path: root/Documentation/ptp
2014-10-24ptp: restore the makefile for building the test program.Richard Cochran
This patch brings back the makefile called testptp.mk which was removed in commit adb19fb66eee (Documentation: add makefiles for more targets). While the idea of that commit was to improve build coverage of the examples, the new Makefile is unable to cross compile the testptp program. In contrast, the deleted makefile was able to do this just fine. This patch fixes the regression by restoring the original makefile. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Acked-by: Peter Foley <pefoley2@pefoley.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-26Documentation: update .gitignore filesPeter Foley
Add some missing files to .gitignore. Push Documentation/.gitignore down into subdirectories. Signed-off-by: Peter Foley <pefoley2@pefoley.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-09-26Documentation: fix misc. warningsPeter Foley
Fix a few warnings that gcc emits during a default build. Signed-off-by: Peter Foley <pefoley2@pefoley.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-09-26Documentation: add makefiles for more targetsPeter Foley
Add a bunch of previously unbuilt source files to the Documentation build machinery. Signed-off-by: Peter Foley <pefoley2@pefoley.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-06-16ptp: In the testptp utility, use clock_adjtime from glibc when availableChristian Riesch
clock_adjtime was included in glibc 2.14. _GNU_SOURCE must be defined to make it available. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Richard Cochran <richardcochran@gmail.com> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-27ptp: Fix compiler warnings in the testptp utilityChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Dong Zhu <bluezhudong@gmail.com> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-27Revert "ptp: Fix compiler warnings in the testptp utility"David S. Miller
This reverts commit 203191c386e83b8c5d95bbbaef13baa629512726. A better version of this fix is forthcoming. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-26ptp: Fix compiler warnings in the testptp utilityChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Dong Zhu <bluezhudong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-26ptp: Add a command line option in testptp to set a specific PTP timeManfred Rudigier
Signed-off-by: Manfred Rudigier <manfred.rudigier@omicron.at> Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-21ptp: add the pin GET/SETFUNC ioctls to the testptp program.Richard Cochran
This patch adds a option to the test program that lists the programmable pins on a PTP Hardware Clock device, assuming there are any such pins. A second option lets the user reprogram the auxiliary function of a single pin. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-04ptp: Allow selecting trigger/event index in testptpStefan Sørensen
Currently the trigger/event is hardcoded to 0, this patch adds a new command line argument -i to select an arbitrary trigger/ event. Signed-off-by: Stefan Sørensen <stefan.sorensen@spectralink.com> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-23ptp: add the PTP_SYS_OFFSET ioctl to the testptp programDong Zhu
This patch add a method into testptp.c to measure the time offset between phc and system clock through the ioctl PTP_SYS_OFFSET. Signed-off-by: Dong Zhu <bluezhudong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-23ptp: Added a brand new class driver for ptp clocks.Richard Cochran
This patch adds an infrastructure for hardware clocks that implement IEEE 1588, the Precision Time Protocol (PTP). A class driver offers a registration method to particular hardware clock drivers. Each clock is presented as a standard POSIX clock. The ancillary clock features are exposed in two different ways, via the sysfs and by a character device. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John Stultz <john.stultz@linaro.org>
