path: root/Documentation/powerpc
2009-09-23Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (58 commits) mtd: jedec_probe: add PSD4256G6V id mtd: OneNand support for Nomadik 8815 SoC (on NHK8815 board) mtd: nand: driver for Nomadik 8815 SoC (on NHK8815 board) m25p80: Add Spansion S25FL129P serial flashes jffs2: Use SLAB_HWCACHE_ALIGN for jffs2_raw_{dirent,inode} slabs mtd: sh_flctl: register sh_flctl using platform_driver_probe() mtd: nand: txx9ndfmc: transfer 512 byte at a time if possible mtd: nand: fix tmio_nand ecc correction mtd: nand: add __nand_correct_data helper function mtd: cfi_cmdset_0002: add 0xFF intolerance for M29W128G mtd: inftl: fix fold chain block number mtd: jedec: fix compilation problem with I28F640C3B definition mtd: nand: fix ECC Correction bug for SMC ordering for NDFC driver mtd: ofpart: Check availability of reg property instead of name property driver/Makefile: Initialize "mtd" and "spi" before "net" mtd: omap: adding DMA mode support in nand prefetch/post-write mtd: omap: add support for nand prefetch-read and post-write mtd: add nand support for w90p910 (v2) mtd: maps: add mtd-ram support to physmap_of mtd: pxa3xx_nand: add single-bit error corrections reporting ...
2009-09-23powerpc: introduce and document sdhci,wp-inverted property for eSDHCAnton Vorontsov
eSDHC block in MPC837x SOCs reports inverted write-protect state, soon sdhci-of driver will look for sdhci,wp-inverted properties to decide whether apply a specific quirk. So, document the property and add it to device tree source files. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: David Vrabel <david.vrabel@csr.com> Cc: Ben Dooks <ben@fluff.org> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21trivial: fix typo "for for" in multiple filesAnand Gadiyar
trivial: fix typo "for for" in multiple files Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-19mtd: maps: add mtd-ram support to physmap_ofWolfram Sang
Use physmap_of to access RAMs as mtd and add documenation for it. This approach is a lot less intrusive as adding an of-wrapper around plat-ram.c. As most extensions of plat-ram.c (e.g. custom map-functions) can't be mapped to the device tree anyhow, extending physmap_of seems to be the cleanest approach. Tested with a phyCORE-MPC5121e. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Vitaly Wool <vwool@ru.mvista.com> Cc: Artem Bityutskiy <dedekind@infradead.org> Cc: Ken MacLeod <ken@bitsko.slc.ut.us> Cc: Albrecht Dreß <albrecht.dress@arcor.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-28Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-ledsLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-leds: leds: Futher document blink_set leds: Add options to have GPIO LEDs start on or keep their state leds: LED driver for National Semiconductor LP3944 Funlight Chip leds: pca9532 - Indent using tabs, not spaces. leds: Remove an orphan Kconfig entry leds: Further document parameters for blink_set() leds: alix-leds2 fixed for Award BIOS leds: leds-gpio - fix a section mismatch leds: add the sysfs interface into the leds-bd2802 driver for changing wave pattern and led current. leds: change the license information leds: fix led-bd2802 errors while resuming
2009-06-26Merge commit 'kumar/next' into mergeBenjamin Herrenschmidt
2009-06-23leds: Add options to have GPIO LEDs start on or keep their stateTrent Piepho
There already is a "default-on" trigger but there are problems with it. For one, it's a inefficient way to do it and requires led trigger support to be compiled in. But the real reason is that is produces a glitch on the LED. The GPIO is allocate with the LED *off*, then *later* when the trigger runs it is turned back on. If the LED was already on via the GPIO's reset default or action of the firmware, this produces a glitch where the LED goes from on to off to on. While normally this is fast enough that it wouldn't be noticeable to a human observer, there are still serious problems. One is that there may be something else on the GPIO line, like a hardware alarm or watchdog, that is fast