implementation USB: xHCI: port power management implementation ... Manually fix up (non-data) conflict: the SCSI merge gad renamed the 'hw_sector_size' member to 'physical_block_size', and the USB tree brought a new use of it.
2010-10-22USB: add USB EHCI support for MPC5121 SoCAnatolij Gustschin
Extends FSL EHCI platform driver glue layer to support MPC5121 USB controllers. MPC5121 Rev 2.0 silicon EHCI registers are in big endian format. The appropriate flags are set using the information in the platform data structure. MPC83xx system interface registers are not available on MPC512x, so the access to these registers is isolated in MPC512x case. Furthermore the USB controller clocks must be enabled before 512x register accesses which is done by providing platform specific init callback. The MPC512x internal USB PHY doesn't provide supply voltage. For boards using different power switches allow specifying DRVVBUS and PWR_FAULT signal polarity of the MPC5121 internal PHY using "fsl,invert-drvvbus" and "fsl,invert-pwr-fault" properties in the device tree USB nodes. Adds documentation for this new device tree bindings. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-12powerpc/of: add eSPI controller dts bindings and DTS modificationMingkai Hu
Also modifiy the document of cell-index in SPI controller. Add the SPI flash(s25fl128p01) support on p4080ds and mpc8536ds board. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-20Documentation: fix ozlabs.org mailing list addressStephen Rothwell
This list moved to lists.ozlabs.org quite some time ago. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-16booting-without-of: Remove nonexistent chapters from TOC, fix numberingAnton Vorontsov
Marvell and GPIO bindings live in their own files, so the TOC should not mention them. Also fix chapters numbering. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-11dts: add sdhci,auto-cmd12 field for p4080 device treeRoy Zang
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Cc: Jerry Huang <Chang-Ming.Huang@freescale.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (79 commits) powerpc/8xx: Add support for the MPC8xx based boards from TQC powerpc/85xx: Introduce support for the Freescale P1022DS reference board powerpc/85xx: Adding DTS for the STx GP3-SSA MPC8555 board powerpc/85xx: Change deprecated binding for 85xx-based boards powerpc/tqm85xx: add a quirk for ti1520 PCMCIA bridge powerpc/tqm85xx: update PCI interrupt-map attribute powerpc/mpc8308rdb: support for MPC8308RDB board from Freescale powerpc/fsl_pci: add quirk for mpc8308 pcie bridge powerpc/85xx: Cleanup QE initialization for MPC85xxMDS boards powerpc/85xx: Fix booting for P1021MDS boards powerpc/85xx: Fix SWIOTLB initalization for MPC85xxMDS boards powerpc/85xx: kexec for SMP 85xx BookE systems powerpc/5200/i2c: improve i2c bus error recovery of/xilinxfb: update tft compatible versions powerpc/fsl-diu-fb: Support setting display mode using EDID powerpc/5121: doc/dts-bindings: update doc of FSL DIU bindings powerpc/5121: shared DIU framebuffer support powerpc/5121: move fsl-diu-fb.h to include/linux powerpc/5121: fsl-diu-fb: fix issue with re-enabling DIU area descriptor powerpc/512x: add clock structure for Video-IN (VIU) unit ...
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-01powerpc/5200/i2c: improve i2c bus error recoveryAlbrecht Dreß
This patch improves the recovery of the MPC's I2C bus from errors like bus hangs resulting in timeouts: 1. make the bus timeout configurable, as it depends on the bus clock and the attached slave chip(s); default is still 1 second; 2. detect any of the cases indicated by the CF, BB and RXAK MSR flags if a timeout occurs, and add a missing (required) MAL reset; 3. use a more reliable method to fixup the bus if a hang has been detected. The sequence is sent 9 times which seems to be necessary if a slave "misses" more than one clock cycle. For 400 kHz bus speed, the fixup is also ~70us (81us vs. 150us) faster. Tested on a custom Lite5200b derived board, with a Dallas RTC, AD sensors and NXP IO expander chips attached to the i2c. Changes vs. v1: - use improved bus fixup sequence for all chips (not only the 5200) - calculate real clock from defaults if no clock is given in the device tree - better description (I hope) of the changes. I didn't split the changes in this file into three parts as recommended by Grant, as they actually belong together (i.e. they address one single problem, just in three places of one single source file). Signed-off-by: Albrecht Dreß <albrecht.dress@arcor.de> [grant.likely@secretlab.ca: fixup for ->node to ->dev.of_node transition] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-01powerpc/fsl-diu-fb: Support setting display mode using EDIDAnatolij Gustschin
