path: root/Documentation/rapidio
2016-09-01rapidio/documentation/mport_cdev: add missing parameter descriptionAlexandre Bounine
Add missing description for rio_mport_cdev driver parameter 'dma_timeout'. This patch is applicable to kernel versions starting from v4.6. Link: http://lkml.kernel.org/r/20160901173104.2928-1-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio/tsi721: add messaging mbox selector parameterAlexandre Bounine
Add module parameter to allow load time configuration of available RapidIO messaging mailboxes (MBOX1 - MBOX4). Having a messaging MBOX selector mask allows to define which MBOXes are controlled by the mport device driver and reserve some of them for direct use by other drivers. Link: http://lkml.kernel.org/r/1469125134-16523-7-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Barry Wood <barry.wood@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio/tsi721: add PCIe MRRS override parameterAlexandre Bounine
Add PCIe Maximum Read Request Size (MRRS) adjustment parameter to allow users to override configuration register value set during PCIe bus initialization. Performance of Tsi721 device as PCIe bus master can be improved if MRRS is set to its maximum value (4096 bytes). Some platforms have limitations for supported MRRS and therefore the default value should be preserved, unless it is known that given platform supports full set of MRRS values defined by PCI Express specification. Link: http://lkml.kernel.org/r/1469125134-16523-6-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio/tsi721_dma: add channel mask and queue size parametersAlexandre Bounine
Add module parameters to allow load time configuration of DMA channels. Depending on application, performance of DMA data transfers can benefit from adjusted sizes of buffer descriptor ring and/or transaction requests queue. Having HW DMA channel selector mask allows to define which channels (from seven available) are controlled by the mport device driver and reserve some of them for direct use by other drivers. Link: http://lkml.kernel.org/r/1469125134-16523-5-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Barry Wood <barry.wood@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio/documentation: fix mangled paragraph in mport_cdevAlexandre Bounine
Minor edits to correct parameter description. This patch is applicable to kernel versions starting from v4.6. Link: http://lkml.kernel.org/r/1469125134-16523-3-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Reported-by: Barry Wood <barry.wood@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio: add RapidIO channelized messaging driverAlexandre Bounine
Add channelized messaging driver to support native RapidIO messaging exchange between multiple senders/recipients on devices that use kernel RapidIO subsystem services. This device driver is the result of collaboration within the RapidIO.org Software Task Group (STG) between Texas Instruments, Prodrive Technologies, Nokia Networks, BAE and IDT. Additional input was received from other members of RapidIO.org. The objective was to create a character mode driver interface which exposes messaging capabilities of RapidIO endpoint devices (mports) directly to applications, in a manner that allows the numerous and varied RapidIO implementations to interoperate. This char mode device driver allows user-space applications to setup messaging communication channels using single shared RapidIO messaging mailbox. By default this driver uses RapidIO MBOX_1 (MBOX_0 is reserved for use by RIONET Ethernet emulation driver). [weiyj.lk@gmail.com: rapidio/rio_cm: fix return value check in riocm_init()] Link: http://lkml.kernel.org/r/1469198221-21970-1-git-send-email-alexandre.bounine@idt.com Link: http://lkml.kernel.org/r/1468952862-18056-1-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Barry Wood <barry.wood@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-22rapidio: add mport char device driverAlexandre Bounine
Add mport character device driver to provide user space interface to basic RapidIO subsystem operations. See included Documentation/rapidio/mport_cdev.txt for more details. [akpm@linux-foundation.org: fix printk warning on i386] [dan.carpenter@oracle.com: mport_cdev: fix some error codes] Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Tested-by: Barry Wood <barry.wood@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-22rapidio/tsi721: add filtered debug outputAlexandre Bounine
Replace "all-or-nothing" debug output with controlled debug output using functional block masks. This allows run time control of debug messages through 'dbg_level' module parameter. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08rapidio/tsi721_dma: rework scatter-gather list handlingAlexandre Bounine
Rework Tsi721 RapidIO DMA engine support to allow handling data scatter/gather lists longer than number of hardware buffer descriptors in the DMA channel's descriptor list. The current implementation of Tsi721 DMA transfers requires that number of entries in a scatter/gather list provided by a caller of dmaengine_prep_rio_sg() should not exceed number of allocated hardware buffer descriptors. This patch removes the limitation by processing long scatter/gather lists by sections that can be transferred using hardware descriptor ring of configured size. It also introduces a module parameter "dma_desc_per_channel" to allow run-time configuration of Tsi721 hardware buffer descriptor rings. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Stef van Os <stef.van.os@prodrive-technologies.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07rapidio: rework device hierarchy and introduce mport class of devicesAlexandre Bounine
This patch removes an artificial RapidIO bus root device and establishes actual device hierarchy by providing reference to real parent devices. It also introduces device class for RapidIO controller devices (on-chip or an eternal bridge, known as "mport"). Existing implementation was sufficient for SoC-based platforms that have a single RapidIO controller. With introduction of devices using multiple RapidIO controllers and PCIe-to-RapidIO bridges the old scheme is very limiting or does not work at all. The implemented changes allow to properly reference platform's local RapidIO mport devices and provide device details needed for upper layers. This change to RapidIO device hierarchy does not break any known existing kernel or user space interfaces. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Stef van Os <stef.van.os@prodrive-technologies.com> Cc: Jerry Jacobs <jerry.jacobs@prodrive-technologies.com> Cc: Arno Tiemersma <arno.tiemersma@prodrive-technologies.com> Cc: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-25doc: Fix typo in doucmentationsMasanari Iida
Correct typo (double words) in documentations. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-03rapidio: documentation updateAlexandre Bounine
Update RapidIO documentation files to reflect modularization changes. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@Prodrive.nl> Cc: Micha Nelissen <micha.nelissen@Prodrive.nl> Cc: Stef van Os <stef.van.os@Prodrive.nl> Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24rapidio: documentation update for enumeration changesAlexandre Bounine
Update RapidIO documentation to reflect changes made to enumeration/discovery build configuration and user space triggering mechanism. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@Prodrive.nl> Cc: Micha Nelissen <micha.nelissen@Prodrive.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02RapidIO: documentation updateAlexandre Bounine
Update rapidio.txt to reflect changes from recent patch. See http://marc.info/?l=linux-kernel&m=131285620113589&w=2 for details. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Liu Gang <Gang.Liu@freescale.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02RapidIO: add mport driver for Tsi721 bridgeAlexandre Bounine
Add RapidIO mport driver for IDT TSI721 PCI Express-to-SRIO bridge device. The driver provides full set of callback functions defined for mport devices in RapidIO subsystem. It also is compatible with current version of RIONET driver (Ethernet over RapidIO messaging services). This patch is applicable to kernel versions starting from 2.6.39. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Signed-off-by: Chul Kim <chul.kim@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23rapidio: add RapidIO documentationAlexandre Bounine
Add RapidIO documentation files as it was discussed earlier (see thread http://marc.info/?l=linux-kernel&m=129202338918062&w=2) Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