enough to notice the glitch. Another is that the kernel may panic before the LED is turned back on, thus hanging with the LED in the wrong state. This is not just speculation, but actually happened to me with an embedded system that has an LED which should turn off when the kernel finishes booting, which was left in the incorrect state due to a bug in the OF LED binding code. We also let GPIO LEDs get their initial value from whatever the current state of the GPIO line is. On some systems the LEDs are put into some state by the firmware or hardware before Linux boots, and it is desired to have them keep this state which is otherwise unknown to Linux. This requires that the underlying GPIO driver support reading the value of output GPIOs. Some drivers support this and some do not. The platform device binding gains a field in the platform data "default_state" that controls this. There are three constants defined to select from on, off, or keeping the current state. The OpenFirmware binding uses a property named "default-state" that can be set to "on", "off", or "keep". The default if the property isn't present is off. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-06-23powerpc: Refactor device tree bindingKumar Gala
Split device tree binding out of booting-without-of.txt and put them into their own files per binding. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-21sdhci: Add support for hosts that are only capable of 1-bit transfersAnton Vorontsov
Some hosts (hardware configurations, or particular SD/MMC slots) may not support 4-bit bus. For example, on MPC8569E-MDS boards we can switch between serial (1-bit only) and nibble (4-bit) modes, thought we have to disable more peripherals to work in 4-bit mode. Along with some small core changes, this patch modifies sdhci-of driver, so that now it looks for "sdhci,1-bit-only" property in the device-tree, and if specified we enable a proper quirk. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Pierre Ossman <pierre@ossman.eu>
2009-06-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1244 commits) pkt_sched: Rename PSCHED_US2NS and PSCHED_NS2US ipv4: Fix fib_trie rebalancing Bluetooth: Fix issue with uninitialized nsh.type in DTL-1 driver Bluetooth: Fix Kconfig issue with RFKILL integration PIM-SM: namespace changes ipv4: update ARPD help text net: use a deferred timer in rt_check_expire ieee802154: fix kconfig bool/tristate muckup bonding: initialization rework bonding: use is_zero_ether_addr bonding: network device names are case sensative bonding: elminate bad refcount code bonding: fix style issues bonding: fix destructor bonding: remove bonding read/write semaphore bonding: initialize before registration bonding: bond_create always called with default parameters x_tables: Convert printk to pr_err netfilter: conntrack: optional reliable conntrack event delivery list_nulls: add hlist_nulls_add_head and hlist_nulls_del ...
2009-06-15Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (103 commits) powerpc: Fix bug in move of altivec code to vector.S powerpc: Add support for swiotlb on 32-bit powerpc/spufs: Remove unused error path powerpc: Fix warning when printing a resource_size_t powerpc/xmon: Remove unused variable in xmon.c powerpc/pseries: Fix warnings when printing resource_size_t powerpc: Shield code specific to 64-bit server processors powerpc: Separate PACA fields for server CPUs powerpc: Split exception handling out of head_64.S powerpc: Introduce CONFIG_PPC_BOOK3S powerpc: Move VMX and VSX asm code to vector.S powerpc: Set init_bootmem_done on NUMA platforms as well powerpc/mm: Fix a AB->BA deadlock scenario with nohash MMU context lock powerpc/mm: Fix some SMP issues with MMU context handling powerpc: Add PTRACE_SINGLEBLOCK support fbdev: Add PLB support and cleanup DCR in xilinxfb driver. powerpc/virtex: Add ml510 reference design device tree powerpc/virtex: Add Xilinx ML510 reference design support powerpc/virtex: refactor intc driver and add support for i8259 cascading powerpc/virtex: Add support for Xilinx PCI host bridge ...