Adds support for encoding display mode information in the device tree using verbatim EDID block. If the EDID entry in the DIU node is present, the driver will build mode database using EDID data and allow setting the display modes from this database. Otherwise display mode will be set using mode entries from driver's internal database as usual. This patch also updates device tree bindings. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-01powerpc/5121: doc/dts-bindings: update doc of FSL DIU bindingsAnatolij Gustschin
Update compatible and interrupt properties description. Furthermore an example for the MPC5121 has been added. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (92 commits) powerpc: Remove unused 'protect4gb' boot parameter powerpc: Build-in e1000e for pseries & ppc64_defconfig powerpc/pseries: Make request_ras_irqs() available to other pseries code powerpc/numa: Use ibm,architecture-vec-5 to detect form 1 affinity powerpc/numa: Set a smaller value for RECLAIM_DISTANCE to enable zone reclaim powerpc: Use smt_snooze_delay=-1 to always busy loop powerpc: Remove check of ibm,smt-snooze-delay OF property powerpc/kdump: Fix race in kdump shutdown powerpc/kexec: Fix race in kexec shutdown powerpc/kexec: Speedup kexec hash PTE tear down powerpc/pseries: Add hcall to read 4 ptes at a time in real mode powerpc: Use more accurate limit for first segment memory allocations powerpc/kdump: Use chip->shutdown to disable IRQs powerpc/kdump: CPUs assume the context of the oopsing CPU powerpc/crashdump: Do not fail on NULL pointer dereferencing powerpc/eeh: Fix oops when probing in early boot powerpc/pci: Check devices status property when scanning OF tree powerpc/vio: Switch VIO Bus PM to use generic helpers powerpc: Avoid bad relocations in iSeries code powerpc: Use common cpu_die (fixes SMP+SUSPEND build) ...
2010-05-17powerpc: Add interrupt support to mpc8xxx_gpioPeter Korsgaard
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-05-05powerpc/4xx: Add optional "reset_type" property to control reboot via dtsStefan Roese
By setting "reset_type" to one of the following values, the default software reset mechanism may be overidden. Here the possible values of "reset_type": 1 - PPC4xx core reset 2 - PPC4xx chip reset 3 - PPC4xx system reset (default) This will be used by a new PPC440SPe board port, which needs a "chip reset" instead of the default "system reset" to be asserted. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-23Merge branch 'master' into for-nextJiri Kosina
2010-03-29Fix comment and Kconfig typos for 'require' and 'fragment'Gilles Espinasse
Signed-off-by: Gilles Espinasse <g.esp@free.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-26powerpc/fsl: add device tree binding for QE firmwareTimur Tabi
Define a binding for embedding a QE firmware blob into the device tree. Also define a new property for the QE node that links to a firmware node. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-03-07powerpc: doc/dts-bindings: update doc of FSL I2C bindingsWolfgang Grandegger
This patch adds the MPC5121 to the list of supported devices, enhances the doc of the "clock-frequency" property and removes the obsolete "cell-index", "device_type" and "fsl-i2c" property. Furthermore an example for the MPC5121 has been added. Signed-off-by: Wolfgang Grandegger <wg@denx.de> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-03-04Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (28 commits) ioat: cleanup ->timer_fn() and ->cleanup_fn() prototypes ioat3: interrupt coalescing ioat: close potential BUG_ON race in the descriptor cleanup path ioat2: kill pending flag ioat3: use ioat2_quiesce() ioat3: cleanup, don't enable DCA completion writes DMAENGINE: COH 901 318 lli sg offset fix DMAENGINE: COH 901 318 configure channel direction DMAENGINE: COH 901 318 remove irq counting DMAENGINE: COH 901 318 descriptor pool refactoring DMAENGINE: COH 901 318 cleanups dma: Add MPC512x DMA driver Debugging options for the DMA engine subsystem iop-adma: redundant/wrong tests in iop_*_count()? dmatest: fix handling of an even number of xor_sources dmatest: correct raid6 PQ test fsldma: Fix cookie issues fsldma: Fix cookie issues dma: cases IPU_PIX_FMT_BGRA32, BGR32 and ABGR32 are the same in ipu_ch_param_set_size() dma: make Open Firmware device id constant ...
2010-02-28Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/firmware/iscsi_ibft.c
2010-02-19Merge commit 'gcl/next' into nextBenjamin Herrenschmidt
2010-02-17powerpc/of: added documentation for spi chipselectsErnst Schwab
Added devicetree binding documentation for gpios used as chipselect. The code to evaluate these is already present in spi_mpc8xxx.c. Signed-off-by: Ernst Schwab <eschwab@online.de> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