2009-06-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/scsi/fcoe/fcoe.c net/core/drop_monitor.c net/core/net-traces.c
2009-06-12trivial: Miscellaneous documentation typo fixesMatt LaPlante
Fix various typos in documentation txts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12trivial: fix typos s/paramter/parameter/ and s/excute/execute/ in ↵Martin Olsson
documentation and source comments. Signed-off-by: Martin Olsson <martin@minimum.se> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-01can: sja1000: generic OF platform bus driverWolfgang Grandegger
This patch adds a generic driver for SJA1000 chips on the OpenFirmware platform bus found on embedded PowerPC systems. You need a SJA1000 node definition in your flattened device tree source (DTS) file similar to: can@3,100 { compatible = "nxp,sja1000"; reg = <3 0x100 0x80>; interrupts = <2 0>; interrupt-parent = <&mpic>; nxp,external-clock-frequency = <16000000>; }; See also Documentation/powerpc/dts-bindings/can/sja1000.txt. CC: devicetree-discuss@ozlabs.org Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-19powerpc/fsl: Update FSL esdhc bindingKumar Gala
Updated the binding spec to use "fsl,eshdc" as the base compatible rather than the first chip in the family. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-05-19powerpc/qe: update QE Serial NumberHaiying Wang
The latest QE chip may have more Serial Number(SNUM)s of thread to use. We will get the number of SNUMs from device tree by reading the new property "fsl,qe-num-snums", and set 28 as the default number of SNUMs so that it is compatible with the old QE chips' device trees which don't have this new property. The macro QE_NUM_OF_SNUM is defined as the maximum number in QE snum table which is 256. Also we update the snum_init[] array with 18 more new SNUMs which are confirmed to be useful on new chip. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-05-19powerpc/qe: update risc allocation for QEHaiying Wang
Change the RISC allocation to macros instead of enum, add function to read the number of risc engines from the new property "fsl,qe-num-riscs" under the qe node in dts. Add new property "fsl,qe-num-riscs" description in qe.txt Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-05-19powerpc/86xx: Add binding for LAWs and MCMKumar Gala
The first 4k region of CCSR space is well defined for local access windows, CCSRBAR, etc. The second 4k region is well defined as register for configuring and getting errors for the MPX coherency module. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-05-19powerpc/85xx: Add binding for LAWs and ECMKumar Gala
The first 4k region of CCSR space is well defined for local access windows, CCSRBAR, etc. The second 4k region is well defined as register for configuring and getting errors for the ECM coherency module. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-04-22Merge branch 'merge' of git://git.secretlab.ca/git/linux-2.6 into mergePaul Mackerras
2009-04-16powerpc/device-tree: Document MTD nodes with multiple "reg" tuplesStefan Roese
Add binding for mtd nodes with multiple reg tuples. Multiple reg tuples are used when the flash region covers multiple devices of the same type, but not necessarily the same size. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-04-16powerpc/of-device-tree: Factor MTD physmap bindings out of booting-without-ofStefan Roese
It's easier to find bindings descriptions in separate files. So factor out the MTD physmap bindings into a separate file to not clutter booting-without-of.txt more. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-04-08powerpc: Document new FSL I2C bindings and cleanupWolfgang Grandegger
This patch documents the new bindings for the MPC I2C bus driver. Furthermore, it removes obsolete FSL device related definitions for I2C. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-04-06Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (53 commits) [MTD] struct device - replace bus_id with dev_name(), dev_set_name() [MTD] [NOR] Fixup for Numonyx M29W128 chips [MTD] mtdpart: Make ecc_stats more realistic. powerpc/85xx: TQM8548: Update DTS file for multi-chip support powerpc: NAND: FSL UPM: document new bindings [MTD] [NAND] FSL-UPM: Add wait flags to support board/chip specific delays [MTD] [NAND] FSL-UPM: add multi chip support [MTD] [NOR] Add device parent info to physmap_of [MTD] [NAND] Add support for NAND on the Socrates board [MTD] [NAND] Add support for 4KiB pages. [MTD] sysfs support should not depend on CONFIG_PROC_FS [MTD] [NAND] Add parent info for CAFÉ controller [MTD] support driver model updates [MTD] driver model updates (part 2) [MTD] driver model updates [MTD] [NAND] move gen_nand's probe function to .devinit.text [MTD] [MAPS] move sa1100 flash's probe function to .devinit.text [MTD] fix use after free in register_mtd_blktrans [MTD] [MAPS] Drop now unused sharpsl-flash map [MTD] ofpart: Check name property to determine partition nodes. ... Manually fix trivial conflict in drivers/mtd/maps/Makefile
2009-04-06leds: Add openfirmware platform device supportTrent Piepho
Add bindings to support LEDs defined as of_platform devices in addition to the existing bindings for platform devices. New options in Kconfig allow the platform binding code and/or the of_platform code to be turned on. The of_platform code is of course only available on archs that have OF support. The existing probe and remove methods are refactored to use new functions create_gpio_led(), to create and register one led, and delete_gpio_led(), to unregister and free one led. The new probe and remove methods for the of_platform driver can then share most of the common probe and remove code with the platform driver. The suspend and resume methods aren't shared, but they are very short. The actual led driving code is the same for LEDs created by either binding. The OF bindings are based on patch by Anton Vorontsov <avorontsov@ru.mvista.com>. They have been extended to allow multiple LEDs per device. Signed-off-by: Trent Piepho <tpiepho@freescale.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06powerpc: NAND: FSL UPM: document new bindingsWolfgang Grandegger
This patch adds documentation for the new NAND FSL UPM bindings for: NAND: FSL-UPM: add multi chip support NAND: FSL-UPM: Add wait flags to support board/chip specific delays It also documents the old binding for "chip-delay". Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-04-01powerpc: add mmc-spi-slot bindingsAnton Vorontsov
The bindings describes a case where MMC/SD/SDIO slot directly connected to a SPI bus. Such setups are widely used on embedded PowerPC boards. The patch also adds the mmc-spi-slot entry to the OpenFirmware modalias table. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <david-b@pacbell.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30trivial: Fix misspelling of firmwareNick Andrew
Fix misspelling of firmware. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-30Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Manual merge of: arch/powerpc/include/asm/elf.h drivers/i2c/busses/i2c-mpc.c
2009-03-27powerpc: clean up ssi.txt, add definition for fsl,ssi-asynchronousTimur Tabi
Add the definition of the fsl,ssi-asynchronous property to ssi.txt (documentation of the device tree bindings for the Freescale SSI device). Also tidy up the layout of ssi.txt. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-09powerpc: add fsl,fifo-depth property to Freescale SSI device nodesTimur Tabi
The Freescale Serial Synchronous Interface (SSI) is an audio device present on some Freescale SOCs. Various implementations of the SSI have a different transmit and receive FIFO depth, but are otherwise identical. To support these variations, add a new property fsl,fifo-depth to the SSI node that specifies the depth of the FIFOs. Also update the MPC8610 HPCD device tree with this property. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-11Merge commit 'kumar/next' into nextBenjamin Herrenschmidt
2009-02-06powerpc: Document FSL eSDHC bindingsAnton Vorontsov
This patch documents OF bindings for the Freescale Enhanced Secure Digital Host Controller. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-04gianfar: Fix stashing supportAndy Fleming
Stashing is only supported on the 85xx (e500-based) SoCs. The 83xx and 86xx chips don't have a proper cache for this. U-Boot has been updated to add stashing properties to the device tree nodes of gianfar devices on 85xx. So now we modify Linux to keep stashing off unless those properties are there. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30powerpc/5200: update device tree binding documentationGrant Likely
This patch updates the mpc5200 binding documentation to match actual usage conventions, to remove incorrect information, and to remove topics which are more thoroughly described elsewhere. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
2009-01-28powerpc: convert dts-bindings/fsl/dma.txt to dts-v1 syntaxPeter Korsgaard
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-09Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (67 commits) [MTD] [MAPS] Fix printk format warning in nettel.c [MTD] [NAND] add cmdline parsing (mtdparts=) support to cafe_nand [MTD] CFI: remove major/minor version check for command set 0x0002 [MTD] [NAND] ndfc driver [MTD] [TESTS] Fix some size_t printk format warnings [MTD] LPDDR Makefile and KConfig [MTD] LPDDR extended physmap driver to support LPDDR flash [MTD] LPDDR added new pfow_base parameter [MTD] LPDDR Command set driver [MTD] LPDDR PFOW definition [MTD] LPDDR QINFO records definitions [MTD] LPDDR qinfo probing. [MTD] [NAND] pxa3xx: convert from ns to clock ticks more accurately [MTD] [NAND] pxa3xx: fix non-page-aligned reads [MTD] [NAND] fix nandsim sched.h references [MTD] [NAND] alauda: use USB API functions rather than constants [MTD] struct device - replace bus_id with dev_name(), dev_set_name() [MTD] fix m25p80 64-bit divisions [MTD] fix dataflash 64-bit divisions [MTD] [NAND] Set the fsl elbc ECCM according the settings in bootloader. ... Fixed up trivial debug conflicts in drivers/mtd/devices/{m25p80.c,mtd_dataflash.c}
2009-01-08Merge commit 'origin/master' into nextBenjamin Herrenschmidt
2009-01-06documentation: update header file pathsRandy Dunlap
Update several Documentation/ files and a few sub-dir files (only one change in each) to reflect changed header files locations. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05[MTD] [NAND] ndfc driverSean MacLennan
The current ndfc driver only compiles under arch/ppc. This arch was removed from the kernel. I notice the event entry for the ndfc in Kconfig has been removed in 2.6.28. This patch converts the ndfc to a proper OF (OpenFirmware) driver. I can give a working example of the DTS if needed. The patch has been in production use on the PIKA Warp Appliance and is in use by others. The Warp basically boots from NAND, so the ndfc driver is very important to us. Signed-off-by: Sean MacLennan <smaclennan@pikatech.com> Acked-By: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-05Merge commit 'kumar/kumar-next' into nextBenjamin Herrenschmidt
2008-12-30powerpc: Add device tree bindings for BCSR GPIO banksAnton Vorontsov
The patch adds bindings for BCSR GPIO banks, the bindings are used to describe particular BCSR registers that act as simple GPIO controllers. These GPIO banks might control power switches, SPI chip-selects, LEDs, etc. While at it, also fix "length" spelling error in the PIXIS FPGA bindings. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-16gianfar: Convert gianfar to an of_platform_driverAndy Fleming
Does the same for the accompanying MDIO driver, and then modifies the TBI configuration method. The old way used fields in einfo, which no longer exists. The new way is to create an MDIO device-tree node for each instance of gianfar, and create a tbi-handle property to associate ethernet controllers with the TBI PHYs they are connected to. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-10powerpc: Repair device bindings documentationTrent Piepho
Commit d0fc2eaaf4c56a95f5ed29b6bfb609e19714fc16 "powerpc/fsl: Refactor device bindings" split out a number of device bindings from booting-without-of.txt into separate files. Having them all in one file was a frequent source of merge conflicts. However, in the next merge, 49997d75152b3d23c53b0fa730599f2f74c92c65, there was another conflict. Some of the bindings removed from booting-without-of.txt were mistakenly added back in and the copies in dts-bindings were kept as well. This patch re-removes "Freescale Display Interface" and "Freescale on board FPGA" and fixes the table of contents. Signed-off-by: Trent Piepho <tpiepho@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-20of/spi: Support specifying chip select as active high via device treeWolfgang Ocker
The patch allows to specify that an SPI device needs an active high chip select. Signed-off-by: Wolfgang Ocker <weo@reccoware.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-20powerpc: Remove device_type = "board_control" properties in .dts filesAnton Vorontsov
We don't want to encourage the bogus device_type usage. The device type isn't used in the code, so we can simply remove it from the documentation and dts files. Boards should specify proper compatible entries instead. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-13powerpc: document the "fsl,ssi-dma-channel" compatible propertyTimur Tabi
The "fsl,ssi-dma-channel" compatible property is used to specify a DMA channel on the Freescale Elo DMA controller that should be used exclusively by the Freescale SSI audio controller. When a property is marked as such, the Elo DMA driver will ignore it, and so it will be available for the sound drivers. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-13powerpc: 83xx: pci: Remove need for get_immrbase from mpc83xx_add_bridge.John Rigby
Modify mpc83xx_add_bridge to get config space register base address from the device tree instead of immr + hardcoded offset. 83xx pci nodes have this change: register properties now contain two address length tuples: First is the pci bridge register base, this has always been there. Second is the config base, this is new. This is documented in dts-bindings/fsl/83xx-512x-pci.txt The changes accomplish these things: mpc83xx_add_bridge no longer needs to call get_immrbase it uses hard coded addresses if the second register value is missing Signed-off-by: John Rigby <jrigby@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
